  3. Entwicklung
  4. Adapter: broadlink2
Adapter: broadlink2
broad2broadlinkrm prorm3 minirm4
1.4k Beiträge 169 Kommentatoren 769.9k Aufrufe 93 Beobachtet
    moj090
    #912
    @frankjoke bei mir klappt bei der neusten Version (GitHub) der Broadlink RM4P nicht mehr. Für mich sieht es so aus als würde er ihn nicht mehr erreichen/finden?
    broadlink2.0	2020-06-28 18:26:05.593	warn	(13014) stateChange error no device found: RM:RM4 { val: true,ack: false,ts: 1593361565587,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1593114356072 }
    broadlink2.0	2020-06-28 18:26:05.592	info	(13014) debug: Change broadlink2.0.RM:RM4._LearnRF to { val: true, ack: false, ts: 1593361565587, q: 0, from: 'system.adapter.admin.0', user: 'system.user.admin', lc: 1593114356072 }
    broadlink2.0	2020-06-28 18:25:10.830	info	(13014) found macs:
    broadlink2.0	2020-06-28 18:25:10.829	info	(13014) broadlink2.0 started and found 0 devices named
    broadlink2.0	2020-06-28 18:25:10.829	info	(13014) Poll every 31 secods.
    broadlink2.0	2020-06-28 18:25:10.828	info	(13014) debug: created State broadlink2.0._SendScene
    broadlink2.0	2020-06-28 18:25:10.821	info	(13014) debug: ChangeState ack:true of _NewDeviceScan = false
    broadlink2.0	2020-06-28 18:25:04.593	info	(13014) discover [ '192.168.0.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:51937
    broadlink2.0	2020-06-28 18:25:04.591	info	(13014) debug: UDP listening on 0.0.0.0:51937
    broadlink2.0	2020-06-28 18:25:04.589	info	(13014) debug: ChangeState ack:true of broadlink2.0._NewDeviceScan = true
    broadlink2.0	2020-06-28 18:25:04.544	info	(13014) debug: created State broadlink2.0._NewDeviceScan
    broadlink2.0	2020-06-28 18:25:04.538	info	(13014) debug: UDP listening on 0.0.0.0:15001
    broadlink2.0	2020-06-28 18:25:04.532	info	(13014) Discover Broadlink devices for 10sec on broadlink2.0
    broadlink2.0	2020-06-28 18:25:04.525	info	(13014) debug: ChangeState ack:false of broadlink2.0.Scenes.Receiver = false
    broadlink2.0	2020-06-28 18:25:04.481	info	(13014) debug: created State broadlink2.0.Scenes.Receiver
    broadlink2.0	2020-06-28 18:25:04.473	info	(13014) debug: ChangeState ack:false of broadlink2.0.Scenes.Fehrnsehen = false
    broadlink2.0	2020-06-28 18:25:04.429	info	(13014) debug: created State broadlink2.0.Scenes.Fehrnsehen
    broadlink2.0	2020-06-28 18:25:04.421	info	(13014) debug: ChangeState ack:false of broadlink2.0.Scenes.Fehrnseher = false
    broadlink2.0	2020-06-28 18:25:04.374	info	(13014) debug: created State broadlink2.0.Scenes.Fehrnseher
    broadlink2.0	2020-06-28 18:25:04.365	info	(13014) debug: ChangeState ack:false of broadlink2.0.Scenes.TV = false
    broadlink2.0	2020-06-28 18:25:04.321	info	(13014) debug: created State broadlink2.0.Scenes.TV
    broadlink2.0	2020-06-28 18:25:04.311	info	(13014) debug: Config IP-Address end to remove: .fritz.box
    broadlink2.0	2020-06-28 18:25:04.311	info	(13014) macObjects: []
    broadlink2.0	2020-06-28 18:25:04.310	info	(13014) interface to be used: { netmaskBits: 24, address: '192.168.0.211/24', addrs: [ 192, 168, 0, 211 ], cidr: '192.168.0.211/24', bcaddr: '192.168.0.255' }:
    broadlink2.0	2020-06-28 18:25:04.306	info	(13014) broadlink2 has 0 old devices!
    broadlink2.0	2020-06-28 18:25:04.305	info	(13014) Devices to rename:
    broadlink2.0	2020-06-28 18:25:04.305	info	(13014) Devices to add: 24994=RM4P
    broadlink2.0	2020-06-28 18:25:04.304	info	(13014) Scanning additional IP's:
    broadlink2.0	2020-06-28 18:25:04.301	info	(13014) broadlink2 initialization started...
    broadlink2.0	2020-06-28 18:25:04.300	info	(13014) debug: broadlink2 received 24 objects and 24 states, with config ip,scenes,switches,poll,new,rename,additional,interface,lang,latitude,longitude,adapterConf,loglevel
    broadlink2.0	2020-06-28 18:25:04.210	info	(13014) starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.21.0, js-controller: 3.1.6
    broadlink2.0	2020-06-28 18:24:59.725	info	(12834) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    broadlink2.0	2020-06-28 18:24:59.724	info	(12834) terminating
    broadlink2.0	2020-06-28 18:24:59.724	info	(12834) Adapter disconnected and stopped with dostop(null) and callback(true)
    broadlink2.0	2020-06-28 18:24:59.722	info	(12834) Got terminate signal TERMINATE_YOURSELF
    broadlink2.0	2020-06-28 18:24:47.473	warn	(12834) stateChange error no device found: RM:RM4 { val: true,ack: false,ts: 1593361487465,q: 0,from: 'system.adapter.admin.0',user: 'system.user.admin',lc: 1593114356072 }
    broadlink2.0	2020-06-28 18:24:47.471	info	(12834) debug: Change broadlink2.0.RM:RM4._LearnRF to { val: true, ack: false, ts: 1593361487465, q: 0, from: 'system.adapter.admin.0', user: 'system.user.admin', lc: 1593114356072 }
    frankjokeF 1 Antwort Letzte Antwort
      Sven79
      #913
      Moin,
      ich verwende ebenfalls die aktuelle 2.1.3 mit einem RM mini 3 und kann die Fehlermeldung bestätigen:
      broadlink2.0	2020-06-28 20:33:07.644	info	(229649) Unrecoverable Send packet error The device storage is full on RM4, RM:RM3-d6-0b-09, 24:df:a7:d6:0b:09, 10.0.1.92, 智能遥控
      Ich hatte das Gerät zunächst über die BroadLink iOS App über die Cloud verbunden, dann nach Reset über die BroadLink e-Control iOS App ins WLAN gebracht. Ein Objekt wird in ioBroker angelegt, jedoch nur mit dem Namen "_notReachable".
      Viele Grüße,
      Sven
      • M moj090
        frankjokeF Offline
        frankjokeF Offline
        frankjoke
        schrieb am zuletzt editiert von frankjoke
        #914
        @moj090
        @swagner
        @ElseKling
        Danke fürs testen!
