ich habe iobroker auf einem unraid-System via docker (buanet/iobroker) laufen. Soweit funktioniert alles problemlos.
Nun bietet mir das System Adapter-Updates an (Admin und e3dc-rscp). Leider schlagen die Updates jedoch fehl.
z.B. e3dc-rscp:
$ iobroker upgrade e3dc-rscp@1.0.7
Update e3dc-rscp from @1.0.6 to @1.0.7
NPM version: 8.15.0
Installing iobroker.e3dc-rscp@1.0.7... (System call)
host.a7cf71cb9b3e Cannot install iobroker.e3dc-rscp@1.0.7: 217
ERROR: Process exited with code 25
Ich habe schon den installer-fix durchgeführt und ein
npm cache clean --force
Weitere Informationen:
iobroker@a7cf71cb9b3e:~$ iobroker update
Used repository: stable
Adapter "admin" : 6.2.17 , installed 6.2.14 [Updatable]
Adapter "alexa2" : 3.11.2 , installed 3.19.5
Adapter "backitup" : 2.4.10 , installed 2.4.12
Adapter "bshb" : 0.1.20 , installed 0.1.20
Adapter "devices" : 1.0.12 , installed 1.0.12
Adapter "discovery" : 3.0.5 , installed 3.0.5
Adapter "e3dc-rscp" : 1.0.7 , installed 1.0.6 [Updatable]
Adapter "flot" : 1.11.0 , installed 1.11.0
Adapter "history" : 2.2.0 , installed 2.2.1
Adapter "homeconnect" : 1.0.1 , installed 1.0.1
Adapter "homee" : 1.2.0 , installed 1.2.0
Adapter "influxdb" : 3.1.7 , installed 3.1.8
Adapter "javascript" : 6.0.0 , installed 6.0.0
Controller "js-controller": 4.0.23 , installed 4.0.23
Adapter "material" : 1.1.2 , installed 1.1.2
Adapter "midea" : 0.0.7 , installed 0.0.7
Adapter "netatmo" : 1.7.1 , installed 1.7.1
Adapter "node-red" : 3.3.1 , installed 4.0.0
Adapter "pvforecast" : 2.3.0 , installed 2.3.0
Adapter "simple-api" : 2.7.0 , installed 2.7.0
Adapter "socketio" : 4.2.0 , installed 6.1.8
Adapter "vis" : 1.4.15 , installed 1.4.15
Adapter "vis-hqwidgets": 1.2.0 , installed 1.2.0
Adapter "web" : 4.3.0 , installed 5.2.4
Adapter "ws" : 1.3.0 , installed 2.1.3
iobroker@a7cf71cb9b3e:~$ iobroker list instances
+ system.adapter.admin.0 : admin : a7cf71cb9b3e - enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.backitup.0 : backitup : a7cf71cb9b3e - enabled
system.adapter.devices.0 : devices : a7cf71cb9b3e - enabled
+ system.adapter.discovery.0 : discovery : a7cf71cb9b3e - enabled
+ system.adapter.e3dc-rscp.0 : e3dc-rscp : a7cf71cb9b3e - enabled
+ system.adapter.history.0 : history : a7cf71cb9b3e - enabled
+ system.adapter.homee.0 : homee : a7cf71cb9b3e - enabled
+ system.adapter.influxdb.0 : influxdb : a7cf71cb9b3e - enabled, port: 8086
+ system.adapter.midea.0 : midea : a7cf71cb9b3e - enabled
+ system.adapter.netatmo.0 : netatmo : a7cf71cb9b3e - enabled
system.adapter.node-red.0 : node-red : a7cf71cb9b3e - disabled, port: 1880, bind: 0.0.0.0
+ system.adapter.pvforecast.1 : pvforecast : a7cf71cb9b3e - enabled
+ instance is alive
iobroker@a7cf71cb9b3e:~$ ps -ef|grep io
root 1 0 0 Aug29 ? 00:00:00 /bin/bash /opt/scripts/iobroker_startup.sh
iobroker 2594 1 1 09:14 ? 00:00:26 iobroker.js-controller
iobroker 2611 2594 0 09:14 ? 00:00:02 io.history.0
iobroker 2626 2594 0 09:14 ? 00:00:07 io.influxdb.0
iobroker 2641 2594 0 09:14 ? 00:00:02 io.homee.0
iobroker 2656 2594 0 09:14 ? 00:00:01 io.netatmo.0
iobroker 2671 2594 0 09:14 ? 00:00:01 io.discovery.0
iobroker 2686 2594 0 09:14 ? 00:00:01 io.backitup.0
iobroker 2701 2594 0 09:14 ? 00:00:01 io.midea.0
iobroker 2716 2594 0 09:14 ? 00:00:01 io.pvforecast.1
iobroker 2731 2594 0 09:14 ? 00:00:09 io.e3dc-rscp.0
iobroker 2764 2594 0 09:15 ? 00:00:04 io.admin.0
root 2867 875 0 09:19 pts/0 00:00:00 su iobroker
iobroker 2868 2867 0 09:19 pts/0 00:00:00 bash
iobroker 3120 2868 0 09:40 pts/0 00:00:00 ps -ef
iobroker 3121 2868 0 09:40 pts/0 00:00:00 grep io
Hat jemand eine Idee, was ich tun kann?
