  2. English
  3. ioBroker general
  4. Telegram SOLVED
    6.6k
Telegram SOLVED
Geplant Angeheftet Gesperrt Verschoben ioBroker general
telegram
10 Beiträge 4 Kommentatoren 1.8k Aufrufe 2 Beobachtet
    ap2017
    schrieb am zuletzt editiert von ap2017
    I use telegram to send notifications in case of any issues in the house, but telegram has very annoying feature - every morning at 5.04 am it sends notifications: Restarting and then Started! Is there a way to disable it?
    SOLVED thanks to community. To get rid of starting messages go to telegram instance properties, then go to messages tab and delete "-" in the message body. Apparently, "-" means default message instead of expected no message.
      Michaelnorge
      No problem, here you can turn off....
      alt text
      • Smart mit: Rasp 4B / ioBroker / Conbee2 / Trådfri / Xiaomi / HUE / Logitech Harmony / Aqara / Easee Wallbox / Hyundai Ioniq / Alexa / Google Home / Fully Kiosk / VIS
      • M Michaelnorge
        alt text
        ap2017
        @Michaelnorge In my system schedule for telegram is disabled
          Adnim
            Adnim
            schrieb am zuletzt editiert von Adnim
            Goto Telegramm Options, Messages, Delete Start and Stop Messages ->as in German PIC above
            I suggest to get that Schedule on, to avoid Problems with Adapter...
            A 2 Antworten Letzte Antwort
            • A Adnim
              ap2017
              @Adnim I don't have start/stop messages configured within telegram adapter configuration
              But, when I switch to Expert mode, I started to see scheduler setting for telegram as suggested by Michaelnorge. I reset the setting, hopefully it will work.
              • A Adnim
                ap2017
                @Adnim I don't have start and stop messages setup, so why I am receiving them?
                X 1 Antwort Letzte Antwort
                • A ap2017
                  X Offline
                  X Offline
                  Xyolyp
                  @ap2017 the "-" does not mean no message but default message. If you completely empty out the input fields you won't get any messages.
                  • A ap2017
                    Michaelnorge
                    @ap2017 But your expert-mode is turned on?
                    alt text
                    • X Xyolyp
                      ap2017
                      @Xyolyp Thank you!
