  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Onkyo
    5.9k
Onkyo
120 Beiträge 4 Kommentatoren 27.3k Aufrufe
  • I Offline
    I Offline
    instalator
    #61
    @Bluefox:
    eiscp.get_commands('main', function (err, cmds) {
                adapter.log.info(JSON.stringify(cmds));
                cmds.forEach(function (cmd) {
                    eiscp.get_command(cmd, function (err, values) {
                        adapter.log.debug('Please send following info to developer: ' + cmd + ', ' + JSON.stringify(values));
    При окннекте выдает только это:
    ! onkyo-0 2015-06-25 21:17:24 info stateChange onkyo.0.command {"val":"MVL2B","ack":true,"ts":1435245444,"from":"system.adapter.onkyo.0","lc":1435245444}
    ! onkyo-0 2015-06-25 21:17:24 info stateChange onkyo.0.volume {"val":43,"ack":true,"ts":1435245444,"from":"system.adapter.onkyo.0","lc":1435243598}
    ! onkyo-0 2015-06-25 21:17:24 info stateChange onkyo.0.master-volume {"val":43,"ack":true,"ts":1435245444,"from":"system.adapter.onkyo.0","lc":1435243598}
    ! onkyo-0 2015-06-25 21:17:24 info Got message: {"command":["master-volume","volume"],"argument":43,"iscp_command":"MVL2B","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
    ! onkyo-0 2015-06-25 21:17:23 info stateChange onkyo.0.command {"val":"MVL2B","ack":true,"ts":1435245444,"from":"system.adapter.onkyo.0","lc":1435245444}
    ! onkyo-0 2015-06-25 21:17:23 info stateChange onkyo.0.volume {"val":43,"ack":true,"ts":1435245444,"from":"system.adapter.onkyo.0","lc":1435243598}
    ! onkyo-0 2015-06-25 21:17:23 info stateChange onkyo.0.master-volume {"val":43,"ack":true,"ts":1435245444,"from":"system.adapter.onkyo.0","lc":1435243598}
    ! onkyo-0 2015-06-25 21:17:23 info Got message: {"command":["master-volume","volume"],"argument":43,"iscp_command":"MVL2B","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
    ! onkyo-0 2015-06-25 21:17:23 info stateChange onkyo.0.command {"val":"AMT00","ack":true,"ts":1435245443,"from":"system.adapter.onkyo.0","lc":1435245443}
    ! onkyo-0 2015-06-25 21:17:23 info stateChange onkyo.0.mute {"val":false,"ack":true,"ts":1435245443,"from":"system.adapter.onkyo.0","lc":1434642794}
    ! onkyo-0 2015-06-25 21:17:23 info Got message: {"command":"audio-muting","argument":"off","iscp_command":"AMT00","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
    ! onkyo-0 2015-06-25 21:17:22 info stateChange onkyo.0.command {"val":"PWR01","ack":true,"ts":1435245443,"from":"system.adapter.onkyo.0","lc":1435245443}
    ! onkyo-0 2015-06-25 21:17:22 info stateChange onkyo.0.power {"val":true,"ack":true,"ts":1435245443,"from":"system.adapter.onkyo.0","lc":1435232679}
    ! onkyo-0 2015-06-25 21:17:22 info Got message: {"command":"system-power","argument":"on","iscp_command":"PWR01","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
    ! onkyo-0 2015-06-25 21:17:22 info stateChange onkyo.0.command {"val":"SLI23","ack":true,"ts":1435245442,"from":"system.adapter.onkyo.0","lc":1435245442}
    ! onkyo-0 2015-06-25 21:17:22 info stateChange onkyo.0.input {"val":["cd","tv","cd"],"ack":true,"ts":1435245442,"from":"system.adapter.onkyo.0","lc":1435151166}
    ! onkyo-0 2015-06-25 21:17:22 info Got message: {"command":"input-selector","argument":["cd","tv","cd"],"iscp_command":"SLI23","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
    ! onkyo-0 2015-06-25 21:17:22 info Initial query: master-volume
    ! onkyo-0 2015-06-25 21:17:22 info Initial query: volume
    ! onkyo-0 2015-06-25 21:17:22 info Initial query: audio-muting
    ! onkyo-0 2015-06-25 21:17:22 info Initial query: system-power
    ! onkyo-0 2015-06-25 21:17:22 info Initial query: input-selector
    ! onkyo-0 2015-06-25 21:17:17 info stateChange onkyo.0.connected {"val":true,"ack":true,"ts":1435245437,"from":"system.adapter.onkyo.0","lc":1434642788}
    ! onkyo-0 2015-06-25 21:17:17 info ["system-power","audio-muting","speaker-a","speaker-b","speaker-layout","master-volume","volume","tone-front","tone-front-wide","tone-front-high","tone-center","tone-surround","tone-surround-back","t
    ! onkyo-0 2015-06-25 21:17:17 info Successfully connected to AVR
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • I Offline
      I Offline
      instalator
      #62
      Я думаю нужно заслать все команды которые описаны в https://github.com/tillbaks/node-eiscp/ … mands.json
      Имею ввиду с параметром QSTN
      • BluefoxB Offline
        BluefoxB Offline
        #63
        Значит твой прибор не поддерживает get_commands…. И решение не работает..
