  3. Entwicklung
  4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
    6.5k
herdsmanzigbee
129 Beiträge 13 Kommentatoren 31.7k Aufrufe 12 Beobachtet
  • D Diamand2k22
    Re: (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
    @Thomas-Braun
    Hallo Thomas, leider stürzt mein Zigbee Adapter seit einem Update über die "Katze" heute früh ständig ab, dachte zwischenzeitlich, dass ich es gefixt hätte, aber leider nein.
    Hast du noch eine Ahnung? hier mal ein Auszug aus dem Log.
    code_text
    ```host.pi4b
    2023-06-19 13:52:57.895	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.pi4b
    2023-06-19 13:52:57.894	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.pi4b
    2023-06-19 13:52:57.894	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22
    host.pi4b
    2023-06-19 13:52:57.894	error	Caught by controller[1]: at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18)
    host.pi4b
    2023-06-19 13:52:57.894	error	Caught by controller[1]: at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32)
    host.pi4b
    2023-06-19 13:52:57.894	error	Caught by controller[1]: at Object.configureScope (/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/@sentry/src/exports.ts:76:1)
    host.pi4b
    2023-06-19 13:52:57.894	error	Caught by controller[1]: at Hub.configureScope (/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/@sentry/src/hub.ts:340:1)
    host.pi4b
    2023-06-19 13:52:57.893	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56
    host.pi4b
    2023-06-19 13:52:57.893	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'Error')
    host.pi4b
    2023-06-19 13:52:57.892	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    zigbee.0
    74435	2023-06-19 13:52:57.071	info	terminating
    zigbee.0
    74435	2023-06-19 13:52:56.862	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    74435	2023-06-19 13:52:56.860	info	terminating
    zigbee.0
    74435	2023-06-19 13:52:56.807	info	Zigbee: disabling joining new devices.
    zigbee.0
    74435	2023-06-19 13:52:56.348	info	cleaned everything up...
    zigbee.0
    74435	2023-06-19 13:52:56.287	error	Cannot read properties of undefined (reading 'Error')
    zigbee.0
    74435	2023-06-19 13:52:56.287	error	TypeError: Cannot read properties of undefined (reading 'Error') at /opt/iobroker/node_modules/iobroker.zigbee/main.js:122:56 at Hub.configureScope (/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/@sentry/src/hub.ts:340:1) at Object.configureScope (/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/@sentry/src/exports.ts:76:1) at Zigbee.sendError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:118:32) at Zigbee.filterError (/opt/iobroker/node_modules/iobroker.zigbee/main.js:142:18) at /opt/iobroker/node_modules/iobroker.zigbee/main.js:699:22
    zigbee.0
    74435	2023-06-19 13:52:56.272	error	unhandled promise rejection: Cannot read properties of undefined (reading 'Error')
    zigbee.0
    74435	2023-06-19 13:52:56.271	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    74435	2023-06-19 13:52:56.268	error	Send command to 0x94deb8fffe458477 failed with no error code (no response received (144)
    #106
    @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
    Macht man ja auch nicht.
      Diamand2k22
      #107
      ich bin jetzt mal zurück gegangen auf 4.0.24 und hab den zigbee adapter nochmal gelöscht und wieder installiert, aber stürzt immer noch ständig ab. jetzt gehen mir die ideen aus.
      • D Diamand2k22
        #108
        @diamand2k22
        Ah, auf dem Beta js-controller unterwegs gewesen?
        (Diese nicht ganz unwesentliche Info vermisste ich oben...)
        Neben dem zigbee-Adapter aus dem github mit weiteren unstabilen Versionen zugange?
        iob diag
        in der Langfassung sagt?
        D 2 Antworten Letzte Antwort
          @diamand2k22
          iob diag
          Diamand2k22
          #109
          ja genau,bin mit dem Beta js-controller unterwegs gewesen und zigbee war die github version, jetzt habe ich alles rückgängig gemacht aber zigbee adapter läuft trotzdem nicht mehr
            @diamand2k22
            iob diag
            Diamand2k22
            schrieb am zuletzt editiert von Diamand2k22
            #110
            Skript v.2023-04-16
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 4 Model B Rev 1.5
            Architecture    : aarch64
            Docker          : false
            Virtualization  : none
            Distributor ID: Debian
            Description:    Debian GNU/Linux 12 (bookworm)
            Release:        12
            Codename:       bookworm
            PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
            NAME="Debian GNU/Linux"
            VERSION_ID="12"
            VERSION="12 (bookworm)"
            VERSION_CODENAME=bookworm
            ID=debian
            HOME_URL="https://www.debian.org/"
            SUPPORT_URL="https://www.debian.org/support"
            BUG_REPORT_URL="https://bugs.debian.org/"
            Systemuptime and Load:
             15:58:49 up 17:15,  2 users,  load average: 0.83, 1.27, 1.44
            CPU threads: 4
            Raspberry only:
            throttled=0x0
            Other values than 0x0 hint to temperature/voltage problems
            temp=40.9'C
            volt=0.9360V
            iob diag has finished.
