  2. English
  3. Visualization
  4. Vis does not start (Terminated (NO_ERROR): Without reason)
    3.0k
    3.0k
Geplant Angeheftet Gesperrt Verschoben Visualization
11 Beiträge 3 Kommentatoren 2.0k Aufrufe 3 Beobachtet
    MahMahoritos
    Hello. I am learning the smart home with the zigbee and ioBroker.
    I installed an official docker image, connected the devices, turned on the Telegram bot, wrote some JS scripts, but I can't start vis.
    It just does not start, and the reasons are not specified in the logs. I didn't find any information by searching the forum.
    Logs are listed below, please help, how do I install and run vis?
    What am I doing:
    0) remove vis and all related drivers, remove the web server - so I try to make a "clean" installation
    1. install vis
      1.1) the web server was installed automatically and have status "started"
      1.2) vis did not start
    2. add the license code in vis settings, check was fine
    3. restart iis
      3.1) vis did not start
      That's it, there are no further ideas. Immediately after installation, it was the same, vis never worked on my server
    host.iobroker
    		2022-12-20 22:42:18.437	info	instance system.adapter.vis.0 terminated while should be started once
    vis.0
    	10212	2022-12-20 22:42:17.883	info	Terminated (NO_ERROR): Without reason
    vis.0
    	10212	2022-12-20 22:42:16.937	info	vis license is OK.
    vis.0
    	10212	2022-12-20 22:42:16.338	info	starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.23
    vis.0
    	10212	2022-12-20 22:42:16.279	debug	States connected to redis: 127.0.0.1:9000
    vis.0
    	10212	2022-12-20 22:42:16.264	debug	States create User PubSub Client
    vis.0
    	10212	2022-12-20 22:42:16.263	debug	States create System PubSub Client
    vis.0
    	10212	2022-12-20 22:42:16.255	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    vis.0
    	10212	2022-12-20 22:42:16.235	debug	Objects connected to redis: 127.0.0.1:9001
    vis.0
    	10212	2022-12-20 22:42:16.199	debug	Objects client initialize lua scripts
    vis.0
    	10212	2022-12-20 22:42:16.168	debug	Objects create User PubSub Client
    vis.0
    	10212	2022-12-20 22:42:16.167	debug	Objects create System PubSub Client
    vis.0
    	10212	2022-12-20 22:42:16.154	debug	Objects client ready ... initialize now
    vis.0
    	10212	2022-12-20 22:42:16.079	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    admin.0
    	1929	2022-12-20 22:42:01.591	info	<== Disconnect system.user.admin from ::ffff:192.168.12.2 devices
    • M MahMahoritos
      What am I doing:
      1. install vis
      3. restart iis
      host.iobroker
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      vis.0
      admin.0
      liv-in-skyL Offline
      liv-in-skyL Offline
      @mahmahoritos
      under special circumstances it helps to downgrade to vis version 1.4.0 and restart the server - if it is running after the downgrade make an update to latest version again
      iobroker upgrade iobroker.vis@1.4.0
      by the way - you should also try to install the web socket adapter and in the setting of the web adapter choose the web-socket adapter (ws0) for the connection
      • liv-in-skyL liv-in-sky
        @mahmahoritos
        MahMahoritos
        @liv-in-sky said in Vis does not start (Terminated (NO_ERROR): Without reason):
        iobroker.vis@1.4.0
        Tried this, nothing changed. All settings of adapters are default (exept license of vis.0 and link to ws.0 in web.0)
        I never tried to use iobroker commands in CLI before, only in admin webpage, so I read some docs. During installation of custom version of vis I mention in the logs that vis tried to connect redis, but there is no redis instance in the docker image
        host.iobroker
        		2023-01-11 22:37:02.921	info	instance system.adapter.vis.0 terminated while should be started once
        vis.0
        	1453	2023-01-11 22:37:02.376	info	Terminated (NO_ERROR): Without reason
        vis.0
        	1453	2023-01-11 22:37:01.668	info	vis license is OK.
