  2. English
  3. Scripting / Logic
  4. JavaScript
  5. time of the last change of a data point.
    2.7k
    2.9k
9 Beiträge 3 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • F Offline
    franzda
    is there a way in javascript (for node-red) to query the time of the last change of a data point.
    The system "knows" this because the time is displayed in the object list.
    paul53P OliverIOO 2 Antworten Letzte Antwort
    • F franzda
      @franzda
      let lc = getState(id).lc;
      // Trigger:
      on(id, function(dp) {
         let lc = dp.state.lc;
      F 2 Antworten Letzte Antwort
        @franzda
        // Trigger:
        franzda
        @paul53 Hi Paul thank you for very quick response. The question ist how can I access to the ts property. I mien ts is the value I am looking for.
        • F franzda
          @franzda sagte: how can I access to the ts property.
          .ts instead of .lc.
          • F franzda
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @franzda
            1. you insert a node "iobroker in"
            2. select your datapoint as topic
            3. select object in payload
            4. then you select a function node with the following code
            msg.payload=msg.payload.lc; //or msg.payload.ts
            return msg;
            5 for testing purpose you can connect the function node with a debug node
            Meine Adapter und Widgets
            Links im Profil
            • OliverIOO OliverIO
              @franzda
              return msg;
              franzda
              @oliverio Hi Oliver Thank you for quick response. it works
              F 1 Antwort Letzte Antwort
              • F franzda
                franzda
                @franzda said in time of the last change of a data point.:
                this is my code thank you for helping: (two different formats for testing)
                  sensor.neulcT = (new Date(msg.payload[i].lc)).toLocaleTimeString();
                  sensor.neulc =  (new Date(msg.payload[i].lc)).toLocaleString();
                  @franzda
                  return msg;
                  franzda
                  @oliverio
                    @franzda
                    // Trigger:
                    franzda
                    @paul53 hi Paul Thank you for quick response. it works
