  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер javascript
    5.9k
Драйвер javascript
28 Beiträge 6 Kommentatoren 7.1k Aufrufe
  • BluefoxB Offline
    BluefoxB Offline
    @Haus:
    @Bluefox:
    Спасибо. Пофиксил. Сейчас не как не могу обновить сервер 0.8.3
    Обновлять только через консоль:
    cd /opt/iobroker
    iobroker stop
    npm install iobroker.js-controller
    iobroker start
    • H Offline
      Haus
      @Bluefox:
      @Haus:
      @Bluefox:
      cd /opt/iobroker
      iobroker stop
      iobroker start
      Сделал
      root@Server1:~# cd /opt/iobroker/
      root@Server1:/opt/iobroker# iobroker stop
      Stopping iobroker controller daemon...
      iobroker controller daemon stopped.
      Exit code for "killall.sh": 0
      root@Server1:/opt/iobroker# npm install iobroker.js-controller
      iobroker.js-controller@0.8.3 install /opt/iobroker/node_modules/iobroker.js-controller
      node lib/setup.js setup first
      ! iobroker.js-controller@0.8.3 node_modules/iobroker.js-controller
      ├── daemonize2@0.4.2
      ├── mime@1.3.4
      ├── ncp@2.0.0
      ├── adm-zip@0.4.7
      ├── node.extend@1.1.5 (is@3.1.0)
      ├── semver@4.3.6
      ├── node-schedule@0.2.9 (long-timeout@0.0.2, cron-parser@0.6.2)
      ├── yargs@3.32.0 (camelcase@2.0.1, window-size@0.1.4, y18n@3.2.0, decamelize@1.1.2, string-width@1.0.1, os-locale@1.4.0, cliui@3.1.0)
      ├── winston@1.1.2 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.1, async@1.0.0, colors@1.0.3)
      ├── socket.io@1.4.4 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6, engine.io@1.6.7, socket.io-adapter@0.4.0)
      ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
      ├── prompt@0.2.14 (revalidator@0.1.8, pkginfo@0.3.1, read@1.0.7, utile@0.2.1, winston@0.8.3)
      ├── socket.io-client@1.4.4 (to-array@0.1.3, indexof@0.0.1, component-emitter@1.2.0, component-bind@1.0.0, backo2@1.0.2, object-component@0.0.3, has-binary@0.1.7, debug@2.2.0, parseuri@0.0.4, socket.io-parser@2.2.5, engine.io-client@1.6.7)
      ├── request@2.67.0 (is-typedarray@1.0.0, aws-sign2@0.6.0, forever-agent@0.6.1, caseless@0.11.0, stringstream@0.0.5, tunnel-agent@0.4.2, oauth-sign@0.8.0, isstream@0.1.2, json-stringify-safe@5.0.1, extend@3.0.0, node-uuid@1.4.7, combined-stream@1.0.5, qs@5.2.0, mime-types@2.1.9, tough-cookie@2.2.1, form-data@1.0.0-rc3, bl@1.0.1, har-validator@2.0.6, http-signature@1.1.0, hawk@3.1.3)
      └── npm@2.14.15
      root@Server1:/opt/iobroker# iobroker start
      Starting iobroker controller daemon...
      iobroker controller daemon started. PID: 2509
      после старта все равно пишет 0.8.2 есть 0.8.3 и есть error
      Нажмите Ctrl+A и Ctrl+C, что бы скопировать в буффер обмена и после этого нажмите мышкой в любом месте.
