    2. BiberM
    B
    BiberM
    @BiberM
    BiberM Follow
    Latest posts made by BiberM
    • RE: [gelöst] objects.jsonl wächst rasant
      @alcalzone
      JS-Controller: 4.0.23
      Objekte: 2398, Zustände: 2036
      Zeilen in objects.jsonl: 6590
      iobroker.json:
      pi@smarthomepi:~ $ cat /opt/iobroker/iobroker-data/iobroker.json
        "system": {
          "memoryLimitMB": 0,
          "hostname": "",
          "statisticsInterval": 15000,
          "statisticsIntervalComment": "Interval how often the counters for input/output in adapters and controller will be updated",
          "checkDiskInterval": 300000,
          "checkDiskIntervalComment": "Interval how often the disk size will be checked",
          "noChmod": false,
          "instanceStartInterval": 2000,
          "noChmodComment": "Flag to test new feature with no chmod call. Must be deleted later and noChmod must be mainline (2018.06.04)",
          "compact": false,
          "compactComment": "Controller will try to start the instances as a part of the same process. No spawn will be done. Only by adapters that support it and have flag compact flag in io-package.json",
          "allowShellCommands": false,
          "allowShellCommandsComment": "Allow execution of \"shell\" sendToHost commands"
        "multihostService": {
          "enabled": false,
          "secure": true
        "network": {
          "IPv4": true,
          "IPv6": true,
          "bindAddress": null
        "objects": {
          "type": "jsonl",
          "typeComment": "Possible values: 'file' - [port 9001], redis - [port 6379], couch - [port 5984].",
          "host": "127.0.0.1",
          "port": 9001,
          "user": "",
          "pass": "",
          "noFileCache": false,
          "connectTimeout": 2000,
          "options": {
            "auth_pass": null,
            "retry_max_delay": 5000
          "backup": {
            "disabled": false,
            "files": 24,
            "filesComment": "Minimal number of backup files, after the deletion will be executed according to backupTime settings",
            "hours": 48,
            "hoursComment": "All backups older than 48 hours will be deleted. But only if the number of files is greater than of backupNumber",
            "period": 120,
            "periodComment": "by default backup every 2 hours. Time is in minutes. To disable backup set the value to 0",
            "path": "",
            "pathComment": "Absolute path to backup directory or empty to backup in data directory"
          "dataDir": "../../iobroker-data/"
        "states": {
          "type": "jsonl",
          "typeComment": "Possible values: 'file' - [port 9000], 'redis' - [port 6379].",
          "port": 9000,
          "maxQueue": 1000,
          "user": "",
          "pass": "",
          "options": {
            "auth_pass": null,
          "backup": {
            "disabled": false,
            "files": 24,
            "hours": 48,
            "period": 120,
            "path": "",
        "log": {
          "level": "info",
          "maxDays": 7,
          "noStdout": true,
          "transport": {
            "file1": {
              "type": "file",
              "enabled": true,
              "filename": "log/iobroker",
              "fileext": ".log",
              "maxSize": null,
              "maxFiles": null
            "syslog1": {
              "type": "syslog",
              "enabled": false,
              "host": "localhost",
              "hostComment": "The host running syslogd, defaults to localhost.",
              "portComment": "The port on the host that syslog is running on, defaults to syslogd's default port(514/UDP).",
              "protocol": "udp4",
              "protocolComment": "The network protocol to log over (e.g. tcp4, udp4, unix, unix-connect, etc).",
              "pathComment": "The path to the syslog dgram socket (i.e. /dev/log or /var/run/syslog for OS X).",
              "facilityComment": "Syslog facility to use (Default: local0).",
              "localhost": "iobroker",
              "localhostComment": "Host to indicate that log messages are coming from (Default: localhost).",
              "sysLogTypeComment": "The type of the syslog protocol to use (Default: BSD).",
              "app_nameComment": "The name of the application (Default: process.title).",
              "eolComment": "The end of line character to be added to the end of the message (Default: Message without modifications)."
        "dataDirComment": "Always relative to iobroker.js-controller/",
      Aktuell läuft iob update / upgrade wieder problemlos. Ich habe gestern noch ein paar unbenutzte Adapter entfernt.
