  3. Einsteigerfragen
  4. Shuttercontrol keine Astrowerte [gelöst]
    5.5k
11 Beiträge 2 Kommentatoren 1.1k Aufrufe 1 Beobachtet
  • A Achim Wirtz
    mein erster Post, hoffe ich mach das nun halbwegs korrekt.
    Anscheinend bekommt Shuttercontrol keine Astrowerte, Logauszug:
    2023-10-22 15:28:21.181 - info: admin.0 (4337) ==> Connected system.user.admin from ::ffff:192.168.10.20
    2023-10-22 15:28:45.563 - info: host.maschinenraum stopInstance system.adapter.shuttercontrol.0 (force=false, process=true)
    2023-10-22 15:28:45.576 - info: host.maschinenraum stopInstance system.adapter.shuttercontrol.0 send kill signal
    2023-10-22 15:28:45.577 - info: shuttercontrol.0 (4999) Got terminate signal TERMINATE_YOURSELF
    2023-10-22 15:28:45.580 - info: shuttercontrol.0 (4999) cleaned everything up...
    2023-10-22 15:28:45.583 - info: shuttercontrol.0 (4999) terminating
    2023-10-22 15:28:45.586 - debug: shuttercontrol.0 (4999) Plugin sentry destroyed
    2023-10-22 15:28:45.588 - info: shuttercontrol.0 (4999) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-10-22 15:28:46.092 - info: shuttercontrol.0 (4999) terminating
    2023-10-22 15:28:46.201 - info: host.maschinenraum instance system.adapter.shuttercontrol.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-10-22 15:28:48.666 - info: host.maschinenraum instance system.adapter.shuttercontrol.0 started with pid 7517
    2023-10-22 15:28:51.598 - debug: shuttercontrol.0 (7517) Redis Objects: Use Redis connection: 0.0.0.0:6379
    2023-10-22 15:28:51.677 - debug: shuttercontrol.0 (7517) Objects client ready ... initialize now
    2023-10-22 15:28:51.682 - debug: shuttercontrol.0 (7517) Objects create System PubSub Client
    2023-10-22 15:28:51.686 - debug: shuttercontrol.0 (7517) Objects create User PubSub Client
    2023-10-22 15:28:52.139 - debug: shuttercontrol.0 (7517) Objects client initialize lua scripts
    2023-10-22 15:28:52.175 - debug: shuttercontrol.0 (7517) Objects connected to redis: 0.0.0.0:6379
    2023-10-22 15:28:52.220 - debug: shuttercontrol.0 (7517) Redis States: Use Redis connection: 0.0.0.0:6379
    2023-10-22 15:28:52.237 - debug: shuttercontrol.0 (7517) States create System PubSub Client
    2023-10-22 15:28:52.240 - debug: shuttercontrol.0 (7517) States create User PubSub Client
    2023-10-22 15:28:52.262 - debug: shuttercontrol.0 (7517) States connected to redis: 0.0.0.0:6379
    2023-10-22 15:28:52.336 - debug: shuttercontrol.0 (7517) Plugin sentry Initialize Plugin (enabled=true)
    2023-10-22 15:28:53.753 - info:
    shuttercontrol.0 (7517) starting. Version 1.6.2 in
    /opt/iobroker/node_modules/iobroker.shuttercontrol, node: v18.18.2,
    js-controller: 5.0.14
    2023-10-22 15:28:53.825 - debug: shuttercontrol.0 (7517) shutter Config Check started
    2023-10-22 15:28:53.827 - debug: shuttercontrol.0 (7517) shutter Config Check successfully completed
    2023-10-22 15:28:53.840 - debug: shuttercontrol.0 (7517) Shutter State: alias.0.Erdgeschoss.Wohnzimmer.Rolladen.Rollade_Wohnzimmer.Position
    2023-10-22 15:28:53.842 - warn: shuttercontrol.0 (7517) system settings cannot be called up. Please check configuration!
    2023-10-22 15:28:53.935 - debug: shuttercontrol.0 (7517) Wohnzimmer: save settings
    2023-10-22 15:28:57.182 - debug: shuttercontrol.0 (7517) Travel times of the shutters are calculated
    2023-10-22 15:28:57.186 - debug: shuttercontrol.0 (7517) calculate astrodata ...
