  2. English
  3. Scripting / Logic
  4. JSON - Reading a datapoint with a . in the name? - Solved
    6.7k
Geplant Angeheftet Gesperrt Verschoben Scripting / Logic
blocklyjavascript
6 Beiträge 2 Kommentatoren 4.2k Aufrufe 1 Beobachtet
  • E Offline
    erwinberlin
    schrieb am zuletzt editiert von erwinberlin
    Hi, I am having trouble reading a data point from a JSON message in blockly. The script works, however there is 1 datapoint with a . in it. Is there a trick to get it done? I tried various solutions I found online, however to no avail. See the JSON message below.
    {"Time":"2021-03-28T11:31:08","BMP180":{"Temperature":11.4,"Pressure":1022.7},"SHT3X-0x45":{"Temperature":11.2,"Humidity":45.3,"DewPoint":-0.3},"SDS0X1":{"PM2.5":3.6,"PM10":7.0},"PressureUnit":"hPa","TempUnit":"C"}
    • E erwinberlin
      @erwinberlin
      obj.SDS0X1['PM2.5']
      Blockly:
      E 1 Antwort Letzte Antwort
        @erwinberlin
        obj.SDS0X1['PM2.5']
        Blockly:
        erwinberlin
        This is my code, however the PM2.5 still does not work in this script. I used the code in blockly and that works fine! Now I can see the differences, but I still would like to understand why the script does not work?
        Probably obvious to experienced Java programmers, however not for a newbie like me. Any help appreciated!
        var AQ;
        on({id: "mqtt.0.tele.tasmota_sensors_7E466A.SENSOR", change: "any"}, async function (obj) {
          var value = obj.state.val;
          AQ = (function () { try {return JSON.parse(getState("mqtt.0.tele.tasmota_sensors_7E466A.SENSOR").val);} catch(e) {return {};}})();
          console.log('PM10 & PM2.5');
          console.log(parseFloat(getAttr(AQ, 'SDS0X1.PM10')));
          console.log(parseFloat(getAttr(AQ, 'SDS0X1['PM2.5']')));
          if (parseFloat(getAttr(AQ, 'SDS0X1.PM10')) != 0) {
            setState("javascript.0.Air-quality.10um", parseFloat(getAttr(AQ, 'SDS0X1.PM10')), true);
          if (parseFloat(getAttr (AQ, 'SDS0X1['PM2.5']') != 0) {
            setState("javascript.0.Air-quality.2_5um", parseFloat(getAttr(AQ, 'SDS0X1['PM2.5']')), true);
        • E erwinberlin
          var AQ;
          @erwinberlin sagte): 'SDS0X1['PM2.5']'
          Try this:
          PM10 and PM2.5 values are numbers.
          let x = getAttr(json, 'SDS0X1['PM2.5']'); // designed for Blockly
          // is not
          let x = JSON.parse(json).SDS0X1['PM2.5']; // Javascript
          because the 2. parameter of getAttr() must be a string or an array with one string element.
          P.S. Spricht ErwinBerlin kein deutsch?
          • E erwinberlin
            var AQ;
            @erwinberlin
            Javascript-Version:
            on('mqtt.0.tele.tasmota_sensors_7E466A.SENSOR', function (dp) {
              let sensor = JSON.parse(dp.state.val);
              let pm10 = sensor.SDS0X1.PM10;
              let pm2_5 = sensor.SDS0X1['PM2.5'];
              log('PM10: ' + pm10);
              log('PM2.5: ' + pm2_5);
              if (pm10) setState("javascript.0.Air-quality.10um", pm10, true);
              if (pm2_5) setState("javascript.0.Air-quality.2_5um", pm2_5, true);
              @erwinberlin
              Javascript-Version:
              erwinberlin
              @paul53 Super, vielen Dank! Das hat mich sehr geholfen.
              Übrigens spreche ich Deutsch, aber schreiben ist jedoch etwas ganz anderes...