      scenes-0 2016-01-22 01:08:30 info starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.scenes
      host-Server1 2016-01-22 01:08:29 info instance system.adapter.scenes.0 started with pid 1798
      simple-api-0 2016-01-22 01:08:22 info http server listening on port 8087
      simple-api-0 2016-01-22 01:08:22 info simpleAPI server listening on port 8087
      simple-api-0 2016-01-22 01:08:22 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.simple-api
      host-Server1 2016-01-22 01:08:21 info instance system.adapter.simple-api.0 started with pid 1784
      sayit-1 2016-01-22 01:08:18 info Upload announce mp3 files
      sayit-1 2016-01-22 01:08:18 info starting. Version 0.3.17 in /opt/iobroker/node_modules/iobroker.sayit
      host-Server1 2016-01-22 01:08:17 info instance system.adapter.sayit.1 started with pid 1766
      sayit-0 2016-01-22 01:08:14 info Upload announce mp3 files
      sayit-0 2016-01-22 01:08:14 info starting. Version 0.3.17 in /opt/iobroker/node_modules/iobroker.sayit
      host-Server1 2016-01-22 01:08:13 info instance system.adapter.sayit.0 started with pid 1760
      ping-2 2016-01-22 01:08:10 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
      host-Server1 2016-01-22 01:08:09 info instance system.adapter.ping.2 started with pid 1749
      email-0 2016-01-22 01:08:06 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.email
      host-Server1 2016-01-22 01:08:05 info instance system.adapter.email.0 started with pid 1729
      ping-1 2016-01-22 01:08:03 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
      socketio-0 2016-01-22 01:08:01 info socket.io server listening on port 8084
      socketio-0 2016-01-22 01:08:01 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.socketio
      host-Server1 2016-01-22 01:08:01 info instance system.adapter.ping.1 started with pid 1677
      host-Server1 2016-01-22 01:07:57 info instance system.adapter.socketio.0 started with pid 1669
      sql-0 2016-01-22 01:07:55 info Connected to mysql
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.temp_heat_tp_out
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.temp_heat_tp_in
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.circ_flap
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.circ_flap_percent
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.water_boller1_out
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.water_boller1_in
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.water_boller1_bottom
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.water_boller1_top
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.temp_in_stair
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.temp_in_sf
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.temp_out
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.akum_heat_1_4
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.akum_heat_1_3
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.akum_heat_1_2
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.akum_heat_1_1
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.heat_boller_out
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.heat_boller_exit
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.circ_temp_water
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.temp_heat_main_in
      sql-0 2016-01-22 01:07:55 info enabled logging of javascript.0.temp_heat_main_out
      sql-0 2016-01-22 01:07:55 info enabled logging of sayit.1.tts.volume
      sql-0 2016-01-22 01:07:55 info enabled logging of sayit.0.tts.volume
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.2.Server1.192_168_1_100
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.2.Server1.192_168_1_65
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.2.Server1.192_168_1_98
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.2.Server1.192_168_1_66
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.1.Server1.192_168_1_76
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.0.Server1.192_168_1_16
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.0.Server1.213_180_193_3
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.0.Server1.192_168_1_10
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.0.Server1.192_168_1_254
      sql-0 2016-01-22 01:07:55 info enabled logging of ping.0.Server1.192_168_1_14
      sql-0 2016-01-22 01:07:55 info enabled logging of owfs.0.wires.akum_heat_1_4
      sql-0 2016-01-22 01:07:55 info enabled logging of owfs.0.wires.akum_heat_1_3
      sql-0 2016-01-22 01:07:55 info enabled logging of owfs.0.wires.akum_heat_1_2
      sql-0 2016-01-22 01:07:55 info enabled logging of owfs.0.wires.akum_heat_1_1
      sql-0 2016-01-22 01:07:55 info enabled logging of owfs.0.wires.heat_boller_out
      sql-0 2016-01-22 01:07:55 info enabled logging of owfs.0.wires.heat_boller_exit
      sql-0 2016-01-22 01:07:55 info enabled logging of system.host.Server1.mem
      sql-0 2016-01-22 01:07:54 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sql
      host-Server1 2016-01-22 01:07:49 info instance system.adapter.sql.0 started with pid 1663
      mqtt-0 2016-01-22 01:07:49 info Client [LCD-accumulator_tanks_1] subscribes on 'mqtt.0.myhome.Boiler_room.#' with regex /^mqtt.0.myhome.Boiler_room..*/
      mqtt-0 2016-01-22 01:07:49 info publishOnSubscribe send all known states
      mqtt-0 2016-01-22 01:07:49 info Client [LCD-accumulator_tanks_1] subscribes on 'myhome.Boiler_room.#' with regex /myhome.Boiler_room.#/
      mqtt-0 2016-01-22 01:07:49 info Client [LCD-accumulator_tanks_1] connected
      mqtt-0 2016-01-22 01:07:49 info Starting MQTT server on port 1883
      mqtt-0 2016-01-22 01:07:46 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.mqtt
      host-Server1 2016-01-22 01:07:45 info instance system.adapter.mqtt.0 started with pid 1651
      ping-0 2016-01-22 01:07:38 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
      host-Server1 2016-01-22 01:07:37 info instance system.adapter.ping.0 started with pid 1638
      host-Server1 2016-01-22 01:07:35 info instance system.adapter.yr.0 terminated with code 0 (OK)
      admin-0 2016-01-22 01:07:34 info Repository received successfully.
