  2. English
  3. ioBroker general
  4. Configuring IOBROKER for the first time problem
    2.4k
    2.7k
    1.5k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
port 8081admin port 8081
13 Beiträge 2 Kommentatoren 3.1k Aufrufe 1 Beobachtet
  • kristfrizhK Offline
    kristfrizhK Offline
    kristfrizh
    schrieb am zuletzt editiert von kristfrizh
    Hello
    I'm very new with this application.
    I have a problem with my installation. I cannot enter the admin page with mine port 8081.
    i follow this intruction for the installation :
    installation pages
    I have configure the port in my VM for port 8081.
    I use linux debian buster with VM.
    I have been searching the answer from here.
    • iobroker troubleshooting
    • iobroker community (off course with google translate)
    I have also tried this code.
    sudo node node_modules/iobroker.js-controller/controller.js --logs
    and the outputs are always (even i changes the port from 9000 and 9001 to others) :
    2021-06-07 12:22:38.027  - info: host.try1 iobroker.js-controller version 3.2.16 js-controller starting
    2021-06-07 12:22:38.031  - info: host.try1 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-06-07 12:22:38.032  - info: host.try1 hostname: try1, node: v12.22.1
    2021-06-07 12:22:38.032  - info: host.try1 ip addresses: 10.184.0.2 fe80::4001:aff:feb8:2
    2021-06-07 12:22:38.145  - info: host.try1-Server  Error inMem-objects listening on port 8011: Error: listen EADDRINUSE: address already in use 127.0.0.1:8011
    ^[[A^[[B2021-06-07 12:23:08.065  - error: host.try1 No connection to databases possible, restart
    2021-06-07 12:23:08.068  - info: host.try1 iobroker _restart
    2021-06-07 12:23:08.273  - info: host.try1 iobroker Starting node restart.js
    anyone can help me please?
    am i do something wrong?
    thank you very much for your kindness
    regards
    • kristfrizhK kristfrizh
      Hello
      installation pages
      regards
      @kristfrizh sagte in Configuring IOBROKER for the first time problem:
      sorry to hear that!
      I'm not familiar with VM and especially containers.
      But I do an iobroker installation on debian in a proxmox VM too.
      I didn`t have to do anything with the ports
      Port 8081 ist the port to reach the admin webUI, port 8082 the port of the webinterface for visualizations
      Port 9000 and 9001 are ports for internal use of databases for objects and states an shouldn't been altered or used for other services.
      the installation procedure is made much easier.
      • install debian
      • configure timezone and language
      • call curl -sLf https://iobroker.net/install.sh | bash -
        • on a brandnew system all necessary packages incl. latest recommended node, will be installed
      • open <IP>:8081
      the troubleshooting page is fairly old and possibly outdated, should/can work.
      What is the output for iobroker list instances
      kristfrizhK 1 Antwort Letzte Antwort
        sorry to hear that!
        • install debian
        • open <IP>:8081
        kristfrizhK Offline
        kristfrizhK Offline
        kristfrizh
        thank you for your reply
        + system.adapter.admin.0                  : admin                 : try1                                     -  enabled, port: 8089, bind: 8081, run as: admin
        + instance is alive
        I have added a new admin in 8089 but still not working
        I have doubt with the version of my dependencies.
        Is it because the NPM, nodejs,node, and js-controller?
        my NPM version is 6.14.13
        nodejs is 12.22.1
        node is 12.22.1
          + instance is alive
          nodejs is 12.22.1
          node is 12.22.1
          I see!
          But you have entered 8081 as IP
          here should be 0.0.0.0 (listen on all interfaces)
          And there is no other instance running at all.
          I guess it would be the easiest way at this stage to delete the VM, and start from anew, as I described in the last post
          node and npm look good.
