Es läuft jetzt. Ich habe Admin einmal deinstalliert und dann neu Installiert.
Der Thread kann geschlossen werden.
Als kleines Update.
VIS läuft, aber der Admin Adapter startet nicht. Ich habe auch schon versucht einen Neuen Admin Adapter zu installieren, aber das Funktioniert auch nicht.
iob status all sagt:
Instance "admin.0" is not running
Instance "alexa2.0" is not running
Instance "backitup.0" is running
Instance "bring.0" is not running
Instance "cloud.0" is not running
Instance "discovery.0" is not running
Instance "fritzbox.0" is not running
Instance "geofency.0" is not running
Instance "hm-rega.0" is not running
Instance "hm-rpc.0" is not running
Instance "hm-rpc.1" is not running
Instance "hm-rpc.2" is not running
Instance "hs100.0" is not running
Instance "hue.0" is not running
Instance "icons-mfd-svg.0" is not running
Instance "influxdb.0" is not running
Instance "influxdb.1" is not running
Instance "info.0" is not running
Instance "iot.0" is not running
Instance "javascript.0" is not running
Instance "mqtt.0" is not running
Instance "nanoleaf-lightpanels.0" is not running
Instance "nina.0" is not running
Instance "nut.0" is not running
Instance "octoprint.0" is not running
Instance "ping.0" is not running
Instance "pushover.0" is not running
Instance "pushover.1" is not running
Instance "pushover.2" is not running
Instance "simple-api.0" is not running
Instance "sonoff.0" is not running
Instance "tankerkoenig.0" is not running
Instance "text2command.0" is not running
Instance "tr-064.0" is not running
Instance "tradfri.0" is not running
Instance "unifi.0" is not running
Instance "vis-colorpicker.0" is not running
Instance "vis-inventwo.0" is not running
Instance "vis-jqui-mfd.0" is not running
Instance "vis-timeandweather.0" is not running
Instance "vis.0" is not running
Instance "web.0" is not running
Instance "wled.0" is not running
Instance "zigbee.0" is not running
SYSTEM/memoryLimitMB: 0
SYSTEM/hostname: buanet-iobroker1
SYSTEM/statisticsInterval: 15000
SYSTEM/checkDiskInterval: 300000
SYSTEM/noChmod: false
SYSTEM/instanceStartInterval: 2000
SYSTEM/compact: false
SYSTEM/allowShellCommands: false
SYSTEM/memLimitWarn: 100
SYSTEM/memLimitError: 50
MULTIHOSTSERVICE/enabled: false
MULTIHOSTSERVICE/secure: true
NETWORK/IPv4: true
NETWORK/IPv6: true
OBJECTS/type: file
OBJECTS/host: 127.0.0.1
OBJECTS/port: 9001
OBJECTS/user:
OBJECTS/pass:
OBJECTS/noFileCache: false
OBJECTS/connectTimeout: 2000
OBJECTS/writeFileInterval: 5000
OBJECTS/OPTIONS/retryStrategy: reconnectCount => {
if (!ready && initError && ignoreErrors) {
return new Error('No more tries');
if (this.stop) {
return new Error('Client has stopped ... no retries anymore');
if (ready && reconnectCount >= retry_max_count) {
return new Error('Stop trying to reconnect');
// A function that receives an options object as parameter including the retry attempt,
// the total_retry_time indicating how much time passed since the last time connected,
// the error why the connection was lost and the number of times_connected in total.
