  2. English
  3. Cloud services
  4. Simple_api adapter syntax problem with esp32
    apollon77A
Geplant Angeheftet Gesperrt Verschoben Cloud services
2 Beiträge 1 Kommentatoren 1.9k Aufrufe 1 Beobachtet
  • kristfrizhK
    kristfrizhK
    kristfrizh
    schrieb am zuletzt editiert von kristfrizh
    Hii
    I have a project to send data using MQTT and restfull api using simple_api adapter.
    I have succed to send data using post via web browser
    simple api wiki
    Right now, i want to use esp32 with post and get http to sending and receive data.
    I want post the data the same like this in web browser via esp32
    192.168.0.120:8087/set/try_simple_api2?value=2
    I have build some code like this but still sent got nothing.
    anyone can help me?
    thank you very much regards
    #include <WiFi.h>
    #include <HTTPClient.h>
    const char* ssid = "asdasd";
    const char* password = "asdasd";
    const char* serverName = "http://192.168.0.120:8087/";
    unsigned long lastTime = 0;
    unsigned long timerDelay = 2000;
    void setup() {
      Serial.begin(115200);
      WiFi.begin(ssid, password);
      Serial.println("Connecting");
      while(WiFi.status() != WL_CONNECTED) {
        delay(500);
        Serial.print(".");
      Serial.println("");
      Serial.print("Connected to WiFi network with IP Address: ");
      Serial.println(WiFi.localIP());
      Serial.println("Timer set to 5 seconds (timerDelay variable), it will take 5 seconds before publishing the first reading.");
    void loop() {
      if ((millis() - lastTime) > timerDelay) {
        if(WiFi.status()== WL_CONNECTED){
          HTTPClient http;
          http.begin(serverName);
       http.addHeader("Content-Type", "text/plain");
          int httpResponseCode = http.POST("/set/try_simple_api2?value=7");
          Serial.print("HTTP Response code: ");
          Serial.println(httpResponseCode);
          // Free resources
          http.end();
        else {
          Serial.println("WiFi Disconnected");
        lastTime = millis();
    kristfrizhK 1 Antwort Letzte Antwort
    • kristfrizhK kristfrizh
      Hii
      simple api wiki
      anyone can help me?
      #include <WiFi.h>
      void setup() {
          delay(500);
          Serial.print(".");
        Serial.println("");
      void loop() {
            HTTPClient http;
            // Free resources
            http.end();
          else {
      kristfrizhK
      kristfrizhK
      kristfrizh
      @kristfrizh Hii
      i just figured it out
      we don't use post at all with those syntax
      thank you
      84.0k
      1.4m
