@tombox Natürlich. Ich werde die Daten über mehrere Tage sammeln und Ihnen die Daten zusenden
Latest posts made by sonny608
    RE: Test Adapter Hoover hONposted in Tester
    RE: Test Adapter Hoover hONposted in Tester@tombox Ja. Nach dem Neustart des Adapters ist für etwa einen Tag alles wieder normal.
    RE: Test Adapter Hoover hONposted in TesterHallo. Ich habe genau das gleiche Problem. Der Adapter stürzt nach 1 Tag Betrieb ab. Um wieder Statusmeldungen von Geräten zu erhalten, muss ich es neu starten. 2022-12-28 09:17:17.267 - info: hoover.0 (401) reconnect
 2022-12-28 09:19:25.648 - info: hoover.0 (401) reconnect
 2022-12-28 09:21:23.340 - info: admin.0 (164) ==> Connected system.user.admin from ::ffff:192.168.0.50
 2022-12-28 09:21:33.974 - info: hoover.0 (401) reconnect
 2022-12-28 09:22:09.294 - info: admin.0 (164) <== Disconnect system.user.admin from ::ffff:192.168.0.50 admin
 2022-12-28 09:22:14.412 - info: admin.0 (164) ==> Connected system.user.admin from ::ffff:192.168.0.50
 2022-12-28 09:22:16.581 - info: host.fd61d37ab4e3 stopInstance system.adapter.hoover.0 (force=false, process=true)
 2022-12-28 09:22:16.635 - info: hoover.0 (401) Got terminate signal TERMINATE_YOURSELF
 2022-12-28 09:22:16.638 - info: hoover.0 (401) terminating
 2022-12-28 09:22:16.640 - info: hoover.0 (401) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
 2022-12-28 09:22:16.675 - info: host.fd61d37ab4e3 stopInstance system.adapter.hoover.0 send kill signal
 2022-12-28 09:22:17.536 - info: host.fd61d37ab4e3 instance system.adapter.hoover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
 2022-12-28 09:22:19.767 - info: host.fd61d37ab4e3 instance system.adapter.hoover.0 started with pid 4192
 2022-12-28 09:22:26.768 - info: hoover.0 (4192) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.hoover, node: v16.18.1, js-controller: 4.0.23
 2022-12-28 09:22:26.850 - info: hoover.0 (4192) starting login
 2022-12-28 09:22:30.601 - info: hoover.0 (4192) Found 1 devices
 2022-12-28 09:22:30.626 - info: hoover.0 (4192) Connecting to MQTT
 2022-12-28 09:22:31.437 - info: hoover.0 (4192) mqtt connected
 2022-12-28 09:22:31.439 - info: hoover.0 (4192) subscribe to xyz……