        Moj, das Device 24994=RM4P ist schon drinnen, nimm das aus dem device add raus und versuche bitte nochmal ein update von git. Mein RM4 Mini und RM3 Pro+ arbeiten perfekt. Dein Listing zeigt aber dass er nicht gefunden wird
        , sprich nicht reagiert. Für doppelten Boden kannst due die IP des Gerätes auch noch in das Feld 'additional IP's to scan' eingeben, dann wird er noch direkt angesprochen wenn er nicht schon auf den discover-Befehl reagiert hat.
        Bei der momentanen git-version werden die Fehler (samt einigen Daten) in debug mode angezeigt aber beim id=0x5f36 wird der Speichefehler ignoriert um mal zu sehen was dann passiert.
        Frank,
        NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
        Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
        • S swagner
          @frankjoke ist das ein Problem mit dem den verschiedenen Typen die es vom RM3 Mini gibt ?
          RM3 Mini alt (id=0x2737) S/N RM31x
          RM3 Mini neu (id=0x5f36) S/N RM61x
          Ich habe S/N RM61x und die funktioniert bei mir mit Sicherheit nicht, möglicherweise gibt es von der S/N RM61x auch mehr als eine Version, oder irgendwas wird in die Firmware geschrieben sobald das Teil einmal in der Cloud war.
          Es wäre vielleicht interessant zu erfahren ob jemand eine RM3 Mini mit S/N RM61x hat der funktioniert und ob das Teil schon einmal in der Cloud war.
          Kannst du mir sagen ob der RM4C Mini auch funktioniert da ich den RM4 Mini nicht bestellen kann.
          https://www.amazon.de/BestCon-RM4C-Universal-Fernbedienung-IR-Controller-App-Steuerung/dp/B07ZVBJF1R/ref=sr_1_3?__mk_de_DE=ÅMÅŽÕÑ&dchild=1&keywords=RM4c+mini&qid=1593332534&sr=8-3
          mfg
          Stefan
          PS: wenn als Gerätetype 0x5f36=SP1 eingetragen wird dann kommt die "storage is full on.." Meldung nicht, wenn andere Typen eingetragen werden kommt die Meldung einmal, zweimal oder dreimal, der RM3 mini ist aber immer _notreachable.
          frankjokeF Offline
          frankjokeF Offline
          frankjoke
          #915
          @swagner sagte in Adapter: broadlink2:
          Danke für das Feedback!
          Dein Gerät schaut gleich aus und selbes Kabel scheint dabei zu sein, also könnte funktionieren.
          laut allen Aufzeichnungen ist benutzt der alte mini das alte RM protokoll (= gleich mit allen anderen Geräten, nur T1 und LB1 haben auch eigene Protokolle).
          der neue sollte das RM4-Protokoll verwenden welches bei meine nRM4 Mini einwandfrei funktioniert und bei anderen Nutzern hier auch.
          p.s.: Der Grund warum bei SP1 kein Fehler kommt und sonst schon ist dass SP1 keinen Abfragebefehl hat und daher nur aus dem Speicher der letzte gesendete Wet zurückgegeben wird, ohne Abfrage des Status!
          Ist irgendwer von euch Python-firm? Wenn ja dann hätte ich gerne dass ihr mal das Gerät unter Python mit dem broadlink treiber dort checken. Mein Adapter implementiert das selbe Protokoll (und manchmal sende ich den Leuten auch updates) https://github.com/mjg59/python-broadlink/tree/master/broadlink
          Ich hab einfach latest Python3 am PC installiert und dann mit pip3 broadlink dazu und schon kann man die command line-Befehle von der Webseite prüfen und scannen.
          Wenn die wort auch probleme machen dann ist das neue RM3 Mini zu vergessen.
          Frank,
            Sven79
            schrieb am zuletzt editiert von Sven79
            #916
            % ./broadlink_cli --type 0x5f36 --host 10.0.1.92 --mac 24dfa7d60b09 --temp
            Traceback (most recent call last):
              File "./broadlink_cli", line 116, in <module>
                print(dev.check_temperature())
              File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 673, in check_temperature
                return self._read_sensor( 0x24, 4, 100.0 )
              File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 653, in _read_sensor
                check_error(response[0x22:0x24])
              File "/usr/local/lib/python3.7/site-packages/broadlink/exceptions.py", line 97, in check_error
                raise exception(error_code)
            broadlink.exceptions.StorageError: The device storage is full
            • frankjokeF frankjoke
              swagner
              #917
              @frankjoke ich habe jetzt die letzte Version von Github installiert mit dem Debug settings bekomme ich folgendes in log angezeigt, mit not reachable.
              broadlink2.0	2020-06-28 21:59:10.102	info	(5159) discover [ '192.168.1.151' ] from 0.0.0.0:48439
              broadlink2.0	2020-06-28 21:59:10.100	info	(5159) debug: UDP listening on 0.0.0.0:48439
              broadlink2.0	2020-06-28 21:59:10.099	info	(5159) debug: should discover/search [ { address: '192.168.1.151', port: 80, devtype: 24374, oname: '智能遥控', cloud: 0, maco: <Buffer ac 41 50 a7 df 24>, mac: '24:df:a7:50:41:ac', type: 'rm4', name: 'RM
              broadlink2.0	2020-06-28 21:59:10.097	info	(5159) debug: device RM:0x5f36_24:df:a7:50:41:ac not reachable, waiting for it again { here: false }
              broadlink2.0	2020-06-28 21:59:10.096	info	(5159) Unrecoverable Send packet error { cmd: 0,command: 238,err: 65531,response:<Buffer 5a a5 aa 55 5a a5 aa 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9d d2 fb ff 36
              broadlink2.0	2020-06-28 21:59:10.094	info	(5159) debug: send Error on device RM4, RM:0x5f36_24:df:a7:50:41:ac, 24:df:a7:50:41:ac, 192.168.1.151, 智能遥控: { cmd: 0, command: 238, err: 65531, response: <Buffer 5a a5 aa 55 5a a5 aa 55 00 00 00 00 0
              broadlink2.0	2020-06-28 21:58:40.079	info	(5159) found macs: 24:df:a7:50:41:ac
              broadlink2.0	2020-06-28 21:58:40.079	info	(5159) broadlink2.0 started and found 1 devices named RM:0x5f36_24:df:a7:50:41:ac
              broadlink2.0	2020-06-28 21:58:40.078	info	(5159) Poll every 30 secods.
