  2. English
  3. Visualization
  4. Node-Red Adapter: Error: EACCES: permission denied
    5.9k
Geplant Angeheftet Gesperrt Verschoben Visualization
7 Beiträge 2 Kommentatoren 4.7k Aufrufe 2 Beobachtet
  • Bit MageB Offline
    Bit MageB Offline
    Bit Mage
    Hello,
    I am using a Linux system with IO-Broker and Node-Red.
    iobroker V6.10.1
    node-red v4.0.3
    I created a ".json" on my linux system under "/home/bitmage/x.json". I am trying to read the file inside Node-Red and I am always getting the following fault: "Error: EACCES: permission denied, open '/home/bitmage/x.json'".
    I did not find any solution in the internet. I opened a post on Node-red forum, but the community said I should ask here, because it seems to be a permission thing of the iobroker.
    My target is to read a .json file with the "read file" node and use the information in node-red.
    I saw this post here: Node-red-contrib-persist on DietPi : EACCES: permission denied, open '/root/data/persistence.json' - #46 by devifast
    but my /mnt folder is empty.
    Thank you in advance
    • Bit MageB Bit Mage
      Hello,
      iobroker V6.10.1
      node-red v4.0.3
      @bit-mage
      Put it in /home/iobroker and change the owner of the file to iobroker:iobroker.
      Bit MageB 1 Antwort Letzte Antwort
        @bit-mage
        Bit MageB Offline
        Bit MageB Offline
        Bit Mage
        First of all thank you for your reply. Really cool from you.
        When I try to move the file into the folder "/home/iobroker" my linux system says "permission denied".
        I then tried the sudo chown command for the file and the the new user and group is now iobroker:iobroker.
        I can see it in my terminal that the user has changed correctly.
        However I still can not move the file into the path: "/home/iobroker".
        Do you know what I am missing?
        Bit MageB Thomas BraunT 2 Antworten Letzte Antwort
          Bit MageB Offline
          Bit MageB Offline
          Bit Mage
          @bit-mage @Thomas-Braun
          Ahhh I found out by myself and it is working now!
          I used the command " sudo mv" command to move the file :)
          YOU ARE A GIANT! TYVM!
            @bit-mage sagte in Node-Red Adapter: Error: EACCES: permission denied:
            Proper rights...
            Your user 'bitmage' should be member of group 'iobroker' and therefore able to write into /home/iobroker.
            Check it:
            groups
            as user 'bitmage' gives?
              Bit MageB Offline
              Bit MageB Offline
              Bit Mage
              You dont accept crypto as donation?
              We all use crypto, right?
                Proper rights...
                Check it:
                groups
                Bit MageB Offline
                Bit MageB Offline
                Bit Mage
                @thomas-braun Thank you - i added the user now too :) Everything is working and I can read the file. Awesome :)
