@wendy2702 ja genau.
Habe kdump abgeschaltet und bekomme die Meldung erstmal nicht. Kaufe mir einfach nochmal 2GB dazu bei Kleinanzeigen.
Allerdings habe ich immer noch das Problem. Gibt es für die DB einen eigenen Service oder so?
Hallo Zusammen,
ich habe seit 2 Wochen Probleme mit meinem iobroker und weiß nicht mehr weiter:
OS: Linux (RHEL8)
Status
[root@iobroker ~]# iobroker status
No connection to databases possible ...
oder manchmal dies
Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
Systemd
[root@iobroker ~]# systemctl status iobroker.service
● iobroker.service - ioBroker Server
Loaded: loaded (/usr/lib/systemd/system/iobroker.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2022-03-16 10:29:19 CET; 4min 15s ago
Docs: http://iobroker.net
Main PID: 918 (node)
Tasks: 132 (limit: 10672)
Memory: 1.0G
CGroup: /system.slice/iobroker.service
├─ 918 iobroker.js-controller
├─1564 io.admin.0
├─1594 /usr/bin/node /opt/iobroker/node_modules/iobroker.backitup/main.js 0 info
├─1595 /usr/bin/node /opt/iobroker/node_modules/iobroker.hmip/main.js 0 info
├─1603 /usr/bin/node /opt/iobroker/node_modules/iobroker.javascript/main.js 0 info
├─1615 /usr/bin/node /opt/iobroker/node_modules/iobroker.hmip/main.js 1 info
├─1621 /usr/bin/node /opt/iobroker/node_modules/iobroker.discovery/main.js 0 info
├─1629 io.ble.0
├─1635 io.ble.1
├─1644 io.whatsapp-cmb.0
├─1710 /usr/bin/node /opt/iobroker/node_modules/iobroker.whatsapp-cmb/main.js 1 info
└─1717 /usr/bin/node /opt/iobroker/node_modules/iobroker.simple-api/main.js 0 info
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.hmip.0" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.hmip.1" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.discovery.0" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.ble.0" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.ble.1" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.whatsapp-cmb.0" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.whatsapp-cmb.1" for host "iobroker"
Mar 16 10:29:39 iobroker bash[918]: host.iobroker check instance "system.adapter.simple-api.0" for host "iobroker"
Version
[root@iobroker ~]# iobroker -v
3.3.18
List Adapters and Instances
[root@iobroker ~]# iobroker list adapters
[root@iobroker ~]# iobroker list instances
Filesystem
[root@iobroker ~]# ls -la /opt/iobroker
total 236
drwxrwxr-x+ 6 iobroker iobroker 4096 Mar 2 19:06 .
drwxr-xr-x. 3 root root 22 Jun 21 2021 ..
-rw-rwxr--+ 1 iobroker iobroker 155 Mar 2 19:05 .npmrc
-rwxrwxrwx+ 1 iobroker iobroker 607 Mar 2 19:06 INSTALLER_INFO.txt
drwxrwxr-x+ 2 iobroker iobroker 4096 Jan 4 02:45 backups
lrwxrwxrwx. 1 iobroker iobroker 22 Mar 2 19:06 iob -> /opt/iobroker/iobroker
-rwxr-xr-x+ 1 iobroker iobroker 309 Mar 2 19:06 iobroker
drwxrwxr-x+ 4 iobroker iobroker 4096 Mar 16 10:37 iobroker-data
drwxrwxr-x+ 2 iobroker iobroker 4096 Mar 16 10:37 log
drwxrwxr-x+ 434 iobroker iobroker 12288 Dec 9 20:51 node_modules
-rw-rwxr--+ 1 iobroker iobroker 182043 Dec 9 20:51 package-lock.json
-rw-rwxr--+ 1 iobroker iobroker 496 Dec 9 20:51 package.json
-rw-rwxr--+ 1 iobroker iobroker 5693 Oct 20 20:35 reinstall.js
Log: nur Errors
[root@iobroker log]# tail -200 iobroker.current.log | grep error
2022-03-16 10:33:22.331 - error: admin.0 (875837) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:30:10.218 - error: host.iobroker Your system has only 34 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
2022-03-16 10:30:10.219 - error: host.iobroker In future versions, the adapter might not be started!
2022-03-16 10:30:10.473 - error: host.iobroker Your system has only 46 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
2022-03-16 10:30:10.473 - error: host.iobroker In future versions, the adapter might not be started!
2022-03-16 10:30:10.475 - error: host.iobroker Your system has only 46 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
2022-03-16 10:30:10.476 - error: host.iobroker In future versions, the adapter might not be started!