              broadlink2.0	2020-06-28 21:58:40.077	info	(5159) debug: ChangeState ack:true of broadlink2.0._SendScene =
              broadlink2.0	2020-06-28 21:58:40.067	info	(5159) debug: created State broadlink2.0._SendScene
              broadlink2.0	2020-06-28 21:58:37.845	info	(5159) discover [ '192.168.1.151' ] from 0.0.0.0:57242
              broadlink2.0	2020-06-28 21:58:37.842	info	(5159) debug: UDP listening on 0.0.0.0:57242
              broadlink2.0	2020-06-28 21:58:37.838	info	(5159) debug: should discover/search [ { address: '192.168.1.151', port: 80, devtype: 24374, oname: '智能遥控', cloud: 0, maco: <Buffer ac 41 50 a7 df 24>, mac: '24:df:a7:50:41:ac', type: 'rm4', name: 'RM
              broadlink2.0	2020-06-28 21:58:37.835	info	(5159) debug: device RM:0x5f36_24:df:a7:50:41:ac not reachable, waiting for it again { here: false }
              broadlink2.0	2020-06-28 21:58:37.834	info	(5159) debug: Device RM:0x5f36_24:df:a7:50:41:ac returned { here: false }
              broadlink2.0	2020-06-28 21:58:37.831	info	(5159) Unrecoverable Send packet error { cmd: 0,command: 238,err: 65531,response:<Buffer 5a a5 aa 55 5a a5 aa 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9c d2 fb ff 36
              broadlink2.0	2020-06-28 21:58:37.828	info	(5159) debug: send Error on device RM4, RM:0x5f36_24:df:a7:50:41:ac, 24:df:a7:50:41:ac, 192.168.1.151, 智能遥控: { cmd: 0, command: 238, err: 65531, response: <Buffer 5a a5 aa 55 5a a5 aa 55 00 00 00 00 0
              broadlink2.0	2020-06-28 21:58:37.786	info	(5159) debug: ChangeState ack:true of _NewDeviceScan = false
              broadlink2.0	2020-06-28 21:58:31.792	info	(5159) debug: ChangeState ack:true of broadlink2.0.RM:0x5f36_24:df:a7:50:41:ac._notReachable = false
              broadlink2.0	2020-06-28 21:58:31.782	info	(5159) debug: created State broadlink2.0.RM:0x5f36_24:df:a7:50:41:ac._notReachable
              broadlink2.0	2020-06-28 21:58:31.763	info	(5159) Device RM:0x5f36_24:df:a7:50:41:ac dedected: address=192.168.1.151, mac=24:df:a7:50:41:ac, typ=rm4, id=0x5f36 devtype=rm4
              broadlink2.0	2020-06-28 21:58:31.654	info	(5159) debug: UDP listening on 0.0.0.0:34892
              broadlink2.0	2020-06-28 21:58:31.541	info	(5159) discover [ '192.168.1.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:40066
              broadlink2.0	2020-06-28 21:58:31.538	info	(5159) debug: UDP listening on 0.0.0.0:40066
              broadlink2.0	2020-06-28 21:58:31.534	info	(5159) debug: ChangeState ack:true of broadlink2.0._NewDeviceScan = true
              broadlink2.0	2020-06-28 21:58:31.518	info	(5159) debug: created State broadlink2.0._NewDeviceScan
              broadlink2.0	2020-06-28 21:58:31.483	info	(5159) debug: UDP listening on 0.0.0.0:15001
              broadlink2.0	2020-06-28 21:58:31.447	info	(5159) Discover Broadlink devices for 10sec on broadlink2.0
              broadlink2.0	2020-06-28 21:58:31.437	info	(5159) debug: Config IP-Address end to remove: .fritz.box
              broadlink2.0	2020-06-28 21:58:31.435	info	(5159) macObjects: []
              broadlink2.0	2020-06-28 21:58:31.432	info	(5159) interface to be used: { netmaskBits: 24, address: '192.168.1.30/24', addrs: [ 192, 168, 1, 30 ], cidr: '192.168.1.30/24', bcaddr: '192.168.1.255' }:
              broadlink2.0	2020-06-28 21:58:31.419	info	(5159) broadlink2 has 0 old devices!
              broadlink2.0	2020-06-28 21:58:31.417	info	(5159) Devices to rename:
              broadlink2.0	2020-06-28 21:58:31.415	info	(5159) Devices to add: 0x5f36=RM4
              broadlink2.0	2020-06-28 21:58:31.413	info	(5159) Scanning additional IP's:
              broadlink2.0	2020-06-28 21:58:31.399	info	(5159) broadlink2 initialization started...
              broadlink2.0	2020-06-28 21:58:31.258	info	(5159) starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.19.0, js-controller: 3.1.6
              host.ioBroker-RasPi	2020-06-28 21:58:28.293	info	instance system.adapter.broadlink2.0 started with pid 5159
                Sven79
                #918
                @frankjoke hilft dir das vielleicht weiter? Ich habe es direkt über Python versucht:
                Python 3.7.4 (default, Oct 12 2019, 18:55:28)
                [Clang 11.0.0 (clang-1100.0.33.8)] on darwin
                Type "help", "copyright", "credits" or "license" for more information.
                >>> import broadlink
                >>> devices = broadlink.discover(timeout=5)
                >>> devices[0].auth()
                True
                >>> devices[0].check_data()
                  File "<stdin>", line 1, in <module>
                  File "/usr/local/lib/python3.7/site-packages/broadlink/__init__.py", line 600, in check_data
                >>> pprint(devices[0], indent=2)
                <broadlink.rm4 object at 0x110454890>
                >>> pprint(vars(devices[0]))
                {'_code_sending_header': b'\xd0\x00',
                 '_request_header': b'\x04\x00',
                 'aes': <cryptography.hazmat.primitives.ciphers.base.Cipher object at 0x110454c50>,
                 'cloud': False,
                 'count': 41593,
                 'devtype': 24374,
                 'host': ('10.0.1.92', 80),
                 'id': b'\x01\x00\x00\x00',
                 'iv': bytearray(b'V.\x17\x99m\t=(\xdd\xb3\xbaiZ.oX'),
                 'lock': <unlocked _thread.lock object at 0x10fdd4b10>,
                 'mac': bytearray(b'\t\x0b\xd6\xa7\xdf$'),
                 'name': '智能遥控',
                 'timeout': 10,
                 'type': 'RM4'}
                >>> pprint(dir(devices[0]))
                ['__class__',
                 '__delattr__',
                 '__dict__',
                 '__dir__',
                 '__doc__',
                 '__eq__',
                 '__format__',
                 '__ge__',
                 '__getattribute__',
                 '__gt__',
                 '__hash__',
                 '__init__',
                 '__init_subclass__',
                 '__le__',
                 '__lt__',
                 '__module__',
                 '__ne__',
                 '__new__',
                 '__reduce__',
                 '__reduce_ex__',
                 '__repr__',
                 '__setattr__',
                 '__sizeof__',
                 '__str__',
                 '__subclasshook__',
                 '__weakref__',
                 '_code_sending_header',
                 '_read_sensor',
                 '_request_header',
                 'aes',
                 'auth',
                 'cancel_sweep_frequency',
                 'check_data',
                 'check_frequency',
                 'check_humidity',
                 'check_sensors',
                 'check_temperature',
                 'cloud',
                 'count',
                 'decrypt',
                 'devtype',
                 'encrypt',
                 'enter_learning',
                 'find_rf_packet',
                 'get_type',
                 'host',
                 'id',
                 'iv',
                 'lock',
                 'mac',
                 'name',
                 'send_data',
                 'send_packet',
                 'sweep_frequency',
                 'timeout',
                 'type',
                 'update_aes']
                • S swagner
                  frankjokeF Offline
                  frankjokeF Offline
                  frankjoke
                  #919
                  @swagner
                  @Sven79
                  Danke für den Python.Test Sven! Also bekommt auch der Python-Treiber den selben Fehler!
