  4. Alias-manager: Objektdaten nicht im Alias
    5.3k
11 Beiträge 2 Kommentatoren 802 Aufrufe 1 Beobachtet
  • W Offline
    W Offline
    warhammer73
    meine Boschthermostate erzeugen u.a. folgende Objektdaten für Netzqualität oder Batterie:
      "type": "state",
      "common": {
        "name": "TRV2.0 18fc26000002fa89.CommunicationQuality.faults",
        "type": "array",
        "role": "list",
        "read": true,
        "write": false
      "native": {
        "device": {
          "@type": "device",
          "rootDeviceId": "64-da-a0-11-96-b6",
          "id": "hdm:ZigBee:18fc26000002fa89",
          "deviceServiceIds": [
            "CommunicationQuality",
            "Thermostat",
            "BatteryLevel",
            "ValveTappet",
            "DisplayedTemperatureConfiguration",
            "DisplayConfiguration",
            "DisplayDirection",
            "TemperatureLevel",
            "Linking",
            "TemperatureOffset"
          "manufacturer": "BOSCH",
          "roomId": "hz_1",
          "deviceModel": "TRV_GEN2",
          "serial": "18FC26000002FA89",
          "profile": "GENERIC",
          "name": "TRV2.0 18fc26000002fa89",
          "status": "AVAILABLE",
          "parentDeviceId": "roomClimateControl_hz_1",
          "childDeviceIds": []
        "deviceService": {
          "@type": "DeviceServiceData",
          "id": "CommunicationQuality",
          "deviceId": "hdm:ZigBee:18fc26000002fa89",
          "state": {
            "@type": "communicationQualityState",
            "quality": "GOOD"
          "path": "/devices/hdm:ZigBee:18fc26000002fa89/services/CommunicationQuality"
        "state": "faults"
      "from": "system.adapter.bshb.0",
      "user": "system.user.admin",
      "ts": 1666674944453,
      "_id": "bshb.0.hdm:ZigBee:18fc26000002fa89.CommunicationQuality.faults",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    Nun versuche ich daraus einen Alias anzulegen, dort sieht das Ergebnis aber so aus:
      "type": "state",
      "common": {
        "name": "link_quality",
        "role": "list",
        "type": "array",
        "read": true,
        "write": false,
        "alias": {
          "id": "bshb.0.hdm:ZigBee:18fc26000002fa89.CommunicationQuality.faults"
      "_id": "alias.0.Arbeitszimmer.Thermostat.faults_2",
      "native": {},
      "ts": 1688827682553,
      "acl": {
        "object": 1636,
        "state": 1636,
    Irgendwas scheint auch dem Alias-Manager schon nicht zu gefallen:
    Jemand eine Idee wie ich die gesamte Struktur von oben in den Alias bekomme, oder noch besser gleich einen einzelnen Eintrag ("quality": "GOOD")?
    • W warhammer73
        "type": "state",
        "common": {
          "type": "array",
          "role": "list",
          "read": true,
          "write": false
        "native": {
          "device": {
            "@type": "device",
              "Thermostat",
              "BatteryLevel",
              "ValveTappet",
              "DisplayDirection",
              "TemperatureLevel",
              "Linking",
              "TemperatureOffset"
            "roomId": "hz_1",
          "deviceService": {
            "state": {
              "quality": "GOOD"
          "state": "faults"
        "acl": {
          "object": 1636,
          "state": 1636,
        "type": "state",
        "common": {
          "role": "list",
          "type": "array",
          "read": true,
          "write": false,
          "alias": {
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      @warhammer73 sagte: Idee wie ich die gesamte Struktur von oben in den Alias bekomme
      Wozu? Wird das Array nicht in den Alias übernommen?
      @warhammer73 sagte in Alias-manager: Objektdaten nicht im Alias:
      Dann muss der Alias vom Typ "string" sein und man verwendet eine Lesekonvertierung:
      JSON.parse(val)[0]
      für "CommunicationQuality", wenn das Array so gefüllt ist wie unter "deviceServiceIds" beschrieben.
      W 1 Antwort Letzte Antwort
        JSON.parse(val)[0]
        W Offline
        W Offline
        warhammer73
        schrieb am zuletzt editiert von warhammer73
        @paul53 said in Alias-manager: Objektdaten nicht im Alias:
        Nein, siehe oben.
        Beim Anlegen meckert der Alias-Manager vor dem Speichern auch:
        Speichert man trotzdem führt das zu der Anzeige oben.
