  2. English
  3. Visualization
  4. Vis displays deleted objects
Geplant Angeheftet Gesperrt Verschoben Visualization
visown project
6 Beiträge 3 Kommentatoren 877 Aufrufe 2 Beobachtet
  • kadircanaksoyK Offline
    kadircanaksoy
    Hi everyone!
    I'm building a VIS page for an adapter I am developing. However, I've just realized something while binding a widget to an object in the system. I can see some of the objects I've deleted from my database in the selector. Example below:
    Objects in my database, just two modules and nothing else:
    Objects that I can select in Vis, lots of artifacts from a bug I had a while ago!
    Does this mean ioBroker keeps a copy of the objects I delete? If not, how can VIS have access to them?
    Thanks a bunch in advance for the responses!
    W 1 Antwort Letzte Antwort
    • kadircanaksoyK kadircanaksoy
      Hi everyone!
      W Offline
      W Offline
      Wildbill
      @kadircanaksoy
      Just restart the VIS-adapter and it should read newer objects and forget those you have deleted.
      Greetings, Jürgen
      kadircanaksoyK 1 Antwort Letzte Antwort
      • W Wildbill
        @kadircanaksoy
        Greetings, Jürgen
        kadircanaksoy
        @Wildbill Hi Jürgen!
        Thanks for the reply, but unfortunately restarting didn't really help, the objects are still visible
          W Offline
          W Offline
          Wildbill
          @kadircanaksoy
          Sorry, if a restart of VIS-adapter doesn't help, there seems to be a problem within the json-file, i which iobroker stores all the objects. But strange, that you only see them in the VIS-adapter and not in the real objects.
          Reboot of hole iobroker didn't help also? Then, I'm sorry, I have no more idea how I could help you.
          Greetings, Jürgen
          • W Wildbill
            @kadircanaksoy
            Greetings, Jürgen
            kadircanaksoy
            @Wildbill
            Yep, iobroker reboot doesn't do it either :/ Thanks a lot for the effort though!
            Cheers
              @Wildbill
              Cheers
              HomoranH Offline
              HomoranH Offline
              @kadircanaksoy did you try to clear the browser's cache?
              (CTRL-F5)
