Salamiofen Steuerung mit Blockly
so da bin ich noch mal
tag 1 wehre dann so
<xml xmlns="http://www.w3.org/1999/xhtml"><block id="{3/VQm.N(J1W92L#xH" type="schedule" y="-737" x="-2113"><field name="SCHEDULE">*/2 * * * *</field> <statement name="STATEMENT"><block id="eh.0FCah#{.P
1kjIn3Z" type="comment"><field name="COMMENT">tag 1</field>
<next><block id="vkN3sS;kqw(oUDfy)q" type="controls_if"><mutation elseif="1"></mutation> <value name="IF0"><block id="FyB}a_/R6P8jX!R;XhK~" type="logic_compare"><field name="OP">LTE</field> <value name="A"><block id="u^:ZzTfjai0HmB*.o8dW" type="get_value"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.MEQ1574232.1.TEMPERATURE</field></block></value> <value name="B"><block id="?yo4-Gj_kZ|I58x|(%AQ" type="math_number"><field name="NUM">18</field></block></value></block></value> <statement name="DO0"><block id="lNE;htd0ndnDx=.(M-SB" type="control"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.2.CUX9001002.1.STATE</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block id="x=sm1F]CrEB)xR}Ax%KE" type="logic_boolean"><field name="BOOL">TRUE</field></block></value></block></statement> <value name="IF1"><block id="K;A~x,S)ZMm?YnN078-_" type="logic_compare"><field name="OP">GTE</field> <value name="A"><block id="cy=tOBwC.0?W@F~~.-RB" type="get_value"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.MEQ1574232.1.TEMPERATURE</field></block></value> <value name="B"><block id="a)3SM)|S_]P:j{4!4Cw-" type="math_number"><field name="NUM">20</field></block></value></block></value> <statement name="DO1"><block id="F?z|7j.*WR;~n#OAlT7}" type="control"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.2.CUX9001002.1.STATE</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block id="I)/mo]kn^3gbjzZ0(rz5" type="logic_boolean"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></statement></block></xml> ! tag 2 ! <xml xmlns="http://www.w3.org/1999/xhtml"><block id="#wfGqi](02!Tg{1,h=Lx" type="comment" y="-863" x="-2288"><field name="COMMENT">tag 2</field> <next><block id="O)r(KJx*R_}F?HSle:nX" type="schedule"><field name="SCHEDULE">*/2 * * * *</field> <statement name="STATEMENT"><block id="ZjgI4;y4j4A|WAwbr@sL" type="controls_if"><value name="IF0"><block id="8tEn{^x./vagKqfC?mb;" type="logic_compare"><field name="OP">LTE</field> <value name="A"><block id="cq_
.MKrc=pg;v#/SR" type="get_value"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.MEQ1574232.1.TEMPERATURE</field></block></value> <value name="B"><block id="xUs~9jq+R^9mEiAF~~kx" type="math_number"><field name="NUM">21</field></block></value></block></value> <statement name="DO0"><block id="l.evk2IGThrB*?WY%3VN" type="control"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.2.CUX9001002.1.STATE</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block id="gJhDPy9NO,b6VVkFFoJi" type="logic_boolean"><field name="BOOL">TRUE</field></block></value></block></statement> <next><block id="
.FNQ-ycN8EAj46=K)NR" type="controls_if"><value name="IF0"><block id="CkX4^Q.3BUt%U*}UxG*A" type="logic_compare"><field name="OP">GTE</field>
<value name="A"><block id="[/yPwnf6uf]%JO]Krp!h" type="get_value"><field name="ATTR">val</field>
<value name="B"><block id="SHJf@hc@10V!g}z/E5q" type="math_number"><field name="NUM">22</field></block></value></block></value> <statement name="DO0"><block id="w(Lms]/mnvrkxUi60T:h" type="control"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.2.CUX9001002.1.STATE</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block id="g~~WA_K1e4aj2Vt=B2^m" type="logic_boolean"><field name="BOOL">FALSE</field></block></value></block></statement> <next><block id="^k]+nWN~~s@x!b(kdA[x" type="controls_if"><value name="IF0"><block id="[,2_]h%dN)kv5sr{Dh3M" type="logic_compare"><field name="OP">LTE</field> <value name="A"><block id="Hcw:[d~:K:s~@I3BA~%[" type="get_value"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.MEQ1574232.1.HUMIDITY</field></block></value> <value name="B"><block id="7Gg[3ewLNdjzew
C/Z%E" type="math_number"><field name="NUM">93</field></block></value></block></value>
