    2. tominspace
    T
    • Posts 16
    tominspace
    @tominspace
    12
    tominspace Follow
    Latest posts made by tominspace
    • RE: Tankerkönig kein Refresh
      Nein so wie es aussieht nicht, es scheint eine Abfrage zu geben, aber es werden keine Werte geschrieben, so wie ich das Log verstehe
      Das steht im LOG
      host.raspberrypi 2017-12-30 23:00:03.389 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
      ical.0 2017-12-30 23:00:03.222 info starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ical, node: v4.8.4
      ical.1 2017-12-30 23:00:03.101 info starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.ical, node: v4.8.4
      tankerkoenig.0 2017-12-30 23:00:02.808 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v4.8.4
      host.raspberrypi 2017-12-30 23:00:00.153 info instance system.adapter.ical.0 started with pid 16526
      host.raspberrypi 2017-12-30 23:00:00.115 info instance system.adapter.ical.1 started with pid 16520
      host.raspberrypi 2017-12-30 23:00:00.059 info instance system.adapter.tankerkoenig.0 started with pid 16514
      Da steht nix von schreiben von Daten.
      Wenn ich manuell anstosse sieht das Log dann so aus:
      host.raspberrypi 2017-12-30 23:39:56.611 info instance system.adapter.tankerkoenig.0 terminated with code 0 (OK)
      tankerkoenig.0 2017-12-30 23:39:56.276 info objects written
      tankerkoenig.0 2017-12-30 23:39:56.033 info starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v4.8.4
      host.raspberrypi 2017-12-30 23:39:53.469 info instance system.adapter.tankerkoenig.0 started with pid 16705
      host.raspberrypi 2017-12-30 23:39:53.425 info instance scheduled system.adapter.tankerkoenig.0 */30 * * * *
      host.raspberrypi 2017-12-30 23:39:50.877 info stopInstance canceled schedule system.adapter.tankerkoenig.0
      host.raspberrypi 2017-12-30 23:39:50.874 info stopInstance system.adapter.tankerkoenig.0
      host.raspberrypi 2017-12-30 23:39:50.868 info object change system.adapter.tankerkoenig.0
      Dann schreibt er was und meine Anzeigen sind auch korrekt
      T
      tominspace
    • RE: Anwesenheitskontrolle Variable in der CCU auslesen in IObroker.. PROBLEM
      Danke…..
      Ebenso gute Bytes und guten Rutsch
      T
      tominspace
      oh mann… wie geil, wie doof...... DANKE!!!!
      Da bin ich nicht drauf gekommen ich depp !
      Das war echt einfach, und löst meine Probleme und meine Frau kann nicht mehr meckern 🙂
      Kannst Du mir auch sagen wie ich an diese Systeminfo komme:
      T
      tominspace
      ja mache ich mal….
      erst einmal herzlichen Dank für die Zeit und Hilfe 😉
      T
      tominspace
    • Anwesenheitskontrolle Variable in der CCU auslesen in IObroker.. PROBLEM
      Hallo Gemeinde,
      autodidaktisch versuche ich mich immer mehr einzuarbeiten und lerne jeden Tag 🙂
      Ich habe folgende Anleitung im Netzt gefunden, die ist ziemlich geil und würde mir sehr helfen bei meiner Haussteuerung.
      Es geht um eine "ich bin zuhause und brauche nix zu tippen oder zu machen, denn ich bin eine Frau und will das nicht" Lösung (Frauen sind da etwas anders 😉
      Also soll die Anwesenheit AUTOMATISCH über das Handy erfolgen.
      Folgedes Video hat mir geholfen:
      https://m.youtube.com/watch?t=1s&v=EUCOb0rlz9s
      Dies ist das Adon für die CCU
      https://homematic-forum.de/forum/viewto … 18&t=23907
      Alles läuft soweit super, es sind auch die Variablene in der CCU und werden sauber geschrieben
      Die Variabeln sind da, siehe Bild 1
      Leider kann ich die Variabeln NICHT in dem Adapter in IObroker finden, nur eine generelle, aber nicht die für mich und/oder meine Frau.
      In diesem Fall könnte ich mit der VIS nur anzeigen ES IST JEMAND zuhause, aber nicht wer 😞
      Siehe Bild 2 , eine ander Variable finde ich nicht ….
      und wo finde ich die Systemangaben Sonnenauf / Sonnenuntergang ? Die sind ja in der CCU zu finden, aber nicht im IObroker
      Danke für einen Tip
      T
      tominspace
      ja habe ich jetzt so umgestellt, aber vorher stand da ALLE 30 MINUTEN…....
      Das steht in meinem HTML
      T
      tominspace
      so sieht cron aus:
      T
      tominspace
      das meinst Du ?
      Ich habe nur den REFRESH in der Konfiguration von Tankerkönig eingegeben alle 30 Minuten, Die Instanz sollte doch dann die Daten holen und wegschreiben, die VIS zeigt noch dann nur an, oder ?
      T
      tominspace
      nach manuellem start so…..
      Wie gesagt was mir auffällt ist das unterschiedliche Logfile, es fehlt das WRITE im Log der Automatik, da werden wohl Daten abgerufen aber nicht weggeschrieben.... ???
      T
      tominspace
      so ist der Refresh eingestellt
      T
      tominspace