        • W warhammer73
            "type": "state",
            "common": {
              "type": "array",
              "role": "list",
              "read": true,
              "write": false
            "native": {
              "device": {
                "@type": "device",
                  "Thermostat",
                  "BatteryLevel",
                  "ValveTappet",
                  "DisplayDirection",
                  "TemperatureLevel",
                  "Linking",
                  "TemperatureOffset"
                "roomId": "hz_1",
              "deviceService": {
                "state": {
                  "quality": "GOOD"
              "state": "faults"
            "acl": {
              "object": 1636,
              "state": 1636,
            "type": "state",
            "common": {
              "role": "list",
              "type": "array",
              "read": true,
              "write": false,
              "alias": {
            "native": {},
            "acl": {
              "object": 1636,
              "state": 1636,
          @warhammer73 sagte: einen Alias anzulegen, dort sieht das Ergebnis aber so aus:
          Das sieht doch gut aus. Damit muss es funktionieren.
          Anmerkung: Was im Original-DP unter "native" steht, interessiert den Alias nicht.
          • W warhammer73
            Nein, siehe oben.
            @warhammer73
            Ich habe mal mit fast identischen Datenpunkten getestet: Bei mir funktioniert der Alias wie erwartet.
            Original-DP:
              "common": {
                "desc": "Manuell erzeugt",
                "role": "list",
                "type": "array",
                "read": true,
                "write": false
              "type": "state",
              "native": {
                "device": {
                  "@type": "device",
                    "Thermostat",
                    "BatteryLevel",
                    "ValveTappet",
                    "DisplayDirection",
                    "TemperatureLevel",
                    "Linking",
                    "TemperatureOffset"
                  "roomId": "hz_1",
                "deviceService": {
                  "state": {
                    "quality": "GOOD"
                "state": "faults"
              "_id": "0_userdata.0.Test.hdm:ZigBee:18fc26000002fa89.CommunicationQuality.faults",
              "acl": {
                "object": 1636,
                "state": 1636,
              "ts": 1688834888359
            Alias mit Lesekonvertierung:
              "common": {
                "name": "link quality",
                "role": "text",
                "type": "string",
                "read": true,
                "write": false,
                "alias": {
                  "id": "0_userdata.0.Test.hdm:ZigBee:18fc26000002fa89.CommunicationQuality.faults",
                  "read": "JSON.parse(val)[0]"
              "type": "state",
              "native": {},
              "_id": "alias.0.Test.Liste_bshb",
              "acl": {
                "object": 1636,
                "state": 1636,
              "ts": 1688835072358
            EDIT: Ich hatte zuerst mit dem Alias als Liste getestet, was auch funktioniert hat.
            • W Offline
              W Offline
              warhammer73
              ... mein Problem liegt ja aber an der Stelle, das "val" bei mir "[]" ist:
              console.log (getState("console.log (getState("bshb.0.hdm:ZigBee:18fc26000002fa89.CommunicationQuality.faults"));"));
              javascript.0 (1833) script.js.Heim.check: {'val':[],'ack':true,'ts':1687715515607,'q':0,'from':'system.adapter.bshb.0','user':'system.user.admin','lc':1670363668833}
              ... ich hatte eigentlich die Hoffnung das mir getState den gesamten Baum wie ich ihn mit "Objekt bearbeiten" (siehe oben) anzeigt und ich mich dann über "deviceService" bis "quality" durchhangeln kann um den Wert "GOOD" zu bekommen. Da aber getState das schon nicht tut, habe ich irgendwo ein anderes Problem. :(
              • W warhammer73
                @warhammer73: "val" bei mir "[]" ist
                Dann kann ein Alias nichts liefern (außer ein leeres Array).
                • W Offline
                  W Offline
                  warhammer73
                  @paul53 :
                  Ja, an der falschen Stelle angefangen mit suche...
                  Tja, und auch wenn jetzt die Überschrift nicht mehr zu 100% passt:
                  Den Wert den ich brauche gibt es ja offensichtlich (Objekt bearbeiten zeigt ihn ja an), aber wie bekomme ich per JS ihn ausgelesen?
                  • W warhammer73
                    @paul53 :
                    @warhammer73 sagte: wie bekomme ich per JS ihn ausgelesen?
                    getObject('bshb.0.hdm:ZigBee:18fc26000002fa89.CommunicationQuality.faults').native.deviceService.state.quality
                    Dieses Attribut sollte allerdings statisch sein, sich also nicht im laufenden Betrieb ändern.
                      W Offline
                      W Offline
                      warhammer73
                      Danke, manchmal kommt man auf naheliegende Sachen nicht...
                      Damit hat sich dann aber auch die Idee das Geräteunabhängig als Alias auslesen zu können erledigt. :(
                      • W warhammer73
                        @warhammer73 sagte: als Alias auslesen zu können
                        Der Datenpunkt heißt "faults": Das Array wird sich wahrscheinlich erst füllen, wenn mind. ein Fehler auftritt.
