    2. SwApy
    SwApy
    @SwApy
    29
    Age 29
    SwApy Follow
    Latest posts made by SwApy
    • RE: Problem mit LetsEncrypt
      keiner eine idee?
      SwApy
      die ports sind offen habe den beitrag kurz angepasst ...
      80, 81, 443, 8081
      SwApy
    • Problem mit LetsEncrypt
      Ich bin recht neu im Thema Smart Home/Iobroker und habe aktuell das Problem kein zertifikat von LetsEncrypt über den Admin adapter zu bekommen.
      admin.0 2020-05-08 19:07:11.866 error (1461) Cannot get certificates: TypeError: invalid options argument
      admin.0 2020-05-08 19:07:06.647 info (1461) accountId:
      admin.0 2020-05-08 19:07:06.603 info (1461) checkAsync failed to find certificates
      admin.0 2020-05-08 19:07:06.564 info (1461) gl getting from disk or registering new
      admin.0 2020-05-08 19:07:06.562 info (1461) [object Object]
      admin.0 2020-05-08 19:07:06.560 info (1461) gl.approveDomains called with certs forNONEand options:
      admin.0 2020-05-08 19:07:06.554 info (1461) gl.getCertificates called for******************.myfritz.netwith certs for
      admin.0 2020-05-08 19:07:01.283 info (1461) Use link "https://localhost:8081" to configure.
      admin.0 2020-05-08 19:07:01.282 info (1461) https server listening on port 8081
      admin.0 2020-05-08 19:07:01.278 info (1461) LetsEncrypt challenge server is started on 81
      admin.0 2020-05-08 19:07:01.210 info (1461) created middleware
      admin.0 2020-05-08 19:07:00.944 info (1461) received all objects
      admin.0 2020-05-08 19:06:59.692 info (1461) requesting all objects
      admin.0 2020-05-08 19:06:59.690 info (1461) requesting all states
      admin.0 2020-05-08 19:06:59.606 info (1461) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.16.3, js-controller: 3.0.20
      Nach mehrfachen testen kommt natürlich die Sperre >.<
      admin.0 2020-05-08 19:56:10.665 error {"termsOfServiceAgreed":true,"onlyReturnExisting":false,"contact":["mailto:@web.de"]}
      admin.0 2020-05-08 19:56:10.665 error (609) Cannot get certificates: Error: account error: 429 {"type":"urn:ietf:params:acme:error:rateLimited","detail":"Error creating new account :: too many registrations for this IP: see https://letse
      admin.0 2020-05-08 19:56:07.834 info (609) accountId:
      admin.0 2020-05-08 19:56:07.806 info (609) checkAsync failed to find certificates
      admin.0 2020-05-08 19:56:07.769 info (609) gl getting from disk or registering new
      admin.0 2020-05-08 19:56:07.768 info (609) [object Object]
      admin.0 2020-05-08 19:56:07.767 info (609) gl.approveDomains called with certs forNONEand options:
      admin.0 2020-05-08 19:56:07.763 info (609) gl.getCertificates called for
      admin.0 2020-05-08 19:56:06.554 info (609) Use link "https://localhost:8081" to configure.
      admin.0 2020-05-08 19:56:06.553 info (609) https server listening on port 8081
      admin.0 2020-05-08 19:56:06.549 info (609) LetsEncrypt challenge server is started on 81
      admin.0 2020-05-08 19:56:06.470 info (609) created middleware
      admin.0 2020-05-08 19:56:05.995 info (609) received all objects
      admin.0 2020-05-08 19:56:04.568 info (609) requesting all objects
      admin.0 2020-05-08 19:56:04.566 info (609) requesting all states
      admin.0 2020-05-08 19:56:03.924 info (609) starting. Version 4.1.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.16.3, js-controller: 3.0.20
      und ja die benötigten Ports sind offen denke ich 🤔
      folgende Ports sind offen:
      80, 81, 443, 8081
      SwApy
