    2. rnc11
    • Posts 1
    rnc11
    @rnc11
    rnc11 Follow
    Latest posts made by rnc11
    • Cannot start Samsung_Tizen Adapter
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Raspberry Pi 4 Model B Rev 1.2
      Arbeitsspeicher: 4GB
      Festplattenart: Samsung SSD
      Betriebssystem: Raspbian 10 (Buster)
      Node-Version: 16.20.2
      Nodejs-Version: 16.20.2
      NPM-Version: 8.19.4
      Installationsart: PivCCU Image
      Image genutzt: Ja
      The adapter has been installed from the following GitHub path:
      https://github.com/dahuby/iobroker.samsung_tizen/tarball/master
      The adapter version is: 0.0.12
      The Adapter creates the following log entries when trying to start:
      2023-11-13 11:06:28.604 - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1031
      2023-11-13 11:06:28.605 - error: host.raspberrypi Caught by controller[0]: throw err;
      2023-11-13 11:06:28.605 - error: host.raspberrypi Caught by controller[0]: ^
      2023-11-13 11:06:28.605 - error: host.raspberrypi Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js'
      2023-11-13 11:06:28.605 - error: host.raspberrypi Caught by controller[0]: Require stack:
      2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js
      2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.samsung_tizen/main.js
      2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15)
      2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:873:27)
      2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1100:19)
      2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at require (node:internal/modules/cjs/helpers:119:18)
      2023-11-13 11:06:28.606 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js:46:25)
      2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1198:14)
      2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1252:10)
      2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1076:32)
      2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:911:12)
      2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1100:19) {
      2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2023-11-13 11:06:28.607 - error: host.raspberrypi Caught by controller[0]: requireStack: [
      2023-11-13 11:06:28.608 - error: host.raspberrypi Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.samsung_tizen/lib/utils.js',
      2023-11-13 11:06:28.608 - error: host.raspberrypi Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.samsung_tizen/main.js'
      2023-11-13 11:06:28.608 - error: host.raspberrypi Caught by controller[0]: ]
      2023-11-13 11:06:28.608 - error: host.raspberrypi Caught by controller[0]: }
      2023-11-13 11:06:28.608 - error: host.raspberrypi instance system.adapter.samsung_tizen.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      rnc11
      rnc11
