  3. Entwicklung
  4. Adapter mit debug output - zu viele Ausgaben wenn redis verwendet wird!
    5.6k
3 Beiträge 2 Kommentatoren 923 Aufrufe 1 Beobachtet
  • frankjokeF Offline
    frankjokeF Offline
    frankjoke
    Hallo mitsammen,
    ich versuche einen (#5) Adapter zu programmieren und verwende auch etliche adapter.log.debug-Messages.
    Wenn man allerdings redis verwendet dann werden vom system alle updates zur adapter-maintenance
    broadlink2.0	2017-07-24 10:36:47.215	debug	redis publish io.system.adapter.broadlink2.0.alive {"val":true,"ack":true,"ts":1500885407192,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884101309}
    broadlink2.0	2017-07-24 10:36:32.209	debug	redis publish io.system.adapter.broadlink2.0.outputCount {"val":8,"ack":true,"ts":1500885392203,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884146307}
    broadlink2.0	2017-07-24 10:36:32.208	debug	redis publish io.system.adapter.broadlink2.0.inputCount {"val":0,"ack":true,"ts":1500885392201,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884146304}
    broadlink2.0	2017-07-24 10:36:32.208	debug	redis publish io.system.adapter.broadlink2.0.uptime {"val":1294,"ack":true,"ts":1500885392199,"q":0,"from":"system.adapter.broadlink2.0","lc":1500885392199}
    broadlink2.0	2017-07-24 10:36:32.208	debug	redis publish io.system.adapter.broadlink2.0.memHeapUsed {"val":9.1,"ack":true,"ts":1500885392197,"q":0,"from":"system.adapter.broadlink2.0","lc":1500885392197}
    broadlink2.0	2017-07-24 10:36:32.207	debug	redis publish io.system.adapter.broadlink2.0.memHeapTotal {"val":12,"ack":true,"ts":1500885392196,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884791833}
    broadlink2.0	2017-07-24 10:36:32.207	debug	redis publish io.system.adapter.broadlink2.0.memRss {"val":28.73,"ack":true,"ts":1500885392192,"q":0,"from":"system.adapter.broadlink2.0","lc":1500885392192}
    broadlink2.0	2017-07-24 10:36:32.207	debug	redis publish io.system.adapter.broadlink2.0.connected {"val":true,"ack":true,"ts":1500885392186,"q":0,"from":"system.adapter.broadlink2.0","lc":1500884101313}
    br
    ````ausgegeben.
    Kann man das nicht ändern und dem js-controller als Adapter zuordnen?
    Man kann den 'debug'-mode kaum verwenden wenn redis aktiv ist da alle 15 sekunden 8 Meldungen erzeugt werden die den Log überschwemmen!
    Frank,
    • apollon77A Online
      apollon77A Online
      Ja, das ist nervig, aber faktisch gehört es nicht zum js-controller.
      Jeder Adapter nutzt eine eigene Verbindnung zum Redis und diese wird vom Adapterprozess direkt aufgebaut.
      grep -v "redis"
      nutze ich :-)
      frankjokeF 1 Antwort Letzte Antwort
      • apollon77A apollon77
        grep -v "redis"
        nutze ich :-)
        frankjokeF Offline
        frankjokeF Offline
        frankjoke
        @apollon77 sagte in Adapter mit debug output - zu viele Ausgaben wenn redis verwendet wird!:
        grep -v "redis"
        nutze ich :-)
        Kann man diesen loglevel bei den redis-logs nicht auf silly setzten? Dann wären sie da wo sie erwartet werden.
        Frank,
