  3. Cloud Dienste
  4. Cloud-Adapter kann keine Verbindung herstellen
    6.5k
65 Beiträge 6 Kommentatoren 12.0k Aufrufe 3 Beobachtet
  • apollon77A apollon77
    @hardl sagte in Cloud-Adapter kann keine Verbindung herstellen:
    Scheduled restart.
    Kann es sein das du einen Restart Schedule eingestellt hat der "falsch" ist und dir so den Adapter selbst immer wiede rneu startest?
    hardl
    schrieb am zuletzt editiert von hardl
    @apollon77 Hier nochmal ein Log "Alle", vielleicht kann man hier was erkennen.
    cloud.0
    4593	2021-09-12 11:04:07.208	info	Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
    cloud.0
    4593	2021-09-12 11:04:07.179	debug	Connected. Check api key...
    cloud.0
    4593	2021-09-12 11:04:07.108	info	Trying to connect as system.user.admin
    cloud.0
    4593	2021-09-12 11:04:06.763	debug	Connection attempt to https://iobroker.net:10555 ...
    admin.0
    189	2021-09-12 11:04:07.232	info	Repository received successfully.
    cloud.0
    4593	2021-09-12 11:04:06.356	info	Connecting with https://iobroker.net:10555 with "XXXXX_797df010-0e4d-11ec-86fd-ed32e7cb0649"
    cloud.0
    4593	2021-09-12 11:04:05.853	debug	Schedule restart: * * * * *
    cloud.0
    4593	2021-09-12 11:04:05.696	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.2, js-controller: 3.3.17
    cloud.0
    4593	2021-09-12 11:04:05.386	debug	Plugin sentry Initialize Plugin (enabled=true)
    host.bff17bd4a275
    2021-09-12 11:04:05.054	info	Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
    admin.0
    189	2021-09-12 11:04:04.424	info	Request actual repository...
    host.bff17bd4a275
    2021-09-12 11:04:01.752	info	instance system.adapter.cloud.0 started with pid 4593
    host.bff17bd4a275
    2021-09-12 11:04:00.667	info	Restart adapter system.adapter.cloud.0 because enabled
    host.bff17bd4a275
    2021-09-12 11:04:00.662	info	instance system.adapter.cloud.0 scheduled normal terminated and will be restarted on schedule.
    cloud.0
    4508	2021-09-12 11:04:00.072	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    cloud.0
    4508	2021-09-12 11:04:00.070	debug	Plugin sentry destroyed
    cloud.0
    4508	2021-09-12 11:04:00.069	info	terminating
    cloud.0
    4508	2021-09-12 11:04:00.023	info	Scheduled restart.
    • H hardl
      @apollon77 Ich habe "Neustart bei Verbindungsabbruch" im Cloud-Adapter eingestellt, wie oben beschrieben. Aber auch wenn ich das rausnehme startet es immer wieder neu.
      so wieich drinrn Screenshot entziffere hast du einen minütlichen Neustart eingestellt
      H 1 Antwort Letzte Antwort
        hardl
        @homoran So hätte ich das auch gelesen, aber ich wüsste nicht wo.
        HomoranH apollon77A 2 Antworten Letzte Antwort
        • H hardl
          Expertenmodus -> Neustart (o.ä.)
          daneben ist doch ein Bleistift!
          • H hardl
            @hardl "* * * * *" ... ...
              hardl
              @apollon77 Das habe ich jetzt gefunden, stand aber scheinbar schon in der Vorgabe auf 1 Minute. Was sollte man da einstellen?
              Aber mit meinem Verbindungsproblem dürfte das ohnehin nichts zu tun haben.
              apollon77A HomoranH 2 Antworten Letzte Antwort
              • H hardl
                @hardl das ist im Default in jedem Fall leer. Einfach alles löschen
                • H hardl
                  aber sicher doch!
                  in der Zeit, die die Instanz zum runter- und wieder hochfahren benötigt ist keine Verbindung da.
                  und kurz bevor sie hergestellt wird, startet die Instanz wieder neu......
                    aber sicher doch!
                    hardl
                    @homoran Das habe ich gerade auch festgestellt.
                    Allerdings kann ich in der oberen Zeile weder löschen, noch eingeben und unten geht auch nicht "0".
                    Bei 120 Minuten in der Einstellung war aber dann der cloud-Adapter grün, hurra...
                    Im ioBroker.net kommen jetzt 3 Anwendungen, allerdings nicht die Jarvis.
                    Dann habe ich auf ioBroker.pro umgestellt und den Pro-Key im cloud-Adapter, aber der stoppt immer wieder.
                    • H hardl
                      @hardl naja du solltest die Frage die jetzt kommt von oben kennen … … … was steht im
                      Log?
                      Und, du hast auch bei pro die fernzugriffslizenz?
                        Log?
