    2. Brainee
    B
    • Posts 2
    Brainee
    @Brainee
    Brainee Follow
    Latest posts made by Brainee
    • RE: KNX Adapter friert ständig ein
      @glasfaser So, nun habe ich mal ein Logfile zum freeze Zeitpunkt erwischen können:
      Erst mal läuft es tagelang normal:
      2022-12-23 12:35:16.217 - info: knx.0 (2416) =====> STATE_TUNNELING_ACK
      2022-12-23 12:35:16.218 - info: knx.0 (2416) ( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 02 5d 00 ChID : 2 SeqCntIN : 93 SeqCntOUT : 3 queue length : 0
      2022-12-23 12:35:16.218 - info: knx.0 (2416) ( 4.b ) return to STATE_READY, processing : false
      2022-12-23 12:35:16.947 - info: knx.0 (2416) ( 3.2 ) Received TUNNEL_REQUEST (WRITE - send ACK ) : 06 10 04 20 00 17 04 02 5e 00 29 00 bc e0 11 21 1b 0a 03 00 80 0c 48 ChID: 2
      2022-12-23 12:35:16.948 - info: knx.0 (2416) WRITE : mappedName : H_Wohnen2_IST (Celsius) dest : 3/3/10 val: 21.92 (DPT9.001) H_Wohnen2_IST_(Celsius)
      2022-12-23 12:35:16.948 - info: knx.0 (2416) =====> STATE_TUNNELING_ACK
      dann plötzlich:
      2022-12-23 12:35:16.948 - info: knx.0 (2416) ( 4 ) Sending Tunnel_Request ACK : 06 10 04 21 00 0a 04 02 5e 00 ChID : 2 SeqCntIN : 94 SeqCntOUT : 3 queue length : 0
      2022-12-23 12:35:16.948 - info: knx.0 (2416) ( 4.b ) return to STATE_READY, processing : false
      2022-12-23 12:35:26.949 - info: knx.0 (2416) checkConnectionState 192.168.1.80 State : true
      2022-12-23 12:35:26.949 - info: knx.0 (2416) Send : conCheck Connection State Request : 06 10 02 07 00 10 02 00 08 01 00 00 00 00 95 74 sent to 192.168.1.80:3671
      2022-12-23 12:35:27.442 - info: smartmeter.0 (307) Received 13 values, 6 updated
      2022-12-23 12:35:28.950 - info: knx.0 (2416) set STATE-NOT-CONNECTED because not receiving CONNECTION-STATE
      2022-12-23 12:35:28.950 - info: knx.0 (2416) Connection persists.....closing now
      2022-12-23 12:35:28.950 - info: knx.0 (2416) ... not able to close connection, because already closed
      2022-12-23 12:35:28.950 - info: knx.0 (2416) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_CONNECTION_STATE_REQUEST(5) to STATE_NOT_CONNECTED(0).
      2022-12-23 12:35:30.951 - info: knx.0 (2416) Using UDP with local IP: 192.168.1.199
      2022-12-23 12:35:30.951 - info: knx.0 (2416) Event : UDP - listening
      2022-12-23 12:35:30.952 - info: knx.0 (2416) Connected - local UDP Server listening on 192.168.1.199:55521
      2022-12-23 12:35:30.952 - info: knx.0 (2416) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 01 c7 d8 e1 08 01 00 00 00 00 d8 e1 04 04 02 00 sent to 192.168.1.80:3671
      2022-12-23 12:35:36.949 - info: knx.0 (2416) checkConnectionState 192.168.1.80 State : false
      2022-12-23 12:35:36.949 - info: knx.0 (2416) Connection persists.....closing now
      2022-12-23 12:35:36.950 - info: knx.0 (2416) ... not able to close connection, because already closed
      2022-12-23 12:35:36.950 - info: knx.0 (2416) STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_CONNECT_REQUEST(3) to STATE_NOT_CONNECTED(0).
