  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Node red
    5.9k
Node red
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
74 Beiträge 8 Kommentatoren 25.2k Aufrufe
  • I Offline
    I Offline
    instalator
    Пока сделал так:
     var h = context.global.Hot_curr;
     h = '' + h;
     msg.Hot_curr = h.substr(0, h.length - 2);
     var c = context.global.Cold_curr;
     c = '' + c;
     msg.Cold_curr = c.substr(0, c.length - 2)
    :D
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • BluefoxB Offline
      BluefoxB Offline
      @instalator:
      Пока сделал так:
       h = '' + h;
       c = '' + c;
      :D `
      Ну в принципе именно так:
       var h = context.global.Hot_curr.toString();
      • I Offline
        I Offline
        instalator
        Как происходит взаимодействие из нодрэда с другими драйверами?
        Например как из нодреда отправить сообщение Pushover.
        • I Offline
          I Offline
          instalator
          Написал условие, переменная меняет свое состояние но клиенту mqtt не уходит команда, что я делаю не так?
          [{"id":"acda5939.5325a8","type":"ioBroker in","name":"myhome/Bathroom/Humidity_room","topic":"mqtt.0.myhome.Bathroom.Humidity_room","payloadType":"value","x":167,"y":131,"z":"865a081c.79a5f8","wires":[["20e9eada.df1616","207b73cb.df848c"]]},{"id":"ffc2e396.003d2","type":"ioBroker out","name":"myhome/Bathroom/Ventilator","topic":"mqtt.0.myhome.Bathroom.Ventilator","ack":"true","autoCreate":"false","x":677,"y":139,"z":"865a081c.79a5f8","wires":[]},{"id":"20e9eada.df1616","type":"debug","name":"","active":true,"console":"false","complete":"false","x":328,"y":292,"z":"865a081c.79a5f8","wires":[]},{"id":"207b73cb.df848c","type":"function","name":"","func":"if (msg.payload > 56){\n    msg.payload = 1;\n}\nelse {\n     msg.payload = 0;\n}\nreturn msg;","outputs":1,"valid":true,"x":431,"y":127,"z":"865a081c.79a5f8","wires":[["9fe832be.6017d","ffc2e396.003d2"]]},{"id":"9fe832be.6017d","type":"debug","name":"1111111111111111","active":true,"console":"false","complete":"payload","x":609,"y":219,"z":"865a081c.79a5f8","wires":[]}]
          • I Offline
            I Offline
            instalator
            @instalator:
            Написал условие, переменная меняет свое состояние но клиенту mqtt не уходит команда, что я делаю не так? `
            Понял в чем была ошибка, нужно было в выводе поставить не value а command.
            Возникает следующий вопрос.
            Как написать чтобы данные отсылались только один раз при срабатывание условия а не постоянно слались на клиента?
            приведенный код срабатывает только раз т.к. flag постоянно устанавливается в 0. В ардуино хорошо можно при инициализации объявить переменные, а как поступить в нодред?
            var flag = 0;
            if (msg.payload > 56 && flag === 0){
                msg.payload = 1;
                var flag = 1;
                return msg;
            else if (msg.payload < 56 && flag === 1){
                 msg.payload = 0;
                 var flag = 0;
                 return msg;
            • BluefoxB Offline
              BluefoxB Offline
              @instalator:
              @instalator:
              var flag = 0;
                  msg.payload = 1;
                  var flag = 1;
                  return msg;
                   msg.payload = 0;
                   var flag = 0;
                   return msg;
              Поменяй на
              if (context.global.flag === undefined) {
                  context.global.flag = msg.payload > 56;
              if (msg.payload > 56 && !context.global.flag){
                  msg.payload = 1;
                  context.global.flag= true;
                  return msg;
              else if (msg.payload < 56 && context.global.flag){
                   msg.payload = 0;
                   context.global.flag= false;
                   return msg;
              • I Offline
                I Offline
                instalator
                @Bluefox:
                Поменяй на
                    msg.payload = 1;
                    return msg;
                     msg.payload = 0;
                     return msg;
                Спасибо заработало. Вчера начинал уже мудрить с глобальными переменными, думал может есть другой способ.
                Как из нодреда отправить сообщение на Pushover?
                • I Offline
                  I Offline
                  instalator
                  @instalator:
                  Например как из нодреда отправить сообщение Pushover. `
                  Так и не понял как отправить сообщение. Или только через javascript?
                  • I Offline
                    I Offline
                    instalator
                    @Bluefox:
                    Вроде работал код, сегодня решил проверить ругается на toString. Было обновление?
                    Добавлено:
                    Нодред не подхватывает значения счетчиков воды.
                    От электросчетчика подхватывает.