        А как выяснить, какаие команды конкретный аппарат поддерживает?
        • I Offline
          I Offline
          instalator
          #64
          @Bluefox:
          А как выяснить, какаие команды конкретный аппарат поддерживает? `
          Короче обманул я тебя. В лог не весь текст выводится
          ! onkyo-0 2015-06-25 21:17:17 info stateChange onkyo.0.connected {'val':true,'ack':true,'ts':1435245437,'from':'system.adapter.onkyo.0','lc':1434642788}
          ! onkyo-0 2015-06-25 21:17:17 info ['system-power','audio-muting','speaker-a','speaker-b','speaker-layout','master-volume','volume','tone-front','tone-front-wide','tone-front-high','tone-center','tone-surround','tone-surround-back','tone-subwoofer','sleep-set','speaker-level-calibration','subwoofer-temporary-level','center-temporary-level','display-mode','dimmer-level','setup','memory-setup','audio-infomation','video-infomation','input-selector','recout-selector','audio-selector','12v-trigger-a','12v-trigger-b','12v-trigger-c','video-output-selector','hdmi-output-selector','hdmi-audio-out','monitor-out-resolution','isf-mode','video-wide-mode','video-picture-mode','listening-mode','late-night','cinema-filter','audyssey-2eq-multeq-multeq-xt','audyssey-dynamic-eq','audyssey-dynamic-volume','dolby-volume','music-optimizer','tuning','preset','preset-memory','rds-information','pty-scan','tp-scan','xm-channel-name-info','xm-artist-name-info','xm-title-info','xm-channel-number','xm-category','sirius-channel-name-info','sirius-artist-name-info','sirius-title-info','sirius-channel-number','sirius-category','sirius-parental-lock','hd-radio-artist-name-info','hd-radio-channel-name-info','hd-radio-title-info','hd-radio-detail-info','hd-radio-channel-program','hd-radio-blend-mode','hd-radio-tuner-status','network-usb','net-usb-artist-name-info','net-usb-album-name-info','net-usb-title-name','net-usb-time-info','net-usb-track-info','net-usb-play-status','internet-radio-preset','net-usb-list-info','net-usb-jacket-art','net-service','net-keyboard','net-popup-message','ipod-mode-change','cd-player','tape1-a','tape2-b','graphics-equalizer','dat-recorder','dvd-player','md-recorder','cd-r-recorder','universal-port','ipod-artist-name-info','ipod-album-name-info','ipod-title-name','ipod-time-info','ipod-track-info','ipod-play-status','ipod-list-info','dab-preset','dab-sation-name','dab-display-info']
          • BluefoxB Offline
            BluefoxB Offline
            #65
            @instalator:
            @Bluefox:
            ! onkyo-0 2015-06-25 21:17:17 info Successfully connected to AVR `
            Тогда попробуй следующее: (строка 169(
                            eiscp.command(cmd + "=query"); // Create for every command the object
            • I Offline
              I Offline
              instalator
              #66
              @Bluefox:
              @instalator:
              @Bluefox:
              Зашуршало!