2022-03-16 10:30:10.487 - error: host.iobroker Your system has only 46 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
2022-03-16 10:30:10.488 - error: host.iobroker In future versions, the adapter might not be started!
2022-03-16 10:30:10.490 - error: host.iobroker Your system has only 46 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
2022-03-16 10:30:10.490 - error: host.iobroker In future versions, the adapter might not be started!
2022-03-16 10:30:11.166 - error: host.iobroker Your system has only 39 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
2022-03-16 10:30:11.167 - error: host.iobroker In future versions, the adapter might not be started!
2022-03-16 10:30:11.168 - error: host.iobroker Your system has only 39 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
2022-03-16 10:30:11.169 - error: host.iobroker In future versions, the adapter might not be started!
2022-03-16 10:35:41.658 - error: ble.1 (1635) States database error: read ECONNRESET
2022-03-16 10:35:41.676 - error: ble.0 (1629) States database error: read ECONNRESET
2022-03-16 10:35:41.691 - error: admin.0 (1564) States database error: read ECONNRESET
2022-03-16 10:35:41.743 - error: whatsapp-cmb.0 (1644) States database error: read ECONNRESET
2022-03-16 10:35:42.113 - warn: simple-api.0 (1717) get state error: Connection is closed.
2022-03-16 10:35:42.256 - warn: whatsapp-cmb.1 (1710) get state error: Connection is closed.
2022-03-16 10:35:42.398 - warn: simple-api.0 (1717) redis get system.adapter.simple-api.0.alive, error - Connection is closed.
2022-03-16 10:35:42.399 - warn: simple-api.0 (1717) redis get system.adapter.simple-api.0.sigKill, error - Connection is closed.
2022-03-16 10:35:46.741 - error: ble.1 (1635) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:46.781 - error: ble.0 (1629) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:46.916 - error: admin.0 (1564) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:47.022 - error: discovery.0 (1621) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:47.179 - error: hmip.1 (1615) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:47.265 - error: backitup.0 (1594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:47.259 - error: whatsapp-cmb.0 (1644) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:47.402 - error: hmip.0 (1595) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:47.491 - error: javascript.0 (1603) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:51.848 - error: ble.1 (1635) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:51.848 - error: ble.0 (1629) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:52.092 - error: discovery.0 (1621) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:52.130 - error: admin.0 (1564) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:52.253 - error: hmip.1 (1615) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:52.630 - error: hmip.0 (1595) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:53.020 - error: javascript.0 (1603) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:53.077 - error: whatsapp-cmb.0 (1644) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:53.220 - error: backitup.0 (1594) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
2022-03-16 10:35:56.649 - warn: ble.1 (1635) get state error: Connection is closed.
2022-03-16 10:35:56.676 - warn: javascript.0 (1603) get state error: Connection is closed.
2022-03-16 10:35:56.678 - warn: backitup.0 (1594) get state error: Connection is closed.
2022-03-16 10:35:56.687 - warn: hmip.0 (1595) get state error: Connection is closed.
2022-03-16 10:35:56.714 - warn: whatsapp-cmb.0 (1644) get state error: Connection is closed.
2022-03-16 10:35:56.743 - warn: admin.0 (1564) get state error: Connection is closed.
2022-03-16 10:35:56.755 - warn: discovery.0 (1621) get state error: Connection is closed.
2022-03-16 10:35:56.694 - warn: javascript.0 (1603) get state error: DB closed
2022-03-16 10:35:56.700 - warn: hmip.0 (1595) get state error: DB closed
2022-03-16 10:35:56.780 - warn: ble.0 (1629) get state error: Connection is closed.
2022-03-16 10:35:56.799 - warn: hmip.1 (1615) get state error: Connection is closed.
2022-03-16 10:36:34.738 - error: host.iobroker No connection to databases possible, restart
Log letzte 200 Zeilen
2022-03-16 10:33:17.331 - info: javascript.0 (875848) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:33:17.329 - info: hmip.1 (875862) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:33:17.336 - info: discovery.0 (875869) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:33:17.340 - info: hmip.0 (875849) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:33:17.338 - info: backitup.0 (875880) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:33:18.831 - info: admin.0 (875837) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:33:26.777 - info: host.iobroker iobroker.js-controller version 3.3.18 js-controller starting
2022-03-16 10:33:26.784 - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2022-03-16 10:33:26.785 - info: host.iobroker hostname: iobroker, node: v12.22.5
2022-03-16 10:33:26.786 - info: host.iobroker ip addresses: 192.168.1.20 fe80::6853:56f4:505b:6c99
2022-03-16 10:33:39.731 - info: host.iobroker connected to Objects and States
2022-03-16 10:33:41.526 - info: host.iobroker added notifications configuration of host
2022-03-16 10:33:44.413 - info: host.iobroker 11 instances found
2022-03-16 10:33:44.443 - info: host.iobroker starting 11 instances
2022-03-16 10:33:45.018 - info: host.iobroker instance system.adapter.admin.0 started with pid 875921
2022-03-16 10:33:52.299 - info: admin.0 (875921) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:33:52.674 - warn: admin.0 (875921) slow connection to objects DB. Still waiting ...