                  Laut log von swagner ist meldet das Gerät bei jedem Befehl einen Fehler (auch wenn ich den Speicherfehler ausblende)!
                  Ich weiß nicht was ich da machen soll, vielleicht hat das Ding einfach nur den Cloud-treiber drin und ist nicht mit dem 'alten' Protokoll kompatibel!
                  Frank,
                  M S 2 Antworten Letzte Antwort
                    @swagner
                    @Sven79
                    muckel
                    #920
                    @frankjoke
                    @Sven79
                    Ich hatte auch mal das Problem, dass er sich aus der Cloud-App nicht mehr in die e-control anmelden lies.
                    Meine Lösung beim RM4 war:
                    Reset RM4 > mit Cloud-App wieder ins Netzwerk bringen (Step 1) und gleich danach die Cloud-App abschießen.
                    Somit war mein RM4 im Netzwerk, aber nicht in der Cloud.
                    Probieren geht über studieren. Vielleicht hilft es.
                      @Christoph1337
                      Die neue Version von git (2.1.3) löst dein Problem ohne Blocky!
                      Ich habe eingebaut dass man in den States auf den Ein's beliebige States angeben kann und auf Aus -x (wobei x nicht 0 sein kann).
                      Wenn du jetzt zum Beispiel deine Temperaturen von 17-29 (13 Stück) anlernst und Namen von T17 bis T29 vergibst und in den eins T17,T18,T19,...T29 angibst und auf dem aus -17 dann wird wenn du 17 in den State speicherst die T17 gesendet ...
                      Christoph1337C Offline
                      Christoph1337
                      #921
                      @frankjoke
                      ooohh! Mega genial! Dank dir!
                      So hast du dir das gedacht, oder?
                      • Christoph1337C Christoph1337
                        @frankjoke
                        frankjokeF Offline
                        frankjokeF Offline
                        frankjoke
                        #922
                        @Christoph1337
                        Im Prinzip ja, aber ins off-Feld musst du noch -16 (in deinem Fall) schreiben!
                        Frank,
                          @swagner
                          @Sven79
                          swagner
                          #923
                          @frankjoke ich habe mir jetzt den RM4C bestellt. Meine Empfehlung wäre eine Liste zu erstellen mit.
                          Type, ID, S/N, Status
                          RM3 MINI, 0x5f36, S/N RM61, funktioniert nicht
                          Mfg
                          Stefan
                          • M muckel
                            @frankjoke
                            @Sven79
                            frankjokeF Offline
                            frankjokeF Offline
                            frankjoke
                            #924
                            @muckel
                            Danke für die Info, vielleicht können es die betroffenen ja mal testen!
                            Ich denke das Problem mein RM3 Mini neu ist jedoch dass er mit e-control ins netzt geholt werden kann aber dann einen storage Fehler bei jedem Befehl bringt! Das einzige was funktioniert scheint das Auth zu sein (sonst würde er einen Auth- oder Key-Fehler melden).
                            Frank,
                            • S swagner
                              Mfg
                              Stefan
                              frankjokeF Offline
                              frankjokeF Offline
                              frankjoke
                              #925
                              @swagner
                              Habe das gemacht, in meinem ersten Post, den ich immer wieder update habe ich eine solche Problemliste angefangen.
                              https://forum.iobroker.net/topic/6881/adapter-broadlink2
                              p.s.: Ich habe die Einstellungen so dass ich im menü unter dem post bei Sortieren nach: Neueste zuerst eingestellt habe, damit kommt immer der letzt post nach meinem 1. post und ich brauch nicht scrollen um die letzten posts zu sehen!
                              Frank,
                              • No NameN Offline
                                No NameN Offline
                                No Name
                                #926
                                Please add Broadlink Bestcon MCB1
                                It is working only with app https://play.google.com/store/apps/details?id=cn.com.broadlink.econtrol.international
                                It is new device.
                                Mac adress Broadlink Bestcon MCB1 c8:f7:42:75:d3:ed
                                Log:
                                2020-06-30 10:33:36.098 - info: broadlink2.0 (12670) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.21.0, js-controller: 3.1.5
                                2020-06-30 10:33:36.759 - info: broadlink2.0 (12670) debug: broadlink2 received 45 objects and 45 states, with config ip,scenes,switches,poll,new,rename,additional,lang,latitude,longitude,adapterConf,loglevel
                                2020-06-30 10:33:36.766 - info: broadlink2.0 (12670) broadlink2 initialization started...
                                2020-06-30 10:33:36.788 - info: broadlink2.0 (12670) Scanning additional IP's: 192.168.1.199
                                2020-06-30 10:33:36.791 - info: broadlink2.0 (12670) Devices to add:
                                2020-06-30 10:33:36.794 - info: broadlink2.0 (12670) Devices to rename: SP:0x7547_78:0f:77:17:8d:49=bathroom
                                2020-06-30 10:33:36.801 - info: broadlink2.0 (12670) broadlink2 has 6 old devices!