<statement name="DO0"><block id="MkznoPf,lI%|ZTxZZ:;" type="control"><mutation delay_input="false"></mutation>
<field name="OID">hm-rpc.2.CUX9001001.1.STATE</field>
<value name="VALUE"><block id="KaXF]/SJYU9!EMtKC;hC" type="logic_boolean"><field name="BOOL">TRUE</field></block></value></block></statement>
<next><block id="22V.YlwEV6]cJ:9+;,{" type="controls_if"><value name="IF0"><block id="b/3Yy8Rt~S})|w)y6Ci" type="logic_compare"><field name="OP">GTE</field> <value name="A"><block id="SQSH*N=fEW=XPQAV0^f)" type="get_value"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.MEQ1574232.1.HUMIDITY</field></block></value> <value name="B"><block id="mW3}?D=r8p{wi}|*;.w(" type="math_number"><field name="NUM">94</field></block></value></block></value> <statement name="DO0"><block id="_4W-RrpmMC[X8j;wYxq+" type="control"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.2.CUX9001001.1.STATE</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block id="hLLno-@lMjc8PWsn-]Fd" type="logic_boolean"><field name="BOOL">FALSE</field></block></value></block></statement> <next><block id="dbru#kEN[1:/4|KuYxhK" type="controls_if"><value name="IF0"><block id="#,7}@:7R8I-mF?LBxV1D" type="logic_compare"><field name="OP">LTE</field> <value name="A"><block id="zAjxz)KXSZmukA3muSDw" type="get_value"><field name="ATTR">val</field> <field name="OID">hm-rpc.0.MEQ1574232.1.TEMPERATURE</field></block></value> <value name="B"><block id="L_aPT(/AR9L7F4a3o,d4" type="math_number"><field name="NUM">20</field></block></value></block></value> <statement name="DO0"><block id="swk_9V=AdMM}hEWTyw)m" type="control"><mutation delay_input="false"></mutation> <field name="OID">hm-rpc.2.CUX9001004.1.STATE</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"><block id="D|=C7WVZ1MSqd8bcHP;j" type="logic_boolean"><field name="BOOL">FALSE</field></block></value></block></statement> <next><block id="Fc#j7GuuS?)d*8v}-{tM" type="controls_if"><value name="IF0"><block id="AQpNyw+G(|Cph_acBT|W" type="logic_compare"><field name="OP">GTE</field> <value name="A"><block id=",:[moCDrO
ub812PIHbE" type="get_value"><field name="ATTR">val</field>
<value name="B"><block id="i75{fawm=0Gj.nQclDc" type="math_number"><field name="NUM">22</field></block></value></block></value>
<statement name="DO0"><block id="m![ww8;!o*_50zHH6+-." type="control"><mutation delay_input="false"></mutation>
<value name="VALUE"><block id="@OeQw9nvEDhZHv2/D`y" type="logic_boolean"><field name="BOOL">TRUE</field></block></value></block></statement></block></next></block></next></block></next></block></next></block></next></block></statement>
<next><block id="9]iE?mg^o/CGIEnFdg06" type="timeouts_setinterval"><field name="NAME">Intervall</field>
<field name="INTERVAL">360</field>
<field name="UNIT">min</field>
<statement name="STATEMENT"><block id="bOYqf!hbva}#fCwbe6~#" type="timeouts_settimeout"><field name="NAME">timeout</field>
<field name="DELAY">15</field>
<statement name="STATEMENT"><block id="j|A)%1aY-F6!Y=ts89u" type="control"><mutation delay_input="false"></mutation>
<field name="OID">hm-rpc.2.CUX9001005.1.STATE</field>
<value name="VALUE"><block id="vRyhs(HGdZP|=QIc:lqD" type="logic_boolean"><field name="BOOL">TRUE</field></block></value></block></statement></block></statement>
<next><block id="zt|jem;cu#Myd2MIYXH}" type="timeouts_setinterval"><field name="NAME">Intervall2</field>
<field name="INTERVAL">60</field>
<statement name="STATEMENT"><block id="t1BT}Du%3b3B#ie]/JSb" type="timeouts_settimeout"><field name="NAME">timeout2</field>
<statement name="STATEMENT"><block id="*WBH8izDX)KByl,4X?=k" type="control"><mutation delay_input="false"></mutation>
<field name="OID">hm-rpc.2.CUX9001003.1.STATE</field>
<value name="VALUE"><block id="P=~.Py%_MZ[|rEONGd/S" type="logic_boolean"><field name="BOOL">TRUE</field></block></value></block></statement></block></statement></block></next></block></next></block></next></block></xml>hoffe mal das das richtig ist so ****mod edit: bitte in spoiler + code tag****
bitte naestes mal in einen spoiler + code tag posten das ist uebersichtlicher.