              • I Offline
                I Offline
                instalator
                #67
                ! onkyo-0 2015-06-25 21:35:23 info stateChange onkyo.0.command {'val':'MVL0A','ack':true,'ts':1435246524,'from':'system.adapter.onkyo.0','lc':1435246523}
                ! onkyo-0 2015-06-25 21:35:23 info stateChange onkyo.0.volume {'val':10,'ack':true,'ts':1435246524,'from':'system.adapter.onkyo.0','lc':1435245983}
                ! onkyo-0 2015-06-25 21:35:23 info stateChange onkyo.0.master-volume {'val':10,'ack':true,'ts':1435246524,'from':'system.adapter.onkyo.0','lc':1435245983}
                ! onkyo-0 2015-06-25 21:35:23 info Got message: {'command':['master-volume','volume'],'argument':10,'iscp_command':'MVL0A','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:23 info stateChange onkyo.0.command {'val':'MVL0A','ack':true,'ts':1435246523,'from':'system.adapter.onkyo.0','lc':1435246523}
                ! onkyo-0 2015-06-25 21:35:23 info stateChange onkyo.0.volume {'val':10,'ack':true,'ts':1435246523,'from':'system.adapter.onkyo.0','lc':1435245983}
                ! onkyo-0 2015-06-25 21:35:23 info stateChange onkyo.0.master-volume {'val':10,'ack':true,'ts':1435246523,'from':'system.adapter.onkyo.0','lc':1435245983}
                ! onkyo-0 2015-06-25 21:35:22 info stateChange onkyo.0.command {'val':'AMT00','ack':true,'ts':1435246523,'from':'system.adapter.onkyo.0','lc':1435246523}
                ! onkyo-0 2015-06-25 21:35:22 info stateChange onkyo.0.mute {'val':false,'ack':true,'ts':1435246523,'from':'system.adapter.onkyo.0','lc':1434642794}
                ! onkyo-0 2015-06-25 21:35:22 info Got message: {'command':'audio-muting','argument':'off','iscp_command':'AMT00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:22 info stateChange onkyo.0.command {'val':'PWR01','ack':true,'ts':1435246522,'from':'system.adapter.onkyo.0','lc':1435246522}
                ! onkyo-0 2015-06-25 21:35:22 info stateChange onkyo.0.power {'val':true,'ack':true,'ts':1435246522,'from':'system.adapter.onkyo.0','lc':1435232679}
                ! onkyo-0 2015-06-25 21:35:22 info Got message: {'command':'system-power','argument':'on','iscp_command':'PWR01','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:21 info stateChange onkyo.0.command {'val':'SLI23','ack':true,'ts':1435246522,'from':'system.adapter.onkyo.0','lc':1435246522}
                ! onkyo-0 2015-06-25 21:35:21 info stateChange onkyo.0.input {'val':['cd','tv','cd'],'ack':true,'ts':1435246522,'from':'system.adapter.onkyo.0','lc':1435151166}
                ! onkyo-0 2015-06-25 21:35:21 info Got message: {'command':'input-selector','argument':['cd','tv','cd'],'iscp_command':'SLI23','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:16 info stateChange onkyo.0.command {'val':'NSTS–','ack':true,'ts':1435246516,'from':'system.adapter.onkyo.0','lc':1435246516}
                ! onkyo-0 2015-06-25 21:35:16 info Create new object: onkyo.0.net-usb-play-status, role = media
                ! onkyo-0 2015-06-25 21:35:16 info Got message: {'command':'net-usb-play-status','iscp_command':'NSTS--','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:15 info stateChange onkyo.0.command {'val':'NTR----/----','ack':true,'ts':1435246516,'from':'system.adapter.onkyo.0','lc':1435246516}
                ! onkyo-0 2015-06-25 21:35:15 info Create new object: onkyo.0.net-usb-track-info, role = media
                ! onkyo-0 2015-06-25 21:35:15 info Got message: {'command':'net-usb-track-info','iscp_command':'NTR----/----','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:15 info stateChange onkyo.0.command {'val':'NTM--:--/--:--','ack':true,'ts':1435246515,'from':'system.adapter.onkyo.0','lc':1435246515}
                ! onkyo-0 2015-06-25 21:35:15 info Create new object: onkyo.0.net-usb-time-info, role = media
                ! onkyo-0 2015-06-25 21:35:15 info Got message: {'command':'net-usb-time-info','iscp_command':'NTM--:--/--:--','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:04 info stateChange onkyo.0.command {'val':'PRS03','ack':true,'ts':1435246505,'from':'system.adapter.onkyo.0','lc':1435246505}
                ! onkyo-0 2015-06-25 21:35:04 info Create new object: onkyo.0.preset, role = media
                ! onkyo-0 2015-06-25 21:35:04 info Got message: {'command':'preset','iscp_command':'PRS03','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:03 info stateChange onkyo.0.music-optimizer {'val':false,'ack':true,'ts':1435246504,'from':'system.adapter.onkyo.0','lc':1435246504}
                ! onkyo-0 2015-06-25 21:35:03 info stateChange onkyo.0.command {'val':'MOT00','ack':true,'ts':1435246504,'from':'system.adapter.onkyo.0','lc':1435246504}
