    2. Taragorm
    T
    • Posts 30
    Taragorm
    @Taragorm
    14
    30
    Taragorm Follow
    Best posts made by Taragorm
    • RE: getting started with visualisations
      Thanks- that solves the problem!
      posted in Visualization
      T
      Taragorm
    Latest posts made by Taragorm
    • RE: using iobroker.socket-client in a NodeJs project
      @bluefox The API seems straightforwards enough; a couple of questions though:
      • How do I unsubscribe? - I didn't see a command for that
      • Can I do a "Bulk" subscribe - i.e. ask for a list of states?
      posted in JavaScript
      T
      Taragorm
      @bluefox So you suggest the REST interface? - I'll go with that then. The app will likely be running on the same machine as ioBroker, anyhow.
      T
      Taragorm
      @alcalzone That was my assumption.
      Is there a NodeJs version?
      I can always use the basic REST interface, but it wouldn't be my first choice here...
      T
      Taragorm
    • using iobroker.socket-client in a NodeJs project
      Hi, I'm in the process of writng a NodeJs project that will talk to IOBroker.
      According to npm:
      @iobroker/socket-client@1.1.14
      when I try to create a connection, I get:
      ReferenceError: window is not defined
          at P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:123:7
          at new Promise (<anonymous>)
          at Connection.waitForSocketLib (P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:122:34)
          at new Connection (P:\Projects\Vue\logik\logik-backend\node_modules\@iobroker\socket-client\dist\cjs\Connection.js:87:10)
      As I understand it, this happens because "window" is not defined in NodeJS projects [I am by no means an expert JS programmer, btw]
      So.
      Is this the right library for the job?
      Does it in fact support Node?
      Am I missing some bit of initialisation to create a suitable "window" object under node.
      Hints appreciated.
      T
      Taragorm
      T
      Taragorm
    • Visualisation setup logic
      Hi, I'm contemplating including webhosting hub gylphs in a visualisation, see:
      https://www.webhostinghub.com/glyphs/
      But their license doesn't allow redistribution, so I was contemplating running some JS at startup to download the font, and (re-)install as required.
      Can I just add this code to main.js?
      Or is there some better way to do it?
      T
      Taragorm
      Appreciated
      T
      Taragorm
      In case it's not obvious, I'd like a widget to be able to generate oids based on, or relative to, an oid in an attribute, and have the object correctly added to the widget/view so I can get data from it.
      Surely there must be a way to do this?
      T
      Taragorm
      That works nicely, thanks.
      Out of curiosity, is there any way to force subscription?
      I have a case where I have mutiple values on a sensor, and I'd like to be able to just specify the sensor oid for the widget, and have the implementation figure out the values.
      e.g. I have
      foo.bah.x
      foo.bah.y
      foo.bah.z
      .. I'd like to only have to supply an oid of foo.bah - the widget can add .x, .y etc as those are fixed.
      or does supplying an oid = "foo.bah" create a subscription for changes of all children too?
      T
      Taragorm
      Ah, that would be it then - I may have missed it.
      I assumed that the /id type in the attr declaration was what did it.
      T
      Taragorm