            • D Diamand2k22
              Skript v.2023-04-16
              *** BASE SYSTEM ***
              Docker          : false
              Release:        12
              Codename:       bookworm
              VERSION_ID="12"
              ID=debian
              CPU threads: 4
              Raspberry only:
              throttled=0x0
              temp=40.9'C
              volt=0.9360V
              #111
              @diamand2k22
              Da biste aber mit allem hart an der Absturzkante.
              Raspberry OS 12 'Bookworm' ist auch noch nicht offiziell released.
                @diamand2k22
                Diamand2k22
                #112
                okay das heißt dann wohl ist nicht mehr zu retten?
                komischweise hat bis gestern alles funktioniert mit bookworm, js controller 5.03 und zigbee github. nach dem update auf 5.0.5 kamen die Probleme.
                • D Diamand2k22
                  #113
                  Das ist halt Beta. Kannst ja im entsprechenden Thread dazu dein Glück versuchen. Aber mit dem ganzen Zoo an unstabiler Software ist das kaum möglich das genauer einzugrenzen.
                    Diamand2k22
                    #114
                    ok dann werde ich mal
                    cd /opt/iobroker
                    sudo iobroker stop
                    sudo iobroker restore 0
                    versuchen und das Backup von gestern einspielen.
                    das sollte ja so funktionieren mit einer Backitup Sicherung oder?
                    • D Diamand2k22
                      cd /opt/iobroker
                      sudo iobroker stop
                      #115
                      @diamand2k22
                      NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN! NEIN!
                      iobroker NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIE NIEMALS mit sudo anpacken . NIE
                      • D Diamand2k22
                        cd /opt/iobroker
                        sudo iobroker stop
                        #116
                        @diamand2k22
                        iob fix
                        ausführen...
                          @diamand2k22
                          iob fix
                          ausführen...
                          Diamand2k22
                          #117
                          das mit dem sudo war aus einem anderen thread hier im forum rauskopiert 🙄
                          iob fix hab ich schon öfter ausprobiert aber kann auch nichts retten.
                          • D Diamand2k22
                            #118
                            @diamand2k22
                            Der Fred muss aber steinalt sein, das wurde zuletzt im frühen Pleistozän gemacht.
                              @diamand2k22
                              Diamand2k22
                              #119
                              ok soll ich dann mal probieren ob ein restore was rettet?
                              wie gesagt, gestern hat noch alles funktioniert mit js controller 5.0.3
                              dann so:
                              cd /opt/iobroker
                              iobroker stop
                              iobroker restore 0
                              • D Diamand2k22
                                dann so:
                                cd /opt/iobroker
                                iobroker stop
                                iobroker restore 0
                                Diamand2k22
                                #120
                                @Thomas-Braun
                                nun läuft wieder alles....sogar mit js-contoller 5.0.5 u. bookworm, trotzdem danke für die Hilfe.
                                • Thomas BraunT Online
                                  #121
                                  @diamand2k22
                                  Dann kannste ja jetzt weiter frickeln.
                                    Dariusz Lenarczyk
                                    #122
                                    @Thomas-Braun
                                    Habe diesen Beitrag gefunden, leider ist die Diskussion an Thema vorbei gegangen. Trotzdem kann mir vielleicht Thoma-Braun helfen. So sieht es bei mir aus. Wie du siehst habe ich von der "Katze" installiert, leider ohne Erfolg. Was ist da zu tun?
                                    pi@raspberrypi:/opt/iobroker $ npm ls --depth=3 | grep zigbee
                                    └─┬ iobroker.zigbee@1.9.5
                                    ├─┬ zigbee-herdsman-converters@16.18.0
                                    │ └── zigbee-herdsman@0.28.0 deduped
                                    └─┬ zigbee-herdsman@0.28.0
                                    └─┬ iobroker.zigbee@1.9.6 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#e5dc704a19a0c550f8b85570445d37bbfa98f58b)
                                    • D Dariusz Lenarczyk
                                      @Thomas-Braun
                                      #123
                                      @dariusz-lenarczyk
                                      Was heißt 'ohne Erfolg'?
                                        Dariusz Lenarczyk
                                        schrieb am zuletzt editiert von Dariusz Lenarczyk
                                        #124
                                        @dariusz-lenarczyk sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                                        Das fett markierte ist wohl nicht richtig? Oder?
                                        Habe ein Gerät der mir ständig Fehler generiert. In dem Log steht was von Zigbee-Herdsmann:
                                        DeviceConfigure:Failed to DeviceConfigure.configure 0x9035eafffe0d8d9c ZBMINIL2 (Error: Unbind 0x9035eafffe0d8d9c/1 genPollCtrl from '0x00212effff059d03/1' failed (Error: status: 136) at DeconzAdapter.unbind (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:828:19) at Endpoint.unbind (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:574:13) at configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/devices/sonoff.ts:63:13) at Object.configure (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:139:25) at DeviceConfigure.doConfigure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:136:17) at DeviceConfigure.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceConfigure.js:114:21))
                                          #125
                                          @dariusz-lenarczyk
                                          Setz das in CodeTags, dann sieht man da auch die Ebenen.