      javascript-0 2016-01-22 01:07:33 info script.js.Time_say: registered 0 subscriptions and 1 schedule
      javascript-0 2016-01-22 01:07:33 info Start javascript script.js.Time_say
      javascript-0 2016-01-22 01:07:33 info script.js.Script4: registered 0 subscriptions and 0 schedules
      javascript-0 2016-01-22 01:07:33 info Start javascript script.js.Script4
      javascript-0 2016-01-22 01:07:33 info script.js.Email_aliarm: registered 1 subscription and 0 schedules
      javascript-0 2016-01-22 01:07:32 info Start javascript script.js.Email_aliarm
      javascript-0 2016-01-22 01:07:32 info script.js.Temp_Outside: registered 1 subscription and 0 schedules
      javascript-0 2016-01-22 01:07:32 info Start javascript script.js.Temp_Outside
      javascript-0 2016-01-22 01:07:32 info script.js.Volume_sayit_1: registered 0 subscriptions and 3 schedules
      javascript-0 2016-01-22 01:07:32 info Start javascript script.js.Volume_sayit_1
      javascript-0 2016-01-22 01:07:32 info script.js.Volume_sayit_0: registered 0 subscriptions and 3 schedules
      javascript-0 2016-01-22 01:07:32 info Start javascript script.js.Volume_sayit_0
      javascript-0 2016-01-22 01:07:32 info script.js.Ping_0_say: registered 6 subscriptions and 0 schedules
      javascript-0 2016-01-22 01:07:32 info Start javascript script.js.Ping_0_say
      javascript-0 2016-01-22 01:07:32 info script.js.Ping_1_say: registered 1 subscription and 0 schedules
      javascript-0 2016-01-22 01:07:32 info Start javascript script.js.Ping_1_say
      javascript-0 2016-01-22 01:07:32 info script.js.Mqtt_LCD: registered 4 subscriptions and 0 schedules
      javascript-0 2016-01-22 01:07:32 info Start javascript script.js.Mqtt_LCD
      javascript-0 2016-01-22 01:07:32 info script.js.Weather_say: registered 0 subscriptions and 1 schedule
      javascript-0 2016-01-22 01:07:31 info Start javascript script.js.Weather_say
      2016-01-22 01:07:31 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      2016-01-22 01:07:31 error at Client.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/client.js:193:14)
      2016-01-22 01:07:31 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/socket.js:295:12)
      2016-01-22 01:07:31 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/socket.js:335:8)
      2016-01-22 01:07:31 error at Socket.emit (events.js:106:17)
      2016-01-22 01:07:31 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2505:28)
      2016-01-22 01:07:31 error at ObjectsInMemServer.setObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:672:13)
      2016-01-22 01:07:31 error at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:532:16)
      2016-01-22 01:07:31 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:676:33)
      2016-01-22 01:07:31 error at ObjectsInMemServer.setObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:683:13)
      2016-01-22 01:07:31 error ReferenceError: adapter is not defined
      javascript-0 2016-01-22 01:07:31 info received all states
      javascript-0 2016-01-22 01:07:31 info received all objects
      yr-0 2016-01-22 01:07:29 info got weather data from yr.no
      yr-0 2016-01-22 01:07:27 info starting. Version 0.1.9 in /opt/iobroker/node_modules/iobroker.yr
      host-Server1 2016-01-22 01:07:25 info instance system.adapter.vis.0 terminated while should be started once
      javascript-0 2016-01-22 01:07:24 info requesting all objects
      javascript-0 2016-01-22 01:07:24 info requesting all states
      javascript-0 2016-01-22 01:07:24 info starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.javascript
      host-Server1 2016-01-22 01:07:21 info instance system.adapter.yr.0 started with pid 1621
