  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер Apple HomeKit
    5.9k
5 Beiträge 3 Kommentatoren 1.7k Aufrufe
  • C Offline
    creo
    Не стартует адаптер, перелистал немецкую ветку но побороть ошибку не получилось:
    host-server 2016-08-20 16:38:33.667 error instance system.adapter.homekit.0 terminated with code 0 (OK)
    homekit-0 2016-08-20 16:38:33.658 info terminating
    TypeError: 2016-08-20 16:38:33.653 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:323:16)
    TypeError: 2016-08-20 16:38:33.653 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:247:12)
    TypeError: 2016-08-20 16:38:33.653 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    TypeError: 2016-08-20 16:38:33.653 error at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    TypeError: 2016-08-20 16:38:33.653 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:333:8)
    TypeError: 2016-08-20 16:38:33.653 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
    TypeError: 2016-08-20 16:38:33.653 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    TypeError: 2016-08-20 16:38:33.653 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
    TypeError: 2016-08-20 16:38:33.653 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
    TypeError: 2016-08-20 16:38:33.653 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:184:29)
    TypeError: 2016-08-20 16:38:33.653 error Cannot read property 'native' of undefined
    uncaught 2016-08-20 16:38:33.651 error exception: Cannot read property 'native' of undefined
    • Alex1808A Offline
      Alex1808A Offline
      Alex1808
      а node какая установлена?
      • H Offline
        Haus
        @creo:
        ! host-server 2016-08-20 16:38:33.667 error instance system.adapter.homekit.0 terminated with code 0 (OK) homekit-0 2016-08-20 16:38:33.658 info terminating TypeError: 2016-08-20 16:38:33.653 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:323:16) TypeError: 2016-08-20 16:38:33.653 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:247:12) TypeError: 2016-08-20 16:38:33.653 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) TypeError: 2016-08-20 16:38:33.653 error at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15) TypeError: 2016-08-20 16:38:33.653 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:333:8) TypeError: 2016-08-20 16:38:33.653 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) TypeError: 2016-08-20 16:38:33.653 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15) TypeError: 2016-08-20 16:38:33.653 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12) TypeError: 2016-08-20 16:38:33.653 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9) TypeError: 2016-08-20 16:38:33.653 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:184:29) TypeError: 2016-08-20 16:38:33.653 error Cannot read property 'native' of undefined uncaught 2016-08-20 16:38:33.651 error exception: Cannot read property 'native' of undefined `
        Примечание: на некоторых системах требуется дополнительный пакет sudo apt-get install libavahi-compat-libdnssd-dev
        Здесь смотрел http://forum.iobroker.net/viewtopic.php?f=16&t=3401
        js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
        admin: 3.6.0
        javascript: 4.1.10
        web: 2.4.1 vis: 1.1.10
        cloud: 2.6.2
        Server: DELL FX170 / linux: Debian 9.5 Stretch
        Adapter: MegaD-2561, Mega-ES…
        • C Offline
          creo
          нода 4,5
          libavahi-compat-libdnssd-dev - установлен
          • C Offline
            creo
            Пробовал менять Node, не помогает (