      2022-12-23 12:35:36.950 - info: knx.0 (2416) ( END ) Sending DISCONNECT_REQUEST : 06 10 02 09 00 10 02 00 08 01 c0 a8 01 c7 d8 e1 ChID : 0 SeqCntIN : 94 SeqCntOUT : 3 msgCode : [object Object]
      2022-12-23 12:35:36.950 - info: knx.0 (2416) STATE_DISCONNECT_REQUEST : Transistion from State: STATE_NOT_CONNECTED(0) to STATE_DISCONNECT_REQUEST(15) not possible because of cancelled connection.
      2022-12-23 12:35:36.950 - info: knx.0 (2416) Connection persists.....closing now
      2022-12-23 12:35:36.950 - info: knx.0 (2416) STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      2022-12-23 12:35:38.950 - info: knx.0 (2416) Using UDP with local IP: 192.168.1.199
      2022-12-23 12:35:38.950 - info: knx.0 (2416) Event : UDP - listening
      2022-12-23 12:35:38.950 - info: knx.0 (2416) Connected - local UDP Server listening on 192.168.1.199:50761
      2022-12-23 12:35:38.950 - info: knx.0 (2416) Send : UDP Connection Request : 06 10 02 05 00 1a 08 01 c0 a8 01 c7 c6 49 08 01 00 00 00 00 c6 49 04 04 02 00 sent to 192.168.1.80:3671
      dann alle 10 Minuten:
      2022-12-23 12:44:24.825 - info: knx.0 (2416) main.js : tGA.write on Statechange : 7/0/2 P-0186-0_GA-968 typeof val: number 742 DPT9.008
      2022-12-23 12:44:24.826 - info: knx.0 (2416) easy-knx.js groupValueWrite value: 742 dpt : DPT9.008{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,17,4,56,2,3,0,128,52,135]}
      2022-12-23 12:44:24.863 - info: knx.0 (2416) main.js : tGA.write on Statechange : 7/0/3 P-0186-0_GA-969 typeof val: number 491 DPT9.008
      2022-12-23 12:44:24.863 - info: knx.0 (2416) easy-knx.js groupValueWrite value: 491 dpt : DPT9.008{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,17,4,56,3,3,0,128,45,254]}
      2022-12-23 12:44:24.939 - info: knx.0 (2416) main.js : tGA.write on Statechange : 7/0/5 P-0186-0_GA-1102 typeof val: number 420 DPT9.008
      2022-12-23 12:44:24.940 - info: knx.0 (2416) easy-knx.js groupValueWrite value: 420 dpt : DPT9.008{"type":"Buffer","data":[6,16,4,32,0,23,4,2,3,0,17,0,188,224,17,4,56,5,3,0,128,45,32]}
      Bin für jeden Tipp dankbar!
      VG
      Brainee
      B
      Brainee
    • KNX Adapter friert ständig ein
      Hallo Zusammen,
      ich bin neu hier und etwas "unerfahren", also bitte vorab schon mal um Entschuldigung.
      Ich habe das Problem, dass ständig (alle paar Tage) meine KNX Instanz auf IOBroker einfriert. Das hat zur Folge, dass keine neuen Werte mehr kommen und zeigt sich in der InfluxDB bzw. im Grafana Dashboard mit konstanten Linien. Gleiches Problem hatte ich früher auch auf meiner RaspPi Umgebung, aber eher seltener (alle paar Wochen). Sowohl nun als auch damals half Neustart (Neustart der KNX Instanz unter IOBroker oder halt Reboot).
      Hat irgendjemand eine Idee, woran es liegen kann? Wie kann ich das Logging konfigurieren, um dem auf die Schliche zu kommen (bin leider kein Linux Profi)?
      Brainee
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC - Proxmox Container
      Arbeitsspeicher: 16GB; 4GB allokiert zu Container
      Festplattenart: SSD 128GB, 16GB allokiert
      Betriebssystem: Ubuntu 22.04.1 LTS 22.04 Jammy
      Node-Version: v14.20.0
      Nodejs-Version: v14.20.0
      NPM-Version: 6.14.17
      Installationsart: skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      B
      Brainee