// If you return a number from this function, the retry will happen exactly after that
// time in milliseconds. If you return a non-number, no further retry will happen and
// all offline commands are flushed with errors. Return an error to return that
// specific error to all offline commands.
if (!ready) {
return 300;
} else {
return retry_max_delay;
/*if (options.error.code === 'ECONNREFUSED') {
// End reconnecting on a specific error and flush all commands with a individual error
return new Error('The server refused the connection');
if (options.total_retry_time > 1000 * 60 * 60) {
// End reconnecting after a specific timeout and flush all commands with a individual error
return new Error('Retry time exhausted');
if (options.times_connected > 10) {
// End reconnecting with built in error
return undefined;
// reconnect after
return Math.max(options.attempt * 100, 3000);*/
OBJECTS/OPTIONS/enableReadyCheck: true
OBJECTS/OPTIONS/host: 127.0.0.1
OBJECTS/OPTIONS/port: 9001
OBJECTS/OPTIONS/db: 0
OBJECTS/OPTIONS/family: 0
OBJECTS/OPTIONS/autoResubscribe: false
OBJECTS/OPTIONS/connectionName:
OBJECTS/BACKUP/disabled: false
OBJECTS/BACKUP/files: 24
OBJECTS/BACKUP/hours: 48
OBJECTS/BACKUP/period: 120
OBJECTS/BACKUP/path:
OBJECTS/maxQueue: 1000
STATES/type: file
STATES/host: 127.0.0.1
STATES/port: 9000
STATES/maxQueue: 1000
STATES/user:
STATES/pass:
STATES/connectTimeout: 2000
STATES/writeFileInterval: 30000
STATES/OPTIONS/retryStrategy: reconnectCount => {
if (!ready && initError) {
if (this.stop) {
if (!ready) {
return 300;
// End reconnecting after a specific timeout and flush all commands with individual error
// End reconnecting with built in error return undefined;
// reconnect after
STATES/OPTIONS/enableReadyCheck: true
STATES/OPTIONS/host: 127.0.0.1
STATES/OPTIONS/port: 9000
STATES/OPTIONS/db: 0
STATES/OPTIONS/family: 0
STATES/OPTIONS/autoResubscribe: false
STATES/OPTIONS/connectionName:
STATES/BACKUP/disabled: false
STATES/BACKUP/files: 24
STATES/BACKUP/hours: 48
STATES/BACKUP/period: 120
STATES/BACKUP/path:
LOG/level: info
LOG/maxDays: 7
LOG/noStdout: true
LOG/TRANSPORT/FILE1/type: file
LOG/TRANSPORT/FILE1/enabled: true
LOG/TRANSPORT/FILE1/filename: log/iobroker
LOG/TRANSPORT/FILE1/fileext: .log
LOG/TRANSPORT/SYSLOG1/type: syslog
LOG/TRANSPORT/SYSLOG1/enabled: false
LOG/TRANSPORT/SYSLOG1/host: localhost
LOG/TRANSPORT/SYSLOG1/protocol: udp4
LOG/TRANSPORT/SYSLOG1/localhost: iobroker
dataDir: ../../iobroker-data/
Der Container Status ist healthy.
restore.log iobroker.2022-02-26.log
Ich habe schon versucht Admin zu starten aber es startet nicht.
Ich habe es jetzt gemacht wie es @Marc-Berg gesagt hat. Die installation ist beendet, aber wenn ich mich verbinden will passiert nichts.
Was ist da schief gelaufen? Laut Konsole kein Fehler.
Hallo Marc,
wenn ich das richtig verstehe soll ich die Dateien aus dem Backup Archiv in den ioBroker data Ordner einfügen?
Mit freundlichen Grüßen
Jerry
-- Edit
Ich meine natürlich das Backup Archiv in den ioBroker Data Ordner.
ich möchte gerne meine vorhandene ioBroker installation in einen anderen Docker Container umziehen, da ich ihn mit einen eigenen IP (macvlan) laufen lassen will, da ich meine ganzen Smarthome Geräte in ein extra Netzwerk gesteckt habe. Docker nutze ich auf einer Synology DS718+.
Jetzt zum Problem:
Wenn ich mein Backup im neuen Container einspielen möchte bekomme ich immer folgende Fehlermeldung.
Wie kann ich das beheben? Was mache ich Falsch?
Der "alte" Container läuft auf folgenden Versionen:
Der "neue" Container auf:
