    2. 孙善明
    孙善明
    @孙善明
    孙善明 Follow
    Latest posts made by 孙善明
    • RE: iobroker/testing error
      solved
      dataDir = path.normalize(utils.controllerDir + '/iobroker-data/')
      孙善明
      孙善明
      I found the problem here.
       * @param {Partial<ioBroker.AdapterOptions>} [options]
      function startAdapter(options) {
      	// Create the adapter and define its methods
      	dataDir = path.normalize(path.join(utils.controllerDir, require(path.join(utils.controllerDir, 'lib', 'tools.js')).getDefaultDataDir()));
      	return adapter = utils.adapter(Object.assign({}, options, {
      		// The ready callback is called when databases are connected and adapter received configuration.
      		// start here!
      		ready: main, // Main method defined below for readability
      		// is called when adapter shuts down - callback has to be called under any circumstances!
      		unload: (callback) => {
      			try {
      				adapter.log.info("cleaned everything up...");
      				callback();
      			} catch (e) {
      				callback();
      孙善明
      孙善明
    • iobroker/testing error
      I wrote an adapter, but the following error occurred during automated testing, I need a little help
      travis-ci log
      github source
      "@iobroker/testing": "^1.2.5",
      The command "npm run test:package" exited with 0.
      1.37s$ npm run test:unit
      > iobroker.serve@0.0.1 test:unit /home/travis/build/smarthomefans/ioBroker.serve
      > mocha test/unit --exit
        Test the adapter (in a mocked environment)
          1) The adapter starts in normal mode
          2) The adapter starts in compact mode
        0 passing (78ms)
        2 failing
        1) Test the adapter (in a mocked environment)
             The adapter starts in normal mode:
           Error: Cannot find module '/home/travis/build/smarthomefans/iobroker.js-controller/lib/tools.js'
            at loadModuleInternal (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:166:26)
            at Module.fakeRequire [as require] (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:36:16)
            at require (internal/module.js:20:19)
            at startAdapter (main.js:36:58)
            at __dirname (main.js:151:2)
            at Object.<anonymous> (main.js:153:3)
            at Module.module._compile (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:158:24)
            at Object.replaceJsLoader (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:162:9)
            at Object.loadModuleInHarness (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:185:12)
            at Object.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:79:45)
            at next (native)
            at /home/travis/build/smarthomefans/ioBroker.serve/node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:8:71
            at __awaiter (node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:4:12)
            at Object.startMockAdapter (node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:36:12)
            at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/index.js:65:83)
            at next (native)
            at /home/travis/build/smarthomefans/ioBroker.serve/node_modules/@iobroker/testing/build/tests/unit/index.js:9:71
            at __awaiter (node_modules/@iobroker/testing/build/tests/unit/index.js:5:12)
            at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/index.js:61:20)
        2) Test the adapter (in a mocked environment)
             The adapter starts in compact mode:
            at Object.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:89:17)
            at next (native)
            at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/index.js:80:105)
            at next (native)
            at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/index.js:76:24)
      npm ERR! Linux 4.4.0-101-generic
      npm ERR! argv "/home/travis/.nvm/versions/node/v6.17.1/bin/node" "/home/travis/.nvm/versions/node/v6.17.1/bin/npm" "run" "test:unit"
      npm ERR! node v6.17.1
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.serve@0.0.1 test:unit: `mocha test/unit --exit`
      npm ERR! Exit status 2
      npm ERR!
      npm ERR! Failed at the iobroker.serve@0.0.1 test:unit script 'mocha test/unit --exit'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the iobroker.serve package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     mocha test/unit --exit
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs iobroker.serve
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls iobroker.serve
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     /home/travis/build/smarthomefans/ioBroker.serve/npm-debug.log
      The command "npm run test:unit" exited with 1.
      @Bluefox
      孙善明
      孙善明