                                2020-06-30 10:33:36.832 - info: broadlink2.0 (12670) interface to be used: { netmaskBits: 24, address: '192.168.1.7/24', addrs: [ 192, 168, 1, 7 ], cidr: '192.168.1.7/24', bcaddr: '192.168.1.255' }:
                                2020-06-30 10:33:36.841 - info: broadlink2.0 (12670) interface to be used: { netmaskBits: 23, address: '10.121.82.11/23', addrs: [ 10, 121, 82, 11 ], cidr: '10.121.82.11/23', bcaddr: '10.121.83.255' }:
                                2020-06-30 10:33:36.850 - info: broadlink2.0 (12670) macObjects: [ '34:ea:34:50:d0:15', '34:ea:34:bd:a7:ec', '34:ea:34:bd:bc:da', '78:0f:77:01:b2:f0', '78:0f:77:17:8d:49', '78:0f:77:17:a3:69' ]
                                2020-06-30 10:33:36.853 - info: broadlink2.0 (12670) debug: Config IP-Address end to remove: .fritz.box
                                2020-06-30 10:33:36.951 - info: broadlink2.0 (12670) debug: created State broadlink2.0.Scenes.Fernsehen
                                2020-06-30 10:33:37.025 - info: broadlink2.0 (12670) debug: ChangeState ack:false of broadlink2.0.Scenes.Fernsehen = false
                                2020-06-30 10:33:37.071 - info: broadlink2.0 (12670) Discover Broadlink devices for 10sec on broadlink2.0
                                2020-06-30 10:33:37.106 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:15001
                                2020-06-30 10:33:37.160 - info: broadlink2.0 (12670) debug: created State broadlink2.0._NewDeviceScan
                                2020-06-30 10:33:37.245 - info: broadlink2.0 (12670) debug: ChangeState ack:true of broadlink2.0._NewDeviceScan = true
                                2020-06-30 10:33:37.261 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:44249
                                2020-06-30 10:33:37.271 - info: broadlink2.0 (12670) discover [ '192.168.1.255', '10.121.83.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:44249
                                2020-06-30 10:33:37.461 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:51877
                                2020-06-30 10:33:37.479 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:51637
                                2020-06-30 10:33:37.488 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:47716
                                2020-06-30 10:33:37.498 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:47712
                                2020-06-30 10:33:37.523 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:36622
                                2020-06-30 10:33:37.986 - info: broadlink2.0 (12670) Device bathroom dedected: address=192.168.1.5, mac=78:0f:77:17:8d:49, typ=sp2, id=0x7547 devtype=OEM branded SPMini2, originalName=SP:0x7547_78:0f:77:17:8d:49
                                2020-06-30 10:33:38.045 - info: broadlink2.0 (12670) Device RM:0x2737_c8:f7:42:16:85:ac dedected: address=192.168.1.25, mac=c8:f7:42:16:85:ac, typ=rm, id=0x2737 devtype=RM Mini
                                2020-06-30 10:33:38.052 - info: broadlink2.0 (12670) Device SP:0x7547_34:ea:34:bd:a7:ec dedected: address=192.168.1.23, mac=34:ea:34:bd:a7:ec, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                                2020-06-30 10:33:38.057 - info: broadlink2.0 (12670) Device SP:0x7547_34:ea:34:bd:bc:da dedected: address=192.168.1.27, mac=34:ea:34:bd:bc:da, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                                2020-06-30 10:33:38.100 - info: broadlink2.0 (12670) debug: created State broadlink2.0.bathroom._notReachable
                                2020-06-30 10:33:38.159 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._notReachable
                                2020-06-30 10:33:38.175 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec._notReachable
                                2020-06-30 10:33:38.205 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da._notReachable
                                2020-06-30 10:33:38.284 - info: broadlink2.0 (12670) Device SP:0x753e_34:ea:34:50:d0:15 dedected: address=192.168.1.21, mac=34:ea:34:50:d0:15, typ=sp2, id=0x753e devtype=OEM branded SPMini2
                                2020-06-30 10:33:38.370 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15._notReachable
                                2020-06-30 10:33:42.745 - info: broadlink2.0 (12670) debug: Try to discover 192.168.1.199
                                2020-06-30 10:33:42.754 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:52636
                                2020-06-30 10:33:42.759 - info: broadlink2.0 (12670) discover [ '192.168.1.199' ] from 0.0.0.0:52636
                                2020-06-30 10:33:47.023 - info: broadlink2.0 (12670) debug: ChangeState ack:true of _NewDeviceScan = false
                                2020-06-30 10:33:47.081 - info: broadlink2.0 (12670) debug: created State broadlink2.0.States.Steckdose_A
                                2020-06-30 10:33:47.190 - info: broadlink2.0 (12670) debug: created State broadlink2.0.States.Lüfter_A
                                2020-06-30 10:33:47.423 - info: broadlink2.0 (12670) debug: created State broadlink2.0.States.TVWZKanal
                                2020-06-30 10:33:47.558 - warn: broadlink2.0 (12670) device SP:0x753e_78:0f:77:01:b2:f0 not found, please rescan later again or delete it! It was: 192.168.1.24,80,30014,[object Object],78:0f:77:01:b2:f0,sp2,SP:0x753e_78:0f:77:01:b2:f0,0x753e,OEM branded SPMini2,SP:0x753e_78:0f:77:01:b2:f0
                                2020-06-30 10:33:47.563 - warn: broadlink2.0 (12670) device SP:0x7547_78:0f:77:17:a3:69 not found, please rescan later again or delete it! It was: 192.168.1.8,80,30023,[object Object],78:0f:77:17:a3:69,sp2,SP:0x7547_78:0f:77:17:a3:69,0x7547,OEM branded SPMini2,SP:0x7547_78:0f:77:17:a3:69
                                2020-06-30 10:33:47.624 - info: broadlink2.0 (12670) debug: Device bathroom returned { here: true, state: false }
                                2020-06-30 10:33:47.741 - info: broadlink2.0 (12670) debug: created State broadlink2.0.bathroom
                                2020-06-30 10:33:47.808 - info: broadlink2.0 (12670) debug: ChangeState ack:true of broadlink2.0.bathroom = false
                                2020-06-30 10:33:47.957 - info: broadlink2.0 (12670) debug: created State broadlink2.0.bathroom.state
                                2020-06-30 10:33:48.393 - info: broadlink2.0 (12670) debug: Device RM:0x2737_c8:f7:42:16:85:ac returned { here: true, temperature: 0 }
                                2020-06-30 10:33:48.438 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac.Temperature
                                2020-06-30 10:33:48.512 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac
                                2020-06-30 10:33:48.584 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._Learn
                                2020-06-30 10:33:48.656 - info: broadlink2.0 (12670) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._SendCode
                                2020-06-30 10:33:48.701 - info: broadlink2.0 (12670) debug: Device SP:0x7547_34:ea:34:bd:a7:ec returned { here: true, state: false }
                                2020-06-30 10:33:48.772 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec
                                2020-06-30 10:33:48.885 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec.state
                                2020-06-30 10:33:48.933 - info: broadlink2.0 (12670) debug: Device SP:0x7547_34:ea:34:bd:bc:da returned { here: true, state: false }
                                2020-06-30 10:33:49.038 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da
                                2020-06-30 10:33:49.068 - info: broadlink2.0 (12670) debug: ChangeState ack:true of broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da = false
                                2020-06-30 10:33:49.103 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da.state
                                2020-06-30 10:33:49.238 - info: broadlink2.0 (12670) debug: Device SP:0x753e_34:ea:34:50:d0:15 returned { here: true, state: false }
                                2020-06-30 10:33:49.284 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15
                                2020-06-30 10:33:49.374 - info: broadlink2.0 (12670) debug: ChangeState ack:true of broadlink2.0.SP:0x753e_34:ea:34:50:d0:15 = false
                                2020-06-30 10:33:49.421 - info: broadlink2.0 (12670) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15.state
                                2020-06-30 10:33:49.429 - info: broadlink2.0 (12670) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                                2020-06-30 10:33:49.435 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:42792
                                2020-06-30 10:33:49.439 - info: broadlink2.0 (12670) discover [ '192.168.1.24' ] from 0.0.0.0:42792
                                2020-06-30 10:33:51.667 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:37634
                                2020-06-30 10:33:51.670 - info: broadlink2.0 (12670) discover [ '192.168.1.8' ] from 0.0.0.0:37634
                                2020-06-30 10:33:54.252 - info: broadlink2.0 (12670) debug: created State broadlink2.0._SendScene
                                2020-06-30 10:33:54.256 - info: broadlink2.0 (12670) Poll every 20 secods.
