    2. Thomas75 0
    T
    Thomas75 0
    @Thomas75 0
    Thomas75 0 Follow
    Latest posts made by Thomas75 0
    • RE: HABPanel Installation klappt nicht
      Danke!
      T
      Thomas75 0
      Okay, hab ich gesehen. Scheint das gleiche zu sein. Dann abwarten?
      T
      Thomas75 0
      Okay, Habe auf node12 umgestellt:
      /usr/bin/nodejs
      v12.20.1
      /usr/bin/node
      v12.20.1
      /usr/bin/npm
      6.14.10
      nodejs:
        Installed: 12.20.1-1nodesource1
        Candidate: 12.20.1-1nodesource1
        Version table:
       *** 12.20.1-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.23.1~dfsg-1~deb10u1 500
      Danach
      cd /opt/iobroker
      npm cache  clear --force
      und
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      Aber leider klappt es immer noch nicht. Gleicher Fehler bei der Installation.
      $ ./iobroker add habpanel  --host raspberrypi
      NPM version: 6.14.10
      npm install iobroker.habpanel@0.4.3 --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code ENOTSUP
      npm ERR! notsup Unsupported engine for got@5.7.1: wanted: {"node":">=0.10.0 <7"} (current: {"node":"12.20.1","npm":"6.14.10"})
      npm ERR! notsup Not compatible with your version of node/npm: got@5.7.1
      npm ERR! notsup Not compatible with your version of node/npm: got@5.7.1npm ERR! notsup Required: {"node":">=0.10.0 <7"}npm ERR! notsup Actual:   {"npm":"6.14.10","node":"12.20.1"}
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-01-17T19_16_10_445Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.habpanel@0.4.3: 1
      ERROR: process exited with code 25
      T
      Thomas75 0
      @thomas-braun said in HABPanel Installation klappt nicht:
      Das hat leider nicht geklappt. Ist immer noch der gleiche Fehler.
      Die node-Installation sagt:
      /usr/bin/nodejs
      v10.23.1
      /usr/bin/node
      v10.23.1
      /usr/bin/npm
      6.14.10
      nodejs:
        Installed: 10.23.1-1nodesource1
        Candidate: 10.23.1-1nodesource1
        Version table:
       *** 10.23.1-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
      T
      Thomas75 0
    • HABPanel Installation klappt nicht
      mein erster Post, ich hoffe ich beschreibe es richtig... Die Installation des HABPanels auf dem Raspberry PI3 mit Betriebssystem RaspIOS lite klappt einfach nicht. Die Fehlermeldung wird angezeigt:
      npm ERR! notsup Unsupported engine for got@5.7.1: wanted: {"node":">=0.10.0 <7"} (current: {"node":"10.23.1","npm":"6.14.10"})
      npm ERR! notsup Actual:   {"npm":"6.14.10","node":"10.23.1"}
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-01-17T14_10_44_513Z-debug.log
      Danke für eure Hilfe.
      Thomas
      T
      Thomas75 0