      Zudem habe ich eben auch schon geantwortet, dass ich mich um eine Größenordnung verrechnet habe. Damit dürfte die Größe als Fehlerquelle für nicht sperrbare Datenbank / nicht zugreifbare Datenbank ausscheiden. Ich werde das mal weiter beobachten. Danke euch beiden für den Schubs in die richtige Richtung.
      B
      BiberM
      @thomas-braun Oh Gott, es war schon zu spät gestern. Der Hinweis ist gar nicht so verkehrt. Sind keine GB sondern MB
      pi@smarthomepi:~ $ ls -lh /opt/iobroker/iobroker-data/
      insgesamt 51M
      drwxrwxr-x+  2 iobroker iobroker 4,0K 13. Jun 20:22 backitup
      drwxrwxr-x+  2 iobroker iobroker  12K 14. Jun 21:52 backup-objects
      drwxrwxr-x+ 28 iobroker iobroker 4,0K 13. Jun 22:23 files
      drwxrwxr-x+ 14 iobroker iobroker 4,0K 13. Jun 21:47 history
      -rw-rwxr--+  1 iobroker iobroker 4,4K 13. Jun 22:38 iobroker.json
      -rw-rwxr--+  1 iobroker iobroker    3 13. Jun 21:49 notifications.json
      -rw-rwxr--+  1 iobroker iobroker 7,4M 17. Mär 21:40 objects.json.bak.migrated
      -rw-rw-r--+  1 iobroker iobroker  30M 14. Jun 22:32 objects.jsonl
      drwxrwxr-x+  2 iobroker iobroker 4,0K 14. Jun 22:49 objects.jsonl.lock
      -rw-rwxr--+  1 iobroker iobroker 7,4M 17. Mär 21:40 objects.json.migrated
      -rw-rwxr--+  1 iobroker iobroker 818K 17. Mär 21:39 states.json.bak.migrated
      -rw-rw-r--+  1 iobroker iobroker 5,2M 14. Jun 22:49 states.jsonl
      drwxrwxr-x+  2 iobroker iobroker 4,0K 14. Jun 22:49 states.jsonl.lock
      -rw-rwxr--+  1 iobroker iobroker 818K 17. Mär 21:40 states.json.migrated
      Damit wahrscheinlich größentechnisch eher unspannend, oder?
      B
      BiberM
    • [gelöst] objects.jsonl wächst rasant
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspi 4b + Conbee II Stick
      Arbeitsspeicher: 4GB
      Festplattenart: 32GB MicroSD
      Betriebssystem: Raspian Bullseye
      Node-Version: 14.19.3
      Nodejs-Version: 14.19.3
      NPM-Version: 6.14.17
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei:
      Guten Abend,
      ich habe seit einigen Tagen das Problem, dass meine objects.jsonl sehr schnell wächst (ca. 1 GB / Tag).
      pi@smarthomepi:~ $ iob list instances
      + system.adapter.admin.0                  : admin                 : smarthomepi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : smarthomepi                              - disabled
      + system.adapter.deconz.0                 : deconz                : smarthomepi                              -  enabled
        system.adapter.discovery.0              : discovery             : smarthomepi                              - disabled
        system.adapter.fritzdect.0              : fritzdect             : smarthomepi                              - disabled
        system.adapter.history.0                : history               : smarthomepi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: smarthomepi                              - disabled
        system.adapter.info.0                   : info                  : smarthomepi                              - disabled
      + system.adapter.javascript.0             : javascript            : smarthomepi                              -  enabled
        system.adapter.material.0               : material              : smarthomepi                              - disabled
        system.adapter.rpi2.0                   : rpi2                  : smarthomepi                              - disabled
      + system.adapter.shelly.1                 : shelly                : smarthomepi                              -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.vis-bars.0               : vis-bars              : smarthomepi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : smarthomepi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : smarthomepi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : smarthomepi                              - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : smarthomepi                              - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : smarthomepi                              - disabled