                                2020-06-30 10:33:54.263 - info: broadlink2.0 (12670) broadlink2.0 started and found 5 devices named bathroom, RM:0x2737_c8:f7:42:16:85:ac, SP:0x7547_34:ea:34:bd:a7:ec, SP:0x7547_34:ea:34:bd:bc:da, SP:0x753e_34:ea:34:50:d0:15
                                2020-06-30 10:33:54.267 - info: broadlink2.0 (12670) 2 were not found: SP:0x753e_78:0f:77:01:b2:f0, SP:0x7547_78:0f:77:17:a3:69
                                2020-06-30 10:33:54.270 - info: broadlink2.0 (12670) found macs: 78:0f:77:17:8d:49, c8:f7:42:16:85:ac, 34:ea:34:bd:a7:ec, 34:ea:34:bd:bc:da, 34:ea:34:50:d0:15
                                2020-06-30 10:34:34.568 - info: broadlink2.0 (12670) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                                2020-06-30 10:34:34.582 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:52590
                                2020-06-30 10:34:34.587 - info: broadlink2.0 (12670) discover [ '192.168.1.24' ] from 0.0.0.0:52590
                                2020-06-30 10:34:36.818 - info: broadlink2.0 (12670) debug: UDP listening on 0.0.0.0:41145
                                2020-06-30 10:34:36.821 - info: broadlink2.0 (12670) discover [ '192.168.1.8' ] from 0.0.0.0:41145
                                2020-06-30 10:35:49.867 - info: host.server iobroker upload [5] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/words.js words.js application/javascript
                                2020-06-30 10:35:50.247 - info: host.server iobroker Update "system.adapter.broadlink2.0"
                                2020-06-30 10:35:50.256 - info: host.server iobroker Update "system.adapter.broadlink2.1"
                                2020-06-30 10:35:50.320 - info: host.server stopInstance system.adapter.broadlink2.0 (force=false, process=true)
                                2020-06-30 10:35:50.326 - info: host.server stopInstance system.adapter.broadlink2.0 send kill signal
                                2020-06-30 10:35:50.336 - info: broadlink2.0 (12670) Got terminate signal TERMINATE_YOURSELF
                                2020-06-30 10:35:50.350 - info: broadlink2.0 (12670) Adapter disconnected and stopped with dostop(null) and callback(true)
                                2020-06-30 10:35:50.354 - info: broadlink2.0 (12670) terminating
                                2020-06-30 10:35:50.361 - info: broadlink2.0 (12670) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2020-06-30 10:35:50.558 - info: host.server iobroker upload [4] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/style.css style.css text/css
                                2020-06-30 10:35:50.648 - info: host.server iobroker upload [3] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/index_m.html index_m.html text/html
                                2020-06-30 10:35:50.730 - info: host.server iobroker upload [2] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/index.html index.html text/html
                                2020-06-30 10:35:50.826 - info: host.server iobroker upload [1] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/broadlink2.png broadlink2.png image/png
                                2020-06-30 10:35:50.956 - info: host.server instance system.adapter.broadlink2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2020-06-30 10:35:51.002 - info: host.server iobroker upload [0] broadlink2.admin /opt/iobroker/node_modules/iobroker.broadlink2/admin/broadlink.png broadlink.png image/png
                                2020-06-30 10:35:51.080 - info: host.server iobroker Adapter "broadlink2" updated
                                2020-06-30 10:35:52.142 - info: host.server iobroker exit 0
                                2020-06-30 10:35:53.834 - info: host.server instance system.adapter.broadlink2.0 started with pid 16215
                                2020-06-30 10:36:00.414 - debug: broadlink2.0 (16215) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                2020-06-30 10:36:00.814 - debug: broadlink2.0 (16215) Objects client ready ... initialize now
                                2020-06-30 10:36:00.854 - debug: broadlink2.0 (16215) Objects create System PubSub Client
                                2020-06-30 10:36:00.864 - debug: broadlink2.0 (16215) Objects create User PubSub Client
                                2020-06-30 10:36:00.869 - debug: broadlink2.0 (16215) Objects client initialize lua scripts
                                2020-06-30 10:36:00.994 - debug: broadlink2.0 (16215) Objects connected to redis: 127.0.0.1:9001
                                2020-06-30 10:36:01.068 - debug: broadlink2.0 (16215) objectDB connected
                                2020-06-30 10:36:01.093 - debug: broadlink2.0 (16215) Redis States: Use Redis connection: 127.0.0.1:9000
                                2020-06-30 10:36:01.266 - debug: broadlink2.0 (16215) States create User PubSub Client
                                2020-06-30 10:36:01.364 - debug: broadlink2.0 (16215) States create System PubSub Client
                                2020-06-30 10:36:01.571 - debug: broadlink2.0 (16215) States connected to redis: 127.0.0.1:9000
                                2020-06-30 10:36:01.577 - debug: broadlink2.0 (16215) statesDB connected
                                2020-06-30 10:36:03.490 - info: broadlink2.0 (16215) starting. Version 2.1.3 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v10.21.0, js-controller: 3.1.5
                                2020-06-30 10:36:04.474 - info: broadlink2.0 (16215) debug: broadlink2 received 45 objects and 45 states, with config ip,scenes,switches,poll,new,rename,additional,lang,latitude,longitude,adapterConf,loglevel
                                2020-06-30 10:36:04.505 - info: broadlink2.0 (16215) broadlink2 initialization started...
                                2020-06-30 10:36:04.557 - info: broadlink2.0 (16215) Scanning additional IP's: 192.168.1.199
                                2020-06-30 10:36:04.564 - info: broadlink2.0 (16215) Devices to add:
                                2020-06-30 10:36:04.575 - info: broadlink2.0 (16215) Devices to rename: SP:0x7547_78:0f:77:17:8d:49=bathroom
                                2020-06-30 10:36:04.586 - info: broadlink2.0 (16215) broadlink2 has 6 old devices!