                    [{"id":"249fe99a.db6016","type":"debug","name":"","active":true,"console":"false","complete":"true","x":701,"y":802,"z":"2c2981e2.d3d67e","wires":[]},{"id":"4ad0b93e.b52f48","type":"function","name":"Текущие показания Холодной воды","func":"context.global.Cold_curr = msg.payload.val;\nreturn msg;","outputs":1,"valid":true,"x":426,"y":789,"z":"2c2981e2.d3d67e","wires":[["249fe99a.db6016"]]},{"id":"c6b46d56.394b9","type":"function","name":"Текущие показания Горячей воды","func":"context.global.Hot_curr = msg.payload.val;\nreturn msg;","outputs":1,"valid":true,"x":420,"y":846,"z":"2c2981e2.d3d67e","wires":[["249fe99a.db6016"]]},{"id":"4c6b878d.b39478","type":"ioBroker in","name":"myhome/Mother/Electro_counter","topic":"mqtt.0.myhome.Mother.Electro_counter","payloadType":"value","x":134,"y":904,"z":"2c2981e2.d3d67e","wires":[["269c6eea.d96392"]]},{"id":"269c6eea.d96392","type":"function","name":"Текущие показания Электросчетчика","func":"context.global.Electro_curr = msg.payload;\nreturn msg;","outputs":1,"valid":true,"x":436,"y":904,"z":"2c2981e2.d3d67e","wires":[object Object]},{"id":"fca376ea.035c88","type":"ioBroker in","name":"myhome/Bathroom/Cold_water","topic":"mqtt.0.myhome.Bathroom.Cold_water","payloadType":"value","x":128.5,"y":789,"z":"2c2981e2.d3d67e","wires":[["4ad0b93e.b52f48"]]},{"id":"3729a205.c8d65e","type":"ioBroker in","name":"myhome/Bathroom/Hot_water","topic":"mqtt.0.myhome.Bathroom.Hot_water","payloadType":"value","x":126,"y":846,"z":"2c2981e2.d3d67e","wires":[["c6b46d56.394b9"]]}]
                    Добавлено:
                    Чудеса, сегодня все работает ок.
                    • I Offline
                      I Offline
                      instalator
                      Как через Node red создать переменную в iobrokere?
                      • I Offline
                        I Offline
                        instalator
                        Node red вообще заглючил.
                        Завис на http reqest.
                        Код не подсвечивает.
                        Перезапустил в логе ошибки
                        ! node-red-0 2015-06-17 10:49:38 warn
                        ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] –----------------------------------------
                        ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [redisout] Error: Cannot find module 'redis'
                        ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [tail] Info : Currently not supported on Windows.
                        ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node.
                        ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
                        ! node-red-0 2015-06-17 10:49:36 warn
                        ! node-red-0 2015-06-17 10:49:36 warn js-bson: Failed to load c++ bson extension, using pure JS version
                        ! node-red-0 2015-06-17 10:49:34 warn
                        ! node-red-0 2015-06-17 10:49:34 warn js-bson: Failed to load c++ bson extension, using pure JS version
                          bondrogeen
                          @instalator:
                          Как через Node red создать переменную в iobrokere? `
                          Возник тот же вопрос.
                          В корне получается создать (пример test) , а вот чтобы добавить сразу топик нет (пример stat/test)
                          И вообще где можно почитать про создание переменных "для чайников" в iobroker?
                          • I Offline
                            I Offline
                            instalator
                            @bondrogeen:
                            И вообще где можно почитать про создание переменных "для чайников" в iobroker? А если так - stat.test ? > И вообще где можно почитать про создание переменных "для чайников" в iobroker? `
                            В JS например так - createState('Climat.Mode_Pritochka_GuestRoom', '');
                              bondrogeen
                              @instalator:
                              @bondrogeen:
                              В iobrokere как создать переменную вроде-бы научился.
                              У меня при работе с ним возникло ложное, как сейчас понял, восприятия древовидной структуры папок и под папок где хранятся переменные.
                              Это сейчас я уже вроде-бы понял, что это переменные типа «object» и сделана это для удобства поиска.
                              Я правильно понял? если нет поправьте меня.
                              Получается нужно создавать переменную test.test.test1, test.test.test2 и т.д.
                              тогда получится
                              test
                              ____test
                              ________test1 1
                              ________test2 2
                              В NODE RED не хочет.
                              Не получается, как только делаешь точку в топике, то не создает переменную вообще.
                              Просто "test" создает переменную и значение.
                              Хотел настроить чтобы NODE RED сам создавал переменные в iobrokere.
                              • E Offline
                                electric69
                                Через консоль не устанавливается node-red. Права chmod 777 для папки /opt/iobroker. Версии nodejs v4.4.4 npm 2.15.1.
                                • E Offline
                                  electric69
                                  Однако через WEB-интерфейс драйвер устанавливается, но не работает, в логе видно как циклически падает с предупреждениями.
