  4. Tuya Adapter nur in eine Richtung.
    5.3k
14 Beiträge 2 Kommentatoren 1.2k Aufrufe 2 Beobachtet
    kg36304
    Meinst Du das?
    • K kg36304
      Meinst Du das?
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @kg36304 sagte in Tuya Adapter nur in eine Richtung.:
      Meinst Du das?
      auf den Bleistift ganz rechts klicken und dann die Objektdaten in Codetags posten
      Lehrling seit 1975 !!!
        kg36304
          "type": "device",
          "common": {
            "name": "Schränkchen",
            "read": true
          "native": {
            "virtual": false,
            "lon": "9.2685",
            "ownerId": "57387027",
            "uuid": "90451b149fdd9bed",
            "mac": "508a06b30b35",
            "accessType": 0,
            "otaInfo": {
              "supportAuto": true,
              "otaUpgradeModes": [
              "otaModuleMap": {
                "wifi": {
                  "upgradeStatus": 0,
                  "cdv": "1.0.0",
                  "bv": "40.00",
                  "verSw": "2.9.16"
                "mcu": {
                  "upgradeStatus": 0,
                  "cdv": "",
                  "verSw": "2.9.16"
            "iconUrl": "https://images.tuyaeu.com/smart/icon/ay15431996119293jn9C/f8b87e6be3ccca4f0d9281b1ed4fd6ee.png",
            "communication": {
              "communicationNode": "bf4cf14e8603a9bd83goud",
              "communicationModes": [
                  "pv": "",
                  "type": 0
                  "pv": "2.2",
                  "type": 1
                  "pv": "",
                  "type": 3
              "connectionStatus": 1
            "gatewayVerCAD": "1.0.2",
            "lat": "50.7333",
            "runtimeEnv": "prod",
            "devKey": "",
            "devId": "bf4cf14e8603a9bd83goud",
            "productId": "ex4ewsy0rowori6r",
            "activeTime": 1671014738,
            "cloudOnline": true,
            "baseAttribute": 1024,
            "devAttribute": 515,
            "dataPointInfo": {
              "dpMaxTime": 1686290625115,
              "dpName": {},
              "dps": {
                "20": false,
                "21": 2,
                "22": 1,
                "23": 0,
                "25": "000e0d0000000000000000c80000",
                "26": 0,
                "28": "",
                "30": "AAAAAAA=",
                "31": "AAA=",
                "32": "AAA=",
                "41": false
              "dpsTime": {
                "20": 1686290625115,
                "21": 1685992396171,
                "22": 1685027519645,
                "23": 1685027519645,
                "25": 1685992284363,
                "26": 1685027519645,
                "28": 1671014738751,
                "30": 1685027519657,
                "31": 1685027519712,
                "32": 1685027519735,
                "41": 1685992295949
            "timezoneId": "Europe/Berlin",
            "deviceTopo": {},
            "localKey": "fbcd8122b3d4be09",
            "dpName": {},
            "groudId": 57387027,
            "schema": [
                "code": "switch_led",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-dp_power",
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "defaultRecommend": true,
                "name": "开关",
                "property": {
                  "type": "bool"
                "id": 20,
                "editPermission": false
                "code": "work_mode",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-dp_mode",
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "模式",
                "property": {
                  "range": [
                    "white",
                    "colour",
                    "scene",
                    "music"
                  "type": "enum"
                "id": 21,
                "code": "bright_value",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-liangdu1",
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "白光亮度",
                "property": {
                  "min": 10,
                  "max": 1000,
                  "scale": 0,
                  "step": 1,
                  "type": "value"
                "id": 22,
                "code": "temp_value",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-dp_half",
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "冷暖值",
                "property": {
                  "min": 0,
                  "max": 1000,
                  "scale": 0,
                  "step": 1,
                  "type": "value"
                "id": 23,
                "code": "scene_data",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-shoucang",
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "场景",
                "property": {
                  "type": "string",
                  "maxlen": 255
                "id": 25,
                "code": "countdown",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-a_nav_timer",
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "倒计时",
                "property": {
                  "unit": "s",
                  "min": 0,
                  "max": 86400,
                  "scale": 0,
                  "step": 1,
                  "type": "value"
                "id": 26,
                "code": "control_data",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-dp_box2",
                "type": "obj",
                "executable": true,
                "mode": "wr",
                "name": "实时调节",
                "property": {
                  "type": "string",
                  "maxlen": 255
                "id": 28,
                "code": "rhythm_mode",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-dp_time3",
                "type": "raw",
                "executable": true,
                "mode": "rw",
                "name": "生物节律",
                "property": {
                  "type": "raw",
                  "maxlen": 128
                "id": 30,
                "code": "sleep_mode",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-dp_sleep",
                "type": "raw",
                "executable": true,
                "mode": "rw",
                "name": "灯光助眠",
                "id": 31,
                "code": "wakeup_mode",
                "defaultValue": "",
                "canTrigger": true,
                "iconname": "icon-dp_sun",
                "type": "raw",
                "executable": true,
                "mode": "rw",
                "name": "灯光唤醒",