                ! onkyo-0 2015-06-25 21:35:03 info Create new object: onkyo.0.music-optimizer, role = media
                ! onkyo-0 2015-06-25 21:35:03 info Got message: {'command':'music-optimizer','argument':'off','iscp_command':'MOT00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:03 info stateChange onkyo.0.dolby-volume {'val':false,'ack':true,'ts':1435246503,'from':'system.adapter.onkyo.0','lc':1435246503}
                ! onkyo-0 2015-06-25 21:35:03 info stateChange onkyo.0.command {'val':'DVL00','ack':true,'ts':1435246503,'from':'system.adapter.onkyo.0','lc':1435246503}
                ! onkyo-0 2015-06-25 21:35:03 info Create new object: onkyo.0.dolby-volume, role = media.volume
                ! onkyo-0 2015-06-25 21:35:03 info Got message: {'command':'dolby-volume','argument':'off','iscp_command':'DVL00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:02 info stateChange onkyo.0.audyssey-dynamic-volume {'val':false,'ack':true,'ts':1435246503,'from':'system.adapter.onkyo.0','lc':1435246503}
                ! onkyo-0 2015-06-25 21:35:02 info stateChange onkyo.0.command {'val':'ADV00','ack':true,'ts':1435246503,'from':'system.adapter.onkyo.0','lc':1435246503}
                ! onkyo-0 2015-06-25 21:35:02 info Create new object: onkyo.0.audyssey-dynamic-volume, role = media.volume
                ! onkyo-0 2015-06-25 21:35:02 info Got message: {'command':'audyssey-dynamic-volume','argument':'off','iscp_command':'ADV00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:02 info stateChange onkyo.0.audyssey-dynamic-eq {'val':true,'ack':true,'ts':1435246502,'from':'system.adapter.onkyo.0','lc':1435246502}
                ! onkyo-0 2015-06-25 21:35:02 info stateChange onkyo.0.command {'val':'ADQ01','ack':true,'ts':1435246502,'from':'system.adapter.onkyo.0','lc':1435246502}
                ! onkyo-0 2015-06-25 21:35:02 info Create new object: onkyo.0.audyssey-dynamic-eq, role = media
                ! onkyo-0 2015-06-25 21:35:02 info Got message: {'command':'audyssey-dynamic-eq','argument':'on','iscp_command':'ADQ01','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:01 info stateChange onkyo.0.command {'val':'ADY00','ack':true,'ts':1435246502,'from':'system.adapter.onkyo.0','lc':1435246502}
                ! onkyo-0 2015-06-25 21:35:01 info stateChange onkyo.0.audyssey-2eq-multeq-multeq-xt {'val':false,'ack':true,'ts':1435246502,'from':'system.adapter.onkyo.0','lc':1435166894}
                ! onkyo-0 2015-06-25 21:35:01 info Got message: {'command':'audyssey-2eq-multeq-multeq-xt','argument':['off'],'iscp_command':'ADY00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:01 info stateChange onkyo.0.cinema-filter {'val':false,'ack':true,'ts':1435246501,'from':'system.adapter.onkyo.0','lc':1435246501}
                ! onkyo-0 2015-06-25 21:35:01 info stateChange onkyo.0.command {'val':'RAS00','ack':true,'ts':1435246501,'from':'system.adapter.onkyo.0','lc':1435246501}
                ! onkyo-0 2015-06-25 21:35:01 info Create new object: onkyo.0.cinema-filter, role = media
                ! onkyo-0 2015-06-25 21:35:01 info Got message: {'command':'cinema-filter','argument':'off','iscp_command':'RAS00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:00 info stateChange onkyo.0.late-night {'val':false,'ack':true,'ts':1435246501,'from':'system.adapter.onkyo.0','lc':1435246501}
                ! onkyo-0 2015-06-25 21:35:00 info stateChange onkyo.0.command {'val':'LTN00','ack':true,'ts':1435246501,'from':'system.adapter.onkyo.0','lc':1435246501}
                ! onkyo-0 2015-06-25 21:35:00 info Create new object: onkyo.0.late-night, role = media
                ! onkyo-0 2015-06-25 21:35:00 info Got message: {'command':'late-night','argument':'off','iscp_command':'LTN00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:35:00 info stateChange onkyo.0.command {'val':'LMD80','ack':true,'ts':1435246500,'from':'system.adapter.onkyo.0','lc':1435246500}
                ! onkyo-0 2015-06-25 21:35:00 info stateChange onkyo.0.listening-mode {'val':['plii','pliix-movie'],'ack':true,'ts':1435246500,'from':'system.adapter.onkyo.0','lc':1435246500}
                ! onkyo-0 2015-06-25 21:35:00 info Got message: {'command':'listening-mode','argument':['plii','pliix-movie'],'iscp_command':'LMD80','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:59 info stateChange onkyo.0.video-picture-mode {'val':'custom','ack':true,'ts':1435246500,'from':'system.adapter.onkyo.0','lc':1435246500}
                ! onkyo-0 2015-06-25 21:34:59 info stateChange onkyo.0.command {'val':'VPM01','ack':true,'ts':1435246500,'from':'system.adapter.onkyo.0','lc':1435246500}