                                  Лог:
                                  ! node-red.0 2016-05-10 10:59:57 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:57 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:57 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:57 warn node-red.0 node-red.0 2016-05-10 10:59:57 warn node-red.0 ^ node-red.0 2016-05-10 10:59:57 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:57 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:57 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:52 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:52 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:52 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:52 warn node-red.0 node-red.0 2016-05-10 10:59:52 warn node-red.0 ^ node-red.0 2016-05-10 10:59:52 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:52 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:52 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:47 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:47 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:47 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:47 warn node-red.0 node-red.0 2016-05-10 10:59:47 warn node-red.0 ^ node-red.0 2016-05-10 10:59:47 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:47 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:46 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:41 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:41 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:41 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:41 warn node-red.0 node-red.0 2016-05-10 10:59:41 warn node-red.0 ^ node-red.0 2016-05-10 10:59:41 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:41 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:41 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:36 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:36 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:36 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:36 warn node-red.0 node-red.0 2016-05-10 10:59:36 warn node-red.0 ^ node-red.0 2016-05-10 10:59:36 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:36 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:36 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:31 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:31 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:31 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:31 warn node-red.0 node-red.0 2016-05-10 10:59:31 warn node-red.0 ^ node-red.0 2016-05-10 10:59:31 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:31 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:31 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:26 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:26 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:26 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:26 warn node-red.0 node-red.0 2016-05-10 10:59:26 warn node-red.0 ^ node-red.0 2016-05-10 10:59:26 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:26 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:26 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:21 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:21 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:21 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:21 warn node-red.0 node-red.0 2016-05-10 10:59:21 warn node-red.0 ^ node-red.0 2016-05-10 10:59:21 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:21 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:20 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:15 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:15 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:15 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:15 warn node-red.0 node-red.0 2016-05-10 10:59:15 warn node-red.0 ^ node-red.0 2016-05-10 10:59:15 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:15 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:15 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:10 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:10 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:10 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:10 warn node-red.0 node-red.0 2016-05-10 10:59:10 warn node-red.0 ^ node-red.0 2016-05-10 10:59:10 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:10 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:10 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:05 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:05 warn node-red.0 ^ Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.j node-red.0 2016-05-10 10:59:05 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:05 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:05 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:00 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:00 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:00 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:00 warn node-red.0 node-red.0 2016-05-10 10:59:00 warn node-red.0 ^ node-red.0 2016-05-10 10:59:00 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:00 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:59 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:58:54 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:58:54 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:58:54 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:58:54 warn node-red.0 node-red.0 2016-05-10 10:58:54 warn node-red.0 ^ node-red.0 2016-05-10 10:58:54 warn node-red.0 throw err; node-red.0 2016-05-10 10:58:54 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:54 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:58:49 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:58:49 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:58:49 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:58:49 warn node-red.0 node-red.0 2016-05-10 10:58:49 warn node-red.0 ^ node-red.0 2016-05-10 10:58:49 warn node-red.0 throw err; node-red.0 2016-05-10 10:58:49 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:49 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red-0 2016-05-10 10:58:44 info node-red exited with 1 node-red-0 2016-05-10 10:58:44 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:44 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:44 warn at Function.Module._load (module.js:300:12) node-red-0 2016-05-10 10:58:44 warn at Module.load (module.js:343:32) node-red-0 2016-05-10 10:58:44 warn at Object.Module._extensions..js (module.js:416:10) node-red-0 2016-05-10 10:58:44 warn at Module._compile (module.js:409:26) node-red-0 2016-05-10 10:58:44 warn at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/fs-extra/node_modules/rimraf/node_modules/glob/node_modules/minimatch/minimatch.js:10:14) node-red-0 2016-05-10 10:58:44 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:44 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:44 warn at Function.Module._load (module.js:276:25) node-red-0 2016-05-10 10:58:44 warn at Function.Module._resolveFilename (module.js:325:15) node-red-0 2016-05-10 10:58:44 warn Error: Cannot find module 'brace-expansion' node-red-0 2016-05-10 10:58:44 warn node-red-0 2016-05-10 10:58:44 warn ^ node-red-0 2016-05-10 10:58:44 warn throw err; node-red-0 2016-05-10 10:58:44 warn module.js:327 node-red-0 2016-05-10 10:58:44 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js admin-0 2016-05-10 10:58:42 info successful