                "id": 32,
                "code": "remote_switch",
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "defaultRecommend": false,
                "name": "遥控器开关",
                "property": {
                  "type": "bool"
                "id": 41,
            "productKey": "ex4ewsy0rowori6r",
            "schemaExt": [],
            "version": "3.3",
            "dpCodes": {
              "switch_led": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "开关",
                "property": {
                  "type": "bool"
                "id": 20,
              "work_mode": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "模式",
                "property": {
                  "range": [
                    "white",
                    "colour",
                    "scene",
                    "music"
                  "type": "enum"
                "id": 21,
              "bright_value": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "白光亮度",
                "property": {
                  "min": 10,
                  "max": 1000,
                  "scale": 0,
                  "step": 1,
                  "type": "value"
                "id": 22,
              "temp_value": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "冷暖值",
                "property": {
                  "min": 0,
                  "max": 1000,
                  "scale": 0,
                  "step": 1,
                  "type": "value"
                "id": 23,
              "scene_data": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "场景",
                "property": {
                  "type": "string",
                  "maxlen": 255
                "id": 25,
              "countdown": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "倒计时",
                "property": {
                  "unit": "s",
                  "min": 0,
                  "max": 86400,
                  "scale": 0,
                  "step": 1,
                  "type": "value"
                "id": 26,
              "control_data": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "wr",
                "name": "实时调节",
                "property": {
                  "type": "string",
                  "maxlen": 255
                "id": 28,
              "rhythm_mode": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "raw",
                "executable": true,
                "mode": "rw",
                "name": "生物节律",
                "property": {
                  "type": "raw",
                  "maxlen": 128
                "id": 30,
              "sleep_mode": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "raw",
                "executable": true,
                "mode": "rw",
                "name": "灯光助眠",
                "id": 31,
              "wakeup_mode": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "raw",
                "executable": true,
                "mode": "rw",
                "name": "灯光唤醒",
                "id": 32,
              "remote_switch": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "遥控器开关",
                "property": {
                  "type": "bool"
                "id": 41,
            "ip": "192.168.62.156",
            "gwId": "bf4cf14e8603a9bd83goud",
            "active": 2,
            "ablilty": 0,
            "encrypt": true
          "from": "system.adapter.tuya.0",
          "user": "system.user.admin",
          "ts": 1690186065277,
          "_id": "tuya.0.bf4cf14e8603a9bd83goud",
          "acl": {
            "object": 1636,
            "owner": "system.user.admin",
        • K kg36304
            "type": "device",
            "common": {
              "read": true
            "native": {
              "virtual": false,
              "lon": "9.2685",
              "accessType": 0,
              "otaInfo": {
                "otaModuleMap": {
                  "wifi": {
                    "upgradeStatus": 0,
                    "cdv": "1.0.0",
                    "bv": "40.00",
                    "verSw": "2.9.16"
                  "mcu": {
                    "upgradeStatus": 0,
                    "cdv": "",
                    "verSw": "2.9.16"
              "communication": {
                    "pv": "",
                    "type": 0
                    "pv": "2.2",
                    "type": 1
                    "pv": "",
                    "type": 3
              "lat": "50.7333",
              "devKey": "",
              "dataPointInfo": {
                "dpName": {},
                "dps": {
                  "20": false,
                  "21": 2,
                  "22": 1,
                  "23": 0,
                  "26": 0,
                  "28": "",
                  "30": "AAAAAAA=",
                  "31": "AAA=",
                  "32": "AAA=",
                  "41": false
                "dpsTime": {
                  "41": 1685992295949
              "deviceTopo": {},
              "dpName": {},
              "schema": [
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "开关",
                  "property": {
                    "type": "bool"
                  "id": 20,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "模式",
                  "property": {
                    "range": [
                      "white",
                      "colour",
                      "scene",
                      "music"
                    "type": "enum"
                  "id": 21,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "白光亮度",
                  "property": {
                    "min": 10,
                    "max": 1000,
                    "scale": 0,
                    "step": 1,
                    "type": "value"
                  "id": 22,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "冷暖值",
                  "property": {
                    "min": 0,
                    "max": 1000,
                    "scale": 0,
                    "step": 1,
                    "type": "value"
                  "id": 23,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "场景",
                  "property": {
                    "type": "string",
                    "maxlen": 255
                  "id": 25,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "倒计时",
                  "property": {
                    "unit": "s",
                    "min": 0,
                    "max": 86400,
                    "scale": 0,
                    "step": 1,
                    "type": "value"