        system.adapter.vis.0                    : vis                   : smarthomepi                              -  enabled
      + system.adapter.web.0                    : web                   : smarthomepi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      pi@smarthomepi:~ $ iob list adapters
      system.adapter.admin                   : admin          - v5.3.8
      system.adapter.backitup                : backitup       - v2.4.9
      system.adapter.deconz                  : deconz         - v1.3.21
      system.adapter.discovery               : discovery      - v3.0.3
      system.adapter.fritzdect               : fritzdect      - v2.2.3
      system.adapter.history                 : history        - v1.11.1
      system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.2
      system.adapter.info                    : info           - v1.9.19
      system.adapter.javascript              : javascript     - v5.7.0
      system.adapter.material                : material       - v1.1.2
      system.adapter.rpi2                    : rpi2           - v1.3.2
      system.adapter.shelly                  : shelly         - v5.3.2
      system.adapter.simple-api              : simple-api     - v2.6.1
      system.adapter.socketio                : socketio       - v4.2.0
      system.adapter.sql                     : sql            - v1.15.7
      system.adapter.vis                     : vis            - v1.4.15
      system.adapter.vis-bars                : vis-bars       - v0.1.4
      system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
      system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.2.0
      system.adapter.vis-justgage            : vis-justgage   - v1.0.2
      system.adapter.vis-plumb               : vis-plumb      - v1.0.2
      system.adapter.web                     : web            - v4.3.0
      2 aufeinanderfolgende ls -al innerhalb weniger Minuten sahen wie folgt aus
      pi@smarthomepi:~ $ ls -al /opt/iobroker/iobroker-data/
      insgesamt 44168
      drwxrwxr-x+  8 iobroker iobroker     4096 13. Jun 22:02 .
      drwxrwxr-x+  6 iobroker iobroker     4096 13. Jun 22:23 ..
      drwxrwxr-x+  2 iobroker iobroker     4096 13. Jun 20:22 backitup
      drwxrwxr-x+  2 iobroker iobroker    12288 13. Jun 17:56 backup-objects
      drwxrwxr-x+ 28 iobroker iobroker     4096 13. Jun 22:23 files
      drwxrwxr-x+ 14 iobroker iobroker     4096 13. Jun 21:47 history
      -rw-rwxr--+  1 iobroker iobroker     4425 13. Jun 22:38 iobroker.json
      -rw-rwxr--+  1 iobroker iobroker  7657352 17. Mär 21:40 objects.json.bak.migrated
      -rw-rw-r--+  1 iobroker iobroker 25530073 13. Jun 22:40 objects.jsonl
      drwxrwxr-x+  2 iobroker iobroker     4096 13. Jun 22:41 objects.jsonl.lock
      -rw-rwxr--+  1 iobroker iobroker  7657352 17. Mär 21:40 objects.json.migrated
      -rw-rwxr--+  1 iobroker iobroker   837073 17. Mär 21:39 states.json.bak.migrated
      -rw-rw-r--+  1 iobroker iobroker  2641643 13. Jun 22:41 states.jsonl
      drwxrwxr-x+  2 iobroker iobroker     4096 13. Jun 22:41 states.jsonl.lock
      -rw-rwxr--+  1 iobroker iobroker   837102 17. Mär 21:40 states.json.migrated
      insgesamt 44208
      -rw-rw-r--+  1 iobroker iobroker 25552652 13. Jun 22:41 objects.jsonl
      drwxrwxr-x+  2 iobroker iobroker     4096 13. Jun 22:43 objects.jsonl.lock
      -rw-rw-r--+  1 iobroker iobroker  2655495 13. Jun 22:42 states.jsonl
      drwxrwxr-x+  2 iobroker iobroker     4096 13. Jun 22:43 states.jsonl.lock
      Ich hatte zudem letztens Fehler, dass iobroker update nicht wollte, weil auf die Datenbank nicht mehr zugegriffen werden konnte. Ich habe Backups der objects und states eingespielt und es ging wieder alles. Bis diese wieder anfingen start zu wachsen (objects deutlich stärker).
      Ich habe den Thread link gefunden. Die hier angesprochenen Einstellungen sind bei mir in der iobroker.json nicht vorhanden, trotzdem scheint keine Komprimierung stattzufinden.
      Hat noch jemand eine Idee, woran das liegen könnte? Welche Informationen werden noch benötigt?
      Vielen Dank im Voraus!
      Michael
      B
      BiberM
