    2. pmcgn
    P
    pmcgn
    @pmcgn
    15
    pmcgn Follow
    Latest posts made by pmcgn
    • RE: Kein Zugriff nach aktivieren von SSL
      Der Adapter wurde erstellt, leider habe ich wieder das gleiche Problem, interessanterweise kann ich die authentifizierung an- und ausschalten:
      root@ioBroker-RasPi2:~# iobroker add admin --port 8090 --enabled
      host.ioBroker-RasPi2 create instance admin
      host.ioBroker-RasPi2 object system.adapter.admin.upload created
      host.ioBroker-RasPi2 object system.adapter.admin.1.uptime created
      host.ioBroker-RasPi2 object system.adapter.admin.1.memRss created
      host.ioBroker-RasPi2 object system.adapter.admin.1.memHeapTotal created
      host.ioBroker-RasPi2 object system.adapter.admin.1.memHeapUsed created
      host.ioBroker-RasPi2 object system.adapter.admin.1.connected created
      host.ioBroker-RasPi2 object system.adapter.admin.1.alive created
      host.ioBroker-RasPi2 object system.adapter.admin.1 created
      root@ioBroker-RasPi2:~# iobroker restart
      Stopping ioBroker controller daemon...
      ioBroker controller daemon stopped.
      Starting ioBroker controller daemon...
      ioBroker controller daemon started. PID: 32657
      root@ioBroker-RasPi2:~# iobroker set admin.1 --ssl false
      /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1756
                                  if (!obj.native.secur === undefinede) {
      ReferenceError: undefinede is not defined
          at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1756:55)
          at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
          at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
          at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
          at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
          at Decoder. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
          at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
          at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
          at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:291:16)
      	root@ioBroker-RasPi2:~# iobroker stop
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1756:55
          at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:504:21)
          at Timer.listOnTimeout (timers.js:119:15)
      	root@ioBroker-RasPi2:~# iobroker set admin.1 --auth false
      New auth setting for "admin.1 is: false
      Instance settings for "admin.1" are changed.</anonymous></anonymous></anonymous>
      Wenn ich das ganze nochmal mache und versuche SSL abzuschalten, bevor ich das erste mal auf die Webseite zugreife, kommt dieser Fehler:
      root@ioBroker-RasPi2:/opt/iobroker/log# iobroker add admin --port 8078 --enabled
      host.ioBroker-RasPi2 object system.adapter.admin.3.uptime created
      host.ioBroker-RasPi2 object system.adapter.admin.3.memRss created
      host.ioBroker-RasPi2 object system.adapter.admin.3.memHeapTotal created
      host.ioBroker-RasPi2 object system.adapter.admin.3.memHeapUsed created
      host.ioBroker-RasPi2 object system.adapter.admin.3.connected created
      host.ioBroker-RasPi2 object system.adapter.admin.3.alive created
      host.ioBroker-RasPi2 object system.adapter.admin.3 created
      root@ioBroker-RasPi2:/opt/iobroker/log# iobroker set admin.3 --ssl false
      events.js:85
            throw er; // Unhandled 'error' event
      Error: listen EADDRINUSE
          at exports._errnoException (util.js:746:11)
          at Server._listen2 (net.js:1156:14)
          at listen (net.js:1182:10)
          at Server.listen (net.js:1267:5)
          at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2418:24)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:143:9
          at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:150:7)
          at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2127:27)
      Im Errorlog finde ich übrigens ca. alle zwei Sekunden soetwas:
      2015-10-11 00:15:52.162  - info: host.ioBroker-RasPi2 instance system.adapter.admin.0 started with pid 2237
      2015-10-11 00:15:55.263  - info: host.ioBroker-RasPi2 instance system.adapter.admin.1 started with pid 2242
      2015-10-11 00:15:58.342  - error: host.ioBroker-RasPi2 instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
      2015-10-11 00:15:58.344  - info: host.ioBroker-RasPi2 Restart adapter system.adapter.admin.0 because enabled
      2015-10-11 00:16:01.838  - error: host.ioBroker-RasPi2 instance system.adapter.admin.1 terminated with code 7 (Adapter already running)
      2015-10-11 00:16:01.839  - info: host.ioBroker-RasPi2 Restart adapter system.adapter.admin.1 because enabled
      2015-10-11 00:16:03.732  - info: host.ioBroker-RasPi2 instance system.adapter.hm-rpc.0 started with pid 2255
      2015-10-11 00:16:06.727  - error: host.ioBroker-RasPi2 instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
      Dann habe ich noch versucht alle Admin und Web instanzen zu löschen und neu zu erzeugen. Aber SSL bleibt aktiviert und das Zahnrad dreht sich 😞
      P
      pmcgn
      Verdammt, auf der Seite war ich, hab's aber übersehen. Gibt leider nen Fehler und der alte Zustand ist weiterhin aktiv.
      root@ioBroker-RasPi2:/opt/iobroker# iobroker set admin.0 --ssl false
      root@ioBroker-RasPi2:/opt/iobroker# ./iobroker stop
      root@ioBroker-RasPi2:/opt/iobroker# iobroker set admin.0 --ssl off
          at Timer.listOnTimeout (timers.js:119:15)</anonymous></anonymous></anonymous>
      P
      pmcgn
    • Kein Zugriff nach aktivieren von SSL
      ich bin gerade dabei von CCU.IO auf ioBroker umzusteigen. Ich bin sehr beeindruckt von dem was ihr geschafft habt!!
      IoBroker läuft auf einem raspberry pi, jetzt wollte ich den Zugriff via Internet erlauben und habe auf einem zweiten pi einen reverse proxy mit nginx erstellt. Es hat auch alles wunderbar funktioniert, bis ich SSL aktiviert habe. Wenn ich jetzt direkt auf die ioBroker webseite zugreife (ohne proxy oder mit proxy, ist egal), wird eine verschlüsselte Verbindung aufgebaut, aber ich sehe nur das sich drehende Zahnrad. Das Zertifikat habe ich noch nicht ausgetasucht, sollte ja nur ein Test sein. Da leider kein unverschlüsselter Zugriff mehr besteht, weiß ich gerade nicht, wie ich an die Einstellungen kommen soll. Über die Konsole habe ich alle Module aktualisiert, aber das Problem besteht immer noch.
      Jemand eine Idee, wie ich SSL ohne die Weboberfläche deaktivieren kann? Ich konnte keine config-Datei finden.
      Viele Grüße
      Philipp
      P
      pmcgn
