Hallo zusammen
ich habe Probleme, den Adapter zu starten. Im Log erscheinen folgenden Meldungen:
tahoma.0	2021-07-09 07:27:29.067	warn	(17898) Terminated (UNCAUGHT_EXCEPTION): Without reason
tahoma.0	2021-07-09 07:27:29.065	info	(17898) terminating
tahoma.0	2021-07-09 07:27:28.678	error	(17898) The state contains the forbidden properties x_time, roll_end_limit_state, application, setting_state, current_position, unroll_end_limit_state!
tahoma.0	2021-07-09 07:27:28.678	error	at processImmediate (internal/timers.js:463:21)
tahoma.0	2021-07-09 07:27:28.678	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:651:23)
tahoma.0	2021-07-09 07:27:28.678	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
tahoma.0	2021-07-09 07:27:28.678	error	at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5848:23)
tahoma.0	2021-07-09 07:27:28.678	error	(17898) Error: The state contains the forbidden properties x_time, roll_end_limit_state, application, setting_state, current_position, unroll_end_limit_state!
tahoma.0	2021-07-09 07:27:28.677	error	(17898) unhandled promise rejection: The state contains the forbidden properties x_time, roll_end_limit_state, application, setting_state, current_position, unroll_end_limit_state!
tahoma.0	2021-07-09 07:27:28.677	error	(17898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
tahoma.0	2021-07-09 07:27:28.634	error	(17898) The state contains the forbidden properties relaunch, absence!
tahoma.0	2021-07-09 07:27:28.633	error	at processImmediate (internal/timers.js:463:21)
tahoma.0	2021-07-09 07:27:28.633	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:651:23)
tahoma.0	2021-07-09 07:27:28.633	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
tahoma.0	2021-07-09 07:27:28.633	error	at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5848:23)
tahoma.0	2021-07-09 07:27:28.633	error	(17898) Error: The state contains the forbidden properties relaunch, absence!
tahoma.0	2021-07-09 07:27:28.632	error	(17898) unhandled promise rejection: The state contains the forbidden properties relaunch, absence!
tahoma.0	2021-07-09 07:27:28.632	error	(17898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
tahoma.0	2021-07-09 07:27:28.629	error	(17898) The state contains the forbidden properties relaunch, absence, rateManagement, energyDemandStatus!
tahoma.0	2021-07-09 07:27:28.629	error	at processImmediate (internal/timers.js:463:21)
tahoma.0	2021-07-09 07:27:28.629	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.tahoma/lib/tahoma.js:651:23)
tahoma.0	2021-07-09 07:27:28.629	error	at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
tahoma.0	2021-07-09 07:27:28.629	error	at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5848:23)
tahoma.0	2021-07-09 07:27:28.629	error	(17898) Error: The state contains the forbidden properties relaunch, absence, rateManagement, energyDemandStatus!
tahoma.0	2021-07-09 07:27:28.626	error	(17898) unhandled promise rejection: The state contains the forbidden properties relaunch, absence, rateManagement, energyDemandStatus!
tahoma.0	2021-07-09 07:27:28.625	error	(17898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
tahoma.0	2021-07-09 07:27:27.194	info	(17898) [INFO] Configured polling interval: 20000
tahoma.0	2021-07-09 07:27:27.170	info	(17898) [START] Starting adapter tahoma v0.3.2
tahoma.0	2021-07-09 07:27:27.068	info	(17898) starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.tahoma, node: v12.22.1, js-controller: 3.2.16
Verhalten: Ich starte den Adapter neu, die Ampel wechselt von rot nach orange, dann auf grün, nach einer Sekunde zurück auf orange, anschliessend wieder rot.
Mein Setting: Neue Installation auf Raspberry 4, sonst sind praktisch noch keine Adapter installiert.
Könnt ihr mir einen Tipp geben, was ich hier unternehmen könnte? Leider verstehe ich im Log nicht alles. Vielen Dank für eure Inputs.
