  4. [Frage] Adapter für LG Fernseher?
    6.4k
189 Beiträge 26 Kommentatoren 46.0k Aufrufe 1 Beobachtet
    SchuetzeSchulz
    #71
    Und? Wird am Fernseher was angezeigt?
    • lobomauL Offline
      lobomauL Offline
      lobomau
      #72
      @SchuetzeSchulz:
      Und? Wird am Fernseher was angezeigt? `
      Habe das Pairing am Pi3 gestartet und die Nummer in Adapter gesichert. Ist der Fehler ok? Am Ende steht Ready:
      lgtv2011.1	2017-10-06 17:34:01.408	info	Ready. Configured TV IP: 192.168.178.47
      lgtv2011.1	2017-10-06 17:34:01.390	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.lgtv2011, node: v6.11.3
      lgtv2011.1	2017-10-06 17:33:47.564	info	terminating
      lgtv2011.1	2017-10-06 17:33:47.055	error	at IncomingMessage.g (events.js:292:16)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1091:12)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at Request.emit (events.js:188:7)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at emitOne (events.js:96:13)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at Request. (/opt/iobroker/node_modules/request/request.js:1171:10)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at Request.emit (events.js:191:7)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at emitTwo (events.js:106:13)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:188:22)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at LgTvApi. (/opt/iobroker/node_modules/iobroker.lgtv2011/lib/api.js:155:9)
      lgtv2011.1	2017-10-06 17:33:47.055	error	at LgTvApi. (/opt/iobroker/node_modules/iobroker.lgtv2011/lib/api.js:26:28)
      lgtv2011.1	2017-10-06 17:33:47.055	error	TypeError: Cannot read property 'statusCode' of null
      lgtv2011.1	2017-10-06 17:33:47.054	error	uncaught exception: Cannot read property 'statusCode' of null
      lgtv2011.1	2017-10-06 17:33:46.929	info	Requesting Pairing Key on TV: 192.168.178.47
      lgtv2011.1	2017-10-06 15:35:24.829	info	Ready. Configured TV IP: 192.168.178.47
      lgtv2011.1	2017-10-06 15:35:24.811	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.lgtv2011, node: v6.11.3
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • lobomauL Offline
        lobomauL Offline
        lobomau
        #73
        Am Brix läuft das Pairing auch so ab wie am Pi3:
        lgtv2011.0	2017-10-06 17:39:27.766	info	Ready. Configured TV IP: 192.168.178.47
        lgtv2011.0	2017-10-06 17:39:27.761	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.lgtv2011, node: v6.11.4
        lgtv2011.0	2017-10-06 17:39:27.726	debug	statesDB connected
        lgtv2011.0	2017-10-06 17:39:27.671	debug	objectDB connected
        lgtv2011.0	2017-10-06 17:39:15.824	info	terminating
        lgtv2011.0	2017-10-06 17:39:15.308	error	at emitNone (events.js:91:20)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.lgtv2011/node_modules/request/request.js:965:12)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at Request.emit (events.js:188:7)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at emitOne (events.js:96:13)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at Request. (/opt/iobroker/node_modules/iobroker.lgtv2011/node_modules/request/request.js:1044:10)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at Request.emit (events.js:191:7)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at emitTwo (events.js:106:13)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.lgtv2011/node_modules/request/request.js:187:22)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at LgTvApi. (/opt/iobroker/node_modules/iobroker.lgtv2011/node_modules/node-lgtv-api/api.js:154:9)
        lgtv2011.0	2017-10-06 17:39:15.308	error	at LgTvApi. (/opt/iobroker/node_modules/iobroker.lgtv2011/node_modules/node-lgtv-api/api.js:25:28)
        lgtv2011.0	2017-10-06 17:39:15.308	error	TypeError: Cannot read property 'statusCode' of null
        lgtv2011.0	2017-10-06 17:39:15.308	error	uncaught exception: Cannot read property 'statusCode' of null
        lgtv2011.0	2017-10-06 17:39:15.225	info	Requesting Pairing Key on TV: 192.168.178.47
        lgtv2011.0	2017-10-06 17:39:15.224	debug	Incoming Adapter message: RequestPairingKey_Msg
        lgtv2011.0	2017-10-06 17:38:53.222	info	Ready. Configured TV IP: 192.168.178.47
        lgtv2011.0	2017-10-06 17:38:53.216	info	starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.lgtv2011, node: v6.11.4
        • Slave: Pi4
          SchuetzeSchulz
          #74
          Das sieht schon mal gut aus.
          Die Fehlermeldung ist "normal". Aber wichtig schon mal das das Pairing angezeigt wird.
          Jetzt muss es nur noch bei krissi funktionieren.
          • lobomauL Offline
            lobomauL Offline
            lobomau
            #75
            @krissi:
            Mit der alten LG-App für Android geht das (LG TV Remote 2011). Der hat mir auch beim ersten Mal verbinden (mit der app) den Code angezeigt.
            node 4.8.3
            npm 2.15.11
            debian 8.8 auf Esxi `
            Sind das weiterhin deine Werte? Kann es daran liegen?
            Auf welcher hardware läuft ioBroker?