      host-Server1 2016-01-22 01:07:21 info instance scheduled system.adapter.yr.0 0 /2 * * *
      vis-0 2016-01-22 01:07:11 info starting. Version 0.8.4 in /opt/iobroker/node_modules/iobroker.vis
      admin-0 2016-01-22 01:07:15 info received all states
      host-Server1 2016-01-22 01:07:15 info Update repository 'default' under 'conf/sources-dist.json'
      admin-0 2016-01-22 01:07:14 info received all objects
      host-Server1 2016-01-22 01:07:13 info instance system.adapter.javascript.0 started with pid 1619
      admin-0 2016-01-22 01:07:12 info Use link 'http://localhost:8081' to configure.
      admin-0 2016-01-22 01:07:12 info http server listening on port 8081
      admin-0 2016-01-22 01:07:12 info Request actual repository...
      admin-0 2016-01-22 01:07:12 info requesting all objects
      admin-0 2016-01-22 01:07:12 info requesting all states
      admin-0 2016-01-22 01:07:12 info starting. Version 0.7.3 in /opt/iobroker/node_modules/iobroker.admin
      web-0 2016-01-22 01:07:10 info starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.web
      host-Server1 2016-01-22 01:07:05 info instance system.adapter.web.0 started with pid 1603
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.temp_heat_tp_out
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.temp_heat_tp_in
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.circ_flap
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.circ_flap_percent
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.water_boller1_out
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.water_boller1_in
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.water_boller1_bottom
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.water_boller1_top
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.temp_in_stair
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.temp_in_sf
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.temp_out
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.akum_heat_1_4
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.akum_heat_1_3
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.akum_heat_1_2
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.akum_heat_1_1
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.heat_boller_out
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.heat_boller_exit
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.circ_temp_water
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.temp_heat_main_in
      history-0 2016-01-22 01:07:04 info enabled logging of javascript.0.temp_heat_main_out
      history-0 2016-01-22 01:07:04 info enabled logging of sayit.1.tts.volume
      history-0 2016-01-22 01:07:04 info enabled logging of sayit.1.tts.text
      history-0 2016-01-22 01:07:04 info enabled logging of sayit.0.tts.volume
      history-0 2016-01-22 01:07:04 info enabled logging of sayit.0.tts.text
      history-0 2016-01-22 01:07:04 info enabled logging of ping.2.Server1.192_168_1_100
      history-0 2016-01-22 01:07:04 info enabled logging of ping.2.Server1.192_168_1_65
      history-0 2016-01-22 01:07:04 info enabled logging of ping.2.Server1.192_168_1_98
      history-0 2016-01-22 01:07:04 info enabled logging of ping.2.Server1.192_168_1_66
      history-0 2016-01-22 01:07:04 info enabled logging of ping.1.Server1.192_168_1_76
      history-0 2016-01-22 01:07:04 info enabled logging of ping.0.Server1.192_168_1_16
      history-0 2016-01-22 01:07:04 info enabled logging of ping.0.Server1.213_180_193_3
      history-0 2016-01-22 01:07:04 info enabled logging of ping.0.Server1.192_168_1_10
      history-0 2016-01-22 01:07:04 info enabled logging of ping.0.Server1.192_168_1_254
      history-0 2016-01-22 01:07:04 info enabled logging of ping.0.Server1.192_168_1_14