                ! onkyo-0 2015-06-25 21:34:59 info Create new object: onkyo.0.video-picture-mode, role = media
                ! onkyo-0 2015-06-25 21:34:59 info Got message: {'command':'video-picture-mode','argument':'custom','iscp_command':'VPM01','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:59 info stateChange onkyo.0.video-wide-mode {'val':'auto','ack':true,'ts':1435246499,'from':'system.adapter.onkyo.0','lc':1435246499}
                ! onkyo-0 2015-06-25 21:34:59 info stateChange onkyo.0.command {'val':'VWM00','ack':true,'ts':1435246499,'from':'system.adapter.onkyo.0','lc':1435246499}
                ! onkyo-0 2015-06-25 21:34:59 info Create new object: onkyo.0.video-wide-mode, role = media
                ! onkyo-0 2015-06-25 21:34:59 info Got message: {'command':'video-wide-mode','argument':'auto','iscp_command':'VWM00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:58 info stateChange onkyo.0.monitor-out-resolution {'val':'auto','ack':true,'ts':1435246498,'from':'system.adapter.onkyo.0','lc':1435246498}
                ! onkyo-0 2015-06-25 21:34:58 info stateChange onkyo.0.command {'val':'RES01','ack':true,'ts':1435246498,'from':'system.adapter.onkyo.0','lc':1435246498}
                ! onkyo-0 2015-06-25 21:34:58 info Create new object: onkyo.0.monitor-out-resolution, role = media
                ! onkyo-0 2015-06-25 21:34:58 info Got message: {'command':'monitor-out-resolution','argument':'auto','iscp_command':'RES01','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:57 info stateChange onkyo.0.hdmi-audio-out {'val':false,'ack':true,'ts':1435246498,'from':'system.adapter.onkyo.0','lc':1435246498}
                ! onkyo-0 2015-06-25 21:34:57 info stateChange onkyo.0.command {'val':'HAO00','ack':true,'ts':1435246498,'from':'system.adapter.onkyo.0','lc':1435246498}
                ! onkyo-0 2015-06-25 21:34:57 info Create new object: onkyo.0.hdmi-audio-out, role = media
                ! onkyo-0 2015-06-25 21:34:57 info Got message: {'command':'hdmi-audio-out','argument':'off','iscp_command':'HAO00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:57 info stateChange onkyo.0.command {'val':'HDO03','ack':true,'ts':1435246497,'from':'system.adapter.onkyo.0','lc':1435246497}
                ! onkyo-0 2015-06-25 21:34:57 info stateChange onkyo.0.hdmi-output-selector {'val':['both'],'ack':true,'ts':1435246497,'from':'system.adapter.onkyo.0','lc':1435163938}
                ! onkyo-0 2015-06-25 21:34:57 info Got message: {'command':'hdmi-output-selector','argument':['both'],'iscp_command':'HDO03','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:56 info stateChange onkyo.0.command {'val':'SLA05','ack':true,'ts':1435246496,'from':'system.adapter.onkyo.0','lc':1435246496}
                ! onkyo-0 2015-06-25 21:34:56 info stateChange onkyo.0.audio-selector {'val':['coax','opt'],'ack':true,'ts':1435246496,'from':'system.adapter.onkyo.0','lc':1435163726}
                ! onkyo-0 2015-06-25 21:34:56 info Got message: {'command':'audio-selector','argument':['coax','opt'],'iscp_command':'SLA05','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:55 info stateChange onkyo.0.command {'val':'SLI23','ack':true,'ts':1435246495,'from':'system.adapter.onkyo.0','lc':1435246495}
                ! onkyo-0 2015-06-25 21:34:55 info stateChange onkyo.0.input {'val':['cd','tv','cd'],'ack':true,'ts':1435246495,'from':'system.adapter.onkyo.0','lc':1435151166}
                ! onkyo-0 2015-06-25 21:34:55 info Got message: {'command':'input-selector','argument':['cd','tv','cd'],'iscp_command':'SLI23','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:54 info stateChange onkyo.0.command {'val':'IFVHDMI 6,UNKNOWN,,24 bit,HDMI Sub,720 x 480p 60 Hz,RGB,24 bit,Custom,','ack':true,'ts':1435246495,'from':'system.adapter.onkyo.0','lc':1435246495}
                ! onkyo-0 2015-06-25 21:34:54 info Create new object: onkyo.0.video-infomation, role = media
                ! onkyo-0 2015-06-25 21:34:54 info Got message: {'command':'video-infomation','iscp_command':'IFVHDMI 6,UNKNOWN,,24 bit,HDMI Sub,720 x 480p 60 Hz,RGB,24 bit,Custom,','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:54 info stateChange onkyo.0.command {'val':'IFAOPTICAL 1,PCM,48 kHz,2.0 ch,Dolby PLII Movie,5.0 ch,','ack':true,'ts':1435246494,'from':'system.adapter.onkyo.0','lc':1435246494}
                ! onkyo-0 2015-06-25 21:34:54 info Create new object: onkyo.0.audio-infomation, role = media
