  2. English
  3. ioBroker general
  4. Shelly doesn't connect to ioBroker anymore
    5.3k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
3 Beiträge 2 Kommentatoren 777 Aufrufe 1 Beobachtet
  • AlexandraA Offline
    AlexandraA Offline
    Alexandra
    Hello everyone!
    I just started using ioBroker and Shelly recently and I thought that maybe more experienced people could help me. I am using a Raspberry Pi 4 Model B and Shelly Plus 1PM and the Shelly doesn't connect to ioBroker anymore. Just earlier today it worked, because I tested turning it off and on from Vis, but after that I installed InfluxDB and Grafana. Everything went well as I connected everything together and the shelly was still displaying the data, but then I enabled Influx on the datapoints I wanted to make a graph with, I selected them in the Data Explorer from Influx and submitted them and after that the Shelly was not working anymore. Does Influx have anything to do with that or was it just bad timing?
    Shelly is connected to the same wi-fi as the Raspberry, MQTT is enabled and configured correctly for the shelly as well as in the shelly adapter for ioBroker.
    Thank you! 😁
    • AlexandraA Alexandra
      Hello everyone!
      Thank you! 😁
      @alexandra sagte in Shelly doesn't connect to ioBroker anymore:
      guess so!
      unfortunately I do not work with any of your components. So I cannot help you. sorry
      AlexandraA 1 Antwort Letzte Antwort
        guess so!
        AlexandraA Offline
        AlexandraA Offline
        Alexandra
        @homoran Thank you anyway!