      history-0 2016-01-22 01:07:04 info enabled logging of owfs.0.wires.akum_heat_1_4
      history-0 2016-01-22 01:07:04 info enabled logging of owfs.0.wires.akum_heat_1_3
      history-0 2016-01-22 01:07:04 info enabled logging of owfs.0.wires.akum_heat_1_2
      history-0 2016-01-22 01:07:04 info enabled logging of owfs.0.wires.akum_heat_1_1
      history-0 2016-01-22 01:07:04 info enabled logging of owfs.0.wires.heat_boller_out
      history-0 2016-01-22 01:07:04 info enabled logging of owfs.0.wires.heat_boller_exit
      history-0 2016-01-22 01:07:04 info enabled logging of yr.0.forecast.day0.temperature_actual
      history-0 2016-01-22 01:07:04 info enabled logging of yr.0.forecast.day0.precipitation_level
      history-0 2016-01-22 01:07:04 info enabled logging of yr.0.forecast.day0.wind_speed
      history-0 2016-01-22 01:07:04 info enabled logging of yr.0.forecast.day0.pressure
      history-0 2016-01-22 01:07:04 info enabled logging of system.host.Server1.mem
      history-0 2016-01-22 01:07:04 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.history
      host-Server1 2016-01-22 01:07:01 info instance system.adapter.history.0 started with pid 1500
      host-Server1 2016-01-22 01:06:57 info instance system.adapter.admin.0 started with pid 1183
      host-Server1 2016-01-22 01:06:57 info starting 24 instances
      host-Server1 2016-01-22 01:06:57 info 30 instances found
      host-Server1 2016-01-22 01:06:57 info InMemoryDB connected
      inMem-objects 2016-01-22 01:06:57 info listening on port 9001
      inMem-states 2016-01-22 01:06:56 info listening on port 9000
      host-Server1 2016-01-22 01:06:56 info ip addresses: 192.168.1.11 fe80::2e0:c5ff:fe6b:eca8
      host-Server1 2016-01-22 01:06:56 info hostname: Server1
      host-Server1 2016-01-22 01:06:56 info Copyright (c) 2014-2015 bluefox, hobbyquaker
      host-Server1 2016-01-22 01:06:56 info iobroker.js-controller version 0.8.2 js-controller starting
      simple-api-0 2016-01-22 01:05:45 info terminating http server on port 8087
      socketio-0 2016-01-22 01:05:45 info terminating http server on port 8084
      scenes-0 2016-01-22 01:05:43 info starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.scenes
      host-Server1 2016-01-22 01:05:42 info instance system.adapter.scenes.0 started with pid 2873
      simple-api-0 2016-01-22 01:05:35 info http server listening on port 8087
      simple-api-0 2016-01-22 01:05:35 info simpleAPI server listening on port 8087
      simple-api-0 2016-01-22 01:05:35 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.simple-api
      host-Server1 2016-01-22 01:05:34 info instance system.adapter.simple-api.0 started with pid 2859
      sayit-1 2016-01-22 01:05:31 info Upload announce mp3 files
      sayit-1 2016-01-22 01:05:31 info starting. Version 0.3.17 in /opt/iobroker/node_modules/iobroker.sayit
      host-Server1 2016-01-22 01:05:30 info instance system.adapter.sayit.1 started with pid 2835
      sayit-0 2016-01-22 01:05:27 info Upload announce mp3 files
      sayit-0 2016-01-22 01:05:27 info starting. Version 0.3.17 in /opt/iobroker/node_modules/iobroker.sayit
      host-Server1 2016-01-22 01:05:26 info instance system.adapter.sayit.0 started with pid 2829
      ping-2 2016-01-22 01:05:23 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
      host-Server1 2016-01-22 01:05:22 info instance system.adapter.ping.2 started with pid 2818
      email-0 2016-01-22 01:05:19 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.email
      host-Server1 2016-01-22 01:05:18 info instance system.adapter.email.0 started with pid 2804
      ping-1 2016-01-22 01:05:15 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
