  2. English
  3. Visualization
  4. Not able to start VIS after recent power loss. SOLVED
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
5 Beiträge 2 Kommentatoren 929 Aufrufe 1 Beobachtet
    ap2017
    schrieb am zuletzt editiert von ap2017
    Not able to start VIS after recent power loss, getting the following messages
    URIError: Failed to decode param '%web_protocol%://192.168.1.74:%web_port%/vis/edit.html'
        at decodeURIComponent (<anonymous>)
        at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
        at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
        at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18)
        at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15)
        at compression (/opt/iobroker/node_modules/compression/index.js:220:5)
        at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
        at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
        at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
        at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
    • A ap2017
      HomoranH Offline
      HomoranH Offline
      @ap2017 Maybe that the filesystem is corrupted and nothing will work anymore.
      But we won't think of the worst case for now.
      please post iobroker list instances
      A 2 Antworten Letzte Antwort
        ap2017
        @homoran said in Not able to start VIS after recent power loss:
        Here we go:
        ap@AP-Tiny:~$ iobroker list instances
        + system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  -  enabled
        + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : AP-Tiny                                  -  enabled
          system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
          system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
        + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
          system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
          system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
        + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
        + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
        + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
          system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  - disabled, port: 5003, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as: admin
          system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
          system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
          system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
          system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
          system.adapter.web.0                    : web                   : AP-Tiny                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ba5ba26a021aec119f4c76e5f01c6278-if00-port0
        + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
        + instance is alive
        ap@AP-Tiny:~$
          ap2017
          @homoran Actually, you got me thinking. Web.o was off. When I turned it on VIS started to work! Thanks
          • A ap2017
            HomoranH Offline
            HomoranH Offline
            @ap2017 sagte in Not able to start VIS after recent power loss. SOLVED:
            Web.o was off
            that was what I wanted to see. But
            you got me thinking
            is the better way!
