Raspbian light Stretch für Raspberry Pi 2/3 All-In-One mit piVCCU
mit dem Win32Diskmanager das Image aus dem Download bereich aufgespielt.
Danach das Password geändert.
reboot
Expand filesystem (Ohne Fehler und über die Konsole geprüft)
sudo reboot
und zum Schluss:
sudo apt-get update && sudo apt-get upgrade -y
sudo reboot
`pi@raspberrypi:~ $ sudo dpkg --get-selection | grep pivccu dpkg: error: unknown option --get-selection Type dpkg --help for help about installing and deinstalling packages [*]; Use 'apt' or 'aptitude' for user-friendly package management; Type dpkg -Dhelp for a list of dpkg debug flag values; Type dpkg --force-help for a list of forcing options; Type dpkg-deb --help for help about manipulating *.deb files; Options marked [*] produce a lot of output - pipe it through 'less' or 'more' ! pi@raspberrypi:~ $ sudo dmesg | grep uart pi@raspberrypi:~ $ cat /boot/config.txt # For more options and information see # http://rpf.io/configtxt # Some settings may impact device functionality. See link above for details # uncomment if you get no picture on HDMI for a default "safe" mode #hdmi_safe=1 # uncomment this if your display has a black border of unused pixels visible # and your display can output without overscan #disable_overscan=1 # uncomment the following to adjust overscan. Use positive numbers if console # goes off screen, and negative if there is too much border #overscan_left=16 #overscan_right=16 #overscan_top=16 #overscan_bottom=16 # uncomment to force a console size. By default it will be display's size minus # overscan. #framebuffer_width=1280 #framebuffer_height=720 # uncomment if hdmi display is not detected and composite is being output #hdmi_force_hotplug=1 # uncomment to force a specific HDMI mode (this will force VGA) #hdmi_group=1 #hdmi_mode=1 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes #hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display #config_hdmi_boost=4 # uncomment for composite PAL #sdtv_mode=2 #uncomment to overclock the arm. 700 MHz is the default. #arm_freq=800 # Uncomment some or all of these to enable the optional hardware interfaces #dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # Uncomment this to enable the lirc-rpi module #dtoverlay=lirc-rpi # Additional overlays and parameters are documented /boot/overlays/README # Enable audio (loads snd_bcm2835) dtparam=audio=on dtoverlay=pi3-disable-bt dtoverlay=pivccu-bcm2835` `~~[code]~~pi@raspberrypi:~ $ sudo pivccu-info piVCCU version: 2.29.23-16 Kernel modules: Not available Raw UART dev: Not available Board serial: Unknown State: STOPPED [/code]` ~~[quote]~~Hi, kannst du bitte genauer beschreiben, wie du das System neu aufgesetzt hast? Besteht das Problem auch nach einem Neustart? Und dann bitte mal die Ausgabe folgender Befehle (jeweils Zeile pro Zeile ausführen) `~~[code]~~sudo dpkg --get-selection | grep pivccu sudo dmesg | grep uart cat /boot/config.txt sudo pivccu-info [/code]` Viele Grüße Alex ` `
Auch nach einem neustart besteht das Problem. Hab auch das ganze mal Spannung's frei gemacht
Ok, ich habe eine Ahnung.
Bitte mal
sudo dpkg --get-selections | grep pivccu sudo dpkg -s pivccu sudo dpkg -s pivccu-modules-raspberrypi cat /etc/apt/source.list
pi@raspberrypi:~ $ sudo dpkg --get-selections | grep pivccu pivccu install pivccu-modules-raspberrypi install pi@raspberrypi:~ $ sudo dpkg -s pivccu Package: pivccu Status: install ok installed Priority: extra Section: misc Maintainer: Alexander Reinert <alex@areinert.de>Architecture: armhf Version: 2.29.23-16 Depends: pivccu-kernel-modules Pre-Depends: lxc, bridge-utils, systemd Conffiles: /etc/piVCCU/lxc.config 5fcfff8ebb7c6f59c48ee5861216edbf /lib/systemd/system/pivccu.service c4c2be318a53f427124b4c0364d12636 Description: piVCCU - Homematic CCU LXC container This package contains piVCCU - a Homematic CCU LXC container Homepage: https://github.com/alexreinert/piVCCU pi@raspberrypi:~ $ sudo dpkg -s pivccu-modules-raspberrypi Package: pivccu-modules-raspberrypi Status: install ok installed Priority: extra Section: kernel Maintainer: Alexander Reinert <alex@areinert.de>Architecture: armhf Version: 1.20171029-1-3 Provides: pivccu-kernel-modules Depends: raspberrypi-kernel (= 1.20171029-1) Description: Raspberry Pi kernel modules needed for Homematic This package contains the Raspberry Pi kernel needed for Homematic. Homepage: https://github.com/alexreinert/piVCCU pi@raspberrypi:~ $ cat /etc/apt/source.list cat: /etc/apt/source.list: No such file or directory pi@raspberrypi:~ $</alex@areinert.de></alex@areinert.de>
Und welches Image genau hast du genommen? Das originale von pivccu.de oder das angepasste mit ioBroker?
