    2. toschi.home
    T
    toschi.home
    @toschi.home
    toschi.home Follow
    Latest posts made by toschi.home
    • RE: ioBroker nicht erreichbar
      Ja geil, der "Fixer" hat es gerichtet. Hab tausend Dank!
      T
      toschi.home
      Das Log spukt folgendes aus:
      pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
      2019-07-03 20:02:51.114  - info: host.raspberrypi iobroker.js-controller version 1.4.2 js-controller s                   tarting
      2019-07-03 20:02:51.127  - info: host.raspberrypi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
      2019-07-03 20:02:51.129  - info: host.raspberrypi hostname: raspberrypi, node: v8.15.0
      2019-07-03 20:02:51.139  - info: host.raspberrypi ip addresses: 192.168.2.121 fe80::ba27:ebff:fe8d:5f2                   6
      2019-07-03 20:02:51.372  - info: host.raspberrypi  inMem-states listening on port 9000
      2019-07-03 20:02:51.858  - info: host.raspberrypi  inMem-objects listening on port 9001
      2019-07-03 20:02:51.909  - info: host.raspberrypi InMemoryDB connected
      2019-07-03 20:02:51.954  - info: host.raspberrypi 16 instances found
      host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.cloud.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.terminal.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.mihome.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.yeelight-2.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.mihome-vacuum.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.ble.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.scenes.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.alexa2.0" for host "raspberrypi"
      host.raspberrypi check instance "system.adapter.harmony.0" for host "raspberrypi"
      2019-07-03 20:02:51.998  - info: host.raspberrypi starting 14 instances
      2019-07-03 20:02:52.123  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 853
      2019-07-03 20:02:52.180  - error: uncaught exception: EACCES: permission denied, open '/opt/iobroker/l                   og/iobroker.2019-07-03.log'
      2019-07-03 20:02:52.182  - error: Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2                   019-07-03.log'
      2019-07-03 20:02:52.197  - info: iobroker _restart
      2019-07-03 20:02:53.435  - info: iobroker Starting node restart.js
      2019-07-03 20:02:53.496  - info: iobroker exit 0
      EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../.                   ./../iobroker-data/objects.json.bak'
      Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/                   ../../../../iobroker-data/objects.json.bak'
          at Object.fs.openSync (fs.js:646:18)
          at Object.fs.writeFileSync (fs.js:1299:33)
          at Timeout.saveConfig [as _onTimeout] (/opt/iobroker/node_modules/iobroker.js-controller/lib/objec                   ts/objectsInMemServer.js:1897:16)
          at ontimeout (timers.js:498:11)
          at tryOnTimeout (timers.js:323:5)
          at Timer.listOnTimeout (timers.js:290:5)
      T
      toschi.home
    • ioBroker nicht erreichbar
      Re: Startseite iobroker nicht erreichbar
      es gibt zwar schon einiger ähnliche Beiträge, aber mit allem, was dort diskutiert wird, komme ich nicht weiter.
      Nach einem Stromausfalls erreiche ich meinen ioBroker über die Weboberfläche nicht mehr und meine Skripte werden auch nicht mehr ausgeführt. Über Putty komme ich auf den ioBroker, hab ihn und auch den raspberry auch schon neugestartet, hat aber nichts gebracht. Hier mal die Liste der Adapter:
      pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0 : admin - enabled, port: 8081, bin d: 0.0.0.0, run as: admin
      system.adapter.alexa2.0 : alexa2 - enabled
      system.adapter.backitup.0 : backitup - enabled
      system.adapter.ble.0 : ble - disabled
      system.adapter.cloud.0 : cloud - enabled
      system.adapter.discovery.0 : discovery - enabled
      system.adapter.harmony.0 : harmony - enabled
      system.adapter.hue.0 : hue - enabled, port: 80
      system.adapter.javascript.0 : javascript - enabled
      system.adapter.mihome-vacuum.0 : mihome-vacuum - enabled, port: 54321
      system.adapter.mihome.0 : mihome - disabled, port: 9898, bin d: 0.0.0.0
      system.adapter.scenes.0 : scenes - enabled
      system.adapter.terminal.0 : terminal - enabled, port: 8088, bin d: 0.0.0.0, run as: admin
      system.adapter.web.0 : web - enabled, port: 8082, bin d: 0.0.0.0, run as: admin
      system.adapter.yeelight-2.0 : yeelight-2 - enabled
      system.adapter.zigbee.0 : zigbee - enabled, port: /dev/seri al/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001936AA0C-if00
      Hat jemand eine Idee? Vielen lieben Dank.
      T
      toschi.home
