  2. Русский
  3. ioBroker
  4. Визуализация
  5. ioBroker.vis Драйвер
  6. Виджеты hqwidgets
    2.8k
    4.9k
    4.1k
Виджеты hqwidgets
Geplant Angeheftet Gesperrt Verschoben ioBroker.vis Драйвер
55 Beiträge 8 Kommentatoren 18.8k Aufrufe
  • I Offline
    I Offline
    instalator
    @Bluefox:
    hqWidgets поправил. mqtt посмотрю `
    В версии 0.2.0? Если да то проблема актуальна:
    Uncaught TypeError: (data.actual || 0).toFixed is not a functionvis.binds.hqwidgets.button.showCenterInfo
     @ hqwidgets.js:965vis.binds.hqwidgets.button.changeState @ hqwidgets.js:1133vis.binds.hqwidgets.button.draw
     @ hqwidgets.js:1313vis.binds.hqwidgets.button.init @ hqwidgets.js:1578(anonymous function) @ hqwidgets.js:1516
    hqwidgets.js:971 hq w00159: actual = 4.81, humidityundefined, table. 1
    hqwidgets.js:965 Uncaught TypeError: (data.actual || 0).toFixed is not a functionvis.binds.hqwidgets.button.showCenterInfo
      @ hqwidgets.js:1516
    hqwidgets.js:971 hq w00160: actual = 24.3, humidity40.3, table. 1
    hqwidgets.js:971 hq w00161: actual = 25.7, humidity40.3, table. 1
    hqwidgets.js:971 hq w00162: actual = 28.1, humidity35.5, table. 1
    conn.js:592 Error: Error: can't create states object for mqtt.0.myhome.Bedroom.Humidity_room(TypeError: (data.actual || 0).toFixed is not a function)
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • I Offline
      I Offline
      instalator
      После обновления до:
      0.7.3 и 0.2.1 пока полет нормальный.
      • I Offline
        I Offline
        instalator
        Добавился виджет
        [{"tpl":"tplHqLock","data":{"visibility-cond":"==","visibility-val":1,"closedIcon":"widgets/hqwidgets/img/lockLocked.png","openedIcon":"widgets/hqwidgets/img/lockUnlocked.png",
        "popupRadius":"75","buttonRadius":"50","closeIcon":"widgets/hqwidgets/img/lockLocked.png",
        "openIcon":"widgets/hqwidgets/img/lockUnlocked.png","openDoorIcon":"widgets/hqwidgets/img/openDoor.png",
        "showTimeout":"5000","infoLeftFontSize":"12","infoFontRightSize":"12","styleNormal":"hq-button-no-background",
        "styleActive":"hq-button-no-background","oid":"javascript.0.Signalizaciya","closeValue":"true","openValue":"false","changeEffect":"swing",
        "waveColor":"","testActive":true},"style":{"left":"426px","top":"31px"},"widgetSet":"hqwidgets"}]
        Я так понимаю это для электрозамка на двери?
        А можно добавить в этот виджет индикатор замок закрыт\открыт (без возможности управления т.е. только индикация) и управление постановкой\снятием сигнализации, причем на снятие с охраны желательно
        добавить цифровую клаву с вводом пароля.
        • aurodionovA Offline
          aurodionovA Offline
          aurodionov
          он уже давно в наличии
          Пишу с пульта….
          • Alex1808A Offline
            Alex1808A Offline
            Alex1808
            Небольшое предложение.. добавить к тумблеру "ctrl,checkbox" настраиваемый индикатор фона. На пример, положение выключено оранжевый (к выбору цвета добавить серый), в положении включено зелёный.
              aurodionovA Offline
              aurodionov
              @Alex1808:
              Небольшое предложение.. добавить к тумблеру "ctrl,checkbox" настраиваемый индикатор фона. На пример, положение выключено оранжевый (к выбору цвета добавить серый), в положении включено зелёный. `
              Ещё лучше , если просто можно задать цвет отдельно вкл и выкл ,тогда можно задать что угодно
              Пишу с пульта….