      host-Server1 2016-01-22 01:05:14 info instance system.adapter.ping.1 started with pid 2797
      socketio-0 2016-01-22 01:05:12 info socket.io server listening on port 8084
      socketio-0 2016-01-22 01:05:12 info starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.socketio
      host-Server1 2016-01-22 01:05:10 info instance system.adapter.socketio.0 started with pid 2785
      sql-0 2016-01-22 01:05:05 info Connected to mysql
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.temp_heat_tp_out
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.temp_heat_tp_in
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.circ_flap
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.circ_flap_percent
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.water_boller1_out
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.water_boller1_in
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.water_boller1_bottom
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.water_boller1_top
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.temp_in_stair
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.temp_in_sf
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.temp_out
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.akum_heat_1_4
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.akum_heat_1_3
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.akum_heat_1_2
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.akum_heat_1_1
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.heat_boller_out
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.heat_boller_exit
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.circ_temp_water
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.temp_heat_main_in
      sql-0 2016-01-22 01:05:05 info enabled logging of javascript.0.temp_heat_main_out
      sql-0 2016-01-22 01:05:05 info enabled logging of sayit.1.tts.volume
      sql-0 2016-01-22 01:05:05 info enabled logging of sayit.0.tts.volume
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.2.Server1.192_168_1_100
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.2.Server1.192_168_1_65
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.2.Server1.192_168_1_98
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.2.Server1.192_168_1_66
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.1.Server1.192_168_1_76
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.0.Server1.192_168_1_16
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.0.Server1.213_180_193_3
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.0.Server1.192_168_1_10
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.0.Server1.192_168_1_254
      sql-0 2016-01-22 01:05:05 info enabled logging of ping.0.Server1.192_168_1_14
      sql-0 2016-01-22 01:05:05 info enabled logging of owfs.0.wires.akum_heat_1_4
      sql-0 2016-01-22 01:05:05 info enabled logging of owfs.0.wires.akum_heat_1_3
      sql-0 2016-01-22 01:05:05 info enabled logging of owfs.0.wires.akum_heat_1_2
      sql-0 2016-01-22 01:05:05 info enabled logging of owfs.0.wires.akum_heat_1_1
      sql-0 2016-01-22 01:05:05 info enabled logging of owfs.0.wires.heat_boller_out
      sql-0 2016-01-22 01:05:05 info enabled logging of owfs.0.wires.heat_boller_exit
      sql-0 2016-01-22 01:05:05 info enabled logging of system.host.Server1.mem
      sql-0 2016-01-22 01:05:04 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.sql
      host-Server1 2016-01-22 01:05:02 info instance system.adapter.sql.0 started with pid 2779
      mqtt-0 2016-01-22 01:05:00 info Client [LCD-accumulator_tanks_1] subscribes on 'mqtt.0.myhome.Boiler_room.#' with regex /^mqtt.0.myhome.Boiler_room..