                                2020-06-30 10:36:04.678 - info: broadlink2.0 (16215) interface to be used: { netmaskBits: 24, address: '192.168.1.7/24', addrs: [ 192, 168, 1, 7 ], cidr: '192.168.1.7/24', bcaddr: '192.168.1.255' }:
                                2020-06-30 10:36:04.683 - info: broadlink2.0 (16215) interface to be used: { netmaskBits: 23, address: '10.121.82.11/23', addrs: [ 10, 121, 82, 11 ], cidr: '10.121.82.11/23', bcaddr: '10.121.83.255' }:
                                2020-06-30 10:36:04.689 - info: broadlink2.0 (16215) macObjects: [ '34:ea:34:50:d0:15', '34:ea:34:bd:a7:ec', '34:ea:34:bd:bc:da', '78:0f:77:01:b2:f0', '78:0f:77:17:8d:49', '78:0f:77:17:a3:69' ]
                                2020-06-30 10:36:04.691 - info: broadlink2.0 (16215) debug: Config IP-Address end to remove: .fritz.box
                                2020-06-30 10:36:04.976 - info: broadlink2.0 (16215) debug: created State broadlink2.0.Scenes.Fernsehen
                                2020-06-30 10:36:05.077 - info: broadlink2.0 (16215) debug: ChangeState ack:false of broadlink2.0.Scenes.Fernsehen = false
                                2020-06-30 10:36:05.136 - info: broadlink2.0 (16215) Discover Broadlink devices for 10sec on broadlink2.0
                                2020-06-30 10:36:05.191 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:15001
                                2020-06-30 10:36:05.249 - info: broadlink2.0 (16215) debug: created State broadlink2.0._NewDeviceScan
                                2020-06-30 10:36:05.317 - info: broadlink2.0 (16215) debug: ChangeState ack:true of broadlink2.0._NewDeviceScan = true
                                2020-06-30 10:36:05.330 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:46514
                                2020-06-30 10:36:05.341 - info: broadlink2.0 (16215) discover [ '192.168.1.255', '10.121.83.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:46514
                                2020-06-30 10:36:05.505 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:49271
                                2020-06-30 10:36:05.517 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:37642
                                2020-06-30 10:36:05.526 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:54922
                                2020-06-30 10:36:05.536 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:32991
                                2020-06-30 10:36:05.554 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:47222
                                2020-06-30 10:36:05.565 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:59820
                                2020-06-30 10:36:05.576 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:58098
                                2020-06-30 10:36:05.685 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                                2020-06-30 10:36:05.689 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063
                                2020-06-30 10:36:05.716 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                                2020-06-30 10:36:05.724 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063
                                2020-06-30 10:36:05.835 - info: broadlink2.0 (16215) Device SP:0x7547_34:ea:34:bd:a7:ec dedected: address=192.168.1.23, mac=34:ea:34:bd:a7:ec, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                                2020-06-30 10:36:05.856 - info: broadlink2.0 (16215) Device bathroom dedected: address=192.168.1.5, mac=78:0f:77:17:8d:49, typ=sp2, id=0x7547 devtype=OEM branded SPMini2, originalName=SP:0x7547_78:0f:77:17:8d:49
                                2020-06-30 10:36:05.864 - info: broadlink2.0 (16215) Device SP:0x7547_34:ea:34:bd:bc:da dedected: address=192.168.1.27, mac=34:ea:34:bd:bc:da, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
                                2020-06-30 10:36:05.885 - info: broadlink2.0 (16215) Device RM:0x2737_c8:f7:42:16:85:ac dedected: address=192.168.1.25, mac=c8:f7:42:16:85:ac, typ=rm, id=0x2737 devtype=RM Mini
                                2020-06-30 10:36:06.038 - info: broadlink2.0 (16215) Device SP:0x753e_34:ea:34:50:d0:15 dedected: address=192.168.1.21, mac=34:ea:34:50:d0:15, typ=sp2, id=0x753e devtype=OEM branded SPMini2
                                2020-06-30 10:36:06.053 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                                2020-06-30 10:36:06.057 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063
                                2020-06-30 10:36:06.065 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec._notReachable
                                2020-06-30 10:36:06.079 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                                2020-06-30 10:36:06.083 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063
                                2020-06-30 10:36:06.106 - info: broadlink2.0 (16215) debug: created State broadlink2.0.bathroom._notReachable
                                2020-06-30 10:36:06.117 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da._notReachable
                                2020-06-30 10:36:06.152 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._notReachable
                                2020-06-30 10:36:06.345 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15._notReachable
                                2020-06-30 10:36:06.384 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                                2020-06-30 10:36:06.387 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d7:23, 192.168.1.34, 30063
                                2020-06-30 10:36:06.437 - info: broadlink2.0 (16215) debug: send Error on device SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063: { cmd: NaN, command: 233, cmdHex: '0xe9', payload: , err: 'Authentication failed' }
                                2020-06-30 10:36:06.442 - info: broadlink2.0 (16215) Unrecoverable Send packet error Authentication failed on SP2, undefined, c8:f7:42:75:d3:ed, 192.168.1.37, 30063
                                2020-06-30 10:36:10.902 - info: broadlink2.0 (16215) debug: Try to discover 192.168.1.199
                                2020-06-30 10:36:10.914 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:49194
                                2020-06-30 10:36:10.924 - info: broadlink2.0 (16215) discover [ '192.168.1.199' ] from 0.0.0.0:49194
                                2020-06-30 10:36:15.179 - info: broadlink2.0 (16215) debug: ChangeState ack:true of _NewDeviceScan = false
                                2020-06-30 10:36:15.231 - info: broadlink2.0 (16215) debug: created State broadlink2.0.States.Steckdose_A
                                2020-06-30 10:36:15.316 - info: broadlink2.0 (16215) debug: created State broadlink2.0.States.Lüfter_A
                                2020-06-30 10:36:15.363 - info: broadlink2.0 (16215) debug: created State broadlink2.0.States.TVWZKanal
                                2020-06-30 10:36:15.486 - warn: broadlink2.0 (16215) device SP:0x753e_78:0f:77:01:b2:f0 not found, please rescan later again or delete it! It was: 192.168.1.24,80,30014,[object Object],78:0f:77:01:b2:f0,sp2,SP:0x753e_78:0f:77:01:b2:f0,0x753e,OEM branded SPMini2,SP:0x753e_78:0f:77:01:b2:f0
                                2020-06-30 10:36:15.490 - warn: broadlink2.0 (16215) device SP:0x7547_78:0f:77:17:a3:69 not found, please rescan later again or delete it! It was: 192.168.1.8,80,30023,[object Object],78:0f:77:17:a3:69,sp2,SP:0x7547_78:0f:77:17:a3:69,0x7547,OEM branded SPMini2,SP:0x7547_78:0f:77:17:a3:69
                                2020-06-30 10:36:15.553 - info: broadlink2.0 (16215) debug: Device SP:0x7547_34:ea:34:bd:a7:ec returned { here: true, state: false }
                                2020-06-30 10:36:15.604 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec
                                2020-06-30 10:36:15.672 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:a7:ec.state
                                2020-06-30 10:36:15.759 - info: broadlink2.0 (16215) debug: Device bathroom returned { here: true, state: false }
                                2020-06-30 10:36:15.801 - info: broadlink2.0 (16215) debug: created State broadlink2.0.bathroom
                                2020-06-30 10:36:15.863 - info: broadlink2.0 (16215) debug: created State broadlink2.0.bathroom.state
                                2020-06-30 10:36:15.935 - info: broadlink2.0 (16215) debug: Device SP:0x7547_34:ea:34:bd:bc:da returned { here: true, state: false }
                                2020-06-30 10:36:15.986 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da
                                2020-06-30 10:36:16.032 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x7547_34:ea:34:bd:bc:da.state
                                2020-06-30 10:36:16.079 - info: broadlink2.0 (16215) debug: Device RM:0x2737_c8:f7:42:16:85:ac returned { here: true, temperature: 0 }
                                2020-06-30 10:36:16.147 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac.Temperature
                                2020-06-30 10:36:16.260 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac
                                2020-06-30 10:36:16.392 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._Learn
                                2020-06-30 10:36:16.435 - info: broadlink2.0 (16215) debug: created State broadlink2.0.RM:0x2737_c8:f7:42:16:85:ac._SendCode
                                2020-06-30 10:36:16.585 - info: broadlink2.0 (16215) debug: Device SP:0x753e_34:ea:34:50:d0:15 returned { here: true, state: false }
                                2020-06-30 10:36:16.712 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15
                                2020-06-30 10:36:16.808 - info: broadlink2.0 (16215) debug: created State broadlink2.0.SP:0x753e_34:ea:34:50:d0:15.state
                                2020-06-30 10:36:16.818 - info: broadlink2.0 (16215) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                                2020-06-30 10:36:16.824 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:54865
                                2020-06-30 10:36:16.828 - info: broadlink2.0 (16215) discover [ '192.168.1.24' ] from 0.0.0.0:54865
                                2020-06-30 10:36:19.068 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:39361
                                2020-06-30 10:36:19.073 - info: broadlink2.0 (16215) discover [ '192.168.1.8' ] from 0.0.0.0:39361
                                2020-06-30 10:36:21.416 - info: broadlink2.0 (16215) debug: created State broadlink2.0._SendScene
                                2020-06-30 10:36:21.419 - info: broadlink2.0 (16215) Poll every 20 secods.