2022-03-16 10:33:52.894 - info: host.iobroker received SIGTERM
2022-03-16 10:33:52.898 - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
2022-03-16 10:33:52.901 - info: host.iobroker stopInstance system.adapter.javascript.0 (force=false, process=false)
2022-03-16 10:33:52.902 - info: host.iobroker stopInstance system.adapter.hmip.0 (force=false, process=false)
2022-03-16 10:33:52.902 - info: host.iobroker stopInstance system.adapter.hmip.1 (force=false, process=false)
2022-03-16 10:33:52.903 - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=false)
2022-03-16 10:33:52.903 - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=false)
2022-03-16 10:33:52.904 - info: host.iobroker stopInstance system.adapter.ble.0 (force=false, process=false)
2022-03-16 10:33:52.904 - info: host.iobroker stopInstance system.adapter.ble.1 (force=false, process=false)
2022-03-16 10:33:52.905 - info: host.iobroker stopInstance system.adapter.whatsapp-cmb.0 (force=false, process=false)
2022-03-16 10:33:52.905 - info: host.iobroker stopInstance system.adapter.whatsapp-cmb.1 (force=false, process=false)
2022-03-16 10:33:52.906 - info: host.iobroker stopInstance system.adapter.simple-api.0 (force=false, process=false)
2022-03-16 10:33:57.250 - info: host.iobroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
2022-03-16 10:33:57.258 - info: host.iobroker All instances are stopped.
2022-03-16 10:33:57.262 - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
2022-03-16 10:33:59.268 - info: host.iobroker terminated
2022-03-16 10:29:22.152 - info: host.iobroker iobroker.js-controller version 3.3.18 js-controller starting
2022-03-16 10:29:22.159 - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2022-03-16 10:29:22.159 - info: host.iobroker hostname: iobroker, node: v12.22.5
2022-03-16 10:29:22.160 - info: host.iobroker ip addresses:
2022-03-16 10:29:35.267 - info: host.iobroker connected to Objects and States
2022-03-16 10:29:37.004 - info: host.iobroker added notifications configuration of host
2022-03-16 10:29:39.852 - info: host.iobroker 11 instances found
2022-03-16 10:29:39.882 - info: host.iobroker starting 11 instances
2022-03-16 10:29:40.426 - info: host.iobroker instance system.adapter.admin.0 started with pid 1564
2022-03-16 10:29:48.325 - warn: admin.0 (1564) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:11.263 - warn: admin.0 (1564) slow connection to states DB. Still waiting ...
2022-03-16 10:30:11.354 - info: host.iobroker instance system.adapter.backitup.0 started with pid 1594
2022-03-16 10:30:11.493 - info: host.iobroker instance system.adapter.hmip.0 started with pid 1595
2022-03-16 10:30:11.622 - info: host.iobroker instance system.adapter.javascript.0 started with pid 1603
2022-03-16 10:30:11.760 - info: host.iobroker instance system.adapter.hmip.1 started with pid 1615
2022-03-16 10:30:11.875 - info: host.iobroker instance system.adapter.discovery.0 started with pid 1621
2022-03-16 10:30:12.012 - info: host.iobroker instance system.adapter.ble.0 started with pid 1629
2022-03-16 10:30:12.151 - info: host.iobroker instance system.adapter.ble.1 started with pid 1635
2022-03-16 10:30:14.144 - warn: host.iobroker Your system has only 58 MB RAM left available and an additional adapter process is started. Please check your system, settings and active instances to prevent swapping and Out-Of-Memory situations!
2022-03-16 10:30:14.283 - info: host.iobroker instance system.adapter.whatsapp-cmb.0 started with pid 1644
2022-03-16 10:30:25.214 - warn: backitup.0 (1594) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:25.201 - warn: discovery.0 (1621) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:25.203 - warn: ble.1 (1635) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:25.196 - warn: ble.0 (1629) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:26.581 - warn: hmip.0 (1595) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:26.665 - warn: hmip.1 (1615) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:26.759 - warn: whatsapp-cmb.0 (1644) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:27.225 - warn: javascript.0 (1603) slow connection to objects DB. Still waiting ...