            Ich habe brix und pi3, jeweils mit js-controller 1.2.0 und npm 3.10.10
            node: 6.11.4 (brix) und 6.11.3 (pi3)
            • Slave: Pi4
              krissi
              #76
              @lobomau
              welche Port hast Du eingestellt? Ich kann nur leider im Moment nicht probieren (später). Wenn ich jetzt was an dem TV mache werde ich erschossen ;)
              ioBroker in VM (unraid) / CCU2 für IP FB-Heizungssteuerung raspi3 / 3x Echo Dot / IKEA Tradfri / zigBee mit Conbee II
                krissi
                #77
                @lobomau:
                @krissi:
                node 4.8.3
                npm 2.15.11
                node: 6.11.4 (brix) und 6.11.3 (pi3) `
                node 6.11.2
                npm 3.10.10
                js ist 1.2.0
                Hardware ist ein NUC
                • lobomauL Offline
                  lobomauL Offline
                  lobomau
                  #78
                  @krissi:
                  @lobomau
                  welche Port hast Du eingestellt? Ich kann nur leider im Moment nicht probieren (später). Wenn ich jetzt was an dem TV mache werde ich erschossen ;) `
                  Hab 8080 gelassen.
                  • Slave: Pi4
                  • C Offline
                    C1500
                    #79
                    Servus Zusammen
                    Gute Nachrichten von meiner Seite ;)
                    Mein LG 47LA6608 ist erfolgreich gepairt.
                    Es wurden auch einige aber funktionslose Objekte angelegt :)
                    Bin bereit weiteres zu testen.
                    Gruß Peer
                      krissi
                      #80
                      Ich guck heute Abend noch mal, sonst macht einfach weiter. Spätestens zur WM 2018 kauf ich eh einen neuen TV. ;) Eventuell hab ich ja auch noch einen Geistesblitz :roll:
                      • R Offline
                        reini
                        #81
                        gibt es hierzu Neuigkeiten? ich könnte ansonsten auch was testen mit nem LG (LA6608)
                          daniello
                          #82
                          Hallo allerseits,
                          kann mir jemand sagen, warum ich den Befehl zwei Mal absetzen muss bevor er funktioniert?
                          Über den LG WebOS SmartTV Adapter
                          Cloud Adapter -> lgtv.0 -> turnOff
                          Wenn ich das gleiche in einer Szene eintrag .. dann muss ich auch zwei Mal auf Play drücken damit der LG Off geht.
                            SchuetzeSchulz
                            #83
                            ich habe Euch nicht vergessen :)
                            Ich plane immer noch einen entsprechenden Adapter für die "älteren" LG TVs.
                            Ich würde jetzt gern ein bisschen Brainstorming betreiben und von Euch wissen, welche Funktionen und Befehle Ihr denn so in dem Adapter benötigen würdet.
                            • C Offline
                              C1500
                              #84
                              das klingt schon mal positiv das du uns nicht vergessen hast ;) ;) ;)
                              Mir würden ganz rudimentäre Sachen wie lauter, leiser, Prog+, Prog-, und wenn machbar PowerOn und PowerOff schon fast reichen.
                              Genial wären Text-Einblendungen wobei ich nicht weis ob der TV das überhaupt kann.
                              Wie gesagt, mein LG 47LA6608 ist erfolgreich gepairt.
                              Gfrei mi scho auf´s testen
                              Gruß Peer
                                TurBion
                                #85
                                ich habe LG 55LA6918 ohne WebOS gibt es da eine Möglichkeit den TV mit iobroker zu steuern?
                                • lobomauL Offline
                                  lobomauL Offline
                                  lobomau
                                  #86
                                  @TurBion:
                                  ich habe LG 55LA6918 ohne WebOS gibt es da eine Möglichkeit den TV mit iobroker zu steuern? `
                                  Genau um diese älteren ohne webOS geht es hier. Schauen wir mal ob es klappt.
                                  Ansonsten reichen mir auch die rudimentären Funktionen aus wie oben angesprochen.
                                  • Slave: Pi4
                                    TurBion
                                    #87
                                    @lobomau:
                                    @TurBion:
                                    Ansonsten reichen mir auch die rudimentären Funktionen aus wie oben angesprochen. `
                                    Wie kann man das einstellen?
                                    Ich Blick da nicht ganz durch.
                                      SchuetzeSchulz
                                      #88
                                      folgende Funktionen habe ich mir notiert:
                                      • Lautstärke lauter
                                      • Lautstärke leiser
                                      • Programm höher (+)
                                      • Programm niedriger (-)
                                      • TV ausschalten
                                      TV einschalten geht nicht, wenn dann evtl. über Wake on Lan, allerdings habe ich kein Modell hier zum Testen.
                                      Text-Einblendungen / Popups gehen leider ebenfalls nicht, da die API des TV's das nicht unterstützt. Das geht nur bei neueren WebOS-Modellen (ab ca. 2012?).
                                      Sonst noch was?!
                                      • lobomauL Offline
                                        lobomauL Offline
                                        lobomau
                                        #89
                                        @SchuetzeSchulz:
                                        • Lautstärke lauter
                                        • Lautstärke leiser
                                        • TV ausschalten
                                        Sonst noch was?! `
                                        • Programm 1,2,3,4,….20
                                        • HDMI 1,2,3,4
                                        • Slave: Pi4
                                          SchuetzeSchulz
                                          #90
                                          OK, Nachtrag:
                                          • Lautstärke lauter
                                          • Lautstärke leiser
                                          • TV ausschalten
                                          • Senderwahl (Kanal 1 bis x)
                                          • externe Eingänge schalten (HDMI …)
