  2. English
  3. Visualization
  4. VIS - error (connect lost) when adding more than 300 widgets
Geplant Angeheftet Gesperrt Verschoben Visualization
1 Beiträge 1 Kommentatoren 408 Aufrufe 1 Beobachtet
    avhoboken
    For hours trying to figure what is going wrong here. Uninstalled and reinstalled VIS with all depencencies but the problem continues to exist:
    All works ok until I want to add a new widget that is nr w00300 or higher. Then connection gets lost and those widgets are not saved anymore. If I delete a few, than adding/modifying is no problem at all. What can be the cause of this?
    I'm using stable releases and all adapters are updated to the latest versions. And further:
    js controller: 4.0.23
    NPM: 8.15
    node.js: v16.17.0
    Raspberry pi 4, 8GB RAM , 32GB SD
    Hope someone can help me with this because I'm totally stuck at the moment :(
    Thanks,
    Alex