    2023-10-22 15:28:57.188 - debug: shuttercontrol.0 (7517) goldenHourEnd today: aN:aN
    2023-10-22 15:28:57.190 - debug: shuttercontrol.0 (7517) goldenHour today: aN:aN
    2023-10-22 15:28:57.191 - debug: shuttercontrol.0 (7517) current day: NaN
    2023-10-22 15:28:57.193 - debug: shuttercontrol.0 (7517) Sunrise today: aN:aN
    2023-10-22 15:28:57.194 - debug: shuttercontrol.0 (7517) Sunset today: aN:aN
    2023-10-22 15:28:57.196 - debug: shuttercontrol.0 (7517) Starting up shutters GoldenHour area: 00:NaN
    2023-10-22 15:28:57.197 - debug: shuttercontrol.0 (7517) Shutdown shutters GoldenHour area: 00:NaN
    2023-10-22 15:28:57.197 - debug: shuttercontrol.0 (7517) Starting up shutters Sunrise area: 00:NaN
    2023-10-22 15:28:57.198 - debug: shuttercontrol.0 (7517) Shutdown shutters Sunset area: 00:NaN
    2023-10-22 15:28:57.204 - debug: shuttercontrol.0 (7517) Starting up shutters living area: undefined debug 0
    2023-10-22 15:28:57.215 - debug: shuttercontrol.0 (7517) Starting up shutters sleep area: undefined debug 0
    2023-10-22 15:28:57.236 - debug: shuttercontrol.0 (7517) Starting up shutters children area: undefined debug 0
    2023-10-22 15:28:57.263 - debug: shuttercontrol.0 (7517) Shutdown shutters living area: undefined debug 0
    2023-10-22 15:28:57.265 - debug: shuttercontrol.0 (7517) shutterDownLiving
    2023-10-22 15:28:57.271 - debug: shuttercontrol.0 (7517) Shutdown shutters children area: undefined debug 0
    2023-10-22 15:28:57.277 - debug: shuttercontrol.0 (7517) Shutdown shutters sleep area: undefined debug 0
    2023-10-22 15:28:57.284 - debug: shuttercontrol.0 (7517) complete down at 22:00
    Was mache ich falsch?
    OS: ubuntu 22.04
    Architektur: arm64
    Node.js: v18.18.2
    NPM: 9.8.1
    Repo: beta
    McFlyers
    @mcflyers
    Sind die Ortskoordinaten in den Systemeinstellungen eingetragen?
      @mcflyers
      Achim Wirtz
      @paul53 Ja, ich hatte Astrosteuerung mit Blockly schon am laufen.
      • A Achim Wirtz
        @mcflyers sagte: ich hatte Astrosteuerung mit Blockly schon am laufen.
        Mit den Ortskoordinaten aus dem System oder mit in der Javascript-Instanz eingetragenen Koordinaten?
        A 2 Antworten Letzte Antwort
          Achim Wirtz
          @paul53 Müßten die aus System sein, da ich sonst nirgendwo die Koordinaten eingetragen habe (Iob), sind aber auch in den Shellys drin ... aber die Shelly Logik läuft nicht mit, ging rein über Blockly.
          • A Achim Wirtz
            Achim Wirtz
            schrieb am zuletzt editiert von Achim Wirtz
            @mcflyers im js-controller hab ich "Häckchen" bei Systemeinstellungen verwenden
              Achim Wirtz
              @paul53 sagte in Shuttercontrol keine Astrowerte:
              Wenn ich die Ortskoordinaten direkt in der Javascript-Instanz eintrage ändert sich auch nichts.
              • A Achim Wirtz
                @mcflyers sagte: Wenn ich die Ortskoordinaten direkt in der Javascript-Instanz eintrage ändert sich auch nichts.
                Die wirken auch nur auf Skripte und nicht auf "Shuttercontrol".
                  Achim Wirtz
                  @paul53 Ok, habe grade in Shuttercontroll selber nachgeschaut dort stehen die Koordinaten aus den Systemeinstellungen drin.
                    Achim Wirtz
                    Jetzt hab ich wieder umgestellt auf Blockly, funktioniert.
                    Leider bin ich noch nicht fit genug in iob um den Fehler selber zu finden.
                    Was mir etwas merkwürdig vorkommt ist, dass trotz der Warnung
                    die Ortskoordinaten wohl im Adapter ankommen, aber anscheinend nicht verarbeitet werden und der Adapter selbst bei reiner Zeitsteuerung ohne Astrosteuerung nicht funsen will.
                    Gibt es irgendwelche Abhängigkeiten die ich überprüfen kann?
                    Da wohl nur ich dieses Problem habe schließe ich einen Bug aus.
                    Keine Ahnung wo ich noch suchen soll 😕
                    • A Achim Wirtz
                      Achim Wirtz
                      Habe die Ortskoordinaten gelöscht und neu konfiguriert, nun sieht's gut aus aus.
