  3. Entwicklung
  4. [gelöst] wiffi-wz Adapter: Received data from unregistered
    2.0k
wiffi-wz
6 Beiträge 3 Kommentatoren 567 Aufrufe 3 Beobachtet
    baluderbär
    schrieb am zuletzt editiert von baluderbär
    bin heute auf den Adapter wiffi-wz gestoßen. Bisher wurden meine Daten der Weatherstation an die CCU geschickt und dann zu ioBroker übertragen. Mit dem Adapter funktioniert es nun auch, jedoch erhalten ich jede Minute eine Warnung (debug-Auszug):
    wiffi-wz.0	2020-12-20 00:41:36.865	debug	(26910) Received states from Wiffi with ip 192.168.xxx.xx and states were updated successfully!
    wiffi-wz.0	2020-12-20 00:41:36.863	debug	(26910) Creating states for wiffi with ip 192.168.xxx.xx, if necessary.
    wiffi-wz.0	2020-12-20 00:41:36.863	warn	(26910) Received data from unregistered Wiffi with ip 192.168.xxx.xx
    wiffi-wz.0	2020-12-20 00:41:36.862	debug	(26910) Received JSON data from Wiffi. Full message: {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.xxx.xx"},{"n
    wiffi-wz.0	2020-12-20 00:41:28.908	debug	(26910) system.adapter.admin.0: logging true
    wiffi-wz.0	2020-12-20 00:41:14.824	debug	(26910) system.adapter.admin.0: logging false
    wiffi-wz.0	2020-12-20 00:40:36.178	debug	(26910) Received states from Wiffi with ip 192.168.xxx.xx and states were updated successfully!
    wiffi-wz.0	2020-12-20 00:40:36.176	debug	(26910) Creating states for wiffi with ip 192.168.xxx.xx, if necessary.
    wiffi-wz.0	2020-12-20 00:40:36.175	warn	(26910) Received data from unregistered Wiffi with ip 192.168.xxx.xx
    wiffi-wz.0	2020-12-20 00:40:36.175	debug	(26910) Received JSON data from Wiffi. Full message: {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.xxx.xx"},{"
    wiffi-wz.0	2020-12-20 00:39:47.844	debug	(26910) Received states from Wiffi with ip 192.168.xxx.xx and states were updated successfully!
    wiffi-wz.0	2020-12-20 00:39:47.841	debug	(26910) Creating states for wiffi with ip 192.168.xxx.xx, if necessary.
    wiffi-wz.0	2020-12-20 00:39:47.841	warn	(26910) Received data from unregistered Wiffi with ip 192.168.xxx.xx
    wiffi-wz.0	2020-12-20 00:39:47.840	debug	(26910) Received JSON data from Wiffi. Full message: {"modultyp":"weatherman","vars":[{"name":"0","homematic_name":"w_ip","desc":"weatherman_ip","type":"string","unit":"","value":"192.168.xxx.xx"},{"
    wiffi-wz.0	2020-12-20 00:39:40.908	debug	(26910) Create basic states for Wiffi with ip http://192.168.xxx.xx/
    Die empfangenen Daten sehen korrekt aus. Wer weiß wie ich die Warnmeldung weg bekomme bzw. woher die kommen?
    Aktuelle FW am Weatherman:weatherman_156
    wiffi-wz-Adapter: 2.2.0
    Gruß Martin
    ioBroker auf VM Proxmox (Intel NUC-Kit i3-7100U 2.4GHz HD620 NUC7I3BNH)
    G GarganoG 2 Antworten Letzte Antwort
    • B baluderbär
      Gruß Martin
      guergen
      @baluderbär Wie ist denn der wiffi-wz konfiguriert? Beim Weatherman muss man auch etwas einstellen. Zeig mal die Einstellungen, ich habe seit fast 2 Jahren den Weatherman im Broker
      • B baluderbär
        Gruß Martin
        GarganoG Offline
        GarganoG Offline
        Gargano
        @baluderbär In der Instanz unter Wiffi Geräte einen Namen , IP Adresse und Zimmer eintragen
        • G guergen
          baluderbär
          @guergen
          Hier meine Einstellung beim wiffi-wz. Unter "lokale Server-IP" habe ich die IP des ioBroker und den "Port" 8181 eingetragen.
          Unter WIFI-Geräte habe ich die IP des Weatherman eingetragen.
          Und hier noch ein Bild vom Weatherman:
          GarganoG 1 Antwort Letzte Antwort
          • B baluderbär
            @guergen
            GarganoG Offline
            GarganoG Offline
            Gargano
            schrieb am zuletzt editiert von Gargano
            @baluderbär Ich weiß nicht ob der Wiffi Adapzer mit Deiner Einstellung der IP Adresse klarkommt . Ich habe nur die IP eingetragen ohne HTTP://
            also nur 192.168.178.86
            • GarganoG Gargano
              baluderbär
              @Gargano
              Hallo, ich habe mal http:// und den / am Ende gelöscht und nun kommen keine Warnmeldungen mehr. Die Daten kamen zwar vorher schon korrekt, aber wer hat schon gerne Warn- oder Fehlermeldungen im Log 😊
              Vielen Dank
              Gruß Martin