connection to socket.io from ::ffff:109.194.66.17 node-red-0 2016-05-10 10:58:39 info node-red exited with 1 node-red-0 2016-05-10 10:58:39 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:39 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:39 warn at Function.Module._load (module.js:300:12) node-red-0 2016-05-10 10:58:39 warn at Module.load (module.js:343:32) node-red-0 2016-05-10 10:58:39 warn at Object.Module._extensions..js (module.js:416:10) node-red-0 2016-05-10 10:58:39 warn at Module._compile (module.js:409:26) node-red-0 2016-05-10 10:58:39 warn at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/fs-extra/node_modules/rimraf/node_modules/glob/node_modules/minimatch/minimatch.js:10:14) node-red-0 2016-05-10 10:58:39 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:39 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:39 warn at Function.Module._load (module.js:276:25) node-red-0 2016-05-10 10:58:39 warn at Function.Module._resolveFilename (module.js:325:15) node-red-0 2016-05-10 10:58:39 warn Error: Cannot find module 'brace-expansion' node-red-0 2016-05-10 10:58:39 warn node-red-0 2016-05-10 10:58:39 warn ^ node-red-0 2016-05-10 10:58:39 warn throw err; node-red-0 2016-05-10 10:58:39 warn module.js:327 node-red-0 2016-05-10 10:58:38 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red-0 2016-05-10 10:58:38 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.node-red iobroker 2016-05-10 10:58:38 info exit 0 iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0 created host-vm32test 2016-05-10 10:58:38 info instance system.adapter.node-red.0 started with pid 3965 host-vm32test 2016-05-10 10:58:38 info object change system.adapter.node-red.0 iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.alive created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.connected created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memHeapUsed created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memHeapTotal created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memRss created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.uptime created iobroker 2016-05-10 10:58:38 info host.vm32test object node-red.0 created iobroker 2016-05-10 10:58:38 info host.vm32test create instance node-red iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red created iobroker 2016-05-10 10:58:38 info upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html iobroker 2016-05-10 10:58:38 info upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png iobroker 2016-05-10 10:58:38 info got /opt/iobroker/node_modules/iobroker.node-red/admin iobroker 2016-05-10 10:58:38 info host.vm32test install adapter node-red iobroker 2016-05-10 10:58:37 info add node-red !
                                  • V Offline
                                    V Offline
                                    VictorS
                                    Добрый вечер,
                                    столкнулся с загадочной проблемой. nodered падает если добавить вот такую ноду:
                                    "id": "b63c97fe.3efc08",
                                    "type": "mqtt in",
                                    "z": "c608cffb.e48a7",
                                    "name": "Ver1 Light",
                                    "topic": "/sh-esp-ver1/output14",
                                    "qos": "2",
                                    "broker": "15a9d586.42d9ba",
                                    "x": 130,
                                    "y": 248,
                                    "wires": [
                                    "id": "15a9d586.42d9ba",
                                    "type": "mqtt-broker",
                                    "z": "",
                                    "broker": "localhost",
                                    "port": "1883",
                                    "clientid": "nodered.0",
                                    "usetls": false,
                                    "compatmode": true,
                                    "keepalive": "60",
                                    "cleansession": true,
                                    "willTopic": "",
                                    "willQos": "0",
                                    "willPayload": "",
                                    "birthTopic": "",
                                    "birthQos": "0",
                                    "birthPayload": ""
                                    т.е. input от mqtt завязанную на gpio от esp. при изменения состояния с "0" -> "1" или "1" -> "0" nodered отваливается от mqtt в логе:
                                    warn Client error [nodered.0]: Error: Invalid message id
                                    потом соединение восстанавливается, значение из mqtt в ноду получено.
                                    где я что сделал не так?
                                    • I Offline
                                      I Offline
                                      instalator
                                      @VictorS:
                                      Добрый вечер,
                                      "type": "mqtt in",
                                      "qos": "2",
                                      "x": 130,
                                      "y": 248,
                                      "wires": [
                                      "z": "",
                                      "port": "1883",
                                      "usetls": false,
                                      "compatmode": true,
                                      "keepalive": "60",
                                      "willTopic": "",
                                      "willQos": "0",
                                      "willPayload": "",
                                      "birthTopic": "",
                                      "birthQos": "0",
                                      "birthPayload": ""
                                      где я что сделал не так? `
                                      Попробуй использовать не mqtt, а объект из иоб
                                      • V Offline
                                        V Offline
                                        VictorS
                                        @instalator:
                                        Попробуй использовать не mqtt, а объект из иоб `
                                        Спасибо, помогло :)
                                        Еще вопросы:
                                        1. В настройках nodered есть "Convert ioBroker values to string" - какой в этом смысл? Удобнее наверное принимать значения в том виде в котором они в IOB?
                                        2. По настройкам выходов с IOB с nodered. Type ("command", "value"). А в чем разница?
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          @VictorS:
                                          @instalator:
                                          Спасибо, помогло :)
                                          Еще вопросы:
                                          2. По настройкам выходов с IOB с nodered. Type ("command", "value"). А в чем разница? `
                                          Первую настройку я что то не могу найти. :lol:
                                          А вот вторую я попытался объяснить тут: https://github.com/ioBroker/ioBroker/wi … d-statuses