                  "id": 26,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "wr",
                  "name": "实时调节",
                  "property": {
                    "type": "string",
                    "maxlen": 255
                  "id": 28,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "raw",
                  "executable": true,
                  "mode": "rw",
                  "name": "生物节律",
                  "property": {
                    "type": "raw",
                    "maxlen": 128
                  "id": 30,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "raw",
                  "executable": true,
                  "mode": "rw",
                  "name": "灯光助眠",
                  "id": 31,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "raw",
                  "executable": true,
                  "mode": "rw",
                  "name": "灯光唤醒",
                  "id": 32,
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "遥控器开关",
                  "property": {
                    "type": "bool"
                  "id": 41,
              "schemaExt": [],
              "version": "3.3",
              "dpCodes": {
                "switch_led": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "开关",
                  "property": {
                    "type": "bool"
                  "id": 20,
                "work_mode": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "模式",
                  "property": {
                    "range": [
                      "white",
                      "colour",
                      "scene",
                      "music"
                    "type": "enum"
                  "id": 21,
                "bright_value": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "白光亮度",
                  "property": {
                    "min": 10,
                    "max": 1000,
                    "scale": 0,
                    "step": 1,
                    "type": "value"
                  "id": 22,
                "temp_value": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "冷暖值",
                  "property": {
                    "min": 0,
                    "max": 1000,
                    "scale": 0,
                    "step": 1,
                    "type": "value"
                  "id": 23,
                "scene_data": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "场景",
                  "property": {
                    "type": "string",
                    "maxlen": 255
                  "id": 25,
                "countdown": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "倒计时",
                  "property": {
                    "unit": "s",
                    "min": 0,
                    "max": 86400,
                    "scale": 0,
                    "step": 1,
                    "type": "value"
                  "id": 26,
                "control_data": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "wr",
                  "name": "实时调节",
                  "property": {
                    "type": "string",
                    "maxlen": 255
                  "id": 28,
                "rhythm_mode": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "raw",
                  "executable": true,
                  "mode": "rw",
                  "name": "生物节律",
                  "property": {
                    "type": "raw",
                    "maxlen": 128
                  "id": 30,
                "sleep_mode": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "raw",
                  "executable": true,
                  "mode": "rw",
                  "name": "灯光助眠",
                  "id": 31,
                "wakeup_mode": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "raw",
                  "executable": true,
                  "mode": "rw",
                  "name": "灯光唤醒",
                  "id": 32,
                "remote_switch": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "遥控器开关",
                  "property": {
                    "type": "bool"
                  "id": 41,
              "active": 2,
              "ablilty": 0,
              "encrypt": true
            "acl": {
              "object": 1636,
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @kg36304 fast, den Bleistift vom DP switch_led ;)
            kg36304
            sorry
              "type": "state",
              "common": {
                "type": "boolean",
                "read": true,
                "write": true,
                "name": "switch_led",
                "role": "switch"
              "native": {
                "defaultValue": "",
                "canTrigger": true,
                "type": "obj",
                "executable": true,
                "mode": "rw",
                "name": "开关",
                "property": {
                  "type": "bool"
                "id": 20,
              "ts": 1690186065382,
              "_id": "tuya.0.bf4cf14e8603a9bd83goud.20",
              "acl": {
                "object": 1636,
                "state": 1636,
            • K kg36304
              sorry
                "type": "state",
                "common": {
                  "type": "boolean",
                  "read": true,
                  "write": true,
                  "role": "switch"
                "native": {
                  "defaultValue": "",
                  "canTrigger": true,
                  "type": "obj",
                  "executable": true,
                  "mode": "rw",
                  "name": "开关",
                  "property": {
                    "type": "bool"
                  "id": 20,
                "acl": {
                  "object": 1636,
                  "state": 1636,
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @kg36304 wenn Du den DP manuell änderst dann natürlich ohne den Haken "Bestätigt" ?!
                kg36304
                Ja, passiert auch nichts.
                Soll ich den Tuya Adapter nochmal löschen und neu installieren?
                • K kg36304
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  neu installieren?
                  das wäre eine Möglichkeit.
                    kg36304
                    Das selbe Problem nach der neuinstallation
                      kg36304
                      Also, Problem gelöst. Ich hatte auf dem Slave IoBroker ebenfalls eine Tuya Instanz am laufen. Warum auch immer.
                      Jetzt läuft eine auf dem Master und alles geht.
                      Danke.