          BTW - what debian image did you use - on/for what hardware?
          kristfrizhK 2 Antworten Letzte Antwort
            I see!
            kristfrizhK Offline
            kristfrizhK Offline
            kristfrizh
            thank you for the reply again!!
            ok will do that
            I'll inform you after i start a new VM
            my debian is
            debian-10-buster-v20210512
              I see!
              kristfrizhK Offline
              kristfrizhK Offline
              kristfrizh
              should be the port and bind in iobroker list instances be like this?
               system.adapter.admin.0                  : admin                 : try1                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + instance is alive
              i follow some code from the forum to changes the instances
              cd /opt/iobroker
              iobroker set admin.0 --bind 0.0.0.0
              iobroker set admin.0 --port 8081
              thank you
                ok will do that
                my debian is
                my debian is
                for what architecture?
                Beware!
                for 64bit Arch you need AMD64 even if you have an Intel CPU; not x386!
                partly yes!
                Now it's correct for the admin, but there should be at least info and discovery too
                  my debian is
                  Beware!
                  partly yes!
                  kristfrizhK Offline
                  kristfrizhK Offline
                  kristfrizh
                  I'm using this VM for server
                  but it's totally new because every time i tried a new language i create a new one then combine it to fix server i want.
                  I have tried php,nodejs,mqtt,python so far and all works (for learning purposes).
                  I'm not quite know about the AMD64 because there is not option for me to choose the type in google cloud. but here is the overall system i get from the google cloud.
                  Architecture:        x86_64
                  CPU op-mode(s):      32-bit, 64-bit
                  Byte Order:          Little Endian
                  Address sizes:       46 bits physical, 48 bits virtual
                  CPU(s):              2
                  On-line CPU(s) list: 0,1
                  Thread(s) per core:  2
                  Core(s) per socket:  1
                  Socket(s):           1
                  NUMA node(s):        1
                  Vendor ID:           GenuineIntel
                  CPU family:          6
                  Model:               85
                  Model name:          Intel(R) Xeon(R) CPU @ 2.00GHz
                  Stepping:            3
                  CPU MHz:             2000.104
                  BogoMIPS:            4000.20
                  Hypervisor vendor:   KVM
                  Virtualization type: full
                  L1d cache:           32K
                  L1i cache:           32K
                  L2 cache:            1024K
                  L3 cache:            39424K
                  NUMA node0 CPU(s):   0,1
                  I have tried run iobroker (with the instances above) but still the same error said that EADDRINUSE
                  even i changed it back to 9001 and 9000
                  Right now i will try to create a new VM
                  thank you for your hospitality
                  regards
                    there has been reported issues when using XEON!
                    I do not remember fully what kind of issue - sorry!
                    what Address is in Use?
                    in your initial log it was 8011.
                    I do not know what this ist used for.
                    download netinstall from debian:
                    https://cdimage.debian.org/debian-cd/current/amd64/iso-cd/debian-10.9.0-amd64-netinst.iso
                      kristfrizhK Offline
                      kristfrizhK Offline
                      kristfrizh
                      i have tried 8011 and 8000 also tried 9000 and 9001.
                      but still the same problem.
                      wow, i just knew that XEON compatibility issues with iobroker.
                      ok will try to changes the XEON (I still not know how but will figure it out).
                      I'll update my trial with a new CPU asap.
                      thank you very much for the knowledge.
                      regards!
                        regards!
                        please don`t change anything!
                        To find out what is going wrong we need the standard settings.
                        If you start up the next try, please wait until the setup by curl... has finished completely with the line
                        open <IP>:8081 and start configuring
                        (or anything like this ;-) )
                        Afterwards you have to re-login into the console
                          kristfrizhK Offline
                          kristfrizh
                          thank your for your hospitality
                          I have build a new system with I7 and linux ubuntu 18.04.
                          IObroker works wonderfully
                          thank you once again
                          regards
                            regards
                            @kristfrizh Thank you for the update!
                            good to hear it works and good luck and have fun!
                            83.2k