                ! onkyo-0 2015-06-25 21:34:54 info Got message: {'command':'audio-infomation','iscp_command':'IFAOPTICAL 1,PCM,48 kHz,2.0 ch,Dolby PLII Movie,5.0 ch,','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:53 info stateChange onkyo.0.dimmer-level {'val':'bright','ack':true,'ts':1435246494,'from':'system.adapter.onkyo.0','lc':1435246494}
                ! onkyo-0 2015-06-25 21:34:53 info stateChange onkyo.0.command {'val':'DIM00','ack':true,'ts':1435246494,'from':'system.adapter.onkyo.0','lc':1435246494}
                ! onkyo-0 2015-06-25 21:34:53 info Create new object: onkyo.0.dimmer-level, role = media
                ! onkyo-0 2015-06-25 21:34:53 info Got message: {'command':'dimmer-level','argument':'bright','iscp_command':'DIM00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:53 info stateChange onkyo.0.display-mode {'val':'selector-volume','ack':true,'ts':1435246493,'from':'system.adapter.onkyo.0','lc':1435246493}
                ! onkyo-0 2015-06-25 21:34:53 info stateChange onkyo.0.command {'val':'DIF00','ack':true,'ts':1435246493,'from':'system.adapter.onkyo.0','lc':1435246493}
                ! onkyo-0 2015-06-25 21:34:53 info Create new object: onkyo.0.display-mode, role = media
                ! onkyo-0 2015-06-25 21:34:53 info Got message: {'command':'display-mode','argument':'selector-volume','iscp_command':'DIF00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:52 info stateChange onkyo.0.command {'val':'CTL-6','ack':true,'ts':1435246493,'from':'system.adapter.onkyo.0','lc':1435246493}
                ! onkyo-0 2015-06-25 21:34:52 info Got message: {'command':'center-temporary-level','iscp_command':'CTL-6','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:52 info stateChange onkyo.0.command {'val':'SWL-F','ack':true,'ts':1435246492,'from':'system.adapter.onkyo.0','lc':1435246492}
                ! onkyo-0 2015-06-25 21:34:52 info Create new object: onkyo.0.subwoofer-temporary-level, role = media
                ! onkyo-0 2015-06-25 21:34:52 info Got message: {'command':'subwoofer-temporary-level','iscp_command':'SWL-F','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:51 info stateChange onkyo.0.command {'val':'SLP00','ack':true,'ts':1435246492,'from':'system.adapter.onkyo.0','lc':1435246492}
                ! onkyo-0 2015-06-25 21:34:51 info Got message: {'command':'sleep-set','iscp_command':'SLP00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:49 info Initial query: master-volume
                ! onkyo-0 2015-06-25 21:34:49 info Initial query: volume
                ! onkyo-0 2015-06-25 21:34:49 info Initial query: audio-muting
                ! onkyo-0 2015-06-25 21:34:49 info Initial query: system-power
                ! onkyo-0 2015-06-25 21:34:49 info Initial query: input-selector
                ! onkyo-0 2015-06-25 21:34:47 info stateChange onkyo.0.command {'val':'TFRB-2T00','ack':true,'ts':1435246488,'from':'system.adapter.onkyo.0','lc':1435246488}
                ! onkyo-0 2015-06-25 21:34:47 info Got message: {'command':'tone-front','iscp_command':'TFRB-2T00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:47 info stateChange onkyo.0.command {'val':'MVL0A','ack':true,'ts':1435246487,'from':'system.adapter.onkyo.0','lc':1435246487}
                ! onkyo-0 2015-06-25 21:34:47 info stateChange onkyo.0.volume {'val':10,'ack':true,'ts':1435246487,'from':'system.adapter.onkyo.0','lc':1435245983}
                ! onkyo-0 2015-06-25 21:34:47 info stateChange onkyo.0.master-volume {'val':10,'ack':true,'ts':1435246487,'from':'system.adapter.onkyo.0','lc':1435245983}
                ! onkyo-0 2015-06-25 21:34:47 info Got message: {'command':['master-volume','volume'],'argument':10,'iscp_command':'MVL0A','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:46 info stateChange onkyo.0.command {'val':'MVL0A','ack':true,'ts':1435246487,'from':'system.adapter.onkyo.0','lc':1435246487}
                ! onkyo-0 2015-06-25 21:34:46 info stateChange onkyo.0.volume {'val':10,'ack':true,'ts':1435246487,'from':'system.adapter.onkyo.0','lc':1435245983}
                ! onkyo-0 2015-06-25 21:34:46 info stateChange onkyo.0.master-volume {'val':10,'ack':true,'ts':1435246487,'from':'system.adapter.onkyo.0','lc':1435245983}
                ! onkyo-0 2015-06-25 21:34:46 info Got message: {'command':['master-volume','volume'],'argument':10,'iscp_command':'MVL0A','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:46 info stateChange onkyo.0.speaker-layout {'val':['front-wide','surrback-front-wide-speakers'],'ack':true,'ts':1435246486,'from':'system.adapter.onkyo.0','lc':1435246486}
                ! onkyo-0 2015-06-25 21:34:46 info stateChange onkyo.0.command {'val':'SPLFW','ack':true,'ts':1435246486,'from':'system.adapter.onkyo.0','lc':1435246486}