        vis.0
        	1453	2023-01-11 22:37:01.106	info	starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
        vis.0
        	1453	2023-01-11 22:37:01.016	debug	States connected to redis: 127.0.0.1:9000
        vis.0
        	1453	2023-01-11 22:37:00.968	debug	States create User PubSub Client
        vis.0
        	1453	2023-01-11 22:37:00.967	debug	States create System PubSub Client
        vis.0
        	1453	2023-01-11 22:37:00.960	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        vis.0
        	1453	2023-01-11 22:37:00.942	debug	Objects connected to redis: 127.0.0.1:9001
        vis.0
        	1453	2023-01-11 22:37:00.896	debug	Objects client initialize lua scripts
        vis.0
        	1453	2023-01-11 22:37:00.871	debug	Objects create User PubSub Client
        vis.0
        	1453	2023-01-11 22:37:00.870	debug	Objects create System PubSub Client
        vis.0
        	1453	2023-01-11 22:37:00.868	debug	Objects client ready ... initialize now
        vis.0
        	1453	2023-01-11 22:37:00.830	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        admin.0
        	172	2023-01-11 22:34:44.074	info	<== Disconnect system.user.admin from ::ffff:192.168.12.2 web
        Is redis required for vis? I didn't found this in any tutorial or docs... May be this is the reason that vis does not start?
        • M MahMahoritos
          iobroker.vis@1.4.0
          host.iobroker
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          vis.0
          admin.0
          liv-in-skyL Offline
          liv-in-skyL Offline
          @mahmahoritos
          what is the output of the command:
          iobroker status
          what is happening when you open the vis editor with a browser ?did you try it with the address ?
          http://192.168.178.59:8082/vis/edit.html?project#view
            @mahmahoritos
            iobroker status
            MahMahoritos
            iobroker status
            root@iobroker:/opt/iobroker# iobroker status
            Objects type: jsonl
            States  type: jsonl
            My address is http://127.0.0.1:8082/vis/edit.html (I am not at home now, so I connected via ssh tunnel, ports 8081 and 8082 are forwarded)
            Nothing is happening - there is no connection
            • M MahMahoritos
              iobroker status
              Objects type: jsonl
              States  type: jsonl
              liv-in-skyL Offline
              liv-in-skyL Offline
              @mahmahoritos I'm sorry - maybe docker and the forwarding is making some trouble - we need somebody else to solve this problem - I don't use iobroker like you :-(
              • wendy2702W Online
                wendy2702W Online
                What is the output of
                 iob list instances
                • wendy2702W wendy2702
                   iob list instances
                  MahMahoritos
                  iob list instances
                  root@iobroker:/opt/iobroker# iob list instances
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    system.adapter.devices.0                : devices               : iobroker                                 - disabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                  + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
                  + instance is alive
                  Also tried to connect to vis (8082 port) from home network - result is the same
                  • wendy2702W Online
                    wendy2702W Online
                    @mahmahoritos If you are using a official Docker image, which one?
                    Did you open the Port 8082 to be able to access VIS ?
                    I guess you missed to open the port 8082 at Docker config. Default is only 8081 if I remember correct.
                      MahMahoritos
                      @wendy2702
                      You are absolutely right! I'm noob...
                      services:
                        iobroker:
                          container_name: iobroker
                          image: buanet/iobroker:latest-v7
                          hostname: iobroker
                          restart: always
                          ports:
                            - "8081:8081"
                          volumes:
                            - iobrokerdata:/opt/iobroker
                          environment:
                            - TZ=Asia/Yekaterinburg
                          devices:
                            - "/dev/ttyUSB0:/dev/ttyUSB0"
                      I added "8082:8082" string and after recreating container demo page started!
                      Thank you a lot!
                      • M MahMahoritos
                        @wendy2702
                        services:
                          iobroker:
                            hostname: iobroker
                            restart: always
                            ports:
                              - "8081:8081"
                            volumes:
                            environment:
                            devices:
                        Thank you a lot!
                        wendy2702W Online
                        wendy2702W Online
                        @mahmahoritos You are welcome