2022-03-16 10:30:53.618 - warn: ble.1 (1635) slow connection to states DB. Still waiting ...
2022-03-16 10:31:00.430 - warn: hmip.0 (1595) slow connection to states DB. Still waiting ...
2022-03-16 10:31:00.434 - warn: whatsapp-cmb.0 (1644) slow connection to states DB. Still waiting ...
2022-03-16 10:31:00.466 - warn: discovery.0 (1621) slow connection to states DB. Still waiting ...
2022-03-16 10:31:00.485 - warn: backitup.0 (1594) slow connection to states DB. Still waiting ...
2022-03-16 10:31:00.520 - warn: ble.0 (1629) slow connection to states DB. Still waiting ...
2022-03-16 10:31:00.528 - warn: hmip.1 (1615) slow connection to states DB. Still waiting ...
2022-03-16 10:31:00.650 - warn: javascript.0 (1603) slow connection to states DB. Still waiting ...
2022-03-16 10:31:04.230 - info: host.iobroker instance system.adapter.whatsapp-cmb.1 started with pid 1710
2022-03-16 10:31:04.350 - info: host.iobroker instance system.adapter.simple-api.0 started with pid 1717
2022-03-16 10:31:04.803 - info: admin.0 (1564) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 3.3.18
2022-03-16 10:31:05.718 - info: admin.0 (1564) requesting all states
2022-03-16 10:31:05.719 - info: admin.0 (1564) requesting all objects
2022-03-16 10:31:14.223 - warn: whatsapp-cmb.1 (1710) slow connection to objects DB. Still waiting ...
2022-03-16 10:31:14.308 - warn: simple-api.0 (1717) slow connection to objects DB. Still waiting ...
2022-03-16 10:31:27.012 - info: whatsapp-cmb.0 (1644) starting. Version 0.1.6 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v12.22.5, js-controller: 3.3.18
2022-03-16 10:31:27.435 - warn: whatsapp-cmb.0 (1644) APIKEY is not provided. No messages will be sent
2022-03-16 10:31:31.998 - warn: simple-api.0 (1717) slow connection to states DB. Still waiting ...
2022-03-16 10:32:18.124 - info: ble.1 (1635) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v12.22.5, js-controller: 3.3.18
2022-03-16 10:32:38.362 - info: ble.0 (1629) starting. Version 0.12.0 in /opt/iobroker/node_modules/iobroker.ble, node: v12.22.5, js-controller: 3.3.18
2022-03-16 10:33:42.589 - warn: whatsapp-cmb.1 (1710) slow connection to states DB. Still waiting ...
2022-03-16 10:35:41.628 - warn: whatsapp-cmb.1 (1710) Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
2022-03-16 10:35:41.834 - info: admin.0 (1564) terminating https server on port 8081
2022-03-16 10:35:42.146 - info: simple-api.0 (1717) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:42.259 - info: whatsapp-cmb.1 (1710) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:42.369 - warn: simple-api.0 (1717) Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
2022-03-16 10:35:42.371 - warn: simple-api.0 (1717) Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
2022-03-16 10:35:43.228 - info: ble.1 (1635) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:43.239 - info: ble.0 (1629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:43.270 - info: discovery.0 (1621) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:43.339 - info: admin.0 (1564) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:43.354 - info: hmip.1 (1615) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:43.668 - info: backitup.0 (1594) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:43.661 - info: javascript.0 (1603) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:43.688 - info: whatsapp-cmb.0 (1644) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:43.726 - info: hmip.0 (1595) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
2022-03-16 10:35:46.698 - info: ble.1 (1635) Objects database successfully reconnected
2022-03-16 10:35:46.762 - info: ble.0 (1629) Objects database successfully reconnected
2022-03-16 10:35:46.904 - info: admin.0 (1564) Objects database successfully reconnected
2022-03-16 10:35:47.221 - info: whatsapp-cmb.0 (1644) Objects database successfully reconnected
2022-03-16 10:36:03.154 - info: host.iobroker iobroker.js-controller version 3.3.18 js-controller starting
2022-03-16 10:36:03.165 - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2022-03-16 10:36:03.166 - info: host.iobroker hostname: iobroker, node: v12.22.5
2022-03-16 10:36:03.167 - info: host.iobroker ip addresses: 192.168.1.20 fe80::6853:56f4:505b:6c99
2022-03-16 10:36:34.745 - info: host.iobroker iobroker _restart
2022-03-16 10:36:36.483 - info: host.iobroker connected to Objects and States
2022-03-16 10:36:42.006 - info: host.iobroker iobroker.js-controller version 3.3.18 js-controller starting
2022-03-16 10:36:42.013 - info: host.iobroker Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
2022-03-16 10:36:42.013 - info: host.iobroker hostname: iobroker, node: v12.22.5
2022-03-16 10:36:42.014 - info: host.iobroker ip addresses: 192.168.1.20 fe80::6853:56f4:505b:6c99
2022-03-16 10:36:54.657 - info: host.iobroker connected to Objects and States
2022-03-16 10:36:56.534 - info: host.iobroker added notifications configuration of host
2022-03-16 10:36:59.440 - info: host.iobroker 11 instances found
2022-03-16 10:36:59.470 - info: host.iobroker starting 11 instances
2022-03-16 10:37:00.042 - info: host.iobroker instance system.adapter.admin.0 started with pid 1842
2022-03-16 10:37:07.769 - warn: admin.0 (1842) slow connection to objects DB. Still waiting ...
