    2. Florian B
    Florian B
    @Florian B
    Florian B Follow
    Latest posts made by Florian B
    • RE: Tuya Adapter ohne Echtzeit Aktualisierung
      Nein, keinen X-Server.. mit Grafana, läuft gschmeidig! 😉
      Hier der Diag Output:
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Model           : Raspberry Pi Model B Rev 2
      Architecture:   armv6l
      Docker:         false
      Virtualization: none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       20:12:39 up 2 days,  5:36,  2 users,  load average: 3.66, 3.69, 3.79
      CPU threads: 2
      *** Time and Time Zones ***
      Fri Mar 17 19:12:39 UTC 2023
      Fri Mar 17 20:12:39 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            429M        211M        100M        0.0K        118M        173M
      Swap:           1.1G        345M        778M
      Total:          1.6G        556M        879M
                429 M total memory
                211 M used memory
                137 M active memory
                145 M inactive memory
                 99 M free memory
                  9 M buffer memory
                108 M swap cache
               1123 M total swap
                345 M used swap
                778 M free swap
      *** FILESYSTEM ***
      df: /mnt/nfs: Host is down
      /dev/root      ext4      7.1G  6.6G  167M  98% /
      devtmpfs       devtmpfs   87M     0   87M   0% /dev
      tmpfs          tmpfs     215M     0  215M   0% /dev/shm
      tmpfs          tmpfs      86M 1008K   85M   2% /run
      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs      43M   16K   43M   1% /run/user/1000
      Messages in dmesg:
      [Wed Mar 15 14:35:56 2023] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=cc9d61f0-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Wed Mar 15 14:35:59 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Wed Mar 15 14:35:59 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Wed Mar 15 14:36:08 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
      TARGET     SOURCE               FSTYPE OPTIONS
      /          /dev/mmcblk0p2       ext4   rw,noatime
      |-/boot    /dev/mmcblk0p1       vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/mnt/nfs //192.168.2.1/backup cifs   rw,relatime,vers=1.0,cache=strict,username=backup,domain=NAS,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.2.1,soft,unix,posixpaths,serverino,mapposix,acl,rsize=61440,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
      /var:
      1.6G    /var/
      1.1G    /var/log
      758M    /var/log/journal/095ae9a8b4eb4c7cb71d821a78a34687
      210M    /var/lib
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      47M     /opt/iobroker/iobroker-data/
      27M     /opt/iobroker/iobroker-data/backup-objects
      15M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      3.5M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      2.6M    /opt/iobroker/iobroker-data/states.jsonl
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v12.22.12
      /usr/bin/node           v12.22.12
      /usr/bin/npm            7.5.2
      /usr/bin/npx            7.5.2
      nodejs:
        Installed: 12.22.12~dfsg-1~deb11u1
        Candidate: 12.22.12~dfsg-1~deb11u3
        Version table:
           12.22.12~dfsg-1~deb11u3 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
       *** 12.22.12~dfsg-1~deb11u1 100
              100 /var/lib/dpkg/status
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
       Unable to increase LUA script timeout: Connection is closed.
       Cannot determine Set feature status: Connection is closed.
      Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
          at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
          at processTicksAndRejections (internal/process/task_queues.js:97:5)
       Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to meta namespace "meta." changes: Connection is closed.
      Objects and States
      Objects:        283
      States:         223
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/enterprise/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
      W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Get:3 https://packages.grafana.com/enterprise/deb stable InRelease [5984 B]
      Err:3 https://packages.grafana.com/enterprise/deb stable InRelease
      Reading package lists...
      Pending Updates: 116
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      116        10601      336/influxd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13841      337/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       13865      337/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11782      370/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          790991     5054/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      117        14015      333/grafana-server
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          790990     5054/cupsd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18615      613/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      116        14073      336/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          11797      370/sshd: /usr/sbin
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13745      275/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          791052     5055/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9876       240/avahi-daemon: r
      udp        0      0 0.0.0.0:51437           0.0.0.0:*                           108        9878       240/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       507125     4252/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       507126     4252/io.tuya.0
      udp6       0      0 :::5353                 :::*                                108        9877       240/avahi-daemon: r
      udp6       0      0 :::33319                :::*                                108        9879       240/avahi-daemon: r
      2023-03-17 20:41:04.365  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:05.076  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:05.095  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:05.586  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:06.604  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:06.778  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:09.967  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:10.042  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:10.813  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:10.833  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:11.909  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:13.799  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:13.864  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:15.605  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:15.628  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:19.115  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:19.176  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:21.023  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:22.533  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:23.090  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:25.215  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:25.812  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:25.854  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:26.374  - info: smartmeter.0 (627) Received 5 values, 2 updated
      2023-03-17 20:41:27.760  - info: smartmeter.0 (627) Received 5 values, 2 updated
      iob diag has finished.
      Florian B
      Florian B
      Also die Versionen sind schon richtig:
      Passen die nicht zusammen?
      Ja, der Raspberry ist ein altes Ding aber für die Visualisierung reicht er.
      Interessant ist jedenfalls, wenn ich die App am Handy öffne, dann klappts auch mit Echtzeit Datenpunkt (siehe um 14 Uhr im Screenshot).
      Florian B
      Florian B
    • Tuya Adapter ohne Echtzeit Aktualisierung
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi1B+
      Arbeitsspeicher: 512MB
      Festplattenart: SD-Karte
      Betriebssystem: Raspian
      Node-Version: 12.22.12
      Nodejs-Version: 12.22.12
      NPM-Version: 7.5.2
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Servus zusammen,
      habe für mein Balkonkraftwerk eine Green Sun Smart Plug die in Smart Life App problemlos läuft. Im iobroker habe ich mir den tuya Adapter installiert und meine Tuya Geräte über die Cloud gesynct. Auch den Tuya IOT Account habe ich angelegt, aber alles was ich bekomme sind vereinzelt Datenpunkte.
      Läuft das bei jemandem von Euch?
      Falls ja, habt Ihr eine Idee was bei mir falsch ist?
      Danke + Grüße
      Flo
      Florian B
      Florian B