              • I Offline
                I Offline
                instalator
                @aurodionov:
                @Alex1808:
                Небольшое предложение.. добавить к тумблеру "ctrl,checkbox" настраиваемый индикатор фона. На пример, положение выключено оранжевый (к выбору цвета добавить серый), в положении включено зелёный. Ещё лучше , если просто можно задать цвет отдельно вкл и выкл ,тогда можно задать что угодно
                Рисуются две картинки, и подставляются при выключенном и включенном состоянии, можно любой выключатель сделать
                [{"tpl":"tplMfdSocketCtrl","data":{"oid":"onkyo.0.audio-muting","visibility-cond":"==","visibility-val":1,"asButton":"true","gestures-offsetX":0,"gestures-offsetY":0,"icon_off":"/vis.0/bt1.png","icon_on":"/vis.0/bt0.png","visibility-oid":"","invert_state":false},"style":{"left":"359px","top":"367px","width":"90px","height":"50px"},"widgetSet":"jqui-mfd"}]
                [266_bt0.png](/assets/uploads/files/266_bt0.png)
                [266_bt1.png](/assets/uploads/files/266_bt1.png)
                • Alex1808A Offline
                  Alex1808A Offline
                  Alex1808
                  @instalator:
                  Рисуются две картинки, и подставляются при выключенном и включенном состоянии, можно любой выключатель сделать `
                  Это понятно и я себе так и делал где надо было, разговор за стандартный набор виджетов. Раз уж он есть (и это классно, когда нет времени или желания рисовать) то вот хотелось бы такой функционал, а то просто не совсем понятно домашним в каком положении тумблер включен или выключен.
                  • BluefoxB Offline
                    BluefoxB Offline
                    @aurodionov:
                    @Alex1808:
                    Здесь мы имеем место с красивым чекбоксом написанным с css. Но как только шаг влево или вправо, то это уже невозможно. К сожалению таких библиотек пруд пруди в инете и это одна из них. Нельзя поменять ни размер, ни цвет.
                    Я расширил как мог.
                    Но под все цвета и размеры это невозможно. Насчет двух цветов это интересный вариант. Но было бы лучше если бы сразу pull request пришёл.
                    Я вообще не понимаю, почему такая низкая активность людей. Из русских только installator смог врубится (1%).
                    У немцев тоже не фонтан. 3-4 человека + 1 на документации (из 1200 человек).
                    То ли я статистику неправильно собираю, и на самом деле пользователей всего 100.
                    То ли это такой проект, что позволил основной массе пользователей без знания программирования поставить и пользоваться системой (я себя тешу именно этим ответом :lol: )
                    То ли javascript не популярный, хотя гугл утверждает обратное.
                    То ли порог вхождения высокий и доки нет.
                    То ли я избаловал народ и всё делаю сам. :D …
                    • Alex1808A Offline
                      Alex1808A Offline
                      Alex1808
                      @Bluefox:
                      То ли это такой проект, что позволил основной массе пользователей без знания программирования поставить и пользоваться системой . `
                      Я себя отношу именно к этой категории, для меня код "темный лес", хорошо названия некоторых языков знаю :? Хотя имею свой сайт с "специфическим функционалом" :D и был вовлечен в несколько проектов, но по нехватки знаний программирования больше участвовал в оформлении и продвижении…
                      Целеустремленности как у тебя, можно только позавидовать... тащить такой проект в одну упряжку огромный труд, боюсь даже представить сколько работа-часов в него вложил, респект!
                      • H Offline
                        Haba
                        @Bluefox:
                        То ли это такой проект, что позволил основной массе пользователей без знания программирования поставить и пользоваться системой (я себя тешу именно этим ответом )
                        То ли я избаловал народ и всё делаю сам. … `
                        Скажу по себе и своему соседу :)
                        я больше специализируюсь на на железках (программирование микроконтроллеров), web постольку по скольку.
                        В изучении тонкостей меня сильно тормозит нехватка документации и примеров. Собираю ее по крупицам, где можно ну и тесты, тесты, тесы + наводящие вопросы :)
                        Соседа тоже подсадил, но он вообще практически чистый железячник, поэтому с верхним уровнем сильно ему помогаю.
                        оказать помощь могу, но в некоторых направлениях. Времени к сожалению мало…
                        Мне например актуальна тема MySensors в первую очередь, было дело писал под Raspberry свой сервер на PHP
                        • Alex1808A Offline
                          Alex1808A Offline
                          Alex1808
                          @Bluefox:
                          Но под все цвета и размеры это невозможно. Насчет двух цветов это интересный вариант. Но было бы лучше если бы сразу pull request пришёл. `
                          Спасибо! Всё отлично!