2022-03-16 10:37:14.661 - warn: admin.0 (1842) slow connection to states DB. Still waiting ...
2022-03-16 10:37:16.873 - info: host.iobroker instance system.adapter.javascript.0 started with pid 1853
2022-03-16 10:37:16.941 - info: host.iobroker instance system.adapter.hmip.0 started with pid 1856
2022-03-16 10:37:17.081 - info: host.iobroker instance system.adapter.hmip.1 started with pid 1867
2022-03-16 10:37:17.275 - info: host.iobroker instance system.adapter.discovery.0 started with pid 1874
2022-03-16 10:37:19.889 - info: host.iobroker instance system.adapter.backitup.0 started with pid 1882
2022-03-16 10:37:29.044 - warn: discovery.0 (1874) slow connection to objects DB. Still waiting ...
2022-03-16 10:37:29.183 - warn: hmip.0 (1856) slow connection to objects DB. Still waiting ...
2022-03-16 10:37:29.215 - warn: hmip.1 (1867) slow connection to objects DB. Still waiting ...
2022-03-16 10:37:29.418 - warn: backitup.0 (1882) slow connection to objects DB. Still waiting ...
2022-03-16 10:37:29.922 - warn: javascript.0 (1853) slow connection to objects DB. Still waiting ...
2022-03-16 10:37:45.748 - info: admin.0 (1842) starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 3.3.18
2022-03-16 10:37:52.533 - warn: backitup.0 (1882) slow connection to states DB. Still waiting ...
2022-03-16 10:37:52.588 - warn: discovery.0 (1874) slow connection to states DB. Still waiting ...
2022-03-16 10:37:52.624 - warn: hmip.1 (1867) slow connection to states DB. Still waiting ...
2022-03-16 10:37:52.625 - warn: hmip.0 (1856) slow connection to states DB. Still waiting ...
2022-03-16 10:37:52.800 - info: admin.0 (1842) requesting all states
2022-03-16 10:37:52.801 - info: admin.0 (1842) requesting all objects
2022-03-16 10:37:54.956 - warn: javascript.0 (1853) slow connection to states DB. Still waiting ...
2022-03-16 10:37:58.972 - info: host.iobroker instance system.adapter.ble.0 started with pid 1911
2022-03-16 10:37:59.094 - info: host.iobroker instance system.adapter.ble.1 started with pid 1912
2022-03-16 10:37:59.197 - info: host.iobroker instance system.adapter.whatsapp-cmb.1 started with pid 1920
2022-03-16 10:37:59.337 - info: host.iobroker instance system.adapter.whatsapp-cmb.0 started with pid 1927
2022-03-16 10:37:59.499 - info: host.iobroker instance system.adapter.simple-api.0 started with pid 1938
2022-03-16 10:38:09.924 - warn: ble.0 (1911) slow connection to objects DB. Still waiting ...
2022-03-16 10:38:09.936 - warn: ble.1 (1912) slow connection to objects DB. Still waiting ...
2022-03-16 10:38:09.949 - warn: simple-api.0 (1938) slow connection to objects DB. Still waiting ...
2022-03-16 10:38:10.466 - warn: whatsapp-cmb.1 (1920) slow connection to objects DB. Still waiting ...
2022-03-16 10:38:10.625 - warn: whatsapp-cmb.0 (1927) slow connection to objects DB. Still waiting ...
2022-03-16 10:38:20.316 - warn: whatsapp-cmb.0 (1927) slow connection to states DB. Still waiting ...
Habt ihr eine Idee? System habe ich geupdatet und auch folgendes durchgeführt:
iobroker fix
Viele Grüße
lnix
