  2. English
  3. ioBroker general
  4. Can I use RM Mini 3 as IR receiver with broadlink2 adapter?
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
broadlinkbroadlink 2 adapterbroadlink rm 3 minibroadlink2
8 Beiträge 3 Kommentatoren 1.4k Aufrufe 2 Beobachtet
  • Tomasz NowakT Offline
    Tomasz Nowak
    Hi.
    I have Broadlink RM Mini 3 and I'm able to learn IR commands and probably send them from ioBroker using Scenes.
    But what I need is to detect that a specific (learned) IR command has been received by Broadlink, so I could publish a message on MQTT broker with MQTT-client adapter? In short: I need to publish MQTT message if I press a IR remote button. I can't find a way how to configure it.
    Albert KA 1 Antwort Letzte Antwort
    • Tomasz NowakT Tomasz Nowak
      Hi.
      Albert KA Offline
      Albert KA Offline
      Albert K
      @Tomasz-Nowak
      I don't have mini, just a RMPro but that shoudn't matter.
      As soon as you have an IR command learned and saved in the broadlink adapter you can set a trigger in a blockly script to fire when you press that button on the remote. What you want the script to do is then pretty much up to you I guess. Sorry, I don't know anything about MQTT.
      Tomasz NowakT 1 Antwort Letzte Antwort
      • Albert KA Albert K
        @Tomasz-Nowak
        Tomasz Nowak
        @Albert-K I combined that learned object with MQTT-Client, but it doesn't send anything if I issue this IR command from other remote. And that's what I'd like to do. I don't want to send any commands from Broadlink.
          Albert KA Offline
          Albert KA Offline
          Albert K
          schrieb am zuletzt editiert von Albert K
          @Tomasz-Nowak
          That is not going to work as far as I know. The adapter only helps to relay the sending of IR commands, not the receiving of signals.
          The Broadlink only processes incoming IR signal while learning.
          • MathiasJM Offline
            MathiasJM Offline
            MathiasJ
            I use RM Mini and it works fine with the broadlink adapter.
            IObroker auf dem NUC als VM.
            • MathiasJM MathiasJ
              Tomasz Nowak
              @MathiasJ Do you use it to receive IR commands?
              Tomasz NowakT MathiasJM 2 Antworten Letzte Antwort
                Tomasz Nowak
                Never mind, I've managed to solve this with fakeroku adapter :)
                  MathiasJM Offline
                  MathiasJM Offline
                  MathiasJ
                  @Tomasz-Nowak
                  No I send IR commands with it to the TV, HIFI, A/C, 433 MHz Signals to the plugs.....