Ich fürchte meins
hast du dir das hier mal angesehen?
http://forum.iobroker.net/viewtopic.php … 76#p100305
Dieses hier aus dem Download bereich:
ioBroker_Image_RPi_2-3_20171109_stretch_pivCCU
Sorry, beim letzten Befehl muss es sources.list sein (Blöde Autokorrektur…)
Sorry, beim letzten Befehl muss es sources.list sein (Blöde Autokorrektur…) `
pi@raspberrypi:~ $ cat /etc/apt/sources.list deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi # Uncomment line below then 'apt-get update' to enable 'apt-get source' #deb-src http://archive.raspbian.org/raspbian/ stretch main contrib non-free rpi deb http://alexreinert.github.io/piVCCU stable main deb http://alexreinert.github.io/piVCCU stable main deb http://alexreinert.github.io/piVCCU testing main
Ich versuch das Image mal bei mir zu starten, kann aber etwas dauern. Welchen Pi hast du? 2 oder 3?
pi2 model B
Auf so einem habe ich die Installation gemacht
Ok, habe das Image jetzt grade mal ausprobiert auf einen Pi2B:
Image auf SD Karte geschrieben
Erster Start –> piVCCU läuft wunderbar
Expand Filesystem über raspi-config & Reboot
sudo apt update && sudo apt upgrade, danach Reboot
Am Image liegt es also nicht.
Aus irgendeinem Grund sind bei dir aber die Kernel Module nicht geladen. Den Grund müssen wir rausbekommen.
Mach bitte mal:
uname -a ls -la /lib/modules/ ls -la /lib/modules/*/kernel/drivers/pivccu/* lsmod ls -la /boot/overlays/pivccu* cat /proc/device-tree/compatible ls -la /proc/device-tree/soc/serial*/compatible cat /proc/device-tree/soc/serial*/compatible
Viele Grüße
Alex
Das Ergebniss:
pi@raspberrypi:~ $ uname -a Linux raspberrypi 4.9.59+ #1047 Sun Oct 29 11:47:10 GMT 2017 armv6l GNU/Linux pi@raspberrypi:~ $ ls -la /lib/modules/ total 16 drwxr-xr-x 4 root root 4096 Nov 1 15:39 . drwxr-xr-x 16 root root 4096 Nov 1 16:15 .. drwxr-xr-x 3 root root 4096 Nov 1 15:39 4.9.59+ drwxr-xr-x 3 root root 4096 Nov 30 19:04 4.9.59-v7+ pi@raspberrypi:~ $ ls -la /lib/modules/*/kernel/drivers/pivccu/* -rw-r--r-- 1 root root 10732 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/dw_apb_raw_uart.ko -rw-r--r-- 1 root root 16680 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/eq3_char_loop.ko -rw-r--r-- 1 root root 17796 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/generic_raw_uart.ko -rw-r--r-- 1 root root 9912 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/pl011_raw_uart.ko -rw-r--r-- 1 root root 5332 Nov 19 12:53 /lib/modules/4.9.59-v7+/kernel/drivers/pivccu/plat_eq3ccu2.ko pi@raspberrypi:~ $ lsmod Module Size Used by iptable_filter 2220 0 bridge 112535 0 stp 2218 1 bridge llc 5790 2 bridge,stp fuse 94600 3 snd_bcm2835 23131 0 snd_pcm 97825 1 snd_bcm2835 snd_timer 22706 1 snd_pcm snd 68784 3 snd_timer,snd_bcm2835,snd_pcm bcm2835_gpiomem 3791 0 uio_pdrv_genirq 3718 0 uio 10166 1 uio_pdrv_genirq fixed 3029 0 ip_tables 12512 1 iptable_filter x_tables 20921 2 ip_tables,iptable_filter ipv6 