      mqtt-0 2016-01-22 01:05:00 info publishOnSubscribe send all known states
      mqtt-0 2016-01-22 01:05:00 info Client [LCD-accumulator_tanks_1] subscribes on 'myhome.Boiler_room.#' with regex /myhome.Boiler_room.#/
      mqtt-0 2016-01-22 01:05:00 info Client [LCD-accumulator_tanks_1] connected
      mqtt-0 2016-01-22 01:05:00 info Starting MQTT server on port 1883
      mqtt-0 2016-01-22 01:04:59 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.mqtt
      host-Server1 2016-01-22 01:04:58 info instance system.adapter.mqtt.0 started with pid 2717
      ping-0 2016-01-22 01:04:51 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.ping
      host-Server1 2016-01-22 01:04:50 info instance system.adapter.ping.0 started with pid 2704
      host-Server1 2016-01-22 01:04:38 info instance system.adapter.yr.0 terminated with code 0 (OK)
      javascript-0 2016-01-22 01:04:34 info script.js.Time_say: registered 0 subscriptions and 1 schedule
      javascript-0 2016-01-22 01:04:33 info Start javascript script.js.Time_say
      javascript-0 2016-01-22 01:04:33 info script.js.Script4: registered 0 subscriptions and 0 schedules
      javascript-0 2016-01-22 01:04:33 info Start javascript script.js.Script4
      javascript-0 2016-01-22 01:04:33 info script.js.Email_aliarm: registered 1 subscription and 0 schedules
      javascript-0 2016-01-22 01:04:33 info Start javascript script.js.Email_aliarm
      javascript-0 2016-01-22 01:04:33 info script.js.Temp_Outside: registered 1 subscription and 0 schedules
      javascript-0 2016-01-22 01:04:33 info Start javascript script.js.Temp_Outside
      javascript-0 2016-01-22 01:04:33 info script.js.Volume_sayit_1: registered 0 subscriptions and 3 schedules
      javascript-0 2016-01-22 01:04:33 info Start javascript script.js.Volume_sayit_1
      javascript-0 2016-01-22 01:04:33 info script.js.Volume_sayit_0: registered 0 subscriptions and 3 schedules
      javascript-0 2016-01-22 01:04:33 info Start javascript script.js.Volume_sayit_0
      javascript-0 2016-01-22 01:04:33 info script.js.Ping_0_say: registered 6 subscriptions and 0 schedules
      javascript-0 2016-01-22 01:04:33 info Start javascript script.js.Ping_0_say
      javascript-0 2016-01-22 01:04:33 info script.js.Ping_1_say: registered 1 subscription and 0 schedules
      javascript-0 2016-01-22 01:04:33 info Start javascript script.js.Ping_1_say
      javascript-0 2016-01-22 01:04:33 info script.js.Mqtt_LCD: registered 4 subscriptions and 0 schedules
      yr-0 2016-01-22 01:04:33 info got weather data from yr.no
      yr-0 2016-01-22 01:04:32 info starting. Version 0.1.9 in /opt/iobroker/node_modules/iobroker.yr
      javascript-0 2016-01-22 01:04:32 info Start javascript script.js.Mqtt_LCD
      javascript-0 2016-01-22 01:04:32 info script.js.Weather_say: registered 0 subscriptions and 1 schedule
      2016-01-22 01:04:32 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      2016-01-22 01:04:32 error at Client.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/client.js:193:14)
      2016-01-22 01:04:32 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/socket.js:295:12)
      2016-01-22 01:04:32 error at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/lib/socket.js:335:8)
      2016-01-22 01:04:32 error at Socket.emit (events.js:106:17)
      2016-01-22 01:04:32 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2505:28)
      2016-01-22 01:04:32 error at ObjectsInMemServer.setObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:672:13)
      2016-01-22 01:04:32 error at checkObjectRights (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:532:16)
      2016-01-22 01:04:32 error at ObjectsInMemServer. (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:676:33)
      2016-01-22 01:04:32 error at ObjectsInMemServer.setObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:683:13)
      2016-01-22 01:04:32 error ReferenceError: adapter is not defined
      javascript-0 2016-01-22 01:04:32 info Start javascript script.js.Weather_say
      javascript-0 2016-01-22 01:04:32 info received all states
      javascript-0 2016-01-22 01:04:32 info received all objects
      host-Server1 2016-01-22 01:04:30 info instance system.adapter.yr.0 started with pid 2691
      host-Server1 2016-01-22 01:04:30 info instance scheduled system.adapter.yr.0 0 */2 * * *
      javascript-0 2016-01-22 01:04:29 info requesting all objects
      javascript-0 2016-01-22 01:04:29 info requesting all states
      javascript-0 2016-01-22 01:04:29 info starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.javascript
      host-Server1 2016-01-22 01:04:28 info instance system.adapter.vis.0 terminated while should be started once
      admin-0 2016-01-22 01:04:26 info Repository received successfully.