                ! onkyo-0 2015-06-25 21:34:46 info Create new object: onkyo.0.speaker-layout, role = media
                ! onkyo-0 2015-06-25 21:34:46 info Got message: {'command':'speaker-layout','argument':['front-wide','surrback-front-wide-speakers'],'iscp_command':'SPLFW','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:45 info stateChange onkyo.0.command {'val':'SPBN/A','ack':true,'ts':1435246486,'from':'system.adapter.onkyo.0','lc':1435246486}
                ! onkyo-0 2015-06-25 21:34:45 info Create new object: onkyo.0.speaker-b, role = media
                ! onkyo-0 2015-06-25 21:34:45 info Got message: {'command':'speaker-b','iscp_command':'SPBN/A','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:45 info stateChange onkyo.0.command {'val':'SPAN/A','ack':true,'ts':1435246486,'from':'system.adapter.onkyo.0','lc':1435246486}
                ! onkyo-0 2015-06-25 21:34:45 info stateChange onkyo.0.command {'val':'AMT00','ack':true,'ts':1435246486,'from':'system.adapter.onkyo.0','lc':1435246486}
                ! onkyo-0 2015-06-25 21:34:45 info stateChange onkyo.0.mute {'val':false,'ack':true,'ts':1435246486,'from':'system.adapter.onkyo.0','lc':1434642794}
                ! onkyo-0 2015-06-25 21:34:45 info Got message: {'command':'speaker-a','iscp_command':'SPAN/A','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:44 info Got message: {'command':'audio-muting','argument':'off','iscp_command':'AMT00','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:44 info stateChange onkyo.0.command {'val':'PWR01','ack':true,'ts':1435246484,'from':'system.adapter.onkyo.0','lc':1435246484}
                ! onkyo-0 2015-06-25 21:34:44 info stateChange onkyo.0.power {'val':true,'ack':true,'ts':1435246484,'from':'system.adapter.onkyo.0','lc':1435232679}
                ! onkyo-0 2015-06-25 21:34:44 info Got message: {'command':'system-power','argument':'on','iscp_command':'PWR01','host':'192.168.1.210','port':'60128','model':'TX-NR818'}
                ! onkyo-0 2015-06-25 21:34:44 info stateChange onkyo.0.connected {'val':true,'ack':true,'ts':1435246484,'from':'system.adapter.onkyo.0','lc':1434642788}
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command dab-display-info
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command ipod-list-info
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command universal-port
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command cd-r-recorder
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command md-recorder
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command dvd-player
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command dat-recorder
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command graphics-equalizer
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command tape2-b
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command tape1-a
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command cd-player
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command net-popup-message
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command net-keyboard
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command net-service
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command net-usb-jacket-art
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command net-usb-list-info
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command internet-radio-preset
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command network-usb
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command sirius-parental-lock
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command tp-scan
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command pty-scan
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command rds-information
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command preset-memory
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command 12v-trigger-c
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command 12v-trigger-b
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command 12v-trigger-a
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command memory-setup
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command setup
                ! onkyo-0 2015-06-25 21:34:44 error Error: ERROR (arg_not_exist) Argument query does not exist in command speaker-level-calibration
                ! onkyo-0 2015-06-25 21:34:44 info Successfully connected to AVR
                • BluefoxB Offline
                  BluefoxB Offline
                  #68
                  Ну что? мне чекинить это?