Koenntest du bitte auch einen screenshot posten das ist einfacher drauf zu reagieren zb aus tapatalk.
Wen ich das richtig verstehe moechtest du ein script welches die bestehende ausfuehrt ?
Blicke irgendwie noch nicht ganz durch was genau das problem und deine frage ist sorry
screenshot am pc wie man das macht weiß ich nicht
Wie soll ich das denn noch besser erklären ich starte das Programm und alle 24h ein neues Programme starten allso Tag1 , Tag2 und immer so weiter bis Tag 30
Warum triggerst du auf Zeit und nicht auf die Änderung der Temperatur? Und was ist mit einer eventuellen Hysterese, oder steigt die Temperatur sofort nicht mehr weiter, wenn die Heizung (CuxD-Gerät?) ausgeht?
Für Screenshot am PC geht bei neueren Windows Versionen Snipping Tool!
Enrico
screenshot am pc wie man das macht weiß ich nicht `
Windows :
Alt + Druck, um aktuelles / aktives Fenster in die Zwischenablage zu kopieren
Druck, um den ganzen Bildschirm (Bildschirme) in die Zwischenablage zu kopieren
Mac:
Shift + Command (Apfel) + 4, und zu kopierenden Ausschnitt zu markieren. Screenshot wird (normalerweise) auf Desktop abgelegt.
Diese Info hätte Dir aber Tante Google auch geben können [emoji6]
Gruß,
Eric
Von unterwegs getippert
Wie soll ich das denn noch besser erklären ich starte das Programm und alle 24h ein neues Programme starten allso Tag1 , Tag2 und immer so weiter bis Tag 30 `
ok also stimmt meine vermutung das du 30 scripte hast und
Tag 1 = Script 1
Tag 2 = Script 2
Tag 3 = Script 3
und dass moechtest du uber ein seperates script realisieren richtig ?
Ja so wollte ich das machen
Ja so wollte ich das machen `
was mir dazu einfaellt:
ein object erstellen was den tag kent (1,2,3 usw)
jeden tag dieses object + 1
per IF abfragen diesen wert auslesen und dan das dazugehoerige script starten
Bei Tag 2 hast du zwei verschiedene Geräte, die auf die Tempertur reagieren, sind das zwei Heizungen? Spielt es eigentlich eine Rolle, wann genau am Tag der erste Tag beginnt, oder ist es nicht so wichtig, ob der Reifeprozess um 8 Uhr morgens oder abends gestartet wird. Oder muss diese Startzeit auch berücksichtgt werden bei den Wechseln zwischen den einzelnen Tagen??
Du kommst mit sehr wenig Infos um die Ecke, du siehst es gibt schon welche, die dir helfen wollen, aber ohne genauere Infos wird das nichts, da wir nicht alle unsere Salami selbst produzieren!