                        hardl
                        @apollon77 sorry,
                        cloud.0
                        12497	2021-09-12 20:46:10.267	info	received all objects
                        cloud.0
                        12497	2021-09-12 20:46:05.882	info	User accessed from cloud: 1hn4_CCPWHxumtBMBugO
                        cloud.0
                        12497	2021-09-12 20:38:16.126	info	User disconnected from cloud: j3Ls1QRsXG1ZBJ9QBuca
                        jarvis.0
                        420	2021-09-12 20:37:28.538	info	Client with IP ::ffff:192.168.178.21 connected
                        cloud.0
                        12497	2021-09-12 20:32:37.920	info	received all objects
                        cloud.0
                        12497	2021-09-12 20:32:33.991	info	User accessed from cloud: j3Ls1QRsXG1ZBJ9QBuca
                        cloud.0
                        12497	2021-09-12 20:00:37.732	debug	Connection not changed: was connected
                        cloud.0
                        12497	2021-09-12 20:00:37.731	debug	API KEY OK
                        cloud.0
                        12497	2021-09-12 20:00:37.706	info	Connection changed: connect
                        cloud.0
                        12497	2021-09-12 20:00:37.706	debug	Connected. Check api key...
                        cloud.0
                        12497	2021-09-12 20:00:37.578	info	Trying to connect as system.user.admin
                        cloud.0
                        12497	2021-09-12 20:00:37.549	debug	Connection attempt to https://iobroker.pro:10556 ...
                        cloud.0
                        12497	2021-09-12 20:00:07.543	info	Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
                        cloud.0
                        12497	2021-09-12 20:00:07.511	info	Connection changed: connect
                        cloud.0
                        12497	2021-09-12 20:00:07.510	debug	Connected. Check api key...
                        cloud.0
                        12497	2021-09-12 20:00:07.382	info	Trying to connect as system.user.admin
                        cloud.0
                        12497	2021-09-12 20:00:07.102	debug	Connection attempt to https://iobroker.pro:10555 ...
                        cloud.0
                        12497	2021-09-12 20:00:07.054	info	Connecting with https://iobroker.pro:10555 with "@pro_XXX_06d4e070-13dc-11ec-8ec2-0700019a6126"
                        cloud.0
                        12497	2021-09-12 20:00:06.921	debug	Schedule restart: */120 * * * *
                        cloud.0
                        12497	2021-09-12 20:00:06.792	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.2, js-controller: 3.3.17
                        cloud.0
                        12497	2021-09-12 20:00:06.399	debug	Plugin sentry Initialize Plugin (enabled=true)
                        cloud.0
                        12497	2021-09-12 20:00:06.034	debug	statesDB connected
                        cloud.0
                        12497	2021-09-12 20:00:06.033	debug	States connected to redis: 127.0.0.1:9000
                        cloud.0
                        12497	2021-09-12 20:00:05.977	debug	States create User PubSub Client
                        cloud.0
                        12497	2021-09-12 20:00:05.969	debug	States create System PubSub Client
                        cloud.0
                        12497	2021-09-12 20:00:05.948	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                        cloud.0
                        12497	2021-09-12 20:00:05.945	debug	objectDB connected
                        cloud.0
                        12497	2021-09-12 20:00:05.924	debug	Objects connected to redis: 127.0.0.1:9001
                        cloud.0
                        12497	2021-09-12 20:00:05.896	debug	Objects client initialize lua scripts
                        cloud.0
                        12497	2021-09-12 20:00:05.892	debug	Objects create User PubSub Client
                        cloud.0
                        12497	2021-09-12 20:00:05.885	debug	Objects create System PubSub Client
                        cloud.0
                        12497	2021-09-12 20:00:05.883	debug	Objects client ready ... initialize now
                        cloud.0
                        12497	2021-09-12 20:00:05.827	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                        host.bff17bd4a275
                        2021-09-12 20:00:01.827	info	instance system.adapter.cloud.0 started with pid 12497
                        host.bff17bd4a275
                        2021-09-12 20:00:00.739	info	Restart adapter system.adapter.cloud.0 because enabled
                        host.bff17bd4a275
                        2021-09-12 20:00:00.734	info	instance system.adapter.cloud.0 scheduled normal terminated and will be restarted on schedule.
                        cloud.0
                        8627	2021-09-12 20:00:00.068	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        cloud.0
                        8627	2021-09-12 20:00:00.065	debug	Plugin sentry destroyed
                        cloud.0
                        8627	2021-09-12 20:00:00.064	info	terminating
                        cloud.0
                        8627	2021-09-12 20:00:00.050	info	Restart adapter by disconnect
                        cloud.0
                        8627	2021-09-12 20:00:00.049	info	Connection lost
                        cloud.0
                        8627	2021-09-12 20:00:00.049	info	Connection changed: io client disconnect
                        cloud.0
                        8627	2021-09-12 20:00:00.044	info	Scheduled restart.
                        und die Lizenz mit Fernzugriff habe ich abonniert.
