    2. s1ckh34d
    • Posts 8
    s1ckh34d
    @s1ckh34d
    21
    s1ckh34d Follow
    Latest posts made by s1ckh34d
    • RE: Frage zu Amazon Dash Button
      ich bilde mir ein das setting in der Vergangenheit auch schon mal angepasst zu haben, jetzt klappt es damit auf jeden Fall 🙂
      Danke für die Hilfe.
      lg S!ck
      s1ckh34d
      damit startet der Adapter dann nicht mehr, hier das log dazu:
      host.iobroker	2018-05-04 08:12:10.219	info	Restart adapter system.adapter.amazon-dash.0 because enabled
      host.iobroker	2018-05-04 08:12:10.219	error	instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
      Caught	2018-05-04 08:12:10.219	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      Caught	2018-05-04 08:12:10.219	error	by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:710:25)
      Caught	2018-05-04 08:12:10.219	error	by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
      Caught	2018-05-04 08:12:10.219	error	by controller[0]: at Adapter.emit (events.js:185:7)
      Caught	2018-05-04 08:12:10.218	error	by controller[0]: at emitNone (events.js:86:13)
      Caught	2018-05-04 08:12:10.218	error	by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:42:5)
      Caught	2018-05-04 08:12:10.218	error	by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
      Caught	2018-05-04 08:12:10.218	error	by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
      Caught	2018-05-04 08:12:10.218	error	by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)
      Caught	2018-05-04 08:12:10.218	error	by controller[0]: at Error (native)
      Caught	2018-05-04 08:12:10.218	error	by controller[0]: Error: syntax error
      host.iobroker	2018-05-04 08:12:09.795	info	instance system.adapter.amazon-dash.0 started with pid 80605
      s1ckh34d
      Das ändern der Zeile hat leider keine Änderung gebracht, mittlerweile glaube ich das der Adapter auf der falschen Netzwerkkarte "lauscht".
      Daher habe ich versucht folgende Zeilen umzuschreiben:
          if (typeof adapter.config.interface == 'undefined' || adapter.config.interface === '' {
              adapter.config.interface = "";
              adapter.log.info('starting pcap session on default interface');
          } else {
              adapter.log.info('starting pcap session on interface '+adapter.config.interface);
      Der einzige Effekt ist jedoch das sich im Log die Meldung von "'starting pcap session on default interface" in "'starting pcap session on interface" geändert hat.
      Kurz zum Setup, der Host hat 2 Interfaces eth0 ist mit dem LAN Verbunden, über dieses Interface spreche ich ihn auch an, eth1 ist mit einem abgetrennten WLAN verbunden welches ausschließlich für IoT Geräte gedacht ist.
      Zwischen beiden Netzwerken besteht keinen Verbindung, lediglich der Host mit ioBroker ist mit beiden netzen verbunden.
      s1ckh34d
      ja der Button ist richtig mit dem wlan verbunden ( nach einem druck auf die taste sehe ich für einige Sekunden den connect am Accesspoint).
      Nachdem soweit ich das ganze verstanden habe ja nur die arp requests ausgewertet werden habe ich im sicherheitshalber keine IP per DHCP zugewiesen, dies hab ich nun geändert, jetzt ist im DHCP Server auch ersichtlich das der Button eine DHCP lease erhält.
      Den Adapter habe ich vor etwa vor 48 Stunden installiert und schon locker 30 mal die taste gedrückt, ich hoffe jetzt mal das ich lang genug gewartet habe 🙂
      Hört der Adapter auf alle Ethernet Interfaces am host, bzw falls nicht kann ich ihm sagen das er nicht auf eth0 sondern auf eth1 lauschen soll?
      lg S1ck
      s1ckh34d
    • Frage zu Amazon Dash Button
      ich versuche aktuell meine Dash Buttons zu integrieren, jedoch will das ganze nicht so wie ich.
      Ich habe den Adapter in der Version 0.2.9 installiert und bei Instanzen wird mir auch das grüne Symbol bei dem Adapter angezeigt.
      Laut der Anleitung sollte bei betätigen des Dash Buttons ein Eintrag bei Objekte hinzukommen, jedoch wird mir dort gar nichts im Bezug auf den Dash Adapter angezeigt.
      Ich habe bereits den Adapter komplett gelöscht und neu installiert sowie im Adapter die MAC von dem Button eingetragen, dies brachte jedoch keine Änderung.
      Mit "sudo tcpdump -i eth1" sehe ich auf dem host auf jeden Fall die requests nach dem druck auf den Button.
      Hat jemand einen tipp für mich was es da haben kann?.
      lg
      s1ckh34d
    • RE: Wunsch: Adapter für Extensible Messaging and Presence Protocol (XMPP)
      Danke für den Tipp, schon weiß womit ich mich am 1. Mai beschäftigen werde 🙂
      s1ckh34d
      auf der suche nach einem Adapter für XMPP bin ich über diesen Thread gestolpert, ich fürchte dafür gibt es noch keine Lösung oder?
      lg S!ck
      s1ckh34d
    • Email Adapter ohne Auth
      Hallo Community,
      ich bin neu auf ioBroker gestoßen und teste aktuell damit ein wenig rum, dabei haben sich mir einige Fragen gestellt in dem Thread einmal die erste 🙂
      Damit mir der ioBroker nachrichten schicken kann hab ich den Mail Adapter installiert und scheitere an der Konfiguration.
      Da ich selber ein Mailgateway betreibe habe ich "Service" auf "Anwender definiert" gestellt sowie den Hostname und Port richtig eingestellt.
      Bei einem Testmail erhalte ich folgende Meldung:
      Fehler getaddrinfo ENOTFOUND ladon.local ladon.local:26
      In einer shell kann der Hostname jedoch richtig aufgelöst werden, verwendet ioBroker nicht die System DNS Server?
      Wenn ich statt dem Hostname die IP eingeben erhalte ich folgende Meldung:
      Fehler Missing credentials for "PLAIN"
      User und Kennwort habe ich keines angegeben da der Mailserver kein Login benötigt, wie kann ich dem Adapter sagen das Mails ohne Authentifizierung am SMTP Server versendet werden?
      lg
      S1ck
      EDIT: sry habe gerade gesehen das ich das falsche Forum erwischt habe, kann den Thread bitte ein Mod verschieben?
      s1ckh34d
