  4. Fehler beim Installieren von Adaptern
5 Beiträge 2 Kommentatoren 1.2k Aufrufe
    Karl_999
    Die Installation (fast) aller Adapter schlägt bei mir fehl.
    Hier die Aufzeichnung der letzten beiden Versuche
    iobroker	2017-11-26 18:32:09.506	info	exit 1
    iobroker	2017-11-26 18:32:09.419	error	at process._tickCallback (internal/process/next_tick.js:104:9)
    iobroker	2017-11-26 18:32:09.419	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
    iobroker	2017-11-26 18:32:09.419	error	at net.js:1408:9
    iobroker	2017-11-26 18:32:09.419	error	at listen (net.js:1298:10)
    iobroker	2017-11-26 18:32:09.419	error	at Server._listen2 (net.js:1262:14)
    iobroker	2017-11-26 18:32:09.419	error	at exports._exceptionWithHostPort (util.js:1043:20)
    iobroker	2017-11-26 18:32:09.419	error	at Object.exports._errnoException (util.js:1020:11)
    iobroker	2017-11-26 18:32:09.419	error	Error: listen EADDRINUSE 127.0.0.1:9001
    iobroker	2017-11-26 18:32:09.419	error	^
    iobroker	2017-11-26 18:32:09.419	error	events.js:160 throw er; // Unhandled 'error' event
    iobroker	2017-11-26 18:31:55.453	info	add vis-hqwidgets
    iobroker	2017-11-26 18:30:33.129	info	exit 1
    iobroker	2017-11-26 18:30:33.037	error	at process._tickCallback (internal/process/next_tick.js:104:9)
    iobroker	2017-11-26 18:30:33.037	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
    iobroker	2017-11-26 18:30:33.037	error	at net.js:1408:9
    iobroker	2017-11-26 18:30:33.037	error	at listen (net.js:1298:10)
    iobroker	2017-11-26 18:30:33.037	error	at Server._listen2 (net.js:1262:14)
    iobroker	2017-11-26 18:30:33.037	error	at exports._exceptionWithHostPort (util.js:1043:20)
    iobroker	2017-11-26 18:30:33.037	error	at Object.exports._errnoException (util.js:1020:11)
    iobroker	2017-11-26 18:30:33.037	error	Error: listen EADDRINUSE 127.0.0.1:9001
    iobroker	2017-11-26 18:30:33.037	error	^
    iobroker	2017-11-26 18:30:33.037	error	events.js:160 throw er; // Unhandled 'error' event
    iobroker	2017-11-26 18:30:18.790	info	add vis-jqui-mfd
    Meine ioBroker läuft auf einem Pi
    Vorhandene Instanzen:
    admin
    cloud
    discovey
    flot
    history
    hm-rega
    hm-rpc
    javascript
    mobile
    rpi2
    socketio
    vis
    web
      Dieser Fehler tritt bestenfalls auf, weil du einen Pi1 nutzst, der einfach zu langsam ist.
      Schlimmstenfalls hast du zwei (oder mehr) Installationen zeitgleich laufen
      Wenn ich die Informationen aus deinem anderen Thread dazu nehme befürchte ich eher letzteres.
        Karl_999
        @Homoran:
        Rainer `
        Danke für die Info.
        Ich habe den Pi nochmals neu aufgesetzt und nun das richtige Image benutzt.
        Allerdings scheitert die Installation von zusätzlichen Adaptern noch immer.
        iobroker	2017-11-26 22:39:12.019	info	exit 1
        iobroker	2017-11-26 22:39:11.910	error	at ontimeout (timers.js:365:14)
        iobroker	2017-11-26 22:39:11.910	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2644:27)
        iobroker	2017-11-26 22:39:11.910	error	at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2732:7)
        iobroker	2017-11-26 22:39:11.910	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2725:9
        iobroker	2017-11-26 22:39:11.910	error	at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2627:24)
        iobroker	2017-11-26 22:39:11.910	error	at Server.listen (net.js:1391:5)
        iobroker	2017-11-26 22:39:11.910	error	at listen (net.js:1295:10)
        iobroker	2017-11-26 22:39:11.910	error	at Server._listen2 (net.js:1259:14)
        iobroker	2017-11-26 22:39:11.910	error	at exports._exceptionWithHostPort (util.js:1045:20)
        iobroker	2017-11-26 22:39:11.910	error	at Object.exports._errnoException (util.js:1022:11)
        iobroker	2017-11-26 22:39:11.910	error	Error: listen EADDRINUSE :::9001
        iobroker	2017-11-26 22:39:11.910	error	^
        iobroker	2017-11-26 22:39:11.910	error	events.js:160 throw er; // Unhandled 'error' event
        iobroker	2017-11-26 22:39:00.235	info	add vis-weather
        host.ioBroker-Pi1	2017-11-26 22:37:51.544	info	Delete log file iobroker.2017-03-01.log
        iobroker	2017-11-26 22:37:42.918	info	exit 1
        iobroker	2017-11-26 22:37:42.812	error	at ontimeout (timers.js:365:14)
        iobroker	2017-11-26 22:37:42.812	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2673:26)
        iobroker	2017-11-26 22:37:42.812	error	at new StatesInMemory (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:204:7)
        iobroker	2017-11-26 22:37:42.812	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:197:9
        iobroker	2017-11-26 22:37:42.812	error	at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemServer.js:1000:20)
        iobroker	2017-11-26 22:37:42.812	error	at Server.listen (net.js:1391:5)
        iobroker	2017-11-26 22:37:42.812	error	at listen (net.js:1295:10)
        iobroker	2017-11-26 22:37:42.812	error	at Server._listen2 (net.js:1259:14)
        iobroker	2017-11-26 22:37:42.812	error	at exports._exceptionWithHostPort (util.js:1045:20)
        iobroker	2017-11-26 22:37:42.812	error	at Object.exports._errnoException (util.js:1022:11)
        iobroker	2017-11-26 22:37:42.812	error	Error: listen EADDRINUSE :::9000
        iobroker	2017-11-26 22:37:42.812	error	^
        iobroker	2017-11-26 22:37:42.812	error	events.js:160 throw er; // Unhandled 'error' event
        iobroker	2017-11-26 22:37:32.551	info	add vis-hqwidgets
        Zur Entlastung des PI habe ich extra gewartet, bis die Initialisierung und Synchronisation des HM-Adapters beendet war und das Logfile sich beruhigte.
        Die installierten Module sind nun auch weniger
        admin
        flot
        history
        hm-rega
        hm-rpc
        javascript
        mobile
        rpi2
        vis
        web
          Die fehler mit dem EADDRINUSE sind typischbfür den pi1
          Workaround
          Installieren übet die konsole. Zuerst
          sudo iobroker stop
          Danach die instanzen anlegen mit
          sudo iobroker add AdapterName
          Wobei AdapterName natürlich ersetzt werden muss durch den Namen des Adapters.
            Karl_999
            Danke für den Tip.
            @Homoran:
            Code:
            So hat es bei mir jetzt auch geklappt.
            ` > Wie kann ich für die von dir vorgeschlagene Installationstechnik die Installationsnamen der Adapter herausfinden?
            Ist es typischerweise der erste Eintrag der Schlüsselworte, die ich zum Adapter im Admin sehe? `
            Beim Stöbern habe ich gerade gefunden, dass es unter http://download.iobroker.net/list.html eine Liste der Adapter mit den benötigten Namen zur Installation gibt.
            82.8k