      host-Server1 2016-01-22 01:04:26 info instance system.adapter.javascript.0 started with pid 2685
      vis-0 2016-01-22 01:04:25 info starting. Version 0.8.4 in /opt/iobroker/node_modules/iobroker.vis
      web-0 2016-01-22 01:04:25 info http server listening on port 8082
      web-0 2016-01-22 01:04:25 info socket.io server listening on port 8082
      web-0 2016-01-22 01:04:23 info simpleAPI server listening on port 8082
      web-0 2016-01-22 01:04:23 info starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.web
      host-Server1 2016-01-22 01:04:18 info instance system.adapter.web.0 started with pid 2673
      history-0 2016-01-22 01:04:17 info enabled logging of javascript.0.temp_heat_tp_out
      history-0 2016-01-22 01:04:17 info enabled logging of javascript.0.temp_heat_tp_in
      history-0 2016-01-22 01:04:17 info enabled logging of javascript.0.circ_flap
      history-0 2016-01-22 01:04:17 info enabled logging of javascript.0.circ_flap_percent
      history-0 2016-01-22 01:04:17 info enabled logging of javascript.0.water_boller1_out
      history-0 2016-01-22 01:04:17 info enabled logging of javascript.0.water_boller1_in
      history-0 2016-01-22 01:04:17 info enabled logging of javascript.0.water_boller1_bottom
      js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
      admin: 3.6.0
      javascript: 4.1.10
      web: 2.4.1 vis: 1.1.10
      cloud: 2.6.2
      Server: DELL FX170 / linux: Debian 9.5 Stretch
      Adapter: MegaD-2561, Mega-ES…
      • I Offline
        I Offline
        instalator
        BlueFox может добавить в драйвер возможность по кнопке сохранять все скрипты, каждый в файле с названием скрипта?
        Удобно было бы синхронизировать с облаком, например залил на гугл диск и можно из любого места (пока время есть))) подредактировать.
        • можно добавить темы подсветки кода
        PS. Убирайте логи в сообщениях под спойлер
        Высокий уровень Децибел вреден для здоровья!
        http://blog.instalator.ru/
        • BluefoxB Offline
          BluefoxB Offline
          @instalator:
          PS. Убирайте логи в сообщениях под спойлер `
          Я чего-то зашиваюсь…. Не знаю, но тема интересная: Экспорт/Импорт
          • I Offline
            I Offline
            instalator
            после сохранение скрипта содержимое скрипта выделяется и курсор встает в конец скрипта, что очень не удобно. приходится каждый раз искать где только что правил код. Лучшим вариантом было бы, если курсор будет оставаться в позиции до сохранения.
            • BluefoxB Offline
              BluefoxB Offline
              @instalator:
              после сохранение скрипта содержимое скрипта выделяется и курсор встает в конец скрипта, что очень не удобно. приходится каждый раз искать где только что правил код. Лучшим вариантом было бы, если курсор будет оставаться в позиции до сохранения. `
              JIRA?
                spectrekr
                Если в скрипте указать "formatDate(obj.ts, "JJJJ.MM.TT SS:mm:ss");" то он не обрабатывает день, так в результат пишет "2016.05.ТТ 19:46:11"
                • BluefoxB Offline
                  BluefoxB Offline
                  @spectrekr:
                  Если в скрипте указать "formatDate(obj.ts, "JJJJ.MM.TT SS:mm:ss");" то он не обрабатывает день, так в результат пишет "2016.05.ТТ 19:46:11" `
                  Поменяй в файле
                  opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js
                  Эту строчку https://github.com/ioBroker/ioBroker.js … r.js#L1689
                  const validFormatChars = 'YJГMDДhSчmмsс';
                  на
                  const validFormatChars = 'YJГMDTДhSчmмsс';
                  У тебя она в другом месте должна быть.
                  Спасибо за ошибку. ;)
