    2. HugoSX22
    H
    • Posts 13
    HugoSX22
    @HugoSX22
    22
    HugoSX22 Follow
    Latest posts made by HugoSX22
    • RE: Falsche Werte
      Ein restart von iobroker hat das Problem gelöst.
      Ich werde das weiter beobachten und mich ggf. melden.
      Danke.
      H
      HugoSX22
    • RE: Falsche Werte
      Hallo Bluefox,
      hier die letzten Einträge im Log:
      ! fritzbox-0 2016-05-13 03:00:22 info data from 192.168.178.1: 13.05.16 11:00:33;DISCONNECT;1;79;
      ! fritzbox-0 2016-05-13 02:59:04 info data from 192.168.178.1: 13.05.16 10:59:15;CONNECT;1;11;7236430;
      ! fritzbox-0 2016-05-13 02:58:57 info data from 192.168.178.1: 13.05.16 10:59:08;CALL;1;11;9039311;7236430;SIP0;
      ! hm-rpc-0 2016-05-13 02:45:21 info binrpc -> 251 devices
      ! hm-rpc-0 2016-05-13 02:45:21 info binrpc <- listDevices ["hm-rpc.0"]
      ! hm-rpc-0 2016-05-13 02:45:21 info binrpc -> 192.168.178.32:2001 init ["xmlrpc_bin://192.168.178.35:2001","hm-rpc.0"]
      ! hm-rpc-0 2016-05-13 02:45:21 info binrpc server is trying to listen on 192.168.178.35:2001
      ! hm-rpc-0 2016-05-13 02:45:20 info starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hm-rpc
      ! host-odroid 2016-05-13 02:45:18 info instance system.adapter.hm-rpc.0 started with pid 4748
      ! host-odroid 2016-05-13 02:45:16 info instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      ! hm-rpc-0 2016-05-13 02:45:16 info terminating
      ! hm-rpc-0 2016-05-13 02:45:16 info binrpc -> 192.168.178.32:2001 init ["xmlrpc_bin://192.168.178.35:2001",""]
      ! host-odroid 2016-05-13 02:45:16 info stopInstance system.adapter.hm-rpc.0 killing pid 4742
      ! host-odroid 2016-05-13 02:45:16 info object change system.adapter.hm-rpc.0
      ! hm-rpc-0 2016-05-13 02:45:06 warn No image for "HM-OU-CFM-TW" found.
      ! hm-rpc-0 2016-05-13 02:45:06 warn No image for "HM-LC-RGBW-WM" found.
      ! hm-rpc-0 2016-05-13 02:45:06 warn No image for "HM-WDS40-TH-I-2" found.
      ! hm-rpc-0 2016-05-13 02:45:06 warn No image for "HM-RC-Dis-H-x-EU" found.
      ! hm-rpc-0 2016-05-13 02:45:06 warn No image for "HM-MOD-Re-8" found.
      ! hm-rpc-0 2016-05-13 02:45:06 warn No image for "HM-RC-8" found.
      ! hm-rpc-0 2016-05-13 02:45:06 warn No image for "HM-OU-CM-PCB" found.
      ! hm-rpc-0 2016-05-13 02:45:06 warn No image for "HM-MOD-EM-8" found.
      ! hm-rpc-0 2016-05-13 02:45:06 info binrpc <- newDevices 251
      ! hm-rpc-0 2016-05-13 02:45:02 info binrpc -> 0 devices
      ! hm-rpc-0 2016-05-13 02:45:02 info binrpc <- listDevices ["hm-rpc.0"]
      ! hm-rpc-0 2016-05-13 02:45:02 info binrpc -> 192.168.178.32:2001 init ["xmlrpc_bin://192.168.178.35:2001","hm-rpc.0"]
      ! hm-rpc-0 2016-05-13 02:45:02 info binrpc server is trying to listen on 192.168.178.35:2001
      ! hm-rpc-0 2016-05-13 02:45:01 info starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.hm-rpc
      ! host-odroid 2016-05-13 02:45:00 info instance system.adapter.hm-rpc.0 started with pid 4742
      ! host-odroid 2016-05-13 02:45:00 info object change system.adapter.hm-rpc.0
      ! host-odroid 2016-05-13 02:44:56 info instance system.adapter.hm-rpc.0 terminated with code 0 (OK)
      ! hm-rpc-0 2016-05-13 02:44:56 info terminating
      ! hm-rpc-0 2016-05-13 02:44:55 info binrpc -> 192.168.178.32:2001 init ["xmlrpc_bin://192.168.178.35:2001",""]
      ! host-odroid 2016-05-13 02:44:55 info stopInstance system.adapter.hm-rpc.0 killing pid 4736
      ! host-odroid 2016-05-13 02:44:55 info object change system.adapter.hm-rpc.0
      Und hier die HM-RPC Einstellungen:
      H
      HugoSX22
    • RE: Falsche Werte
      Hallo Pix,
      Danke für den Hinweis. Aber leider hat das nichts geändert. Die Werte auf beiden Seite sind immer noch die alten und damit unterschiedlich.