                          Там в редакторе только с обозначением немного недоделано, можно было обозначить как "Fabre für Aus" и "Fabre für An" (ну или без "für") (на русском не проверял) на немецком выглядит так
                          ![](</s><URL url=)http://i.imgur.com/7Uvk7A6.png" />
                          • Alex1808A Offline
                            Alex1808A Offline
                            Alex1808
                            Так как зоопарк разных устройств расширился уже прилично то вот родилась у меня такая идея, а нельзя ли расширить (или добавить отдельно) функционал температурного виджета до термостата?
                            В принципе, там всё уже есть.. выбор температуры и вентиля, осталось только добавить в каком режиме температуры он должен этот вентиль включать или выключать.
                            • BluefoxB Offline
                              BluefoxB Offline
                              @Alex1808:
                              filename="4440269e46574da79870eca772ee301b.png" index="0">~~
                              В принципе, там всё уже есть.. выбор температуры и вентиля, осталось только добавить в каком режиме температуры он должен этот вентиль включать или выключать. `
                              А как выглядят режимы? Сколько устройств, столько и режимов: auto, boost, manual, off,…
                              • Alex1808A Offline
                                Alex1808A Offline
                                Alex1808
                                @Bluefox:
                                А как выглядят режимы? Сколько устройств, столько и режимов: auto, boost, manual, off,… `
                                Я думал за простой актор, многие ставят себе на отопление 4х Канальный актор от HomeМatic (у нас), у меня тоже кстати такие стоят.
                                вот такой актор или любой другой типа МегаД и всякие беспроводные розетки термостат мог бы переключать. Областей применения можно найти много.
                                Максимальную температуру выставлять ободком, как и сейчас. Хорошо бы временные рамки, типа с 22:00 до 5:00 выкл/вкл., в другое время регулируется температурой.
                                Ну это так, мысли в слух :)
                                  MSapogov
                                  Возможно и не сюда со своей проблемой, но заключается она в следующем:
                                  Есть виджет HQwidgets - inner temperarure , так вот значение от ID Объекта передается в События только тогда, когда я именно "покручу" темпераруру в зажатой кнопкой мыши ну а потом ее отпустить. Но если при появлении регулятора значения просто нажать и отпустить в нужном месте (в нужном значении), то сбоку на сером фоне это значение запоминается, а в события не передается.
                                  Мало того, если я это значение поменяю в другом месте, то на виджете оно не меняется уже пока не перезагрузишь страницу.
                                  С HQwidgets CircleCnob - такой проблемы нет.
                                  • BluefoxB Offline
                                    BluefoxB Offline
                                    @MSapogov:
                                    С HQwidgets CircleCnob - такой проблемы нет. `
                                    Есть проблема если установлены hqWidgets и knob одновременно. У тебя оба установлены?
                                      MSapogov
                                      @Bluefox:
                                      @MSapogov:
                                      С HQwidgets CircleCnob - такой проблемы нет. Есть проблема если установлены hqWidgets и knob одновременно. У тебя оба установлены?
                                      ? Не понял ??? inner temperarure и circleknob находятся в HQwidgets.
                                      Управление одним и тем-же элементом? Просто на экране?
                                      Они у меня на разных страницах и управляют разными объектами.
                                      PS: обновил до 1.0.4. Изменения:
                                      Но если при появлении регулятора значения просто нажать и отпустить в нужном месте (в нужном значении), то сбоку на сером фоне это значение запоминается, а в события не передается. - без изменений.
                                      Если я это значение поменяю в другом месте, то на виджете оно уже стало меняется.
                                      PPS: Оказывается это (проблему) можно повторить только на компе и только мышкой, т.к. на телефоне с тачем это повторить невозможно (нет там мышки).
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        @MSapogov:
                                        @Bluefox:
                                        @MSapogov:
                                        PPS: Оказывается это (проблему) можно повторить только на компе и только мышкой, т.к. на телефоне с тачем это повторить невозможно (нет там мышки). `
                                        Подержи 300мс и значение поставится. Это сделано специально.
                                          MSapogov
                                          @Bluefox:
                                          Подержи 300мс и значение поставится. Это сделано специально. `
                                          Да это я понял… Но если не передвигать по "кружку", то значение не передается.