                                2020-06-30 10:36:21.421 - info: broadlink2.0 (16215) broadlink2.0 started and found 5 devices named SP:0x7547_34:ea:34:bd:a7:ec, bathroom, SP:0x7547_34:ea:34:bd:bc:da, RM:0x2737_c8:f7:42:16:85:ac, SP:0x753e_34:ea:34:50:d0:15
                                2020-06-30 10:36:21.423 - info: broadlink2.0 (16215) 2 were not found: SP:0x753e_78:0f:77:01:b2:f0, SP:0x7547_78:0f:77:17:a3:69
                                2020-06-30 10:36:21.425 - info: broadlink2.0 (16215) found macs: 34:ea:34:bd:a7:ec, 78:0f:77:17:8d:49, 34:ea:34:bd:bc:da, c8:f7:42:16:85:ac, 34:ea:34:50:d0:15
                                2020-06-30 10:37:01.707 - info: broadlink2.0 (16215) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                                2020-06-30 10:37:01.721 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:48069
                                2020-06-30 10:37:01.725 - info: broadlink2.0 (16215) discover [ '192.168.1.24' ] from 0.0.0.0:48069
                                2020-06-30 10:37:03.961 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:33564
                                2020-06-30 10:37:03.967 - info: broadlink2.0 (16215) discover [ '192.168.1.8' ] from 0.0.0.0:33564
                                2020-06-30 10:38:21.755 - info: broadlink2.0 (16215) debug: should discover/search [ { address: '192.168.1.24', port: 80, devtype: 30014, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:01:b2:f0', type: 'sp2', name: 'SP:0x753e_78:0f:77:01:b2:f0', devhex: '0x753e', devname: 'OEM branded SPMini2', iname: 'SP:0x753e_78:0f:77:01:b2:f0' }, { address: '192.168.1.8', port: 80, devtype: 30023, maco: { type: 'Buffer', data: [Array] }, mac: '78:0f:77:17:a3:69', type: 'sp2', name: 'SP:0x7547_78:0f:77:17:a3:69', devhex: '0x7547', devname: 'OEM branded SPMini2', iname: 'SP:0x7547_78:0f:77:17:a3:69' } ]
                                2020-06-30 10:38:21.762 - info: broadlink2.0 (16215) debug: UDP listening on 0.0.0.0:54709
                                2020-06-30 10:38:21.766 - info: broadlink2.0 (16215) discover [ '192.168.1.24' ] from 0.0.0.0:54709
                                • E Offline
                                  ElseKling
                                  #927
                                  Mein RM4 mini (S/N: RM9250201405) kam heute. Per e-control is WLAN und sofort alles funktioniert.👍
                                  Beim R3 Mini (S/N: RM6120204399) gebe ich auf. Egal ob per e-control oder cloud-App kommt immer der Storage Fehler.
                                  Da hier ja noch einige R3 minis zum Testen vorhanden sind, geht meiner wieder zurück.
                                    Sven79
                                    #928
                                    Mein RM mini 4 kam heute ebenfalls - und funktioniert auf Anhieb mit dem ioBroker Adapter. Der Weg über Python führt allerdings wieder direkt in den StorageError:
                                    % python3
                                    >>> import broadlink
                                    >>> devices[0].auth()
                                    True
                                    Dies funktioniert hingegen fehlerfrei:
                                    % ./broadlink_cli --type 0x5f36 --host 10.0.1.108 --mac 24DFA7E83C47 --sensors
                                    temperature 0.0
                                    humidity 0.0
                                    Ich werde den RM mini 3 daher zurücksenden und beim RM mini 4 bleiben. Danke für eure Unterstützung!
                                    • No NameN No Name
                                      It is new device.
                                      Log:
                                      frankjokeF Offline
                                      frankjokeF Offline
                                      frankjoke
                                      #929
                                      @No-Name
                                      Do confirm that the device is not even listed as unknown and does not answer to device scan?
                                      If you bring in the device with this app then it's definitely in cloud mode and would not work with broadlink2.
                                      Did you try to bring it in with e-control? You may not be able to use it on the e-control app but it might be found then.
                                      If the device does not answer it means it is not in the network or does not support old BL protocol.
                                      p.s.: You seem to have a very strange and unrealiable network because you have a lot of errors! I don't know what you use but I would replace it with a Mesch-Wlan!
                                      Frank,
                                      • frankjokeF Offline
                                        frankjokeF Offline
                                        frankjoke
                                        #930
                                        @alle
                                        Habe gerade ein update von der v2.1.4 beta (um 22:59) auf git gestellt!
                                        Der Hauptgrund ist dass ich heute das Kabel (https://www.amazon.de/gp/product/B081GDH5TM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1) geliefert bekommen habe und bin drauf gekommen dass ich die Humidity nur dem RM4P und nicht dem RM4 (mini...) einprogrammiert habe.
                                        Nun funktioniert die Temperatur und Humidity auch auf meinen RM4-Mini!
                                        Frank,
                                        • F Offline
                                          Flugschüler
                                          #931
                                          Habe auch das Kabel aber bei mir funktioniert es nicht, mit welcher app hast du den RM4 mini ins netz gestellt?