      H
      HugoSX22
    • Falsche Werte
      Hallo Leute, ich verstehe hier etwas nicht. Ich versuche die Temperatur und die Luftfeuchtigkeit über Vis anzuzeigen. Dabei ist mir aufgefallen, dass die Werte die die CCU anzeigt nicht mit den in Vis angezeigten Werte übereinstimmen. Ich hoffe, dass man das im angehängten Bild erkennen kann. Dort ist die Temperatur die die CCU hat 22.8 in Vis aber 22.5. Noch gravierender ist der Unterschied bei der Luftfeuchtigkeit. CCU zeigt 60%, Vis 57%. Was mache ich hier falsch?
      H
      HugoSX22
    • RE: Iobroker kann nicht mehr gestartet werden
      Ok, werde ich tun 😄
      H
      HugoSX22
      Hallo Thisoft: Kein Problem. Ich hoffe ich lerne dank eurer Unterstützung schnell dazu!
      Hallo Bluefox: Auch dir noch einmal vielen Dank!
      Im Übrigen ist iobroker schon eine tolle Sache.
      Dann hätte ich noch eine Frage. Bei der Installation des js-controllers habe ich verschiedene Warnmeldungen bekommen. Sollte ich da was tun?
      H
      HugoSX22
      Ok, war mir nicht bewusst.
      npm install iobroker.js-controller unter /opt/iobroker funktioniert nun. Danke!!!!
      H
      HugoSX22
      Danke, aber leider hat das auch nichts gebracht. Die Installation läuft einige Zeit und endet dann damit:
      iobroker.js-controller@0.8.10 node_modules/iobroker.js-controller
      ├── mime@1.3.4
      ├── daemonize2@0.4.2
      ├── ncp@2.0.0
      ├── node.extend@1.1.5 (is@3.1.0)
      ├── adm-zip@0.4.7
      ├── semver@4.3.6
      ├── node-schedule@1.0.0 (long-timeout@0.0.2, cron-parser@1.1.0)
      ├── yargs@3.32.0 (decamelize@1.2.0, camelcase@2.1.1, y18n@3.2.1, window-size@0.1.4, os-locale@1.4.0, cliui@3.2.0, string-width@1.0.1)
      ├── winston@2.2.0 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.1, async@1.0.0, colors@1.0.3)
      ├── socket.io@1.4.5 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, socket.io-adapter@0.4.0, engine.io@1.6.8)
      ├── winston-daily-rotate-file@1.0.1 (winston@2.1.1)
      ├── socket.io-client@1.4.5 (component-emitter@1.2.0, to-array@0.1.4, indexof@0.0.1, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, parseuri@0.0.4, has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, engine.io-client@1.6.8)
      ├── request@2.72.0 (is-typedarray@1.0.0, aws-sign2@0.6.0, forever-agent@0.6.1, caseless@0.11.0, stringstream@0.0.5, tunnel-agent@0.4.2, oauth-sign@0.8.1, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, combined-stream@1.0.5, node-uuid@1.4.7, qs@6.1.0, aws4@1.3.2, mime-types@2.1.10, tough-cookie@2.2.2, form-data@1.0.0-rc4, bl@1.1.2, har-validator@2.0.6, hawk@3.1.3, http-signature@1.1.1)
      ├── prompt@1.0.0 (revalidator@0.1.8, colors@1.1.2, pkginfo@0.4.0, read@1.0.7, winston@2.1.1, utile@0.3.0)
      ├── iobroker.admin@1.0.2 (connect-flash@0.1.1, xtend@4.0.1, cookie-parser@1.4.1, passport-local@1.0.0, passport@0.2.2, express-session@1.13.0, body-parser@1.15.0, express@4.13.4)
      ├── tar.gz@1.0.3 (commander@2.9.0, tar@2.2.1, bluebird@2.10.2, fstream@1.0.8, chai@3.5.0, mout@0.11.1, mocha@2.4.5)
      └── npm@2.15.4
      root@odroid:~#
      Schade. Gibt es noch andere Möglichkeiten?
      H
      HugoSX22
    • Iobroker kann nicht mehr gestartet werden
      Hallo, ich bin gerade am verzweifeln. Nachdem mein odroid c1 sauber nun zwei Wochen lief, habe ich zur Lastverteilung auf meinem RPI 2 auch iobroker installiert und in dann über './iobroker setup custom' die IP des odroid mitgeteilt. Dann bin ich auf Host im odroid gegangen. Der hat mit angezeigt, dass es einen Update gibt. Leider ist der Update (warum auch immer) schief gegangen - und nicht nur das - jetzt kann ich auf dem odroid iobroker nicht mehr starten.
      Wenn ich iobroker aufrufen kommt:
      root@odroid:/opt/iobroker# ./iobroker start
      module.js:340
      throw err;
      at Function.Module._resolveFilename (module.js:338:15)
      at Function.Module._load (module.js:280:25)
      at Function.Module.runMain (module.js:497:10)
      at startup (node.js:119:16)
      at node.js:901:3
      Was kann ich tun? Bin hier noch recht neu!
      H
      HugoSX22
    • RE: IOBroker Admin steht auf bearbeiten
      Hallo Bluefox,
      nach dem 'iobroker update' und dem 'sudo iobroker restart' geht es nun wieder!
      Vielen Dank!!!!
      Hugo
      H
      HugoSX22
