@stefank Auch ich habe Probleme (KIA Niro EV) - folgende Fehlermeldungen bei der Installation:
$ iobroker upgrade bluelink@3.1.20 --debug
Update bluelink from @3.1.3 to @3.1.20
NPM version: 10.9.3
Installing iobroker.bluelink@3.1.20... (System call)
npm warn deprecated npmlog@4.1.2: This package is no longer supported.
npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
npm warn deprecated gauge@2.7.4: This package is no longer supported.
bluelinky@9.1.0 prepare> tsc
usocket@0.3.0 install> node-gyp rebuild
gyp info it worked if it ends with ok
gyp info using node@22.19.0 | linux | arm64
(node:122369) [DEP0060] DeprecationWarning: Theutil._extendAPI is deprecated. Please use Object.assign() instead.(Usenode --trace-deprecation ...to show where the warning was created)
gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
gyp ERR! UNCAUGHT EXCEPTION
gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)gyp ERR! System Linux 6.12.34+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usocket/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/usocketgyp ERR! node -v v22.19.0gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
changed 2 packages in 29s
240 packages are looking for funding runnpm fundfor details
Updating objects from io-package.json for adapter "bluelink" with version "3.1.20"
Update "system.adapter.bluelink.0"
upload [12] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png
upload [11] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/de/translations.json i18n/de/translations.json application/json
upload [7] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/it/translations.json i18n/it/translations.json application/json
upload [6] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
upload [5] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
upload [4] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
upload [3] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/jsonConfig.json jsonConfig.json application/json
Process exited with code 0
Wer kann da weiterhelfen bzw. die Fehlermeldungen ausdeutschen?