                          Log?
                          hardl
                          @apollon77 Danke zunächst.
                          Ich muss morgen erst mal nachsehen, ob der Fernzugriff auf Jarvis überhaupt möglich ist, da es mit Vis funktioniert.
                          • H hardl
                            aber den Button "löschen" kannst du anklicken?
                            • H hardl
                              @apollon77 sorry,
                              cloud.0
                              cloud.0
                              cloud.0
                              jarvis.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              host.bff17bd4a275
                              host.bff17bd4a275
                              host.bff17bd4a275
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              cloud.0
                              @hardl also ich sehe da das er startet. Letzter log Eintrag sagt nur das ein User via Cloud verbunden war und dann disconnected. Hat
                              • H hardl
                                @hardl ich wüsste nicht warum jarvis nicht gehen sollte.
                                  hardl
                                  @homoran Den Löschen-Button kann ich anklicken und hatte das auch probiert, aber leider nicht lange genug gewartet.
                                  Jetzt weiß ich, daß ich einfach zu ungeduldig war. Danke.
                                    hardl
                                    @apollon77
                                    1. Wenn ich ioBroker.pro -> Anwendungen -> Vis Editor oder Vis Runtime klicke, klappt das. Auch im Protokoll:
                                    cloud.0
                                    2068	2021-09-13 12:08:13.069	info	received all objects
                                    cloud.0
                                    2068	2021-09-13 12:08:09.586	info	User accessed from cloud: wikkmYGGQzlKAcMiB1QK
                                    cloud.0
                                    2068	2021-09-13 12:08:01.786	info	User disconnected from cloud: NerHVZjeRqMY3mp4B1P_
                                    cloud.0
                                    2068	2021-09-13 12:07:34.406	info	User accessed from cloud: NerHVZjeRqMY3mp4B1P_
                                    cloud.0
                                    2068	2021-09-13 12:06:57.365	info	User disconnected from cloud: hJ5AQNhup_x4c9F7B1Pw
                                    cloud.0
                                    2068	2021-09-13 12:06:51.964	debug	Subscribes: *, vis.0.control.instance, vis.0.control.data, vis.0.control.command
                                    cloud.0
                                    2068	2021-09-13 12:06:51.668	debug	Subscribes: *
                                    cloud.0
                                    2068	2021-09-13 12:06:51.615	debug	2021-09-13T10:06:51.615Z Request authenticate [system.user.admin]
                                    cloud.0
                                    2068	2021-09-13 12:06:51.500	info	User accessed from cloud: hJ5AQNhup_x4c9F7B1Pw
                                    1. Wenn ich Minuvis aufrufe kann ich den Editor laden, das entsprechende config-file laden, aber bei "Preview in new tab" hängt es:
                                    Im Protokoll erscheint nur der Aufruf.
                                    1. Jarvis erscheint nicht unter Anwendungen, wenn ich dann über Admin gehe, kommt auch Jarvis, aber beim Aufruf kommt nur eine leere Seite mit laufendem Balken und dann "Connection delayed".
                                      Im Protokoll allerdings auch nichts.
                                      hardl
                                      @apollon77 Noch als Ergänzung:
                                      Beim Weg über Admin->Instanzen->Jarvis-> Adapter Website öffnen kommt:Bildschirmfoto 2021-09-13 um 12.24.10.png
                                      und im Protokoll:
                                      cloud.0
                                      2068	2021-09-13 12:20:52.259	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                      cloud.0
                                      2068	2021-09-13 12:20:52.128	debug	Subscribes: system.adapter.*, system.host.*, *.info.connection
                                      cloud.0
                                      2068	2021-09-13 12:20:52.123	debug	Subscribes: system.adapter.*, system.host.*
                                      cloud.0
                                      2068	2021-09-13 12:20:52.116	debug	Subscribes: system.adapter.*
                                      cloud.0
                                      2068	2021-09-13 12:20:20.393	info	received all objects
                                      cloud.0
                                      2068	2021-09-13 12:20:16.963	info	User accessed from cloud: swV8mUXz31vc8oMeB1Vj
                                      • apollon77A Offline
                                        Ok, dann liegt es wohl eher daran das die Adapter etwas tun was der pro Server nicht erwartet oder kann.
                                        Da sollten am besten die Adapter ENtwickler ggf mit Bluefox schauen. Also am besten issues dort bei den Adaptern anlegen das der Adapter über .pro nicht aufgerufen werden aknn. Dann können die schauen was ist und ggf spezifische Tickets im cloud Adapter Repo öffnen.
                                          hardl
                                          @apollon77 Ich habe gerade mit Zefau kommuniziert:
                                          Jarvis funktioniert nicht mit der ioBroker Cloud. Nur lokal oder VPN.
                                          Es wird scheinbar an einem eigenen Fernzugriff gearbeitet.
                                          Da hätte ich mir viele Stunden sparen können....