384613 13 bridge pi@raspberrypi:~ $ ls -la /boot/overlays/pivccu* -rwxr-xr-x 1 root root 296 Nov 30 19:04 /boot/overlays/pivccu-bcm2835.dtbo pi@raspberrypi:~ $ cat /proc/device-tree/compatible brcm,bcm2835pi@raspberrypi:~ $ ls -la /proc/device-tree/soc/serial*/compatible -r--r--r-- 1 root root 13 Nov 30 21:28 /proc/device-tree/soc/serial@7e201000/compatible -r--r--r-- 1 root root 22 Nov 30 21:28 /proc/device-tree/soc/serial@7e215040/compatible pi@raspberrypi:~ $ cat /proc/device-tree/soc/serial*/compatible pivccu,pl011brcm,bcm2835-aux-uartpi@raspberrypi:~ $
Danke, dann sehe ich da heute abend mal nach. `
Ergebnis 1 ( /etc/apt/sources.list)
deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free $ # Uncomment line below then 'apt-get update' to enable 'apt-get source' #deb-src http://archive.raspbian.org/raspbian/ stretch main contrib non-free rpi deb http://alexreinert.github.io/piVCCU stable main deb http://alexreinert.github.io/piVCCU stable main deb http://alexreinert.github.io/piVCCU testing main
Ergebnis 1 ( Ergebnis 1 ( /etc/apt/sources.list.d/pivccu.list)
=leer
muss ich dann wohl nochmal mit deinem Image neu machen :shock: `
Die drei Einträge in der sources.list sind nicht gut, aber das produziert erstmal nur Warnungen und man kann sich nicht sicher sein, ob jetzt testing oder stable verwendet wird.
Das die zweite Datei nicht exisitiert ist nicht schlimm. Es muss ein Eintrag entweder in der ersten oder in der zweiten sein. In meinem Image habe ich das immer in der zweiten eigenen, aber das muss nicht zwingend so sein. In meiner ersten Anleitung war es auch noch direkt in der sources.list.
Viele Grüße
Alex
ok, das sieht erstmal gut aus. Dann jetzt bitte mal
sudo modprobe pl011_raw_uart sudo lsmod sudo dmesg | grep uart sudo pivccu-info
pi@raspberrypi:~ $ sudo modprobe pl011_raw_uart modprobe: FATAL: Module pl011_raw_uart not found in directory /lib/modules/4.9.59+ pi@raspberrypi:~ $ sudo lsmod Module Size Used by iptable_filter 2220 0 bridge 112535 0 stp 2218 1 bridge llc 5790 2 bridge,stp fuse 94600 3 snd_bcm2835 23131 0 snd_pcm 97825 1 snd_bcm2835 snd_timer 22706 1 snd_pcm snd 68784 3 snd_timer,snd_bcm2835,snd_pcm bcm2835_gpiomem 3791 0 uio_pdrv_genirq 3718 0 uio 10166 1 uio_pdrv_genirq fixed 3029 0 ip_tables 12512 1 iptable_filter x_tables 20921 2 ip_tables,iptable_filter ipv6 384613 13 bridge pi@raspberrypi:~ $ sudo dmesg | grep uart pi@raspberrypi:~ $ sudo pivccu-info piVCCU version: 2.29.23-16 Kernel modules: Not available Raw UART dev: Not available Board serial: Unknown State: STOPPED
Ok, ich habe einen neuen Verdacht. Machst du bitte mal ein Detail-Foto von deinem Pi?
Foto pi~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201711 ... 530fb9.jpg">https://uploads.tapatalk-cdn.com/20171130/bb328ae59fa6dd90d33b8c277c530fb9.jpg</link_text>" />
Gesendet von meinem ONEPLUS A3003 mit Tapatalk~~
Verdacht bestätigt: Das ist kein Pi 2 B.
