    2. kob1
    K
    kob1
    @kob1
    kob1 Follow
    Latest posts made by kob1
    • RE: Hilfe bei Fehlermeldung "Syntax Error"
      @thomas-braun Is ein RPi2 Rev 1.1. 😬
      Mich wunderts nur, mein letzter Zugriff auf das System war im Feb 24, bisher hat alles wunderbar geklappt.
      Heut war Stromausfall, danach ging nichts mehr...
      Danke soweit für eure Hilfe, ich werde schaun ob ich OS12 drauf bekomme!
      posted in Einsteigerfragen
      K
      kob1
      Hier die Summary, das dazwischen folgt gleich...
                              v.2024-05-22
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 4.19.97-v7+
            Architecture: arm
      Installation:           native
      Kernel:                 armv7l
      Userland:               32 bit
      Timezone:               Europe/Vienna (CEST, +0200)
      User-ID:                1000
      Display-Server:         false
      Pending OS-Updates:     1
      /opt/iobroker/node_modules/is/index.js:3
      import * as fs from 'fs';
      SyntaxError: Cannot use import statement outside a module
          at internalCompileFunction (node:internal/vm:73:18)
          at wrapSafe (node:internal/modules/cjs/loader:1178:20)
          at Module._compile (node:internal/modules/cjs/loader:1220:27)
          at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
          at Module.load (node:internal/modules/cjs/loader:1119:32)
          at Module._load (node:internal/modules/cjs/loader:960:12)
          at Module.require (node:internal/modules/cjs/loader:1143:19)
          at require (node:internal/modules/cjs/helpers:119:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/node.extend/lib/extend.js:12:10)
          at Module._compile (node:internal/modules/cjs/loader:1256:14)
      Node.js v18.18.2
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v18.18.2
      /usr/bin/node           v18.18.2
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      /usr/bin/corepack       0.19.0
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:           926M         60M        417M         19M        448M        782M
      Swap:           99M        5.0M         94M
      Total:         1.0G         66M        511M
      Active iob-Instances:   0
      Node.js v18.18.2
      Node.js v18.18.2
      ioBroker Core:          js-controller
      Node.js v18.18.2
                              admin
      Node.js v18.18.2
      ioBroker Status:
      Objects:                0
      States:                 0
      Size of iob-Database:
      7.2M    /opt/iobroker/iobroker-data/objects.jsonl
      5.4M    /opt/iobroker/iobroker-data/objects.json.migrated
      5.4M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      1.2M    /opt/iobroker/iobroker-data/states.jsonl
      1.2M    /opt/iobroker/iobroker-data/states.json.migrated
      1.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
      K
      kob1
      @thomas-braun sagte in Hilfe bei Fehlermeldung "Syntax Error":
      iob diag
      Das fängt genauso an:
      *** iob diag is starting up, please wait ***
      Node.js v18.18.2
      Node.js v18.18.2
      Node.js v18.18.2
      Node.js v18.18.2
      K
      kob1
    • Hilfe bei Fehlermeldung "Syntax Error"
      ich habe seit heute keinen Zugriff aufs Admin Interface und komme auch sonst nicht wirklich weiter. Ich bin totaler Neuling was ioBroker angeht und brauche es "nur" für die Kommunikation zw. KNX und einer Wetterstation
      Kann mir hier jemand weiterhelfen?
      Ich logge mich mit Putty ein und mit
       iobroker list instances
      will ich schaun was läuft. Egal was ich eingebe, die Fehlermeldung ist immer:
      pi@raspberrypi:/opt/iobroker $ iobroker list instances
      Node.js v18.18.2
      Bitte um Hilfe und beste Grüße!
      K
      kob1