So wie @Dutchman das grad geschrieben hat würde ich auch anfangen, dazu wäre aber eben die Beantwortung meiner Frage interessant.
Enrico
Ja bei Tag 2 sind es zwei Geräte einmal Heizung und Kühlung ist es zu warm geht die Kühlung an wird es zu kalt geht Kühlung aus und Heizung an
Startzeit muss nicht berücksichtigt werden nur dann 24h durchlaufen und dann auf das näste Programm umschalten und dann wider 24h durchlaufen
ok ich probier dar mal was siehe blockly, meine theorie:
ich mache mir ein object welches jeden tag um 23:59 + 1 gesetzt wird (also soll tag 1, 2, 3 usw darstellen)
in einem trigger kan ich diesen wert auf 1 setzen
in einem anderen trigger verarbeite ich diese werte um damit das script einzuschalten (und das vom vorigen tag aus)
ist mal ein anfang da mus noch mehr logic rein wie eine variable ob das ganze laeuft und nach 30 tagen aus usw aber wollte erstmal einen ansat machen.
Ja bei Tag 2 sind es zwei Geräte einmal Heizung und Kühlung ist es zu warm geht die Kühlung an wird es zu kalt geht Kühlung aus und Heizung an `
Ok, danke. Und was ist mit einer möglichen Hysterese? Wie genau muss die Temperatur sein? Normalerweise ist es ja so, dass die Temperatur noch ein wenig weiter steigt/fällt, wenn die Heizung/Kühlung ausgestellt wird, ist das wichtig?
Startzeit muss nicht berücksichtigt werden nur dann <u>24h durchlaufen</u> und dann auf das näste Programm umschalten und dann <u>wider 24h durchlaufen</u> `
Das war ja die Frage, wenn ich um 8 Uhr morgens das Programm starte sind es ja entweder 16h oder eben 40h bis zum nächsten Umschalten des Tages und bei 8 Uhr abends nur 4h bzw 28h! :?:
Enrico
Also wenn ich es zum Beispiel um 17 Uhr starte soll es bis zum nächsten Tag 17 Uhr laufen also 24 h laufen laufen
Also wenn ich es zum Beispiel um 17 Uhr starte soll es bis zum nächsten Tag 17 Uhr laufen also 24 h laufen laufen `
Genau das meinte ich , also muss die Startzeit beim Reife-Tageswechsel berücksichtigt werden!
Was ist mit der Hysterese???
Enrico
Wie meinst du das mit der hysterse
Das hatte ich doch weiter oben schon geschrieben, meine Frage dazu war, wie genau die Temperatur eingehalten werden muss?! Bei Heizungen ist es meist so, dass die Temperatur noch etwas weiter steigt, wenn die Heizung ausgeht und andersherum die Temperatur noch etwas fällt, wenn die Heizung angegangen ist.
Enrico
Naja so plus,minus 2-3 Grad geht noch
Könnte mir mal bitte einer weiter helfen komme überhaupt nicht weiter
Könnte mir mal bitte einer weiter helfen komme überhaupt nicht weiter `
Du bist wahrscheinlich im Weihnachtsstress untergegangen.
30 Programme für 30 Tage finde ich "uncool". 8-)
Aber jetzt bist Du erstmal wieder mit Infos dran.
Ist das Foto der Reifetabelle die Grundlage?
Tag 1 bis 15 diverse Schaltungen
Tag 16 bis 22 einheitliche Schaltungen
Tag 23 bis 30 einheitliche Schaltungen
[EDIT] Habe gerade Deinen Blockly Export gefunden. Schaltungen sind mir jetzt klar.
Womit prüfst Du Temperatur und Luftfeuchtigkeit?
Womit regelst Du die Temperatur.
Womit schaltest Du den Absauglüfter und die Luftzirkulation?
Wie soll das Verhältnis Temperatur und Luftfeuchtigkeit geregelt werden?
Oder ist nur die Temperatur ausschlaggebend?
Fragen über Fragen….
Schön das es weiter geht also schalten und messen alles mit homematic Geräte
Und die Reifetabelle ist die Grundlagen