                  • I Offline
                    I Offline
                    instalator
                    #69
                    @Bluefox:
                    Ну что? мне чекинить это? `
                    Думаю да
                    • I Offline
                      I Offline
                      instalator
                      #70
                      Перестала работать команда power, работает только system-power. Раньше работало, вроде ничего не делал. В принципе не принципиально, подвязал на другую переменную (Правда пришлось в onkyo.js заменить power на system-power), но сам факт не понятен. Может фильтр по моделям какой сработал из-за добавленных новых переменных. Надо поковырять список команд "высокого уровня".
                      var newVal = state.val;
                                      if (newVal === true || newVal === 'true' || newVal === '1' || newVal === 1) {
                                          newVal = "on";
                                      } else if (newVal === false || newVal === 'false' || newVal === '0' || newVal === 0) {
                                      	if (ids == 'system-power') {
                      				newVal = "standby";
                      			} else {
                      		    	newVal = "off";
                      • I Offline
                        I Offline
                        instalator
                        #71
                        Странно, в списке команд как раз system-power… А как до этого тогда работало непонятно)
                        • BluefoxB Offline
                          BluefoxB Offline
                          #72
                          A ONKYO может проигрывать по http ссылке mp3 файл?
                          • E Offline
                            electric69
                            #73
                            @Bluefox:
                            A ONKYO может проигрывать по http ссылке mp3 файл? `
                            Знаю точно, что может проигрывать по http плейлист в m3u, у меня так онлайн радио-станции воспроизводятся.
                            Сеня попробую mp3-ху ему скормить, но что то мне подсказывает….
                            • I Offline
                              I Offline
                              instalator
                              #74
                              @Bluefox:
                              В винде по пкм можно отправить файл на воспроизведение, по какому протоколу работает не знаю
                              • I Offline
                                I Offline
                                instalator
                                #75
                                @electric69:
                                Сеня попробую mp3-ху ему скормить, но что то мне подсказывает…. `
                                В фаворит добавляешь плейлист?
                                @Bluefox:
                                У рессивера есть dlna и по сети он берет и флак и мр3.
                                А что придумал?
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  #76
                                  @instalator:
                                  @electric69:
                                  @Bluefox:
                                  А что придумал? `
                                  Подумал, что его можно для sayIt использовать. Но для этого он должен по http мочь проигрывать.
                                  • I Offline
                                    I Offline
                                    instalator
                                    #77
                                    Возникла проблемка после обновления. Жму в виз кнопку, она ставит system-power в false, а рессивер тутже в standby и так они борятся без конца т.е. состояние мигает
                                    Хм похоже этот виджет постоянно пытается послать false.
                                    [{"tpl":"tplHqCheckbox","data":{"visibility-cond":"==","visibility-val":1,"oid":"onkyo.0.system-power","checkboxSize":"small","checkboxColor":"orange"},"style":{"left":"45px","top":"600px","width":"","height":""},"widgetSet":"hqWidgets"}]
                                    • I Offline
                                      I Offline
                                      instalator
                                      #78
                                      @Bluefox:
                                      Подумал, что его можно для sayIt использовать. Но для этого он должен по http мочь проигрывать. `
                                      А как ему можно скормить мр3? Я думаю только можно попробовать ему в My Favorit добавть m3u и когда нужно что либо воспроизвести включать NET и выбирать воспроизведение yfituj плейлиста из My Favorit? главное потом вернуть рес в изначальное состояние
                                      261_navigation_raeume_quer.txt
                                      • I Offline
                                        I Offline
                                        instalator
                                        #79
                                        В драйвере вроде ничего не менялось, но что то он последнее время заглючил, регулирую громкость а драйвер не делает запрос текущего значения, появилось на прошлой недели. В других местах не было изменений? которые могли повлиять на работу драйвера?
                                        (Сейчас вообще меняю значение громкости из драйвера он обновляет текущее но подставляет предыдущее значение.)
                                        • I Offline
                                          I Offline
                                          instalator
                                          #80
                                          Переустановил драйвер. system-power не создается почему то. Громкость так же глючит.
                                          Лог в файле
                                          266_new__1.txt
