@david-jung
so, ich habe folgendes gemacht:
die Datei: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/saswell.js
etwas erweitert, jetzt kann ich die Ist-Temperatur ablesen, so wie die Soll-Temperatur setzen/lesen.
Den Modus (heizen/auto/aus) lesen, setzen.
Ventil Status ablesen.
Und Offset für Temperatur setzen/lesen.
const exposes = require('../lib/exposes');
const fz = {...require('../converters/fromZigbee'), legacy: require('../lib/legacy').fromZigbee};
const tz = require('../converters/toZigbee');
const tuya = require('../lib/tuya');
const reporting = require('../lib/reporting');
const e = exposes.presets;
const ea = exposes.access;
module.exports = [
fingerprint: [{modelID: 'GbxAXL2\u0000', manufacturerName: '_TYST11_KGbxAXL2'},
{modelID: 'uhszj9s\u0000', manufacturerName: '_TYST11_zuhszj9s'},
{modelID: '88teujp\u0000', manufacturerName: '_TYST11_c88teujp'},
{modelID: 'w7cahqs\u0000', manufacturerName: '_TYST11_yw7cahqs'},
{modelID: 'w7cahqs', manufacturerName: '_TYST11_yw7cahqs'},
{modelID: 'TS0601', manufacturerName: '_TZE200_c88teujp'},
{modelID: 'TS0601', manufacturerName: '_TZE200_yw7cahqs'},
{modelID: 'TS0601', manufacturerName: '_TZE200_azqp6ssj'},
{modelID: 'TS0601', manufacturerName: '_TZE200_bvu2wnxz'},
{modelID: 'TS0601', manufacturerName: '_TZE200_zuhszj9s'},
{modelID: 'TS0601', manufacturerName: '_TZE200_9gvruqf5'},
{modelID: 'TS0601', manufacturerName: '_TZE200_zr9c0day'},
model: 'SEA801-Zigbee/SEA802-Zigbee',
vendor: 'Saswell',
description: 'Thermostatic radiator valve',
whiteLabel: [{vendor: 'HiHome', model: 'WZB-TRVL'}, {vendor: 'Hama', model: '00176592'},
{vendor: 'RTX', model: 'ZB-RT1'}],
fromZigbee: [fz.saswell_thermostat, fz.ignore_tuya_set_time, fz.ignore_basic_report, fz.legacy.tuya_thermostat_weekly_schedule],
toZigbee: [tz.saswell_thermostat_current_heating_setpoint, tz.saswell_thermostat_mode, tz.saswell_thermostat_away,
tz.saswell_thermostat_child_lock, tz.saswell_thermostat_window_detection, tz.saswell_thermostat_frost_detection,
tz.saswell_thermostat_calibration, tz.saswell_thermostat_anti_scaling, tz.tuya_thermostat_weekly_schedule],
onEvent: tuya.onEventSetTime,
meta: {
thermostat: {
weeklyScheduleMaxTransitions: 4,
weeklyScheduleSupportedModes: [1], // bits: 0-heat present, 1-cool present (dec: 1-heat,2-cool,3-heat+cool)
weeklyScheduleConversion: 'saswell',
configure: async (device, coordinatorEndpoint, logger) => {
const endpoint = device.getEndpoint(1);
await reporting.bind(endpoint, coordinatorEndpoint, ['genBasic']);
exposes: [e.battery_low(), e.window_detection(), e.child_lock(),
exposes.binary('heating', ea.STATE, 'ON', 'OFF').withDescription('Device valve is open or closed (heating or not)'),
exposes.climate()
.withSetpoint('current_heating_setpoint', 5, 30, 0.5, ea.STATE_SET).withLocalTemperature(ea.STATE)
.withSystemMode(['off', 'heat', 'auto'], ea.STATE_SET)
// Range is -6 - 6 and step 1: https://github.com/Koenkk/zigbee2mqtt/issues/11777
.withLocalTemperatureCalibration(-6, 6, 1, ea.STATE_SET)
.withAwayMode()],
/*added by djung 10.11.2022*/
fingerprint: [{modelID: 'TS0601', manufacturerName: '_TZE200_h4cgnbzg'}],
model: 'HZ',
vendor: 'HAMA',
whiteLabel: [{vendor: 'Hama', model: 'XXXxxxXXX'},],
fromZigbee: [fz.saswell_thermostat],
tz.saswell_thermostat_calibration],
exposes: [
e.battery_low(),
/*e.switch(),*/
/*e.lock(),*/
exposes.climate()
soll man das irgendwo auf github oder so noch posten? Wenn ja, bitte zeigen wo
Grüße.
David.
